Media Server Error: A network error has occurred. (00000000)
spcurtis81
Post Tue Oct 04, 2011 10:27 pm
Hi I've seen a similar issue to this in the forums but from a Linux user and I'm wondering if I have the same symptoms however I'm not quite sure how to solve it.
I'm running Serviio 0.6.0.1 on Windows Homeserver 2011 and I'm trying to render on my PS3 however I am getting the following error...
"Media Server Error: A network error has occurred. (00000000)"
My .AVI files play fine but .MKV's return the error above (I guess it's related to the transcoding).
The following code is from my serviio log however I limited it to a small selection around which I thought I was getting the error as the full files is about 300k lines long. With any luck I got the bit that is of use.
Having read another post with a similar issue, the user was instructed to upgrade their ffmpeg but unfortunately I am struggling with this bit.
Can anyone advise...
    Is the solution to my problem updating my ffmpeg?
    Does anyone know any easy way of doing this for someone with no previous experience (e.g. an installer or a step by step guide)?
Any help would be appreciated. :)
2011-10-04 23:06:26,440 DEBUG [MediaItemDAOImpl] Media item 1-10 Fanny (Be Tender With My Love).mp3 already exists in DB
2011-10-04 23:06:26,460 DEBUG [LibraryAdditionsCheckerThread] Found file '1-11 Warm Ride (Bonus).mp3', checking if it's already in the Library
2011-10-04 23:06:26,460 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item 1-11 Warm Ride (Bonus).mp3
2011-10-04 23:06:26,461 DEBUG [MediaItemDAOImpl] Media item 1-11 Warm Ride (Bonus).mp3 already exists in DB
2011-10-04 23:06:26,481 DEBUG [LibraryAdditionsCheckerThread] Found file '1-12 Stayin' Alive (Promo 12_ Versio.mp3', checking if it's already in the Library
2011-10-04 23:06:26,481 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item 1-12 Stayin' Alive (Promo 12_ Versio.mp3
2011-10-04 23:06:26,482 DEBUG [MediaItemDAOImpl] Media item 1-12 Stayin' Alive (Promo 12_ Versio.mp3 already exists in DB
2011-10-04 23:06:26,502 DEBUG [LibraryAdditionsCheckerThread] Found file '2-13 If I Can't Have You.mp3', checking if it's already in the Library
2011-10-04 23:06:26,502 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item 2-13 If I Can't Have You.mp3
2011-10-04 23:06:26,503 DEBUG [MediaItemDAOImpl] Media item 2-13 If I Can't Have You.mp3 already exists in DB
2011-10-04 23:06:26,523 DEBUG [LibraryAdditionsCheckerThread] Found file '2-14 You Stepped Into My Life.mp3', checking if it's already in the Library
2011-10-04 23:06:26,523 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item 2-14 You Stepped Into My Life.mp3
2011-10-04 23:06:26,524 DEBUG [MediaItemDAOImpl] Media item 2-14 You Stepped Into My Life.mp3 already exists in DB
2011-10-04 23:06:26,544 DEBUG [LibraryAdditionsCheckerThread] Found file '2-15 Love Me.mp3', checking if it's already in the Library
2011-10-04 23:06:26,544 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item 2-15 Love Me.mp3
2011-10-04 23:06:26,544 DEBUG [MediaItemDAOImpl] Media item 2-15 Love Me.mp3 already exists in DB
2011-10-04 23:06:26,561 ERROR [ResourceTransportRequestHandler] Error while processing resource, sending back 500 error. Message: FFmpeg execution failed
   at org.serviio.delivery.resource.AbstractTranscodingDeliveryEngine.retrieveTranscodedResource(AbstractTranscodingDeliveryEngine.java:117)
   at org.serviio.delivery.resource.AbstractDeliveryEngine.deliver(AbstractDeliveryEngine.java:93)
   at org.serviio.delivery.MediaResourceRetrievalStrategy.retrieveResource(MediaResourceRetrievalStrategy.java:121)
   at org.serviio.upnp.webserver.ResourceTransportRequestHandler.handleRequest(ResourceTransportRequestHandler.java:116)
2011-10-04 23:06:26,565 DEBUG [LibraryAdditionsCheckerThread] Found file '2-16 More Than A Woman.mp3', checking if it's already in the Library
2011-10-04 23:06:26,579 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item 2-16 More Than A Woman.mp3
2011-10-04 23:06:26,580 DEBUG [MediaItemDAOImpl] Media item 2-16 More Than A Woman.mp3 already exists in DB
