Serviio console not starting
airsick
Post Fri Jan 20, 2012 12:27 pm
Hi all,
I searched the forums but couldn't find anything similar to my problems so apologies if this is a repeat of another topic.
I have just installed Serviio and I cannot get the console to startup. It shows up in the task manager as though it is running but I can't see it anywhere, switch to it, etc. Very frustrating.
Running Windows 7 64bit with Java Version 6 (update 30) also 64 bit. Tried uninstalling/reinstalling Java, Serviio, etc. but all to no avail.
The Serviio log is as follows:
2012-01-20 23:10:22,988 INFO [MediaServer] ------------------------------------------------------------------------
2012-01-20 23:10:22,988 INFO [MediaServer] Serviio DLNA media streaming server v 0.6.1 (rev. c81bc5334890)
2012-01-20 23:10:22,988 INFO [MediaServer] Petr Nejedly 2009-2011
2012-01-20 23:10:22,988 INFO [MediaServer] http://www.serviio.org
2012-01-20 23:10:22,988 INFO [MediaServer] Java 1.6.0_30-Sun Microsystems Inc.
2012-01-20 23:10:22,988 INFO [MediaServer] OS Windows 7 amd64 6.1
2012-01-20 23:10:22,988 INFO [MediaServer] File encoding: windows-1252
2012-01-20 23:10:22,988 INFO [MediaServer] Headless mode enabled: true
2012-01-20 23:10:22,988 INFO [MediaServer] User home dir: C:\
2012-01-20 23:10:22,988 INFO [MediaServer] Temp dir: C:\Windows\TEMP\
2012-01-20 23:10:23,035 INFO [RestletServer] Starting Restlet server exposed on port 23423
2012-01-20 23:10:23,066 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2012-01-20 23:10:30,008 INFO [DBSchemaUpdateExecutor] Updating DB schema
2012-01-20 23:11:36,792 INFO [ServiioConsole] Starting Serviio Console
2012-01-20 23:11:36,792 INFO [MediaServer] ------------------------------------------------------------------------
2012-01-20 23:11:36,963 INFO [MediaServer] Serviio DLNA media streaming server v 0.6.1 (rev. c81bc5334890)
2012-01-20 23:11:36,963 INFO [MediaServer] Petr Nejedly 2009-2011
2012-01-20 23:11:36,963 INFO [MediaServer] http://www.serviio.org
2012-01-20 23:11:36,963 INFO [MediaServer] Java 1.6.0_30-Sun Microsystems Inc.
2012-01-20 23:11:36,963 INFO [MediaServer] OS Windows 7 amd64 6.1
2012-01-20 23:11:36,963 INFO [MediaServer] File encoding: windows-1252
2012-01-20 23:11:36,963 INFO [MediaServer] Headless mode enabled: true
2012-01-20 23:11:36,963 INFO [MediaServer] User home dir: C:\
2012-01-20 23:11:36,963 INFO [MediaServer] Temp dir: C:\Windows\TEMP\
2012-01-20 23:11:36,963 INFO [MediaServer] ------------------------------------------------------------------------
2012-01-20 23:11:38,320 INFO [RestletServer] Starting Restlet server exposed on port 23423
2012-01-20 23:11:38,445 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2012-01-20 23:11:41,171 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2012-01-20 23:11:48,800 INFO [DBSchemaUpdateExecutor] Updating DB schema
2012-01-20 23:11:51,701 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2012-01-20 23:11:52,013 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2012-01-20 23:11:52,185 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2012-01-20 23:11:52,279 INFO [ProfilesDefinitionParser] Added profile 'Xbox 360' (id=3)
2012-01-20 23:11:52,357 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2012-01-20 23:11:52,419 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2012-01-20 23:11:52,450 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2012-01-20 23:11:52,637 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2012-01-20 23:11:52,653 INFO [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2012-01-20 23:11:52,856 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011)' (id=9)
2012-01-20 23:11:53,137 INFO [ProfilesDefinitionParser] Added profile 'Sony BD Player / SMP' (id=10)
2012-01-20 23:11:53,277 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera' (id=12)
2012-01-20 23:11:53,386 INFO [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2012-01-20 23:11:53,449 INFO [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2012-01-20 23:11:53,464 INFO [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2012-01-20 23:11:53,527 INFO [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2012-01-20 23:11:53,558 INFO [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2012-01-20 23:11:53,636 INFO [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2012-01-20 23:11:53,698 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2010)' (id=19)
2012-01-20 23:11:53,807 INFO [ProfilesDefinitionParser] Added profile 'Philips' (id=20)
2012-01-20 23:11:53,870 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2009)' (id=21)
2012-01-20 23:14:43,477 INFO [WebServer] Socket buffer set to 65535 bytes
2012-01-20 23:14:43,477 INFO [Device] Created UPnP Device with UUID: ee0616d5-435a-38f5-b546-b92dd884093e, bound address: 192.168.1.113
2012-01-20 23:14:43,558 INFO [PluginCompilerThread] Looking for plugins at C:\Program Files\Serviio\bin\..\plugins
2012-01-20 23:14:43,574 INFO [PluginCompilerThread] Started looking for plugins
2012-01-20 23:14:43,873 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2012-01-20 23:14:43,917 INFO [WebServer] WebServer starting on port 8895
2012-01-20 23:14:43,933 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2012-01-20 23:14:43,933 INFO [EventDispatcher] Starting EventDispatcher
2012-01-20 23:14:43,933 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2012-01-20 23:14:43,937 INFO [RendererSearchSender] Searching for Renderer devices
2012-01-20 23:14:43,937 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2012-01-20 23:14:44,355 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface net4 (TP-LINK Wireless N Adapter) and address 192.168.1.113, timeout = 0
2012-01-20 23:18:26,934 INFO [Messages] Loaded console message bundle for locale: en
2012-01-20 23:18:26,947 INFO [UpdateChecker] Checking if a new version is available
2012-01-20 23:18:36,838 INFO [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2012-01-20 23:18:37,122 INFO [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: en
2012-01-20 23:18:45,793 INFO [FeedUpdaterThread] Started looking for information about online resources
2012-01-20 23:18:45,793 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-01-20 23:18:45,793 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
Any hints? I've read plenty of reports about how Serviio is the best DLNA server out there but this is really spoiling my fun...
