Sony SMP N100 locks up
chrisc200
Post Fri Feb 17, 2012 3:06 pm
I have installed serviio 0.62 on ubuntu 11.10, and am streaming videos/pictures over the wifi connection to the smp 100 box, works well apart from one thing:
when I am playing an avi file (not tested other video file types) on the player and I fast forward the movie, after about 30 seconds of fast forward the smp100 box locks up and the only way to recover it is to do a hard power reset. I am not sure if this is due to
- Serviio side locking up
- wireless glitch - i will try with a ethernet cable, I am not sure how this is handled.
- something wrong with the avi file.
I did notice that the java process was consuming 100% cpu, but after I changed openjdk with the Sun one this seemed to improve and the cpu is back down to normal.
Any advice on where to look at this locking up issue? I think it could be the smp100 more than anything.
thanks
eclp
Post Fri Feb 17, 2012 3:29 pm
Re: Sony SMP N100 locks up
I can confirm with the BDP-S780. Some avi files (mkv) can freeze the device. It helps mostly a hard reset.
Post Fri Feb 17, 2012 6:20 pm
chrisc200 wrote:Hi,
thanks
not sure on this can you post a debug log file of when this happens ( howto in my signature ) as dont know of any specific crash issues relating to this device.
edit: also make sure u have the sony blu-ray profile selected for this device in serviio console.
eclp wrote:I can confirm with the BDP-S780. Some avi files (mkv) can freeze the device. It helps mostly a hard reset.
that makes no sense bro what files can freeze the blu-ray device AVI or MKV there 2 different file types?
eclp
Post Fri Feb 17, 2012 7:44 pm
sorry, for not playable (not supported) mkv files.
Post Fri Feb 17, 2012 7:46 pm
eclp wrote:sorry, for not playable (not supported) mkv files.
thats ok then cause patter factored that into teh profile and is remuxing them, from what i understand, he will comment if im mistaken :)
chrisc200
Post Sat Feb 18, 2012 8:46 am
Here is the debug. What actually happened in this case is the picture frame freezes during FF. Then after a while the avi starts from the beginning and I just hear the sound but sometimes it doesnt, I also found that a restart of serviio resolves when the player is completely hung,
(138.14 KiB) Downloaded 730 times
patters
Post Sat Feb 18, 2012 10:24 am
This is unlikely to be a Serviio problem, I'd suspect the file. All Serviio does is send the bitstream. Any decode problems are going to be the renderer's fault - especially since AVI is unmodified by the profile for SMP. There are many non-compliant/badly authored ones out there.
Post Sat Feb 18, 2012 10:39 am
chrisc200
Post Sat Feb 18, 2012 11:19 am
Thanks Ill check it out.