2011-10-04 23:06:26,586 DEBUG [WebServer] Incoming connection from /192.168.1.95:64938
2011-10-04 23:06:26,586 DEBUG [ResourceTransportRequestHandler] GET /resource/33458/MEDIA_ITEM/AVC_TS_MP_HD_AC3_ISO$0 HTTP/1.1, headers = [Host: 192.168.1.71:8895,User-Agent: PLAYSTATION 3,Connection: Keep-Alive,Accept-Encoding: identity,transferMode.dlna.org: Streaming,TimeSeekRange.dlna.org: npt=0.000-]]
2011-10-04 23:06:26,586 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.95
2011-10-04 23:06:26,587 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.1.95, Profile=Playstation 3'
2011-10-04 23:06:26,588 DEBUG [ResourceTransportRequestHandler] Request for resource 33458 and type 'MEDIA_ITEM' received
2011-10-04 23:06:26,588 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 33458 (local)
2011-10-04 23:06:26,588 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 33458)
2011-10-04 23:06:26,588 DEBUG [VideoDAOImpl] Reading a Video (id = 33458)
2011-10-04 23:06:26,588 DEBUG [VideoDeliveryEngine] Delivering item '33458' for client 'IPAddress=/192.168.1.95, Profile=Playstation 3'
2011-10-04 23:06:26,589 DEBUG [VideoDeliveryEngine] Delivering file 'Greys.Anatomy.S08E03.720p.WEB-DL.DD5.1.H.264-KiNGS.mkv' using transcoding
2011-10-04 23:06:26,589 DEBUG [AbstractTranscodingDeliveryEngine] A suitable transcoding job already exists, re-use it for client 'IPAddress=/192.168.1.95, Profile=Playstation 3'
2011-10-04 23:06:26,589 ERROR [ResourceTransportRequestHandler] Error while processing resource, sending back 500 error. Message: FFmpeg execution failed
2011-10-04 23:06:26,600 DEBUG [LibraryAdditionsCheckerThread] Found file '2-17 Rest Your Love On Me.mp3', checking if it's already in the Library
2011-10-04 23:06:26,600 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item 2-17 Rest Your Love On Me.mp3
2011-10-04 23:06:26,600 DEBUG [MediaItemDAOImpl] Media item 2-17 Rest Your Love On Me.mp3 already exists in DB
2011-10-04 23:06:26,621 DEBUG [LibraryAdditionsCheckerThread] Found file '2-18 Nights On Broadway.mp3', checking if it's already in the Library
2011-10-04 23:06:26,621 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item 2-18 Nights On Broadway.mp3
2011-10-04 23:06:26,621 DEBUG [MediaItemDAOImpl] Media item 2-18 Nights On Broadway.mp3 already exists in DB
2011-10-04 23:06:26,642 DEBUG [LibraryAdditionsCheckerThread] Found file '2-19 Spirits (Having Flown).mp3', checking if it's already in the Library
2011-10-04 23:06:26,642 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item 2-19 Spirits (Having Flown).mp3
2011-10-04 23:06:26,643 DEBUG [MediaItemDAOImpl] Media item 2-19 Spirits (Having Flown).mp3 already exists in DB
Post Tue Oct 04, 2011 11:36 pm
Re: Media Server Error: A network error has occurred. (00000
If you look at the serviio.log file it will give information about your system. Please post that. We need to know your O/S. Also from a command prompt run ffmpeg.exe -i and post the information here.
Post Tue Oct 04, 2011 11:53 pm
moltra wrote:If you look at the serviio.log file it will give information about your system. Please post that. We need to know your O/S. Also from a command prompt run ffmpeg.exe -i and post the information here.
we know what his OS is he told us? - WHS 2011
it look to me as if his temp folder is full and taht whats causing serviio to time out,
@spcurtis81
nope not a FFmpeg issue as your runnig windows ao you have one bundled with serviio.
check and empty your tempory (temp) folder as it appears to me to be full and thats whats making serviio time out. :)
spcurtis81
Post Wed Oct 05, 2011 5:51 pm
Hi Moltra. Sorry, I'm having loads of trouble pasting my serviio log here. It's massive. Made what is probably a mistake of deleting it's contents and then trying to play an MKV on my PS3 again in order to create the same message but in a shorter log but the file has so many lines this page just freezes when I try to submit the post. I've checked through the log and can't see any info on OS but I can confirm that I'm running Windows Home Server 2011 64 bit and my Serviio version is 0.6.0.1.