TIA.
Post Fri Jan 20, 2012 12:34 pm
Re: Serviio console not starting
is there not a little yellow icon on taskbar by the clock? have you try killing the console process, and rerunning it from the Bat file in serviio\bin\ directory ?
airsick
Post Fri Jan 20, 2012 12:40 pm
No yellow icon in the taskbar by the clock but killing the process and trying to restart via the batch file worked. Got a few other issues now though. Will try more searches to work through them.
Thanks for the help.
airsick
Post Fri Jan 20, 2012 1:02 pm
One step forward, two back. Rebooted and back to square one...
Post Fri Jan 20, 2012 6:29 pm
airsick wrote:One step forward, two back. Rebooted and back to square one...
nope i know what the issue is server is starting before network is ready for it, so then console fails to as it requires the server befre it will start.
http://wiki.serviio.org/doku.php?id=net_reboot
airsick
Post Fri Jan 20, 2012 10:40 pm
I found this article and thought I was onto a winner but alas, no dice. When the computer reboots I get a message about the service not running and the console can't connect when I set it to delayed start. Manually starting the service and then running the batch file from the command line now has no impact. Nothing has changed in my setup except for changing the rendering profile for my TV and then rebooting to see if this had any effect.
Post Sat Jan 21, 2012 7:56 am
if you edited the profiels.xml file check the serviio log has no errors.
jlodvo
Post Sat Jan 21, 2012 8:57 pm
hello airsick what version win 7 x64 are you using?
had this similar problem before when i was using windows 7 x64 enterprise did everything i can but didnt work!
i reformated and installed new os and used windows 7 x64 ultimate and everything went ok
but wasnt able to pinpoint if enterprise had a problem with serviio or java , went straight to installing the ultimate version
try to reinstall a fresh copy of your os and start from thier
2 of us having problems was solve just by reinstalling windows os
here's the thread, both of us ended up reinstalling and everything was good "wish had done it sooner, it took me more then a week of testing till i finally gave up and decided to reformat, would have save me the head ache hahahaha"
viewtopic.php?f=5&t=4436
airsick
Post Sun Jan 22, 2012 5:13 am
Thanks for your help guys but I've given up on this. No errors in the log, tried reinstalling Serviio, Java, etc. plus a few other things to get it going and still no luck. Reinstalling Windows is too much. If it won;t work out of the box then sorry, it's just not worth it. I ain't going to sit through hours of reinstalling Windows, apps, then Serviio just on the hope that it will fix this problem.
On the upside, I have installed the software onto a VM running Win Server 2K3 and it runs nicely. Unfortunately I can't take it with me when I travel so it isn't portable which is what I was hoping for but hey, I guess you can't have everything...
chtimi
Post Mon Jan 23, 2012 9:02 am
Hello
I have the same problem on Win 7 64 bits the console doesn't start :?: :?:
Post Mon Jan 23, 2012 6:50 pm
chtimi wrote:Hello
Post serviio.log please. Does this happen even if you run ServiioConsole again from the Start menu?
RichardJLegault
Post Mon Jan 23, 2012 7:13 pm
Hello All,
I'm a newbie as of today. My knowledge is limited.
My goal is to stream pictures and music from my notebook to my TV as follows:
TO: a Panasonic VIERA Plasma HDTV model TC-P60S30 equipped with Panasonic's Wireless LAN Adapter model DY-WL10PP-K.
FROM: a Hewlett-Packard model HP ENVY 17 Notebook PC running Windows 7 Home Premium.
SET-UP: High-speed internet service and HD Cable service are provided by a company called Century Link - Prism over a CISCO 1399 Router connected by coaxial cable to a Motorola DVR model VIP 1232. The TV and DVR are connected by coaxial cable. The TV and Notebook are connected to each other wirelessly. I think the Century Link services are managed by a Microsoft product called Mediaroom. (The overall set-up also includes another TV and secondary DVR box connected to the CISCO Router.)
