Preparing to Play
philokokus
Post Thu Feb 16, 2012 9:14 am
Preparing to Play
Hi
sometimes when streaming a movie I get this messages in my Samsung UE46C5100 TV. I chequed it and my PC is only using 10% of the 150 mbps available when it happens.
Why is this happening anyway?
Any solution?
Best Regards
José
Post Thu Feb 16, 2012 9:18 am
Re: Preparing to Play
it could be as the transcoding is starting. Can you enable detailed logging and then play a fle that gives the warning. Then attach that file here.
philokokus
Post Thu Feb 16, 2012 9:31 am
moltra wrote:it could be as the transcoding is starting. Can you enable detailed logging and then play a fle that gives the warning. Then attach that file here.
I dont use transcoding.
Best Regards
José
Post Thu Feb 16, 2012 9:49 am
even if you do not use transcoding, the log would be helpful.
Can you supply the information about the file tha gives this error. (see signature)
philokokus
Post Sun Mar 04, 2012 6:25 pm
moltra wrote:even if you do not use transcoding, the log would be helpful.
This is the log. It was done with ps3 wired connected to router and pc also wired connect to same router. Even so, when streaming live hd tv, Sky Sports 1 HD, it plays 1 second and stops 5 seconds and so on.
What am I doing wrong?
Any Help?
Tks
Jose
PS: I can't attach the log, it always says it is to long.
philokokus
Post Thu Mar 08, 2012 7:26 am
Any Help?
Tks
Jose
Hi
can this be related to version 0.6.2? When I had 0.6.0.1 everything was fine, even HD streaming.
Should I go back to 0.6.0.1?
Best Regards
José
