New Panasonic Profiles Requiring Testers.
Post Fri Feb 03, 2012 7:10 pm
Re: New Panasonic Profiles Requiring Testers.
PMI wrote:MKV with H.264 encoding and AC-3 audio, or AAC audio play without transcoding.
WITH transcoding they do play, but HD video quality is not as good, and in some scenes, just plain bad. I do not think this is a profile issue, so not relevant in this thread if you just want to know that the files play... (not trying to be an ass, just mention for completeness)
Same in the case of MP4 files, H.264 and AC-3 or AAC plays.
That wasnt what i asked, as for MOST h264 im not transcoding at all im just remuxing into TS container. so please try the change, i stated above.
PMI
Post Fri Feb 03, 2012 7:37 pm
ok well its not refframes then as the working file has 5 reframes and one of your failed file has 5 reframes too, so must be something else.
@pmi - can you do the same remove that line and then try playing the woody_allen_5 file
Yes, I know, just doing as you asked.
Increasing the number of ref frames is just one way to cause the problem.
I can take a video, and encode a few samples with increasing number of ref frames, and sooner or later, the file will not play. BUT, it will not always happen with the SAME number of ref frames, or the SAME Level (depends on frame size, and other factors). For example, memory is not always allocated as a function of resolution and ref frames. Sometimes as a function of resolution using modulo 16 math, and (# of ref frames +1). Not sure how it is done on this TV, but if level detection does not match, problems WILL show up sooner or later.
I will do that later. In general, my H.264 test files play the same, or better in MKV container with no remux into MPEG-TS, not sure about this one.
By your command, ;)
Peter
iCO
Post Fri Feb 03, 2012 7:39 pm
Cerberus wrote:
iCO wrote:Whith "Panasonic Viera With AVI Support" the above file does not play at all. Receive "The file is not read" on the tv set (not sure about the exact message in english). The same is with several other MKV files I've tested.
comented out:
<!-- <Matches container="matroska" vCodec="h264" /> -->
Now file plays ok.
hmm thats odd one then, ok will look into this and please see my previous message about profile lvls and subtitles.
can you provide mediainfo readout on that file please. so i can see what exactly is happening.
Unique ID                                : 243305344964448675274187887313844495843 (0xB70AE7AAC7BE5CD7A332EA9AC068E5E3)
Complete name                            : Z:\Media\Tau ming chong.mkv
File size                                : 7.80 GiB
Duration                                 : 2h 5mn
Overall bit rate                         : 8 882 Kbps
Movie name                               : The Warlords (Tau ming chong) (2007)
Encoded date                             : UTC 2012-01-30 17:15:19
Writing application                      : mkvmerge v5.2.1 ('A Far Off Place') built on Jan  2 2012 23:21:10
Writing library                          : libebml v1.2.3 + libmatroska v1.3.0
Attachment                               : Yes / Yes / Yes
Format settings, ReFrames                : 6 frames
Duration                                 : 2h 5mn
Bit rate                                 : 7 370 Kbps
Height                                   : 544 pixels
Display aspect ratio                     : 2.35:1
Frame rate                               : 24.000 fps
Bits/(Pixel*Frame)                       : 0.441
Stream size                              : 6.32 GiB (81%)
Writing library                          : x264 core 60 r915M 14046ae
Encoding settings                        : cabac=1 / ref=6 / deblock=1:-3:-3 / analyse=0x3:0x133 / me=umh / subme=6 / psy_rd=0.800000 / brdo=1 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=1 / cqm=2 / deadzone=9,9 / chroma_qp_offset=0 / threads=3 / nr=0 / decimate=1 / mbaff=0 / bframes=3 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=3 / wpredb=1 / bime=1 / keyint=250 / keyint_min=25 / scenecut=40(pre) / rc=2pass / bitrate=7370 / ratetol=1.0 / rceq='blurCplx^(1-qComp)' / qcomp=1.00 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / aq=2:0.80
Language                                 : Chinese
Format                                   : DTS
Format/Info                              : Digital Theater Systems
Codec ID                                 : A_DTS
Duration                                 : 2h 5mn
Bit rate                                 : 1 510 Kbps
Stream size                              : 1.33 GiB (17%)
Title                                    : Main audio DTS 1.5 mbit
Language                                 : Chinese
Text #1
Format                                   : ASS
Codec ID                                 : S_TEXT/ASS
Codec ID/Info                            : Advanced Sub Station Alpha
Compression mode                         : Lossless
Title                                    : Eng sub for main track
Text #2
Format                                   : UTF-8
Codec ID                                 : S_TEXT/UTF8
Codec ID/Info                            : UTF-8 Plain Text
Language                                 : Bulgarian
Forced                                   : Yes
voodooo wrote:You have 2 subs inside the mkv with different formats and different languages, try to remuxe again and remove the one you don't need.