WHY SERVIIO: Panasonic's manual for the TV states "The DNLA control function of Windows 7 is not supported with this TV." After a lot of searching, guessing and Forum reading, I've selected Serviio as a tool to perform the streaming that Windows 7 cannot do with this TV.
PROGRESS TO DATE: CONSOLE DOES NOT DISPLAY
I've installed Serviio on my PC. The Serviio Console does not display. I have no button in the system tray. I have a Servio button on the Start menu, but clicking it does nothing. The Windows Task Manager shows the Serviio services are runnung. The TV's VIERA Tools work: I can connect from the TV to subscribed internet services such as Netflix, Facebook and others. Also the VIERA tools find the DNLA Server named Serviio. However there are no files or folders available to the TV from this DNLA Server. The Windows Media Player (version 12) seems to recognize Serviio as an "Other Library", but I can't figure out how to put anything in it or whether I even should.
(The two DVR boxes were intermittently freezing up at first, but I think this is an unrelated issue caused by trying to record and play too many items to/from the DVR all at once. This settled down once the recording tasks completed.)
I've tried uninstalling and reinstalling Serviio from the PC. I've used the Windows Task Manager to stop the Servio services and tried starting them and the console again using the batch files. This failed.
Removing and reinstalling Windows 7, as recommended in other members' posts in this topic, is not a good option for me as I'm not a power-user and I don't want to take the risk of really screwing things up.
Here is a copy of the serviio.log file:
2012-01-23 10:52:59,217 INFO [MediaServer] ------------------------------------------------------------------------
2012-01-23 10:52:59,217 INFO [MediaServer] Serviio DLNA media streaming server v 0.6.1 (rev. c81bc5334890)
2012-01-23 10:52:59,217 INFO [MediaServer] Petr Nejedly 2009-2011
2012-01-23 10:52:59,217 INFO [MediaServer] http://www.serviio.org
2012-01-23 10:52:59,217 INFO [MediaServer] Java 1.6.0_20-Sun Microsystems Inc.
2012-01-23 10:52:59,217 INFO [MediaServer] OS Windows 7 amd64 6.1
2012-01-23 10:52:59,217 INFO [MediaServer] File encoding: windows-1252
2012-01-23 10:52:59,217 INFO [MediaServer] Headless mode enabled: true
2012-01-23 10:52:59,217 INFO [MediaServer] User home dir: C:\
2012-01-23 10:52:59,217 INFO [MediaServer] Temp dir: C:\Windows\TEMP\
2012-01-23 10:52:59,310 INFO [RestletServer] Starting Restlet server exposed on port 23423
2012-01-23 10:52:59,357 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2012-01-23 10:53:01,541 INFO [DBSchemaUpdateExecutor] Updating DB schema
2012-01-23 10:53:04,614 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2012-01-23 10:53:05,160 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2012-01-23 10:53:05,394 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2012-01-23 10:53:05,519 INFO [ProfilesDefinitionParser] Added profile 'Xbox 360' (id=3)
2012-01-23 10:53:05,675 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2012-01-23 10:53:05,784 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2012-01-23 10:53:05,847 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2012-01-23 10:53:06,174 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2012-01-23 10:53:06,190 INFO [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2012-01-23 10:53:06,533 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011)' (id=9)
2012-01-23 10:53:06,954 INFO [ProfilesDefinitionParser] Added profile 'Sony BD Player / SMP' (id=10)
2012-01-23 10:53:07,142 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera' (id=12)
2012-01-23 10:53:07,344 INFO [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2012-01-23 10:53:07,438 INFO [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2012-01-23 10:53:07,469 INFO [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2012-01-23 10:53:07,594 INFO [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2012-01-23 10:53:07,703 INFO [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2012-01-23 10:53:07,875 INFO [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2012-01-23 10:53:07,937 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2010)' (id=19)
2012-01-23 10:53:08,093 INFO [ProfilesDefinitionParser] Added profile 'Philips' (id=20)
2012-01-23 10:53:08,218 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2009)' (id=21)
2012-01-23 10:53:08,655 INFO [WebServer] Socket buffer set to 65535 bytes
2012-01-23 10:53:08,655 INFO [Device] Created UPnP Device with UUID: 845849ff-fb73-3682-9791-500c0f07784e, bound address: 192.168.1.68
2012-01-23 10:53:08,670 INFO [PluginCompilerThread] Looking for plugins at C:\Program Files\Serviio\bin\..\plugins
2012-01-23 10:53:08,670 INFO [PluginCompilerThread] Started looking for plugins
2012-01-23 10:53:09,216 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2012-01-23 10:53:09,232 INFO [WebServer] WebServer starting on port 8895
2012-01-23 10:53:09,232 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2012-01-23 10:53:09,232 INFO [EventDispatcher] Starting EventDispatcher
2012-01-23 10:53:09,232 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2012-01-23 10:53:09,248 INFO [RendererSearchSender] Searching for Renderer devices
2012-01-23 10:53:09,248 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2012-01-23 10:53:09,279 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface net5 (Intel(R) Centrino(R) Advanced-N 6200 AGN) and address 192.168.1.68, timeout = 0
2012-01-23 10:53:12,664 INFO [RendererManager] Stored a new renderer: uuid='3b8d3423-15b6-4a1c-b77b-2323c4a824c6', name = 'Mediaroom', ipAddress='192.168.1.69', profile = '1'
2012-01-23 10:53:35,813 INFO [FeedUpdaterThread] Started looking for information about online resources
2012-01-23 10:53:35,813 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-01-23 10:53:35,829 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2012-01-23 10:54:37,683 INFO [RendererManager] Stored a new renderer: uuid='f2beb4bf-21c8-42a4-8f40-21ef6c83455b', name = 'Unrecognized device', ipAddress='192.168.1.68', profile = '1'
2012-01-23 10:55:05,475 INFO [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2012-01-23 10:55:05,490 INFO [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2012-01-23 10:55:08,657 INFO [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: en
2012-01-23 11:07:46,632 WARN [EventDispatcher] Error 400 received from event subscriber
2012-01-23 11:29:09,770 INFO [MediaServer] ------------------------------------------------------------------------
2012-01-23 11:29:09,770 INFO [MediaServer] Serviio DLNA media streaming server v 0.6.1 (rev. c81bc5334890)
2012-01-23 11:29:09,770 INFO [MediaServer] Petr Nejedly 2009-2011
2012-01-23 11:29:09,770 INFO [MediaServer] http://www.serviio.org
2012-01-23 11:29:09,770 INFO [MediaServer] Java 1.6.0_20-Sun Microsystems Inc.