I did however manage to get the ffmpeg info...
c:\Program Files (x86)\Serviio\lib>ffmpeg.exe -i
nfig
ffmpeg.exe: missing argument for option 'i'
Maybe this is of use?
@spcurtis81
Hi Cerberus,
I am sure I am being quite dense here but I need to clarify what you mean by temp folder. At first I thought you meant Windows temp folder (C:\Windows\Temp\) so I ran CCleaner. Then it occurred to me that you meant a temp folder for Serviio specifically so I went looking and the only thing I found was the "tmp" folder here... C:\Program Files (x86)\Serviio\library\db\tmp and I found this folder to be empty. I don't suppose you could clarify the folder you mean here could you?
I appreciate both your support (and patience probably) :)
Post Wed Oct 05, 2011 7:02 pm
im guessing you are using the normal serviio console and not the WHS intergration thing?
and that you have latest version of java install (1.6 update 27)?
spcurtis81
Post Wed Oct 05, 2011 10:30 pm
Cerberus wrote:im guessing you are using the normal serviio console and not the WHS intergration thing?
Yeah I used the standard Windows version from the downloads page which looks like this....
Windows: serviio-0.6.0.1-win-setup.exe [mirror] (18,267,542 bytes, MD5: baf79a6249b946c2882de7a2673b7dbd)
and yes my Java is as you say 1.6 update 27.
I decided to unistall Java and Serviio and start again. I installed Java first and then Serviio (re-booting inbetween each step). I'm still experiencing the issue but I've found that some .mkv's appear to work and some don't. I do now have a copy of my serviio log though. This bit I'm guessing is the OS bit...
2011-10-05 21:28:28,534 INFO  [MediaServer] ------------------------------------------------------------------------
2011-10-05 21:28:28,534 INFO  [MediaServer] Serviio DLNA media streaming server v 0.6.0.1 (rev. 8e4ee98bff12)
2011-10-05 21:28:28,550 INFO  [MediaServer] Petr Nejedly 2009-2011
2011-10-05 21:28:28,550 INFO  [MediaServer] http://www.serviio.org
2011-10-05 21:28:28,550 INFO  [MediaServer] Java 1.6.0_23-Sun Microsystems Inc.
2011-10-05 21:28:28,550 INFO  [MediaServer] OS Windows Server 2008 R2 amd64 6.1
2011-10-05 21:28:28,550 INFO  [MediaServer] File encoding: windows-1252
2011-10-05 21:28:28,550 INFO  [MediaServer] Headless mode enabled: true
2011-10-05 21:28:28,550 INFO  [MediaServer] User home dir: C:\
2011-10-05 21:28:28,550 INFO  [MediaServer] Temp dir: C:\Windows\TEMP\
2011-10-05 21:28:28,550 INFO  [MediaServer] ------------------------------------------------------------------------
2011-10-05 21:28:28,721 INFO  [RestletServer] Starting Restlet server exposed on port 23423
2011-10-05 21:28:28,799 INFO  [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2011-10-05 21:28:37,988 INFO  [DBSchemaUpdateExecutor] Updating DB schema
2011-10-05 21:28:51,310 INFO  [ProfilesDefinitionParser] Parsing Profiles definition
2011-10-05 21:28:52,168 INFO  [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2011-10-05 21:28:52,574 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2011-10-05 21:28:52,792 INFO  [ProfilesDefinitionParser] Added profile 'XBox 360' (id=3)
2011-10-05 21:28:53,010 INFO  [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2011-10-05 21:28:53,166 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2011-10-05 21:28:53,322 INFO  [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2011-10-05 21:28:53,712 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2011-10-05 21:28:53,775 INFO  [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2011-10-05 21:28:54,352 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV' (id=9)
2011-10-05 21:28:55,272 INFO  [ProfilesDefinitionParser] Added profile 'Sony BD Player' (id=10)
2011-10-05 21:28:55,631 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera' (id=12)
2011-10-05 21:28:55,943 INFO  [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2011-10-05 21:28:56,021 INFO  [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2011-10-05 21:28:56,068 INFO  [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2011-10-05 21:28:56,208 INFO  [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2011-10-05 21:28:56,302 INFO  [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2011-10-05 21:28:56,520 INFO  [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2011-10-05 21:28:57,144 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV 2011' (id=19)
2011-10-05 21:28:57,800 INFO  [ProfilesDefinitionParser] Added profile 'Sony SMP-N100' (id=20)
2011-10-05 21:28:57,831 INFO  [CompositeCacheManager] Creating cache manager from config file: /cache.ccf
2011-10-05 21:28:57,846 INFO  [ThreadPoolManager] thread_pool.default PoolConfiguration = useBoundary = [true] boundarySize = [2000] maximumPoolSize = [150] minimumPoolSize = [4] keepAliveTime = [300000] whenBlockedPolicy = [RUN] startUpSize = [4]
2011-10-05 21:28:57,862 INFO  [CompositeCacheConfigurator] Setting default auxiliaries to null
2011-10-05 21:28:57,862 INFO  [CompositeCacheConfigurator] No special CompositeCacheAttributes class defined for key [jcs.default.cacheattributes], using default class.