And there's no need to transcode cause both audio and video should play without transcoding on your TV.
There are no issue with subs inside mkv. Without transcoding/remuxing they both payed fine.
Are you sure that VT30 do not support AVI? VT30 is Panasonic top model. It's not logical to suport less formats than GT30 and other. If unshure move it to the second group, so people with VT30 start test with AVI support.
Post Fri Feb 03, 2012 7:48 pm
By your command, ;)
awsome that what i wanted to hear :D so just the stutter issue let excellent :D
Post Fri Feb 03, 2012 7:51 pm
iCO wrote:
comented out:
Now file plays ok.
Duration                                 : 2h 5mn
Duration                                 : 2h 5mn
Height                                   : 544 pixels
Language                                 : Chinese
Format                                   : DTS
Codec ID                                 : A_DTS
Duration                                 : 2h 5mn
Language                                 : Chinese
Text #1
Format                                   : ASS
Text #2
Format                                   : UTF-8
Forced                                   : Yes
1. thanks thats now confirmed so that line has been remove form profile on post 1 ( new profile uploaded now with profile lvl stuff )
2. yes im certain i have the sink information from that device.
iCO
Post Fri Feb 03, 2012 9:04 pm
Here some tests with new version with profile lvl stuff.
The folowing gives "Unsupported file format" (not sure about english translation) on TV set.
Unique ID                                : 228548773225618984760463757803348508669 (0xABF0E482248285C57C904A5654473FFD)
Complete name                            : Z:\Media\Doctor Who\Doctor Who - 01x01a - 100,000BC (Episode 1 - An Unearthly Child).mkv
Format version                           : Version 1
File size                                : 347 MiB
Duration                                 : 23mn 23s
Overall bit rate                         : 2 073 Kbps
Encoded date                             : UTC 2003-11-27 10:17:26
Writing application                      : mkvmerge v0.7.6
Writing library                          : libebml v0.6.2 + libmatroska v0.6.1
Format                                   : MPEG-4 Visual
Codec ID                                 : DIVX
Codec ID/Info                            : Project Mayo
Codec ID/Hint                            : DivX 4
Duration                                 : 23mn 23s
Bit rate                                 : 1 903 Kbps
Width                                    : 516 pixels
Height                                   : 570 pixels
Display aspect ratio                     : 4:3
Frame rate                               : 25.000 fps
Bits/(Pixel*Frame)                       : 0.259
Stream size                              : 318 MiB (92%)
Format                                   : Vorbis
Format settings, Floor                   : 1
Codec ID                                 : A_VORBIS
Duration                                 : 23mn 23s
Bit rate                                 : 128 Kbps
Stream size                              : 21.4 MiB (6%)
Writing library                          : libVorbis 1.0 (UTC 2002-07-17)
Changed profile the folowing way in order to play:
         <!-- unsupported codecs will be transcoded into mpeg-ts, mpeg2 video and ac3 audio -->
            <Matches container="matroska" vCodec="mpeg4"/>
            <Matches container="mp4" vCodec="mpeg4" />
            <Matches container="mpeg" vCodec="mpeg1video" />
            <Matches container="asf" />
            <Matches container="flv" />
            <Matches container="ogg" />
            <Matches container="3gp" />
Post Fri Feb 03, 2012 9:09 pm
ok cool i can live with that one will update the first post. :)
Candoris
Post Fri Feb 03, 2012 9:28 pm
TC-L42E30 = I got this one - can I be of some use to you guys for testing? if yes - let me know what to do.