2012-01-23 11:29:09,770 INFO [MediaServer] OS Windows 7 amd64 6.1
2012-01-23 11:29:09,770 INFO [MediaServer] File encoding: windows-1252
2012-01-23 11:29:09,770 INFO [MediaServer] Headless mode enabled: true
2012-01-23 11:29:09,770 INFO [MediaServer] User home dir: C:\Users\Richard Legault
2012-01-23 11:29:09,770 INFO [MediaServer] Temp dir: C:\Users\RICHAR~1\AppData\Local\Temp\
2012-01-23 11:29:09,848 INFO [RestletServer] Starting Restlet server exposed on port 23423
2012-01-23 11:29:09,926 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2012-01-23 11:29:11,549 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2012-01-23 11:29:12,126 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2012-01-23 11:29:12,360 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2012-01-23 11:29:12,500 INFO [ProfilesDefinitionParser] Added profile 'Xbox 360' (id=3)
2012-01-23 11:29:12,641 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2012-01-23 11:29:12,750 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2012-01-23 11:29:12,812 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2012-01-23 11:29:13,109 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2012-01-23 11:29:13,124 INFO [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2012-01-23 11:29:13,436 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011)' (id=9)
2012-01-23 11:29:13,936 INFO [ProfilesDefinitionParser] Added profile 'Sony BD Player / SMP' (id=10)
2012-01-23 11:29:14,138 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera' (id=12)
2012-01-23 11:29:14,372 INFO [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2012-01-23 11:29:14,466 INFO [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2012-01-23 11:29:14,497 INFO [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2012-01-23 11:29:14,575 INFO [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2012-01-23 11:29:14,606 INFO [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2012-01-23 11:29:14,731 INFO [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2012-01-23 11:29:14,794 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2010)' (id=19)
2012-01-23 11:29:14,934 INFO [ProfilesDefinitionParser] Added profile 'Philips' (id=20)
2012-01-23 11:29:15,090 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2009)' (id=21)
2012-01-23 11:29:15,527 INFO [WebServer] Socket buffer set to 65535 bytes
2012-01-23 11:29:15,527 INFO [Device] Created UPnP Device with UUID: 845849ff-fb73-3682-9791-500c0f07784e, bound address: 192.168.1.68
2012-01-23 11:29:15,542 INFO [PluginCompilerThread] Looking for plugins at C:\Program Files\Serviio\plugins
2012-01-23 11:29:15,542 INFO [PluginCompilerThread] Started looking for plugins
2012-01-23 11:29:15,605 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2012-01-23 11:29:15,683 INFO [WebServer] WebServer starting on port 8895
2012-01-23 11:29:15,683 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2012-01-23 11:29:15,683 INFO [EventDispatcher] Starting EventDispatcher
2012-01-23 11:29:15,683 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2012-01-23 11:29:15,698 INFO [RendererSearchSender] Searching for Renderer devices
2012-01-23 11:29:15,698 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2012-01-23 11:29:15,732 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface net5 (Intel(R) Centrino(R) Advanced-N 6200 AGN) and address 192.168.1.68, timeout = 0
2012-01-23 11:29:24,702 INFO [MediaServer] Serviio server instance is already running
2012-01-23 11:29:42,298 INFO [FeedUpdaterThread] Started looking for information about online resources
2012-01-23 11:29:42,298 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-01-23 11:29:42,314 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2012-01-23 11:30:57,695 INFO [MediaServer] Serviio server instance is already running
2012-01-23 12:34:04,644 INFO [MediaServer] Serviio server instance is already running
2012-01-23 12:41:43,897 INFO [MediaServer] ------------------------------------------------------------------------
2012-01-23 12:41:43,897 INFO [MediaServer] Serviio DLNA media streaming server v 0.6.1 (rev. c81bc5334890)
2012-01-23 12:41:43,897 INFO [MediaServer] Petr Nejedly 2009-2011
2012-01-23 12:41:43,897 INFO [MediaServer] http://www.serviio.org
2012-01-23 12:41:43,897 INFO [MediaServer] Java 1.6.0_20-Sun Microsystems Inc.