2011-10-05 21:28:57,862 INFO  [CompositeCacheConfigurator] setting defaultCompositeCacheAttributes to [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 100, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-10-05 21:28:57,862 INFO  [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.default.elementattributes], using default class.
2011-10-05 21:28:57,862 INFO  [CompositeCacheConfigurator] setting defaultElementAttributes to [ IS_LATERAL = true, IS_SPOOL = true, IS_REMOTE = true, IS_ETERNAL = true, MaxLifeSeconds = -1, IdleTime = -1, CreateTime = 1317846537862, LastAccessTime = 1317846537862, getTimeToLiveSeconds() = -1, createTime = 1317846537862 ]
2011-10-05 21:28:57,909 INFO  [LRUMemoryCache] initialized LRUMemoryCache for thumbnails
2011-10-05 21:28:57,909 INFO  [CompositeCache] Constructed cache with name [thumbnails] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-10-05 21:28:57,909 INFO  [LRUMemoryCache] initialized LRUMemoryCache for online_feeds
2011-10-05 21:28:57,909 INFO  [CompositeCache] Constructed cache with name [online_feeds] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-10-05 21:28:57,909 INFO  [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_default.elementattributes], using default class.
2011-10-05 21:28:57,909 INFO  [LRUMemoryCache] initialized LRUMemoryCache for local_default
2011-10-05 21:28:57,909 INFO  [CompositeCache] Constructed cache with name [local_default] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-10-05 21:28:57,909 INFO  [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_resetafterplay.elementattributes], using default class.
2011-10-05 21:28:57,909 INFO  [LRUMemoryCache] initialized LRUMemoryCache for local_resetafterplay
2011-10-05 21:28:57,909 INFO  [CompositeCache] Constructed cache with name [local_resetafterplay] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-10-05 21:28:57,909 INFO  [CompositeCacheConfigurator] Parsed regions [thumbnails, online_feeds, local_default, local_resetafterplay]
2011-10-05 21:28:57,909 INFO  [CompositeCacheConfigurator] Finished configuration in 47 ms.