Post Fri Feb 03, 2012 9:35 pm
Candoris wrote:TC-L42E30 = I got this one - can I be of some use to you guys for testing? if yes - let me know what to do.
yep welcome to the party :) im Cerberus i will be your MC for this thread ;)
There is a profile on the first post (second one down as you have e30 series ) you need to copy that profile to you profile.xml file in your serviio directory and then restart serviio, once restarted select the new profile for your device and try playing all your files and report to me if any dont play. :) hopefully they all do :) reading through this thtread will also help you understand exactly what we are doing and if you get stuck just ask and we will help you :).
Candoris
Post Fri Feb 03, 2012 10:12 pm
Thanks, mate! I'll get right to it than...
Candoris
Post Fri Feb 03, 2012 11:00 pm
Belated thanks for such a warm welcome, by the way... Have to admit this profile + the software update (not sure which one did it in the end) are magical - everything works including p1024 vids, which previously stuttered and do not play if I hook the hdd up to the tv itself. I failed to present it with a file, that wouldn't play well... So I thought and then I bumped into this (it plays in mpc with k-lite megacodec pack installed), but on the tv audio is fine, video is slideshow. I did this splitting myself some time back to play the vid on xbox directly...
Complete name                            : F:\The.Town.2010.THEATRICAL.720p.Blu-ray.DTS.x264-CtrlHD.split_1.mp4
Format profile                           : Base Media
Codec ID                                 : isom
File size                                : 3.73 GiB
Duration                                 : 1h 47mn
Overall bit rate                         : 4 950 Kbps
Writing application                      : XviD4PSP 6.0 / 53.6.0
Format settings, ReFrames                : 11 frames
Codec ID                                 : avc1
Codec ID/Info                            : Advanced Video Coding
Duration                                 : 1h 47mn
Bit rate                                 : 4 667 Kbps
Height                                   : 534 pixels
Display aspect ratio                     : 2.40:1
Frame rate mode                          : Variable
Minimum frame rate                       : 23.810 fps
Maximum frame rate                       : 24.390 fps
Bits/(Pixel*Frame)                       : 0.285
Stream size                              : 3.65 GiB (98%)
Writing library                          : x264 core 110 r1820 fdcf2ae
Encoding settings                        : cabac=1 / ref=11 / deblock=1:-3:-3 / analyse=0x3:0x133 / me=umh / subme=10 / psy=1 / psy_rd=0.90:0.00 / mixed_ref=1 / me_range=32 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=6 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=6 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=4667 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Codec ID                                 : 40
Duration                                 : 1h 47mn
Bit rate                                 : 98.7 Kbps
Stream size                              : 76.1 MiB (2%)
Post Fri Feb 03, 2012 11:04 pm
never come accross that encoder before and my guess is that is the issue as rest looks fine on that file, try remuxing it into MKV with mkvmerge and try playing the remuxed mkv.