2012-01-23 12:41:43,897 INFO [MediaServer] OS Windows 7 amd64 6.1
2012-01-23 12:41:43,897 INFO [MediaServer] File encoding: windows-1252
2012-01-23 12:41:43,897 INFO [MediaServer] Headless mode enabled: true
2012-01-23 12:41:43,897 INFO [MediaServer] User home dir: C:\
2012-01-23 12:41:43,912 INFO [MediaServer] Temp dir: C:\Windows\TEMP\
2012-01-23 12:41:43,912 INFO [MediaServer] ------------------------------------------------------------------------
2012-01-23 12:41:48,452 INFO [RestletServer] Starting Restlet server exposed on port 23423
2012-01-23 12:41:52,820 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2012-01-23 12:41:58,202 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2012-01-23 12:41:58,779 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2012-01-23 12:41:59,044 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2012-01-23 12:41:59,216 INFO [ProfilesDefinitionParser] Added profile 'Xbox 360' (id=3)
2012-01-23 12:41:59,388 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2012-01-23 12:41:59,544 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2012-01-23 12:41:59,606 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2012-01-23 12:42:00,012 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2012-01-23 12:42:00,027 INFO [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2012-01-23 12:42:00,355 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011)' (id=9)
2012-01-23 12:42:00,885 INFO [ProfilesDefinitionParser] Added profile 'Sony BD Player / SMP' (id=10)
2012-01-23 12:42:01,088 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera' (id=12)
2012-01-23 12:42:01,353 INFO [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2012-01-23 12:42:01,462 INFO [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2012-01-23 12:42:01,494 INFO [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2012-01-23 12:42:01,587 INFO [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2012-01-23 12:42:01,634 INFO [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2012-01-23 12:42:01,790 INFO [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2012-01-23 12:42:01,868 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2010)' (id=19)
2012-01-23 12:42:02,008 INFO [ProfilesDefinitionParser] Added profile 'Philips' (id=20)
2012-01-23 12:42:02,133 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2009)' (id=21)
2012-01-23 12:42:03,069 INFO [WebServer] Socket buffer set to 65535 bytes
2012-01-23 12:42:03,069 INFO [Device] Created UPnP Device with UUID: 845849ff-fb73-3682-9791-500c0f07784e, bound address: 192.168.1.68
2012-01-23 12:42:03,210 INFO [PluginCompilerThread] Looking for plugins at C:\Program Files\Serviio\bin\..\plugins
2012-01-23 12:42:03,210 INFO [PluginCompilerThread] Started looking for plugins
2012-01-23 12:42:05,004 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2012-01-23 12:42:05,082 INFO [WebServer] WebServer starting on port 8895
2012-01-23 12:42:05,097 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2012-01-23 12:42:05,097 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2012-01-23 12:42:05,097 INFO [EventDispatcher] Starting EventDispatcher
2012-01-23 12:42:05,113 INFO [RendererSearchSender] Searching for Renderer devices
2012-01-23 12:42:05,113 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2012-01-23 12:42:05,144 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface net5 (Intel(R) Centrino(R) Advanced-N 6200 AGN) and address 192.168.1.68, timeout = 0
2012-01-23 12:42:06,267 INFO [RendererManager] Stored a new renderer: uuid='20698480-3a2c-4f99-bb61-898a3479e2c5', name = 'Unrecognized device', ipAddress='192.168.1.65', profile = '1'
2012-01-23 12:42:31,717 INFO [FeedUpdaterThread] Started looking for information about online resources
2012-01-23 12:42:31,733 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-01-23 12:42:31,764 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2012-01-23 12:42:36,718 INFO [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2012-01-23 12:42:37,290 INFO [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: en
2012-01-23 12:58:34,299 WARN [IndexedDiskCache] Region [online_technical_metadata] Disk cache not shutdown properly, shutting down now.
2012-01-23 12:58:34,299 WARN [IndexedDiskCache] Region [thumbnails] Disk cache not shutdown properly, shutting down now.
2012-01-23 12:58:34,300 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2012-01-23 12:58:34,400 INFO [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2012-01-23 12:58:34,500 INFO [FeedUpdaterThread] Finished looking for online resources information
2012-01-23 12:58:34,600 INFO [PluginCompilerThread] Finished looking for plugins
2012-01-23 12:58:34,700 INFO [WebServer] WebServer shutting down
2012-01-23 12:58:34,700 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2012-01-23 12:58:34,700 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2012-01-23 12:58:34,700 INFO [EventDispatcher] Leaving EventDispatcher
2012-01-23 12:58:34,999 INFO [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2012-01-23 12:58:35,092 INFO [DatabaseManager] Shutting down database
2012-01-23 12:58:35,217 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2012-01-23 12:59:22,965 INFO [MediaServer] ------------------------------------------------------------------------
2012-01-23 12:59:22,965 INFO [MediaServer] Serviio DLNA media streaming server v 0.6.1 (rev. c81bc5334890)
2012-01-23 12:59:22,965 INFO [MediaServer] Petr Nejedly 2009-2011
2012-01-23 12:59:22,965 INFO [MediaServer] http://www.serviio.org
2012-01-23 12:59:22,965 INFO [MediaServer] Java 1.6.0_20-Sun Microsystems Inc.
