Original XBox transcoding profile reqd
I'm sure one must have been posted but I have searched & cannot find a transcoding profile for the original XBox (mainly, I want .MKVs transcoding but I have no clue regards the profile config).
Thanks,
Fes
moltra wrote:I think the original xbox used the original XBMC (Xbox Media Center). Alot depends on if the xbox is modded or not. I think it use to support upnp. I will have to dig out my sons old xbox and hook it up and see if it works.
Fes wrote:I'll give that a go - didn't want to make work here btw lol.
