At aloss with Serviio and Samsung
theboneman21
Post Tue Jan 03, 2012 5:56 pm
Hello gang.
Forgive me if this specific one has been posted; I don't know enough to know all the possible lingo to perform a proper search.
TV is Samsung pn50c540
Blu Ray is Samsung BDC 5500
Both wireless and Wired, the tv can see my PC
I have assigned subfolders; My S drive is my external. On there I keep everything such as tv shows, movies, football games, images, apps etc
So, i added Movies, TV Shows and Football games, all subfolders of the S drive, thus, S:\Movies, S:\TV Shows, S:\Football Games
Inside each are the folders of each item, so, for example, Start Trek is S:\Movies\Star Trek 2009
Here's the problem > i am only seeing the first tier of sub folder, so S:\Movies, S:\TV Shows, S:\Football Games
Is it possibly a Serviio limitation where it can only show so many sub folders ?
Or (more likely) am I missing a step somewhere ?
Post Tue Jan 03, 2012 6:24 pm
Re: At aloss with Serviio and Samsung
FAQ wrote:My files (on remote drive) are not scanned
Make sure the user that runs Serviio server/service has got access to the shared folders. If you are on Windows, check that the user running the Windows service has got access. To run the service as a different user go to Services (from the Windows Control Panel → Administrative Tools or typing "Services.msc" in the Run command on Start menu), select Serviio, right-click -> Properties, Log On tab, enter user's details and restart the service.
To access a NAS device the exact same set of credentials must be created on the NAS device. The Windows credentials must be a local user and not a domain user. The user must have "Run As Service" rights. The remote path must be entered as a UNC path in the Serviio Console (e.g. \\server\folder)), mapped drive letters will not work since user running the Serviio service is not aware of your mapped drives.
theboneman21
Post Tue Jan 03, 2012 6:39 pm
Thanks for the quick reply cerebrus
great name too
so, when i do that (enter the user's details) are you referring to my windows login credentials ?
Post Tue Jan 03, 2012 6:48 pm
what type of drive is it ? USB/network/internal ?
theboneman21
Post Tue Jan 03, 2012 7:21 pm
External USB 1 TB Samsung
Post Tue Jan 03, 2012 7:25 pm
check that " system " has permission to access the drive.
theboneman21
Post Tue Jan 03, 2012 8:11 pm
Not sure what you mean there ?
System ?
As in Serviio ?
How would I go about that ? Do I still have to do anything in the services interface ?
Post Tue Jan 03, 2012 9:10 pm
1. go to my computer,
2. right click on the S drive
3. click properties
4. select security
5. check that SYSTEM has full access/permissions to the folder.
theboneman21
Post Tue Jan 03, 2012 9:18 pm
There's no "system"
There's an "Everyone"
it has allow checked all the way down the line until the option called "Special Permissions" which has no checks at all
Post Tue Jan 03, 2012 9:22 pm
there is the issue then, you need to give SYSTEM permissions to that drive, so that the serviio service can then work.
theboneman21
Post Tue Jan 03, 2012 10:54 pm
Cerberus wrote:there is the issue then, you need to give SYSTEM permissions to that drive, so that the serviio service can then work.
Do you know what my next question is ?
*Ducks for cover*
Post Tue Jan 03, 2012 11:49 pm
come on please try and help yourself.
http://www.addictivetips.com/windows-ti ... ownership/
theboneman21
Post Wed Jan 04, 2012 1:14 pm
Cerberus wrote:come on please try and help yourself.
No dice.
There was no SYSTEM present. Added it in the below interfac. First picture is the before. Second pic is after I manually added "SYSTEM" I have not tried it having changed the owner to SYSTEM because I don;t want to get too far and possibly brick up my system. Is this on the right track ie can I properly save, reboot, and give it a whirl ?
Post Wed Jan 04, 2012 1:33 pm
Look at the serviio files on your computer and see what groups and users are Authorized to start and run it.
Post Wed Jan 04, 2012 2:22 pm
yer that it, you dont need
full control
special permissions
selected but all rest have to be. :)
or compare with the setting for your main C:\ they should really be identical
theboneman21
Post Thu Jan 05, 2012 9:25 am
Seem to have it figured out
thanks guys
Users browsing this forum: Google [Bot] and 21 guests