2012-01-23 12:59:22,965 INFO [MediaServer] OS Windows 7 amd64 6.1
2012-01-23 12:59:22,965 INFO [MediaServer] File encoding: windows-1252
2012-01-23 12:59:22,965 INFO [MediaServer] Headless mode enabled: true
2012-01-23 12:59:22,965 INFO [MediaServer] User home dir: C:\Users\Richard Legault
2012-01-23 12:59:22,965 INFO [MediaServer] Temp dir: C:\Users\RICHAR~1\AppData\Local\Temp\
2012-01-23 12:59:23,074 INFO [RestletServer] Starting Restlet server exposed on port 23423
2012-01-23 12:59:23,105 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2012-01-23 12:59:24,104 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2012-01-23 12:59:24,650 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2012-01-23 12:59:24,899 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2012-01-23 12:59:25,040 INFO [ProfilesDefinitionParser] Added profile 'Xbox 360' (id=3)
2012-01-23 12:59:25,180 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2012-01-23 12:59:25,289 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2012-01-23 12:59:25,367 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2012-01-23 12:59:25,679 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2012-01-23 12:59:25,710 INFO [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2012-01-23 12:59:26,007 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011)' (id=9)
2012-01-23 12:59:26,506 INFO [ProfilesDefinitionParser] Added profile 'Sony BD Player / SMP' (id=10)
2012-01-23 12:59:26,740 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera' (id=12)
2012-01-23 12:59:26,990 INFO [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2012-01-23 12:59:27,099 INFO [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2012-01-23 12:59:27,114 INFO [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2012-01-23 12:59:27,208 INFO [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2012-01-23 12:59:27,239 INFO [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2012-01-23 12:59:27,364 INFO [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2012-01-23 12:59:27,426 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2010)' (id=19)
2012-01-23 12:59:27,598 INFO [ProfilesDefinitionParser] Added profile 'Philips' (id=20)
2012-01-23 12:59:27,707 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2009)' (id=21)
2012-01-23 12:59:28,066 INFO [WebServer] Socket buffer set to 65535 bytes
2012-01-23 12:59:28,066 INFO [Device] Created UPnP Device with UUID: 845849ff-fb73-3682-9791-500c0f07784e, bound address: 192.168.1.68
2012-01-23 12:59:28,082 INFO [PluginCompilerThread] Looking for plugins at C:\Program Files\Serviio\plugins
2012-01-23 12:59:28,082 INFO [PluginCompilerThread] Started looking for plugins
2012-01-23 12:59:28,144 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2012-01-23 12:59:28,175 INFO [WebServer] WebServer starting on port 8895
2012-01-23 12:59:28,175 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2012-01-23 12:59:28,175 INFO [EventDispatcher] Starting EventDispatcher
2012-01-23 12:59:28,175 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2012-01-23 12:59:28,191 INFO [RendererSearchSender] Searching for Renderer devices
2012-01-23 12:59:28,191 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2012-01-23 12:59:28,223 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface net5 (Intel(R) Centrino(R) Advanced-N 6200 AGN) and address 192.168.1.68, timeout = 0
2012-01-23 12:59:54,759 INFO [FeedUpdaterThread] Started looking for information about online resources
2012-01-23 12:59:54,759 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-01-23 12:59:54,774 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
I hope one of you out there can help me with this.
Richard J Legault
23 Jan 2012
Post Mon Jan 23, 2012 7:22 pm
If you look in the directory that you installed serviio in there will be a serviioconsole program. It should have been added to the startmenu but sounds like for some reason it did not. When you find serviioconsole you can double click on it to start the console.
Post Mon Jan 23, 2012 8:24 pm
@RichardJLegault - update your Java to 1.6 update 30.
RichardJLegault
Post Mon Jan 23, 2012 9:12 pm
Installed Java 1.6 Update 30 and rebooted. Still no console. Serviio button on the start menu still does nothing. Double clicking the Servio-console exe or batch files they don't run. The batch file makes a command prompt window flash open and closed for about a nano-second but that's it. Same thing if I right-click them and run as administrator.
Any other ideas?
RJL
Post Mon Jan 23, 2012 9:15 pm
Try and re-install serviio and see if that helps. There is nothing in the log about the console even trying to start. If you want you can use the below third party app until we can get this working correctly.
http://forum.serviio.org/viewtopic.php?f=17&t=2427.