2011-10-05 21:28:58,642 INFO  [WebServer] Socket buffer set to 65535 bytes
2011-10-05 21:28:58,642 INFO  [Device] Created UPnP Device with UUID: 3bcd0932-7532-328d-bc48-cb77b4f9b378, bound address: 192.168.1.71
2011-10-05 21:28:58,689 INFO  [PluginCompilerThread] Looking for plugins at C:\Program Files (x86)\Serviio\bin\..\plugins
2011-10-05 21:28:58,689 INFO  [PluginCompilerThread] Started looking for plugins
2011-10-05 21:28:58,970 INFO  [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2011-10-05 21:28:59,048 INFO  [WebServer] WebServer starting on port 8895
2011-10-05 21:28:59,079 INFO  [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2011-10-05 21:28:59,079 INFO  [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2011-10-05 21:28:59,094 INFO  [RendererSearchSender] Searching for Renderer devices
2011-10-05 21:28:59,126 INFO  [RendererExpirationChecker] Starting RendererExpirationChecker
2011-10-05 21:28:59,126 INFO  [EventDispatcher] Starting EventDispatcher
2011-10-05 21:28:59,223 INFO  [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth3 (Broadcom NetXtreme Gigabit Ethernet) and address 192.168.1.71, timeout = 0
2011-10-05 21:29:00,471 INFO  [RendererManager] Stored a new renderer: uuid='f0f87f73-4675-4d25-b895-b81805b66d9a', name = 'Unrecognized device', ipAddress='192.168.1.71', profile = '1'
2011-10-05 21:29:26,352 INFO  [FeedUpdaterThread] Started looking for information about online feeds
2011-10-05 21:29:26,398 INFO  [LibraryAdditionsCheckerThread] Started looking for newly added files
2011-10-05 21:29:26,476 INFO  [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2011-10-05 21:33:05,044 INFO  [ServiioConsole] Starting Serviio Console
2011-10-05 21:33:05,217 INFO  [ServiioConsole] Connecting to Serviio REST on localhost:23423
2011-10-05 21:33:06,537 INFO  [Messages] Loaded console message bundle for locale: en
2011-10-05 21:33:07,403 INFO  [Messages] Loaded console message bundle for locale: en
2011-10-05 21:33:07,540 INFO  [UpdateChecker] Checking if a new version is available
2011-10-05 21:33:14,746 INFO  [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2011-10-05 21:33:15,628 INFO  [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: en
2011-10-05 21:36:42,668 INFO  [RendererManager] Stored a new renderer: uuid='8a664e08-818e-4d97-9e19-ee20a322797c', name = 'Playstation 3', ipAddress='192.168.1.95', profile = '4'
2011-10-05 21:37:16,321 INFO  [RendererManager] Stored a new renderer: uuid='227e8395-0115-499a-b02f-9486b71ea839', name = 'PS3', ipAddress='192.168.1.95', profile = '4'
2011-10-05 21:37:16,323 INFO  [EventDispatcher] Leaving EventDispatcher
2011-10-05 21:37:16,323 INFO  [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2011-10-05 21:37:16,351 INFO  [WebServer] WebServer shutting down
2011-10-05 21:37:16,399 INFO  [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2011-10-05 21:37:16,936 INFO  [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2011-10-05 21:37:16,948 INFO  [WebServer] WebServer starting on port 8895
2011-10-05 21:37:16,951 INFO  [RendererSearchSender] Searching for Renderer devices
2011-10-05 21:37:16,960 INFO  [EventDispatcher] Starting EventDispatcher
2011-10-05 21:37:16,960 INFO  [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2011-10-05 21:37:16,955 INFO  [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2011-10-05 21:37:16,995 INFO  [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth3 (Broadcom NetXtreme Gigabit Ethernet) and address 192.168.1.71, timeout = 0
2011-10-05 21:37:18,904 INFO  [RendererManager] Stored a new renderer: uuid='94aff449-4e94-4a91-b0fb-3cbdde6620f8', name = 'Playstation 3', ipAddress='192.168.1.95', profile = '4'
2011-10-05 21:37:19,258 INFO  [RendererExpirationChecker] Leaving RendererExpirationChecker
2011-10-05 21:38:11,907 INFO  [LibraryAdditionsCheckerThread] Finished looking for newly added files
2011-10-05 21:38:12,007 INFO  [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2011-10-05 21:38:12,125 INFO  [LibraryAdditionsCheckerThread] Started looking for newly added files
2011-10-05 21:38:12,125 INFO  [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
...it then goes on to list the addition of lots of movie files etc... and then at the end of the log there are some errors...
2011-10-05 23:10:53,630 WARN  [ProcessExecutor] Process cmd has a return code of 1! This is a possible error.
2011-10-05 23:10:53,979 ERROR [ResourceTransportRequestHandler] Error while processing resource, sending back 500 error. Message: FFmpeg execution failed
2011-10-05 23:10:54,019 ERROR [ResourceTransportRequestHandler] Error while processing resource, sending back 500 error. Message: FFmpeg execution failed
2011-10-05 23:22:49,300 INFO  [ServiioConsole] Leaving Serviio Console
Post Wed Oct 05, 2011 10:56 pm
ok cool so its no longer a network issue, that good our problem now relates to this in your log.
ok from reading back through old post this seems top relate to FFmpeg missing a lib that it requires to work, which to me seems very strange as you are on windows so ffmpeg should be the only bundled in the package.
