Preparing to Play
sometimes when streaming a movie I get this messages in my Samsung UE46C5100 TV. I chequed it and my PC is only using 10% of the 150 mbps available when it happens.
Why is this happening anyway?
Any solution?
Best Regards
José
moltra wrote:it could be as the transcoding is starting. Can you enable detailed logging and then play a fle that gives the warning. Then attach that file here.
moltra wrote:even if you do not use transcoding, the log would be helpful.
Can you supply the information about the file tha gives this error. (see signature)
philokokus wrote:moltra wrote:even if you do not use transcoding, the log would be helpful.
This is the log. It was done with ps3 wired connected to router and pc also wired connect to same router. Even so, when streaming live hd tv, Sky Sports 1 HD, it plays 1 second and stops 5 seconds and so on.
What am I doing wrong?
Any Help?
Tks
Jose
PS: I can't attach the log, it always says it is to long.
