DLNA Samsung UE40D5700 (Serviio - AllShare - ...)
Missy_X
Post Thu Dec 29, 2011 10:52 am
I'm having a problem getting movies to play on my new UE40D5700. My tv sees Serviio or Samsung's AllShare just fine and i can play whatever i share but it's constantly buffering. The movie files first load for about 30 seconds, then plays for maximum 10 seconds, then loads again for 10-20 seconds, then plays again for 10 seconds, and so on.
I have a wired network through a switch, not a router (not sure if that could cause a problem ?). The thing is that i can play movies from youtube just fine without any buffering and barely a couple seconds initial loading.
Any ideas what could be wrong ?
(13.92 KiB) Downloaded 612 times
Post Thu Dec 29, 2011 12:11 pm
Re: DLNA Samsung UE40D5700 (Serviio - AllShare - ...)
I am surprised that it is even working at all. The computer running serviio and the renderer needs to be on the same IP subnet. Serviio is using 81.83.79.190 and the samsung TV is using 84.196.23.140
2011-12-29 11:48:05,921 INFO  [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth3 (Intel(R) 82579V Gigabit Network Connection) and address 81.83.79.190, timeout = 0
2011-12-29 11:48:06,067 DEBUG [RendererSearchSender] Multicasting SSDP M-SEARCH using interface eth3 (Intel(R) 82579V Gigabit Network Connection) and address 81.83.79.190, timeout = 0
2011-12-29 11:48:06,763 DEBUG [WebServer] Incoming connection from /84.196.23.140:42722
2011-12-29 11:48:06,852 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 84.196.23.140
2011-12-29 11:48:06,852 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Samsung TV / player (C/D-series)'
2011-12-29 11:48:07,039 DEBUG [WebServer] Incoming connection from /84.196.23.140:34295
Missy_X
Post Thu Dec 29, 2011 2:18 pm
Ok, i solved this problem by manually inputting network settings in the tv. But now i've lost internet connection on the tv.
I set :
ip to 81.83.79.191 (pc is 81.83.79.190)
subnet mask to 255.255.254.0
gateway to 81.83.78.1
(found those in ipconfig)
But then it ask me for a DNS server and i'm not sure where to find that. I tried the one it fills in when i let it set up the network settings automatically (195.130.130.132) but that doesn't work.
Any ideas ?
Post Thu Dec 29, 2011 2:54 pm
Your IP addresses are not standard. The standard Home network IP addresses are something like the following.
192.168.1.1 - 192.168.1.90
Your internet IP might be the 81.83.79.190, but anything on your personal home network probably should be on 192.168.x.x. I know this is how it is in the USA, not sure how it is anywhere else.
Anyone in UK or anywhere else want to chime in on what the normal Ip addresses for home networks in your area is.
for DNS in USA I use 8.8.8.8 and 8.8.4.4 which are google DNS servers.
what is the brand of router you are using?
Missy_X
Post Thu Dec 29, 2011 3:42 pm
I'm not behind a router, i'm using a D-Link DES-1005D switch. The weird thing is that when i manually put the network info in my tv, it says it can't find the network. But a minute later, the Serviio thing pops up and it works fine. When i go back to check the network settings, it still says it can't find a network .. But Serviio works fine and very fast. I'm a complete noob to networks obviously lol
Post Thu Dec 29, 2011 3:56 pm
Using that switch, instead of a router is causing all your problems. Right now your TV and computer can be directly accessed from the internet. Using a router with a hardware firewall will protect your devices and allow them to work together better, while maintaining full internet connection for each device.
A router is a device that forwards data packets between computer networks, creating an overlay internetwork. A router is connected to two or more data lines from different networks. When a data packet comes in on one of the lines, the router reads the address information in the packet to determine its ultimate destination. Then, using information in its routing table or routing policy, it directs the packet to the next network on its journey. Routers perform the "traffic directing" functions on the Internet. A data packet is typically forwarded from one router to another through the networks that constitute the internetwork until it gets to its destination node.[1]