Tarrasque
Post Fri Feb 03, 2012 11:16 pm
Some more strange issues (once again I do believe it is more to do with the TV firmware than the program). Panasonic UT30 (same as E and G series)
This file does not play
Complete name                    : D:\TV Shows\Spartacus Blood and Sands\Spartacus.Blood.and.Sand.S01E03.HDTV.XviD-SYS.avi
Format                           : AVI
Format/Info                      : Audio Video Interleave
File size                        : 546 MiB
Duration                         : 55mn 49s
Overall bit rate                 : 1 368 Kbps
Writing application              : Nandub v1.0rc2
Writing library                  : Nandub build 1853/release
Format profile                   : Advanced Simple@L5
Format settings, BVOP            : Yes
Format settings, QPel            : No
Format settings, GMC             : No warppoints
Format settings, Matrix          : Default (H.263)
Codec ID                         : XVID
Codec ID/Hint                    : XviD
Duration                         : 55mn 49s
Bit rate                         : 1 229 Kbps
Width                            : 624 pixels
Height                           : 352 pixels
Frame rate                       : 23.976 fps
Bits/(Pixel*Frame)               : 0.233
Stream size                      : 491 MiB (90%)
Writing library                  : XviD 1.3.0.dev55
Format                           : MPEG Audio
Format profile                   : Layer 3
Mode                             : Joint stereo
Mode extension                   : MS Stereo
Codec ID                         : 55
Codec ID/Hint                    : MP3
Duration                         : 55mn 49s
Bit rate mode                    : Variable
Bit rate                         : 128 Kbps
Channel(s)                       : 2 channels
Stream size                      : 50.3 MiB (9%)
Alignment                        : Aligned on interleaves
Interleave, duration             : 24 ms (0.58 video frame)
Interleave, preload duration     : 140 ms
Writing library                  : LAME3.92
Encoding settings                : -m j -V 4 -q 2 -lowpass 17.5 --abr 128
While this one does
Complete name                    : D:\TV Shows\Spartacus Blood and Sands\Spartacus.Blood.and.Sand.S01E02.DVDSCR.XviD-FFNDVD.avi
Format                           : AVI
File size                        : 550 MiB
Duration                         : 52mn 53s
Overall bit rate                 : 1 454 Kbps
Writing library                  : Nandub build 1852/release
Format profile                   : Simple@L3
Format settings, BVOP            : No
Codec ID                         : XVID
Duration                         : 52mn 53s
Bit rate                         : 1 312 Kbps
Width                            : 640 pixels
Height                           : 368 pixels
Bits/(Pixel*Frame)               : 0.232
Stream size                      : 496 MiB (90%)
Writing library                  : XviD 1.2.1 (UTC 2008-12-04)
Format                           : MPEG Audio
Codec ID                         : 55
Codec ID/Hint                    : MP3
Duration                         : 52mn 53s
Bit rate                         : 135 Kbps
Stream size                      : 48.9 MiB (9%)
Interleave, preload duration     : 457 ms
Writing library                  : LAME3.98r
Encoding settings                : -m s -V 4 -q 3 -lowpass 17 --abr 135
once agian I just remux using mkvmerge and the new file plays fine.
Post Fri Feb 03, 2012 11:27 pm
Tarrasque wrote:Some more strange issues (once again I do believe it is more to do with the TV firmware than the program). Panasonic UT30 (same as E and G series)
Format                           : AVI
File size                        : 546 MiB
Duration                         : 55mn 49s
Codec ID                         : XVID
Duration                         : 55mn 49s
Width                            : 624 pixels
Height                           : 352 pixels
Format                           : MPEG Audio
Mode                             : Joint stereo
Codec ID                         : 55
Codec ID/Hint                    : MP3
Duration                         : 55mn 49s
Bit rate                         : 128 Kbps
While this one does
Format                           : AVI
File size                        : 550 MiB
Duration                         : 52mn 53s
Codec ID                         : XVID
Duration                         : 52mn 53s
Width                            : 640 pixels
Height                           : 368 pixels
Format                           : MPEG Audio
Codec ID                         : 55
Codec ID/Hint                    : MP3
Duration                         : 52mn 53s
Bit rate                         : 135 Kbps
yep nandub is a known issue, files never work right.
