Help wanted for SMP-N100 and live streaming
Post Fri Feb 10, 2012 4:03 pm
Re: Help wanted for SMP-N100 and live streaming
Larzendk wrote:No, i am lost too.
I think it maby is the unit itself that is the problem, and i am thinking of getting another, do someone know what to go for?
I am thinking abouth WDTV Live or Sony SMP-N200 what is best?
Best regards
Morten
Denmark
the new WDTV live streamer seems a good unit from when i did a profile for it lol.
Post Fri Feb 10, 2012 4:09 pm
i get same error with latest daily build of ffmpeg.
Larzendk
Post Fri Feb 10, 2012 4:16 pm
And that means :geek:
npuser
Post Fri Feb 10, 2012 8:49 pm
HUMMM! This is interesting. I have similar issue.
I have a Sony KDL -52EX700 (TV), a PS3 and a Sony BDP-BX52 (BluRay) as renders. Single serviio installation serves all three renders - TV and PS3 plays streams perfectly fines. But just like OP, my bluray gives me a pink screen after few seconds and then reboots the unit. As i can watch the feeds on TV or PS3 directly so i thought may be my blueray going bad and never looked back. I wonder if the render hardware is the culprit.
jamesbess
Post Fri Feb 10, 2012 8:54 pm
Hi, i also have a Sony N100 and get the same pink screen when i try to run live streams. the unit works perfectly on local files, netflix, hulu, etc.. but If i try to view live streams i get a few seconds of searching (about 5-8) then pink screen for about 30 seconds then the unit reboots. While the unit has a pink screen it is locked up and even pressing the on unit power button will not turn it off.
Post Fri Feb 10, 2012 9:03 pm
Can you guys give us your exact setup including router, computer running serviio, where files are, what renderes you can play video and renderers you cannot play videos on. For your renderers can you supply the model and the firmware version.
This information will help us determine what is causing this problem.
Larzendk
Post Sat Feb 11, 2012 7:07 am
My router is Linksys WRP400
I have tryed to run Serviio from diffrent computers to see if that is the problem, but its make pink screen no matter what computer i try, but the "main computer" is running Win 7 home premium 32 bit, and is a MSI GX700, the second is a ASUS Eeepc running Win 7 Starter.
My unit is a Sony SMP-N100 with latest firmware from 23/6-2011 M05.R.084 connectet via HDMI to TV , i have tryed to run both with WIFI and cabel, but no diffrent, it makes pink screen no matter what.
I can run MKV movie from my Buffalo linkstation without any problems.
It is not one live stream that make problems it is them all, sometime i can get one to work, next time not, it dosent matter if it is HD channel or regular channels. As sayed, if i am lucky i can get one to play, and it is not the same, but most of the time i get pink screen.
All feed link, plugin and groovey files is taken from the forum.
I hope this can help
Best regards
Morten
Denmark
npuser
Post Sat Feb 11, 2012 5:32 pm
My router/switch is Cisco SRP 520W. Sony KDL-52EX700 and Serviio (Win 7 Business Edtn 64bit) are hard wire to the router. The bluray (BDP-BX57) and PS3 are wireless/wire units but right now both of them are connected wireless-ly. The local medias are served from serviio work without any issues on any of these renderers. The trouble is with RSS/Video Streams playing from bluray (BDP-BX57) - wire or wirelees same outcome. My setup is attached for reference.
sa
Post Sat Feb 11, 2012 7:02 pm
npuser wrote:My router/switch is Cisco SRP 520W. Sony KDL-52EX700 and Serviio (Win 7 Business Edtn 64bit) are hard wire to the router. The bluray (BDP-BX57) and PS3 are wireless/wire units but right now both of them are connected wireless-ly. The local medias are served from serviio work without any issues on any of these renderers. The trouble is with RSS/Video Streams playing from bluray (BDP-BX57) - wire or wirelees same outcome. My setup is attached for reference.
sa
Is there a certain feed that is causing the problem? if so can you provide a ffmpeg - i of it?
Also how did you create the homenet.jpg? It is real helpful.
npuser
Post Sun Feb 12, 2012 1:27 am
For me all feeds - the wheel spins in tv for a while then after few secs the bluray pucks. The comcast speed is 25 down/4 up. Attached pic is the bluray renderer detected by serviio.
As far network diagram - i used Gliffy http://www.gliffy.com/gliffy/#templateId=blank&signup=1. I created the diagram as guest and used windows 7 snipping tool to snip the diagram.
sa
Larzendk
Post Tue Feb 14, 2012 9:18 am
Hmm, i have found out that the pink screen is relatet to the HDMI, when i use regular AV cables the screen goes BLACK and the unit restarts, so the problem is the same, just a diffrent coulor.
I AM GOING NUTS OVER THIS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Post Tue Feb 14, 2012 9:40 am
No problem with my SMP-N100 and NASA HD live stream
Larzendk
Post Tue Feb 14, 2012 10:01 am
What feed are you useing?
9 out of 10 times my SMP-N100 goes down when i try NASA HD, (and other chanells)
Post Tue Feb 14, 2012 11:19 am
Larzendk
Post Tue Feb 14, 2012 11:36 am
Hi Illico
The first link will not show up in my online folder
The second link is the one i have problems with (pink/black screen and restart)
Post Tue Feb 14, 2012 12:44 pm
What is your firmware version and region ?
Larzendk
Post Tue Feb 14, 2012 12:50 pm
If you means the SMP-N100 it's M05.R.084 from 23/6-2011 (the latest)
My region is EU (Denmark)
npuser
Post Mon Feb 20, 2012 2:56 pm
I had few minutes over weekend to play around with my bdp-bx57 to find a cause for the pink issue. It turns out it can't handle m2ts but it plays streams fine if they are mpeg. I am not familiar with on-the-fly transcoding settings or terms. I tried to unsuccessfully transcode all online streams with mpeg codec.
How do i force them to trancode or to put them in mpeg container instead of m2ts?
thanks
sa
Post Mon Feb 20, 2012 4:20 pm
Could you try to edit profiles.xml file and change the following line 123
to
<Video targetContainer="mpeg" targetACodec="ac3" aBitrate="384">
Could you provide a feed link that I can test with my SMP-N100 device ?
Larzendk
Post Mon Feb 20, 2012 4:59 pm
It did not help on my SMP-N100 , i still got pink screen 9 out of 10 times :evil:
Morten
