Re: Chapter function
No, but you could generate them with a default image and add an option for the people who want them.
Regards,
Krater
Cerberus wrote:- what about files already containing chapters information and currently not using them? if device supported them they would already be used
firesnail wrote:Cerberus wrote:- what about files already containing chapters information and currently not using them? if device supported them they would already be used
But if the device doesn't support them it would be nice if the .mta generated on the fly by Serviio reflects the content of the chapters saved in the .mkv!
zip wrote:Most of what cerberus said is right. Not sure about number of chapters - I assume the TV only supports fixed number (5?) if I remember the UI correctly. Will start with a proportional chapter split and if it works we can add mkv chapter split in future.