Candoris
Post Fri Feb 03, 2012 11:49 pm
I do realize the split itself is unorthodox in its means of creation, however, why would it play on the pc, but not on the tv?
http://www.winnydows.com - that's where the encoder is from, and I used a daily beta to make that split. Its earlier opensourced version fares better, although not faster: http://code.google.com/p/xvid4psp/downloads/list. Really is an amazing piece of software if you're with xbox 360 without lan and need subs to work.
found two more files it wouldn't play:
Complete name                            : D:\Video\Mobile\The War Of Stars - A New Hope 2010 DVDRip [A Release-Lounge H264]\The War Of Stars - A New Hope 2010 DVDRip [A Release-Lounge H264].mp4
Format profile                           : Base Media / Version 2
Codec ID                                 : mp42
File size                                : 1.00 GiB
Duration                                 : 1h 37mn
Overall bit rate                         : 1 477 Kbps
Encoded date                             : UTC 2010-04-25 10:00:01
Tagged date                              : UTC 2010-04-25 10:00:01
Writing application                      : Yamb 2.1.0.0 [http://yamb.unite-video.com]
Format settings, ReFrames                : 3 frames
Format settings, GOP                     : N=1
Codec ID                                 : avc1
Duration                                 : 1h 37mn
Bit rate                                 : 1 345 Kbps
Maximum bit rate                         : 2 870 Kbps
Width                                    : 720 pixels
Height                                   : 304 pixels
Frame rate                               : 29.970 fps
Bits/(Pixel*Frame)                       : 0.205
Stream size                              : 936 MiB (91%)
Writing library                          : x264 core 67 r1162M f7bfcfa
Encoding settings                        : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=7 / psy_rd=1.0:0.0 / mixed_ref=1 / me_range=12 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=-2 / threads=6 / nr=0 / decimate=1 / mbaff=0 / bframes=3 / b_pyramid=0 / b_adapt=2 / b_bias=0 / direct=3 / wpredb=1 / keyint=250 / keyint_min=25 / scenecut=40 / rc=2pass / bitrate=1345 / ratetol=1.0 / qcomp=0.50 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=24000 / vbv_bufsize=24000 / ip_ratio=1.10 / pb_ratio=1.10 / aq=1:1.00
Tagged date                              : UTC 2010-04-25 10:01:45
Codec ID                                 : 40
Duration                                 : 1h 37mn
Bit rate                                 : 128 Kbps
Maximum bit rate                         : 133 Kbps
Stream size                              : 89.1 MiB (9%)
Encoded date                             : UTC 2010-04-25 10:01:31
Complete name                            : D:\Video\Mobile\The Forbidden Kingdom 2008 BRRip 720p H264-3Li\The Forbidden Kingdom.mp4
Codec ID                                 : isom
File size                                : 2.18 GiB
Duration                                 : 1h 44mn
Overall bit rate                         : 2 990 Kbps
Encoded date                             : UTC 2010-04-14 18:44:28
Tagged date                              : UTC 2010-04-14 18:44:28
Format settings, ReFrames                : 8 frames
Codec ID                                 : avc1
Duration                                 : 1h 44mn
Bit rate                                 : 2 668 Kbps
Maximum bit rate                         : 20.4 Mbps
Height                                   : 544 pixels
Bits/(Pixel*Frame)                       : 0.160
Stream size                              : 1.94 GiB (89%)
Title                                    : The Forbidden Kingdom By 3Li
Writing library                          : x264 core 80 r1376M 3feaec2
Encoding settings                        : cabac=1 / ref=8 / deblock=1:-2:-2 / analyse=0x3:0x113 / me=umh / subme=9 / psy=1 / psy_rd=0.2:0.0 / mixed_ref=1 / me_range=32 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-1 / threads=3 / sliced_threads=0 / slices=2 / nr=0 / decimate=0 / mbaff=0 / constrained_intra=0 / bframes=6 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=1 / wpredb=1 / wpredp=2 / keyint=250 / keyint_min=25 / scenecut=42 / rc_lookahead=42 / rc=2pass / mbtree=1 / bitrate=2668 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Encoded date                             : UTC 2010-04-14 04:28:18
Tagged date                              : UTC 2010-04-14 18:45:08
Codec ID                                 : 40
Duration                                 : 1h 44mn
Bit rate                                 : 320 Kbps
Maximum bit rate                         : 344 Kbps
Stream size                              : 239 MiB (11%)
Encoded date                             : UTC 2010-04-14 18:44:56
Says "cannot read file" in both cases although in case of forbidden kingdom started playing preview. both files naturally work on pc.
