Empty folders and missing files
uridavid
Post Wed Feb 08, 2012 5:25 pm
I gave been struggling for almost 2 weeks with Serviio.
I managed to install and connect to my TV (Samsung ua32d5000) easily and the content that I see in the folders works great
But I have some problems:
The content of folders and sub-folders of videos are not shown in full. Folders and files are missing.
My music folder is empty.
My photos folder are also show partial folders or files.
I reviewed all the forums and everything I tried to do didn’t help.
I waited long time enough that the Serviio will scan my files, i installed the plugins, I changed the folders name, I changed the profile.
Attached are log files.
Please help.
Copy of serviio 2.log
(409.9 KiB) Downloaded 698 times
(43.83 KiB) Downloaded 645 times
Post Wed Feb 08, 2012 8:39 pm
Re: Empty folders and missing files
can you take a screen shot of teh library tab (serviio console) so i can see how u have it set. :)
uridavid
Post Wed Feb 08, 2012 10:00 pm
Screen shot of library screen
Post Wed Feb 08, 2012 10:08 pm
ah ok is H an internal drive\usb drive?
ok so you have ticked every box no wonder serviio is struggling from left to right 1-5 )
1. H:\movies - tick only boxes 1, 4 and 5
2. erm cant read that language so cant say ( provide it in english and will advise )
3. see 2
4. D:\my-music - tick only boxes 2 and 6
5. E:\downloads firefox\movies - same as 1
also make sure you have your locale setting on your OS set to utf-8
uridavid
Post Wed Feb 08, 2012 10:20 pm
Cerberus wrote:ah ok is H an internal drive\usb drive?
3. see 2
All drives are internal.
i checked all the boxes because it didn't work correctly.
2 - is movies folder
3 - is pictures folder.
where do i set the utf-8??
i will try your suggestions and let you know the results.
Post Wed Feb 08, 2012 10:26 pm
3. see 2
2 - is same as 1 then
3 - leave completely unticked for now.
uridavid
Post Wed Feb 08, 2012 10:37 pm
3. see 2
my music is now OK (system still updating).
see my new settings.
what should i do with 3 my pictures?
Post Wed Feb 08, 2012 10:50 pm
as i supected your issue is caused by a picture file that serviio doesnt like, i will put money the exif rotation data is damaged. OK remove number 3 and add it again so its then at the bottom,(leave it unticked for now ) wait till refresh is completely finished on all other folders.
ok for the next step i need to hand over to ZIP as i can see from your log that none english named folders and files have issues and that beyond my knowlege.
Post Wed Feb 08, 2012 11:06 pm
it doesn't seem to be related to the non english characters. From the log it looks the images are not added because they are 'invalid' for the library Serviio uses to parse images metadata.
