Change the icon
umbs
Post Fri Jan 20, 2012 11:29 am
Change the icon
It's possibile change the serviio icon?
To be honest I find it ugly :)
You could try doing a icon contest.
Best Regards.
Umberto
Post Fri Jan 20, 2012 11:37 am
Re: Change the icon
I'm open to ideas :-)
Post Fri Jan 20, 2012 11:42 am
Re: Change the icon
Not simply.
- unarchive serviio.jar
- change ./org/serviio/upnp serviio-icon files
- archive serviio.jar
eclp
Post Fri Jan 20, 2012 11:59 am
Re: Change the icon
This was the first thing I replaced. ;)
Sorry zip!
Post Fri Jan 20, 2012 12:29 pm
Re: Change the icon
eclp wrote:This was the first thing I replaced. ;)
Sorry zip!
Small suggestion:
way to common and open to copyright stuff as im sure it close to what have seen on other products.
Xmantium
Post Sun Jan 22, 2012 1:56 pm
Re: Change the icon
Ive always used my own icon that is still faithfull to the original, it works better on my Bravia and PS3 too
Image Image
If anyone want to use the yellow icon for their serviio, its available here, renamed to correct filename to overite in your .jar file using WinRAR
You dont need to unarchive the jar file.
Locate your serviio.jar file, open with WinRAR, and just repace the the icons with the same filename just by pressing "Add", then close WinRAR
eclp
Post Sun Jan 22, 2012 5:51 pm
Re: Change the icon
My draft:
Xmantium, I've used your border. ;)
Post Sun Jan 22, 2012 5:54 pm
Re: Change the icon
eclp wrote:My draft:
try making background slightly darker than arrows and do a green version for teh android app ;) and then its perfect :) imho
Xmantium
Post Sun Jan 22, 2012 6:40 pm
Re: Change the icon
I actually used this site -> http://wizardtoolkit.com/shooter/iPhone-Icon-Generator ;)
Im liking it, but yeah i agree with Cerberus, background shoud be darker
Can the arrows be in the same position as the original, i got a liking to the original :P
Post Sun Jan 22, 2012 7:49 pm
Re: Change the icon
Xmantium wrote:I actually used this site -> http://wizardtoolkit.com/shooter/iPhone-Icon-Generator ;)
i second that :)
eclp
Post Sun Jan 22, 2012 10:35 pm
Re: Change the icon
Another little experiment:
eclp
Post Mon Jan 23, 2012 12:55 pm
Re: Change the icon
and another:
Xmantium
Post Mon Jan 23, 2012 6:36 pm
Re: Change the icon
I'm liking eclp_3 alot!!
its like serviio on fire! :twisted:
can the arrows be anti-clockwise?
eclp
Post Mon Jan 23, 2012 8:21 pm
Re: Change the icon
ok:
Post Mon Jan 23, 2012 8:29 pm
Re: Change the icon
eclp wrote:ok:
B
umbs
Post Wed Feb 01, 2012 4:54 pm
Re: Change the icon
Great!
lazyskate
Post Mon Nov 12, 2012 11:31 am
Re: Change the icon
here's a quick icon I made for mac users; Serviio Application Image, Serviio Console Image
heathen462
Post Fri Nov 16, 2012 4:50 pm
Re: Change the icon
When I replace these icon files with my own icon, both jpeg and png of the same pixel size, the Serviio service will not start. I've re-archived the jar using 7zip. Should I be using the jar cvf 'filename" via CLI instead?
Can someone share the process they used to do this, please?
I've renamed Serviio to "Hypnotoad" and would like the icon to reflect the name ;)
edit: I did rename the file to serviio.jar, and did not leave it as serviio.zip. Also tried compressing through Windows Explorer, but had the same issue.
dimdim
Post Sat Feb 02, 2013 9:22 am
Re: Change the icon
Hi!
Мy version of the icon.
PNG and ICNS (Mac) 512x512px files in the archive - http://cl.ly/3j0b1q2Y0o1C
Biker
Post Thu Jun 27, 2013 8:00 pm
Re: Change the icon
This last one is very good.
Return to Feature requests