Also need your advice - given this tv doesn't see subtitles unless the file is .avi + .srt, what software do I use to convert my .mkv => .avi + .srt if mkv has h264 inside and what audio codec would work in this new avi?
upon conversion of the initial file to mkv - the file becomes unplayable completely and only playable on pc with vlc, but not with mpc, converted with mkv merge, like you suggested.
Unique ID                                : 199660528448259717484446106539306900407 (0x96353813566CAE66BB71CFBD918DDBB7)
Complete name                            : F:\The.Town.2010.THEATRICAL.720p.Blu-ray.DTS.x264-CtrlHD.split_1.mkv
Duration                                 : 1h 47mn
Overall bit rate                         : 4 946 Kbps
Encoded date                             : UTC 2012-02-03 23:37:39
Muxing mode                              : Header stripping
Duration                                 : 1h 47mn
Nominal bit rate                         : 4 667 Kbps
Height                                   : 534 pixels
Frame rate                               : 23.810 fps
Original frame rate                      : 23.976 fps
Bits/(Pixel*Frame)                       : 0.287
Codec ID                                 : A_AAC
Duration                                 : 1h 47mn
Post Sat Feb 04, 2012 12:09 am
see your using some really nasty encoding software packages, and they are adding odd encoding settling that ffmpeg and the tv dont like.
there is only 2 encoders id recommend and that is mkvmerge and virtualdub.
Candoris wrote:Also need your advice - given this tv doesn't see subtitles unless the file is .avi + .srt, what software do I use to convert my .mkv => .avi + .srt if mkv has h264 inside and what audio codec would work in this new avi?
please keep topic on track, best avi encoder is virtualdub.
Candoris
Post Sat Feb 04, 2012 1:09 am
Well, they play on pc no sweat... thought there might be some simple kink that could've been sorted out...
Post Sat Feb 04, 2012 1:15 am
there are several encoding programs that are known to cause problems YAMB and NANDUB are two of them as for XVID4PSP i have never heard of it, most people use handbrake or mkvmerge to build there files, but thats taking the topic of track its not about what encoder is best its about getting the best profile for the device, and i cant take encoder used into account.
PMI
Post Sat Feb 04, 2012 1:58 am
Cerberus wrote:... so just the stutter issue let excellent :D
edit:
To answer your question as you asked it, this file plays differently/better with the line you specified removed. But not 100%. To analyze just the stutter issue, I think this file is a red herring.
The problem voodooo and I started working together occurs with this particular video when the number of ref frames increases from 9 to 10. I created test files with different number of reference frames:
5 ref frames and above, there are some issues during playback, but not all are the same.
9 or fewer ref frames = some issues, but no stutter (Media Info reports Main@L 4.0)
10 or more ref frames = stutter (Media Info reports Main @ Level 5.0)
Peter
Post Sat Feb 04, 2012 2:07 am
yer i have a feeling, we are barking up the wrong tree with this, but i wont go into details till i have spoken to ZIP, so far i think we have the profile as good as its going to get, at teh current time.
ok think i might have fixed the problems with mkv i was seeing so hopefully this will sort the stutter too.
assuming your running windows 64bit.
download and replace your ffmpeg.exe file with this one (rename your old file .bak incase your have to go back to it) and restart serviio do your files still stutter?
http://www.mediafire.com/?f74ngkv4ext3pe4
Return to Panasonic
