about metadata [solved]
erikblade
Post Sat Jan 14, 2012 10:04 pm
hi,
First, apologize for my English.
may already be addressed in some other post on the forum but have not been able to find.
The point is that when I select the metadata obtained from the internet, sometimes the titles of the films are changed.
I'm interested in it only adds the missing metadata leaving the existing ones as they are
Post Sat Jan 14, 2012 10:06 pm
Re: about metadata
Are you talking about the movie title changing? That is the title that the online database has for the title. That is not easily changed while maintaining the rest of the metadata.
erikblade
Post Sat Jan 14, 2012 10:10 pm
Re: about metadata
perhaps a way could be that the metadata are not rewritten, only adds the missing
thanks for your quick response
Post Sat Jan 14, 2012 10:13 pm
Re: about metadata
You could setip a special folder that uses xbmc nfo files for metadata not the online metadata. You would have use xbmc to get the initial data and then you could edit the data to what you want it to be.
http://www.serviio.org/index.php?option=com_content&view=article&id=12
Swisscenter
Serviio supports importing XML files generated by Swisscenter media center. Using this extractor will enable you to completely manage your media library metadata via Swisscenter.
XBMC
Serviio supports importing .nfo XML files generated by XBMC. Using this extractor will enable you to completely manage your media library metadata via XBMC.
erikblade
Post Sat Jan 14, 2012 10:20 pm
Re: about metadata
thanks i´ll try it
Post Sat Jan 14, 2012 10:21 pm
Re: about metadata
if you have any more questions please ask. If this works the way you want please mark the post [Solved].
Return to Feature requests
Users browsing this forum: Google [Bot] and 10 guests
