Online Source - my wish list
Citronel
Post Fri Feb 10, 2012 1:23 pm
At Online Source:
- Source Name possibility to move UP/Down. ( this will help organize sources by priority and speed up display at Serviio start )
- Remove button moved down. ( I had to edit many of my links and by mistake I pressed Remove few time and lost some Source )
- No thumbnails option ( for speed up, fast only links )
- Import / Export. ( Back-up / Restore Library, useful if you use Servio on 2 computers or just to make back-up and keep it safe or to share your sources )
Post Fri Feb 10, 2012 1:25 pm
Re: Online Source - my wish list
1 and 4 are already planned
Citronel
Post Fri Feb 10, 2012 2:05 pm
Thank you.
Another one useful if you have 2 or more Serviio servers in LAN; now you have to exit&close console, and start another console for that IP ...
- IP/identification of server where console is connected on
- Possibility to Switch/Connect console to Serviio servers listed in Server Status ( need a profile to identify as Serviio server or IP inserted manual )
2012.02.10 15.51.02.jpg (67.2 KiB) Viewed 16817 times
Post Fri Feb 10, 2012 2:11 pm
Citronel wrote:Thank you.
why would you want more than one imstance of serviio on your network ? only reason i can think of is for beta testing and in that case 99% of users would never use the function so it would be next to useless.
Citronel
Post Fri Feb 10, 2012 7:57 pm
Because I have an old computer as file server and tv will access files stored on HDD from him and another computers that tv will access for online stream, Youtube...
Post Fri Feb 10, 2012 9:00 pm
Citronel wrote:Because I have an old computer as file server and tv will access files stored on HDD from him and another computers that tv will access for online stream, Youtube...
You could have the second computer access the harddrive on the old computer, that way you would only have one running instance of serviio.
Citronel
Post Fri Feb 10, 2012 10:24 pm
I prefer not, because the file server it is online 24h / 7days, for storage & accessing files by any device from LAN ( mediaplayer, dreambox, tv, computers ) it is perfect.
Post Fri Feb 10, 2012 10:28 pm
I have an old Athlon 64 from 2004 that I am running serviio on Mint linux on it and it runs 24/7 and I stream all my movies from the HD in it, and I stream my online feeds from it also. This way all the programs I have on the computer are available all the time, serviio, calbre, and all my shared folders.
Citronel
Post Sat Feb 11, 2012 7:02 am
What do you think about my file server that now run also Serviio:
Compaq year ~199x with Intel Pentium 2 - 348Mhz 128Mb Ram, 70Gb HDD with 1.5Tb HDD on USB 2
XP Pro SP3 - with all unneeded services disabled ( ~37Mb Ram free with Serviio running ).
Any how if it is not important or to much time consumming for developers to program console to have the Switch to another server function - button, I can survive without problems, I made my .bat and from there I can select which of my server I connect, no problem.
Post Sat Feb 11, 2012 11:35 am
Citronel wrote:What do you think about my file server that now run also Serviio:
I think that you should be fine, what I would do is turn on performance monitor and see what the CPU and memory loads are. It would probably be slower doing the initial indexing, but that is about all. You will probably only be limited if you are transcoding a few streams at the same time. Ie using 2-3 renderers at the same time.
If you do not mind can you post the results of the performance monitor if you use it, so we can use it as a reference point.
On my athlon 64 I rarely get above 1-2% load.
Citronel
Post Sat Feb 11, 2012 12:44 pm
I never used performance monitor, will try to see if I can manage.
Post Sat Feb 11, 2012 12:57 pm
Here is a link on how to use it.
http://www.informit.com/articles/article.aspx?p=23757
I would only worry about processor and memory monitoring.
Citronel
Post Sat Feb 11, 2012 4:04 pm
This settings are ok ?
How do I see the log after it is saved ?
2012.02.11 17.58.05.jpg (81.87 KiB) Viewed 16120 times
2012.02.11 17.58.10.jpg (76.71 KiB) Viewed 16120 times
p.s.
On this old computer I have disabled transcoding by default because I think it it is to much for this old CPU and so little memory.
Citronel
Post Sat Feb 11, 2012 4:40 pm
This is a log, first I try to play online TV -HD then TV -SD, and finally a movie mkv from HDD ( no subtitle support ), all this done on media player EGR-1
Log.zip
(45.81 KiB) Downloaded 644 times
edit:
Finally I seen how to see the log as graph.
Xmantium
Post Sat Feb 11, 2012 9:28 pm
zip wrote:1 and 4 are already planned
@zip - Have you got plans to put online feeds into folders? for example i want all my iPlayer feeds in one "iPlayer" folder, all 4OD feeds in "4OD" folder ect
i would defo like to see this on next release
Post Sun Feb 12, 2012 1:52 am
I'm thinking about how to do this. Not sure if next version but should be there at some point.
Xmantium
Post Sun Feb 12, 2012 7:45 pm
i think the best way is to use Display Name, could use double forwardslash or a symbol so Serviio knows its a folder
for example
iPlayer\\Highlight Feeds
4OD\\New Girl
iPlayer\\Popular feeds
Post Sun Feb 12, 2012 8:14 pm
Citronel wrote:This settings are ok ?
p.s.
yes they are.
Return to Feature requests
Users browsing this forum: No registered users and 65 guests
