livestreams howto for udp/rtp
Is it possibel to use this in serviio as a live stream, because now I see a unknown protocol error in the log file?
jhb50 wrote:
Both of those hang ffmpeg -i and vlc, with or without the @, so they will not play in Serviio
zip wrote:Ok, Serviio itself doesn't handle UDP delivery (only http), the other protocols must go through FFmpeg. Therefore you have to add mpegts container matcher to the online transcoding of your profile (or the generic one).
hanslinux wrote:I've used an util called udxpy which translates multicasts to unicasts , give an url like this http://1.2.3.4:5555/udp/6.7.8.9:8888 as live stream and it works.zip wrote:Ok, Serviio itself doesn't handle UDP delivery (only http), the other protocols must go through FFmpeg. Therefore you have to add mpegts container matcher to the online transcoding of your profile (or the generic one).
Users browsing this forum: Google [Bot] and 127 guests