@ZIP - can you take a look at this one please seems to be your area :)
MUK1
Post Sat Oct 08, 2011 11:30 pm
Hi there,
For extra info, and diff OS:
2011-10-09 00:20:03,905 INFO  [MediaServer] ------------------------------------------------------------------------
2011-10-09 00:20:03,905 INFO  [MediaServer] Serviio DLNA media streaming server v 0.6.0.1 (rev. 8e4ee98bff12)
2011-10-09 00:20:03,905 INFO  [MediaServer] Petr Nejedly 2009-2011
2011-10-09 00:20:03,905 INFO  [MediaServer] http://www.serviio.org
2011-10-09 00:20:03,905 INFO  [MediaServer] Java 1.6.0_23-Sun Microsystems Inc.
2011-10-09 00:20:03,905 INFO  [MediaServer] OS Windows 7 amd64 6.1
2011-10-09 00:20:03,905 INFO  [MediaServer] File encoding: windows-1252
2011-10-09 00:20:03,906 INFO  [MediaServer] Headless mode enabled: true
2011-10-09 00:20:03,906 INFO  [MediaServer] User home dir: C:\
2011-10-09 00:20:03,906 INFO  [MediaServer] Temp dir: C:\Windows\TEMP\
2011-10-09 00:20:03,906 INFO  [MediaServer] ------------------------------------------------------------------------
2011-10-09 00:20:03,998 INFO  [RestletServer] Starting Restlet server exposed on port 23423
I get the same error:
2011-10-09 00:23:30,099 DEBUG [WebServer] Incoming connection from /192.168.1.105:59777
2011-10-09 00:23:30,099 DEBUG [ResourceTransportRequestHandler] GET /resource/970/MEDIA_ITEM/AVC_TS_MP_HD_AC3_ISO$0 HTTP/1.1, headers = [Host: 192.168.1.100:8895,User-Agent: PLAYSTATION 3,Connection: Keep-Alive,Accept-Encoding: identity,transferMode.dlna.org: Streaming,TimeSeekRange.dlna.org: npt=0.000-]]
2011-10-09 00:23:30,099 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.105
2011-10-09 00:23:30,099 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.1.105, Profile=Playstation 3'
2011-10-09 00:23:30,100 DEBUG [ResourceTransportRequestHandler] Request for resource 970 and type 'MEDIA_ITEM' received
2011-10-09 00:23:30,100 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 970 (local)
2011-10-09 00:23:30,100 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 970)
2011-10-09 00:23:30,100 DEBUG [VideoDAOImpl] Reading a Video (id = 970)
2011-10-09 00:23:30,101 DEBUG [VideoDeliveryEngine] Delivering item '970' for client 'IPAddress=/192.168.1.105, Profile=Playstation 3'
2011-10-09 00:23:30,101 DEBUG [VideoDeliveryEngine] Delivering file 'The.Walking.Dead.S02E00.Preview.mkv' using transcoding
2011-10-09 00:23:30,101 DEBUG [AbstractTranscodingDeliveryEngine] A suitable transcoding job already exists, re-use it for client 'IPAddress=/192.168.1.105, Profile=Playstation 3'
2011-10-09 00:23:30,101 ERROR [ResourceTransportRequestHandler] Error while processing resource, sending back 500 error. Message: FFmpeg execution failed
Any help truly appreciated,
MUK1
Post Sun Oct 09, 2011 4:30 pm
there is the ffmpeg command used to start the transcoding somewhere further up in the log, above of what you posted. you'll have to execute that ffmpeg command and post the (error) message here.