RichardJLegault
Post Mon Jan 23, 2012 10:32 pm
Thanks for your suggestions. Tried both. No change. Here is the log:
2012-01-23 16:37:45,924 INFO [MediaServer] ------------------------------------------------------------------------
2012-01-23 16:37:45,924 INFO [MediaServer] Serviio DLNA media streaming server v 0.6.1 (rev. c81bc5334890)
2012-01-23 16:37:45,924 INFO [MediaServer] Petr Nejedly 2009-2011
2012-01-23 16:37:45,924 INFO [MediaServer] http://www.serviio.org
2012-01-23 16:37:45,924 INFO [MediaServer] Java 1.6.0_20-Sun Microsystems Inc.
2012-01-23 16:37:45,924 INFO [MediaServer] OS Windows 7 amd64 6.1
2012-01-23 16:37:45,924 INFO [MediaServer] File encoding: windows-1252
2012-01-23 16:37:45,924 INFO [MediaServer] Headless mode enabled: true
2012-01-23 16:37:45,924 INFO [MediaServer] User home dir: C:\
2012-01-23 16:37:45,924 INFO [MediaServer] Temp dir: C:\Windows\TEMP\
2012-01-23 16:37:46,189 INFO [RestletServer] Starting Restlet server exposed on port 23423
2012-01-23 16:37:46,283 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2012-01-23 16:37:51,603 INFO [DBSchemaUpdateExecutor] Updating DB schema
2012-01-23 16:37:58,857 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2012-01-23 16:37:59,980 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2012-01-23 16:38:00,557 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2012-01-23 16:38:00,885 INFO [ProfilesDefinitionParser] Added profile 'Xbox 360' (id=3)
2012-01-23 16:38:01,197 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2012-01-23 16:38:01,446 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2012-01-23 16:38:01,602 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2012-01-23 16:38:02,320 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2012-01-23 16:38:02,367 INFO [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2012-01-23 16:38:03,193 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011)' (id=9)
2012-01-23 16:38:04,254 INFO [ProfilesDefinitionParser] Added profile 'Sony BD Player / SMP' (id=10)
2012-01-23 16:38:04,722 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera' (id=12)
2012-01-23 16:38:05,143 INFO [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2012-01-23 16:38:05,393 INFO [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2012-01-23 16:38:05,440 INFO [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2012-01-23 16:38:05,752 INFO [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2012-01-23 16:38:05,830 INFO [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2012-01-23 16:38:06,157 INFO [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2012-01-23 16:38:06,313 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2010)' (id=19)
2012-01-23 16:38:06,688 INFO [ProfilesDefinitionParser] Added profile 'Philips' (id=20)
2012-01-23 16:38:06,953 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2009)' (id=21)
2012-01-23 16:38:07,967 INFO [WebServer] Socket buffer set to 65535 bytes
2012-01-23 16:38:07,967 INFO [Device] Created UPnP Device with UUID: 845849ff-fb73-3682-9791-500c0f07784e, bound address: 192.168.1.68
2012-01-23 16:38:07,998 INFO [PluginCompilerThread] Looking for plugins at C:\Program Files\Serviio\bin\..\plugins
2012-01-23 16:38:07,998 INFO [PluginCompilerThread] Started looking for plugins
2012-01-23 16:38:08,887 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2012-01-23 16:38:08,934 INFO [WebServer] WebServer starting on port 8895
2012-01-23 16:38:08,950 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2012-01-23 16:38:08,950 INFO [EventDispatcher] Starting EventDispatcher
2012-01-23 16:38:08,950 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2012-01-23 16:38:08,965 INFO [RendererSearchSender] Searching for Renderer devices
2012-01-23 16:38:08,965 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2012-01-23 16:38:09,043 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface net5 (Intel(R) Centrino(R) Advanced-N 6200 AGN) and address 192.168.1.68, timeout = 0
2012-01-23 16:38:10,291 INFO [RendererManager] Stored a new renderer: uuid='1248c6d0-e450-4919-bc05-d718dc57638b', name = 'Unrecognized device', ipAddress='192.168.1.65', profile = '1'
2012-01-23 16:38:13,292 INFO [RendererManager] Stored a new renderer: uuid='d13d81f4-6761-41db-be5e-cc06227d29ec', name = 'Unrecognized device', ipAddress='192.168.1.68', profile = '1'
2012-01-23 16:38:13,573 INFO [RendererManager] Stored a new renderer: uuid='3b8d3423-15b6-4a1c-b77b-2323c4a824c6', name = 'Mediaroom', ipAddress='192.168.1.69', profile = '1'
2012-01-23 16:38:36,106 INFO [FeedUpdaterThread] Started looking for information about online resources
2012-01-23 16:38:36,106 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-01-23 16:38:36,122 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2012-01-23 16:39:42,869 INFO [MediaServer] Serviio server instance is already running
2012-01-23 17:00:10,277 INFO [MediaServer] Serviio server instance is already running
2012-01-23 17:01:14,452 WARN [IndexedDiskCache] Region [online_technical_metadata] Disk cache not shutdown properly, shutting down now.
2012-01-23 17:01:14,452 WARN [IndexedDiskCache] Region [thumbnails] Disk cache not shutdown properly, shutting down now.
