livestreams howto for udp/rtp
hanslinux
Post Sun Jan 15, 2012 5:43 pm
In Vlc I use am url like this udp://@233.81.233.41:11080 or rtp://@233.81.235.41:11234.
Is it possibel to use this in serviio as a live stream, because now I see a unknown protocol error in the log file?
Post Sun Jan 15, 2012 5:45 pm
Re: livestreams howto for udp/rtp
hanslinux
Post Sun Jan 15, 2012 6:06 pm
In the log file I get the following error :
2012-01-15 19:01:28,514 WARN [ResourceTransportRequestHandler] Error while processing resource, sending back 404 error. Message: Cannot retrieve online media item URL: unknown protocol: rtp
I'm using vlc for testing, which gives the following error:
VLC is unable to open the MRL 'http://192.168.1.10:8895/resource/1000000000030001/MEDIA_ITEM/AVC_TS_HP_HD_MPEG1_L2_ISO$0'. Check the log for details.
The next live stream is working ok:
rtsp://media2.lsops.net/live/bbcworld1_en_high.sdp
Howto solve this?
Post Sun Jan 15, 2012 6:32 pm
can you enable detailed log and post it here?
Post Mon Jan 16, 2012 12:52 am
Both of those hang ffmpeg -i and vlc, with or without the @, so they will not play in Serviio
hanslinux
Post Mon Jan 16, 2012 8:22 am
In my case vlc does NOT hang when using those urls. I don't know about ffmpeg -i, because I am not at home.
Those urls are only possible in my providers network and not free available on the internet, maybe that is the reason why you think they will hang.
Tonight I'll try to post a detailed log.
hanslinux
Post Mon Jan 16, 2012 8:47 pm
Here is the debug log. I've zipped the log directory.
I've try to look at the live stream at 21:38.
I hope this is sufficient for solving the problem.
serviio.log.zip
(175.89 KiB) Downloaded 895 times
hanslinux
Post Mon Jan 16, 2012 9:01 pm
Addtionally here is the output of ffmpeg -i
ffmpeg.txt
(1.83 KiB) Downloaded 1177 times
Post Tue Jan 17, 2012 10:14 am
Ok, Serviio itself doesn't handle UDP delivery (only http), the other protocols must go through FFmpeg. Therefore you have to add mpegts container matcher to the online transcoding of your profile (or the generic one).
hanslinux
Post Thu Jan 19, 2012 9:51 am
I've used an util called udxpy which translates multicasts to unicasts , give an url like this http://1.2.3.4:5555/udp/6.7.8.9:8888 as live stream and it works.
zip wrote:Ok, Serviio itself doesn't handle UDP delivery (only http), the other protocols must go through FFmpeg. Therefore you have to add mpegts container matcher to the online transcoding of your profile (or the generic one).
eafpunto
Post Fri Feb 10, 2012 8:13 pm
I have the same issue with a http/udp link.
http://89.212.74.135:1234/udp/239.1.1.166:5000
For zip, "Therefore you have to add mpegts container matcher to the online transcoding of your profile (or the generic one).", how to do it?
Thx. in advance
eafpunto
Post Sat Feb 18, 2012 10:29 pm
hanslinux wrote:I've used an util called udxpy which translates multicasts to unicasts , give an url like this http://1.2.3.4:5555/udp/6.7.8.9:8888 as live stream and it works.
I have downloaded the udxpy tool and would like some advice howto use it. I want to stream "http://89.212.74.135:1234/udp/239.1.1.166:5000" to my TV using serviio.
Thank you in advance
sarsonuk
Post Fri Mar 30, 2012 11:18 am
Can anyone help me to get this link to work in serviio, I think the extra . is stopping it from working as it works fine in Quicktime,
rtsp://live187.la3.edge.filmon.com/live ... low.stream
Post Fri Mar 30, 2012 12:23 pm
it should work, what errors are you getting? (in the log)