MUK1
Post Mon Oct 10, 2011 8:00 pm
Hi Zip, that command as requested:
nfig
Post Mon Oct 10, 2011 8:25 pm
post the whole log (zip it up and attach), this is not it
MUK1
Post Tue Oct 11, 2011 12:38 pm
Hi Zip
1st issue:
ffmpeg.exe -i F:\SHARE\Series\Walking Dead\The.Walking.Dead.S02E00.Preview.mkv -y -vcodec copy -vbsf h264_mp4toannexb -copyts -acodec ac3 -ab 384k -ac 2 -map 0:1 -map 0:0 -sn -f mpegts C:\Windows\TEMP\Serviio\transcoding-temp-970-MPEG2TS.stf
I get:
D:\Program Files (x86)\Serviio\lib>ffmpeg.exe -i F:\SHARE\Series\Walking Dead\Th
nfig
F:\SHARE\Series\Walking: No such file or directory
So I put it in ""
ffmpeg.exe -i "F:\SHARE\Series\Walking Dead\The.Walking.Dead.S02E00.Preview.mkv" -y -vcodec copy -vbsf h264_mp4toannexb -copyts -acodec ac3 -ab 384k -ac 2 -map 0:1 -map 0:0 -sn -f mpegts C:\Windows\TEMP\Serviio\transcoding-temp-970-MPEG2TS.stf
and i get:
D:\Program Files (x86)\Serviio\lib>ffmpeg.exe -i "F:\SHARE\Series\Walking Dead\T
nfig
[matroska,webm @ 0003c280] Estimating duration from bitrate, this may be inaccur
ate
Seems stream 1 codec frame rate differs from container frame rate: 47.95 (5994/1
25) -> 23.98 (24000/1001)
Input #0, matroska,webm, from 'F:\SHARE\Series\Walking Dead\The.Walking.Dead.S02
E00.Preview.mkv':
  Duration: 00:01:30.38, start: 0.000000, bitrate: N/A
    Stream #0.0(eng): Audio: aac, 48000 Hz, stereo, s16 (default)
      title           : English
    Stream #0.1(eng): Video: h264 (High), yuv420p, 1280x720 [PAR 1:1 DAR 16:9],
23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc (default)
[ac3 @ 0334de20] channel_layout not specified
[ac3 @ 0334de20] No channel layout specified. The encoder will guess the layout,
 but it might be incorrect.
[mpegts @ 0003b960] muxrate VBR, pcr every 2 pkts, sdt every 200, pat/pmt every
40 pkts
Output #0, mpegts, to 'C:\Windows\TEMP\Serviio\transcoding-temp-970-MPEG2TS.stf'
    encoder         : Lavf53.6.0
    Stream #0.0(eng): Video: [0][0][0][0] / 0x0000, yuv420p, 1280x720 [PAR 1:1 D
AR 16:9], q=2-31, 90k tbn, 23.98 tbc (default)
    Stream #0.1(eng): Audio: ac3, 48000 Hz, stereo, s16, 384 kb/s (default)
      title           : English
Stream mapping:
  Stream #0.1 -> #0.0
  Stream #0.0 -> #0.1
[mpegts @ 0003b960] pts < dts in stream 0
av_interleaved_write_frame(): Invalid argument
Hope this can be of help
Thank
MUK1
MUK1
Post Tue Oct 11, 2011 12:41 pm
NB:
renaming the folder on my HDD without a space does not make any difference, the file still does not play.
NB2:
Using PS3 media server [MENCODER] as a test, this file plays ok.... obv i don't want to use that tho lol
thx M
Post Tue Oct 11, 2011 1:03 pm
OK, it's caused by FFmpeg's bug. I will see if I can update FFmpeg with a patch for a future version(s) to get around this.
MUK1
Post Tue Oct 11, 2011 5:39 pm
Thanks Zip, great stuff, look forward to patch :-)
If you need a tester, give me a shout.
spcurtis81
Post Fri Oct 14, 2011 4:30 pm
Blu3Fr0g
Post Thu Jan 05, 2012 8:55 pm
So, I am running v0.6.0.1 and am getting this error quite frequently when trying to play MKV files on my PS3 via the Serviio server. Here is the Serviio log:
2012-01-05 12:42:22,334 ERROR [ResourceTransportRequestHandler] Error while processing resource, sending back 500 error. Message: FFmpeg execution failed
So is there something, anything I can do to fix this? I tried renaming the folder to remove spaces to no avail.
Post Thu Jan 05, 2012 9:17 pm
Blu3Fr0g wrote:So, I am running v0.6.0.1 and am getting this error quite frequently when trying to play MKV files on my PS3 via the Serviio server. Here is the Serviio log:
thats for an online feed it just means feed was unavailible when serviio tried to access it.
PC Bigboy
Post Thu Dec 12, 2013 11:04 am
I'm encountering the same issue. I use Serviio exclusively for online media & I can't even play THAT without encountering this error message
I've resorted to setting aside a tewmp folder SPECIFICALLY for Serviio instead of using the system default of C:\WINDOWS\TEMP which every other program under the sun uses in the hopes that will solve the problem. My question is how many of you have had better luck with this ??
Cheers :)
Pat Cook
Englewood, CO
Users browsing this forum: Baidu [Spider] and 17 guests