2012-01-23 17:01:14,453 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2012-01-23 17:01:14,552 INFO [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2012-01-23 17:01:14,652 INFO [FeedUpdaterThread] Finished looking for online resources information
2012-01-23 17:01:14,752 INFO [PluginCompilerThread] Finished looking for plugins
2012-01-23 17:01:14,852 INFO [WebServer] WebServer shutting down
2012-01-23 17:01:14,853 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2012-01-23 17:01:14,853 INFO [EventDispatcher] Leaving EventDispatcher
2012-01-23 17:01:14,853 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2012-01-23 17:01:15,134 INFO [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2012-01-23 17:01:15,150 INFO [DatabaseManager] Shutting down database
2012-01-23 17:01:15,571 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2012-01-23 17:03:25,524 INFO [MediaServer] ------------------------------------------------------------------------
2012-01-23 17:03:25,556 INFO [MediaServer] Serviio DLNA media streaming server v 0.6.1 (rev. c81bc5334890)
2012-01-23 17:03:25,556 INFO [MediaServer] Petr Nejedly 2009-2011
2012-01-23 17:03:25,556 INFO [MediaServer] http://www.serviio.org
2012-01-23 17:03:25,556 INFO [MediaServer] Java 1.6.0_20-Sun Microsystems Inc.
2012-01-23 17:03:25,556 INFO [MediaServer] OS Windows 7 amd64 6.1
2012-01-23 17:03:25,556 INFO [MediaServer] File encoding: windows-1252
2012-01-23 17:03:25,556 INFO [MediaServer] Headless mode enabled: true
2012-01-23 17:03:25,556 INFO [MediaServer] User home dir: C:\
2012-01-23 17:03:25,556 INFO [MediaServer] Temp dir: C:\Windows\TEMP\
2012-01-23 17:03:25,556 INFO [MediaServer] ------------------------------------------------------------------------
2012-01-23 17:03:25,836 INFO [RestletServer] Starting Restlet server exposed on port 23423
2012-01-23 17:03:25,899 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2012-01-23 17:03:43,433 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2012-01-23 17:03:44,057 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2012-01-23 17:03:44,385 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2012-01-23 17:03:44,603 INFO [ProfilesDefinitionParser] Added profile 'Xbox 360' (id=3)
2012-01-23 17:03:44,790 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2012-01-23 17:03:44,915 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2012-01-23 17:03:45,009 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2012-01-23 17:03:45,414 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2012-01-23 17:03:45,446 INFO [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2012-01-23 17:03:45,836 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011)' (id=9)
2012-01-23 17:03:46,460 INFO [ProfilesDefinitionParser] Added profile 'Sony BD Player / SMP' (id=10)
2012-01-23 17:03:46,725 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera' (id=12)
2012-01-23 17:03:47,021 INFO [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2012-01-23 17:03:47,146 INFO [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2012-01-23 17:03:47,162 INFO [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2012-01-23 17:03:47,255 INFO [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2012-01-23 17:03:47,302 INFO [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2012-01-23 17:03:47,442 INFO [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2012-01-23 17:03:47,505 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2010)' (id=19)
2012-01-23 17:03:47,661 INFO [ProfilesDefinitionParser] Added profile 'Philips' (id=20)
2012-01-23 17:03:47,770 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2009)' (id=21)
2012-01-23 17:03:48,534 INFO [WebServer] Socket buffer set to 65535 bytes
2012-01-23 17:03:48,534 INFO [Device] Created UPnP Device with UUID: 845849ff-fb73-3682-9791-500c0f07784e, bound address: 192.168.1.68
2012-01-23 17:03:48,659 INFO [PluginCompilerThread] Looking for plugins at C:\Program Files\Serviio\bin\..\plugins
2012-01-23 17:03:48,659 INFO [PluginCompilerThread] Started looking for plugins
2012-01-23 17:03:49,361 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2012-01-23 17:03:49,439 INFO [WebServer] WebServer starting on port 8895
2012-01-23 17:03:49,455 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2012-01-23 17:03:49,455 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2012-01-23 17:03:49,455 INFO [EventDispatcher] Starting EventDispatcher
2012-01-23 17:03:49,470 INFO [RendererSearchSender] Searching for Renderer devices
2012-01-23 17:03:49,470 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2012-01-23 17:03:49,506 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface net5 (Intel(R) Centrino(R) Advanced-N 6200 AGN) and address 192.168.1.68, timeout = 0
2012-01-23 17:04:16,121 INFO [FeedUpdaterThread] Started looking for information about online resources
2012-01-23 17:04:16,121 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-01-23 17:04:16,153 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2012-01-23 17:20:32,965 INFO [MediaServer] Serviio server instance is already running
Post Tue Jan 24, 2012 12:19 pm
your still not using latest JAVA you are running update 20 and not update 30.
RichardJLegault
Post Tue Jan 24, 2012 8:14 pm
Okay, thank you everyone. You have the thanks of a grateful mere mortal for all your help and suggestions. But this is getting way too complicated for me. From my very simple minded point of view Serviio is simply not yet sufficiently mature for an ordinary user like me.
I've had other alternatives pointed out to me that I think will work much better. One is TVersity, which you guys might want to look at.
Cheers!
RJL
Post Tue Jan 24, 2012 8:24 pm
i know Tversity well i came from there when i joined serviio
Users browsing this forum: No registered users and 51 guests
