Help wanted for SMP-N100 and live streaming
Post Mon Feb 20, 2012 5:06 pm
Re: Help wanted for SMP-N100 and live streaming
After profiles.xml modification, did you restart the serviio service?
Could you please give me one feed link I could test?
npuser
Post Mon Feb 20, 2012 5:50 pm
Illico - how do you like N100? I am contemplating on getting either N100 or N200 myself. Looking at the OP issue i am not sure it is worth it. Looks like you are not having that issue at all.
I will try you suggestion on bdp-bx57 when i get home. Thank you
sa
Larzendk
Post Mon Feb 20, 2012 6:27 pm
Yes i did restart Serviio
You can try the test feeds, they also gives me pink screen
mmsh://live1.wm.skynews.servecast.net/s ... z_live300k"
"rtmp://216.155.128.59:1935/2e2cd swfUrl=http://www3.nhk.or.jp/nhkworld/r/movie/fivecool_player.0.3.6.2.swf pageURL=http://www3.nhk.or.jp/nhkworld/r/movie/index.html playpath=nhkworldhd.sdp swfVfy=0 live=1"
Morten
serviio-buddy
Post Thu Feb 23, 2012 6:39 pm
Same problems here with Sony SMP-N100 (M05.R.084 latest firmware).
Most live streams fail and reboot SMP-N100 but sometimes they will work.
Testing stream using ffmpeg -i (version 0.9 built on Dec 13 2011 20:46:11) looks ok.
NASA HD Live Stream used:
rtmp://ustreamvip.fc.llnwd.net/ustreamvip playpath=ustreamvip_llnw_live_1_95413586 swfUrl=http://static-cdn1.ustream.tv/swf/live/viewer.rsl:96.swf swfVfy=1 live=1
serviio-buddy
SONY SMP-N100 Media Player, HP PC: Vista 32/Ubuntu 11.10, Serviio 0.6.2, XBMC, VLC, ASUS eeePC Netbook: Vista 32, XBMC, SHARP Aquos BD-HP25U DLNA Blu-Ray Player
HowTo: Provide supported formats of a device | Record a new ticket on Bitbucket | Provide details of a video file that doesn't play | Turn on detailed logging
Post Thu Feb 23, 2012 7:20 pm
serviio-buddy wrote:NASA HD Live Stream used:
On my Sony Bravia 2010 TV, I have to add the port like this:
rtmp://ustreamvip.fc.llnwd.net:80/ustreamvip playpath=ustreamvip_llnw_live_1_95413586 swfUrl=http://static-cdn1.ustream.tv/swf/live/viewer.rsl:96.swf swfVfy=1 live=1
This NAZA HD Live works too :
http://liveips.nasa.gov.edgesuite.net/msfc/Wifi.m3u8
serviio-buddy
Post Thu Feb 23, 2012 8:33 pm
Thanks for your quick response.
I had an old version of livefeeds.groovy and updated to v3.
Then, I added the :80 to the NASA HD Stream as you suggested and the Sony SMP-N100 took about 1 minute with whirling loading icon and it started streaming the content! After the next 4 and more tries, it wouldn't load the same stream once again rebooting the SMP-N100.
ffmpeg -i "rtmp://ustreamvip.fc.llnwd.net:80/ustreamvip playpath=ustreamvip_llnw_live_1_95413586 swfUrl=http://static-cdn1.ustream.tv/swf/live/viewer.rsl:96.swf swfVfy=1 live=1" resulted in no errors with or without the :80 addition.
Then I tried:
http://liveips.nasa.gov.edgesuite.net/msfc/Wifi.m3u8 , but Sony SMP-N100 still failed (got whirling loading icon, black screen for about 1 minute) then rebooted again.
Not sure what is causing this problem, but it seems to be at least a 90% failure rate and is common to multiple Sony SMP-N100 owners. Have tried powering off and on the Sony SMP-N100 and restarting PC running Serviio also.
All audio live streams work great.
If anyone has any more ideas to try, please advise.
Thanks again.
serviio-buddy
Post Fri Feb 24, 2012 3:55 pm
Ok, I also have issue with this live streaming:
After a very long time (10s-30s) and the either video is running, either reboot the device. Need some investigation...
Larzendk
Post Sat Feb 25, 2012 5:39 am
Glad that i am not the only one with rebooting om live stream.
Larzendk
Post Sat Feb 25, 2012 11:38 am
Hmm can not see stream from ustream in my online folder at all????????????????
Larzendk
Post Tue Feb 28, 2012 10:49 am
Hmm, if HTTPS is not supported, acording to zip, then why does the updated RSS folders by JBH50 stille have HTTPS in the link?
Best regards
Morten
toksy
Post Mon Mar 05, 2012 1:12 pm
I'm getting the same, I have 3 devices, most of the times I will get the pink screen and the device will reset. I updated java to its latest version and also inted to update ffmpeg from 0.09 to 0.10.
I have a xbox360 which I want to test to see if it reacts the same way.
Thank you.
Larzendk
Post Mon Mar 05, 2012 1:44 pm
Yes, its a pain in the a..
toksy
Post Tue Mar 06, 2012 3:32 am
I did a test disabling the transcoding feature on the transcoding tab and got some of the channels to stream no problem.
It seems like if the channel is MPEG it streams fine but if the channel is M2TS it shows the pink screen.
I'll keep testing.
serviio-buddy
Post Tue Mar 06, 2012 3:40 am
I did a test disabling the transcoding feature on the transcoding tab, but my SMP-N100 still rebooted on most M2TS live streams. The MPEG live streams play ok consistently.
serviio-buddy
toksy
Post Thu Mar 08, 2012 12:25 am
I did a test from another computer I have with the nhk link directly with ffmpeg and this is what I got:
C:\Program Files\Serviio\lib>ffmpeg.exe -i rtmp://216.155.128.59:1935/2e2cd swfU
live=1
nfig
libavutil 51. 32. 0 / 51. 32. 0
libavcodec 53. 42. 0 / 53. 42. 0
libavformat 53. 24. 0 / 53. 24. 0
libavdevice 53. 4. 0 / 53. 4. 0
libavfilter 2. 53. 0 / 2. 53. 0
libswscale 2. 1. 0 / 2. 1. 0
rtmp://216.155.128.59:1935/2e2cd: Operation not permitted
It says "Operation not permitted", any thoughts why this shows up?
Thank you.
serviio-buddy
Post Thu Mar 08, 2012 2:45 am
This error might indicate that you need to enclose your statement with quotes since it contains spaces.
For example: ffmpeg -i "rtmp etc"
serviio-buddy
toksy
Post Thu Mar 08, 2012 3:04 am
You are absolutely right, now how are you suppose to put the statment in the console?
toksy
Post Thu Mar 08, 2012 3:08 am
It's also interesting because for mmsh://live1.wm.skynews.servecast.net/s ... z_live300k, it makes no difference if you enclose your statement or not.
But if I enclose the NHK like you suggested I get something that makes sense:
C:\Program Files\Serviio\lib>ffmpeg.exe -i "rtmp://216.155.128.59:1935/2e2cd swf
0 live=1
nfig
audiochannels 2.00
audiosamplerate 48000.00
audiocodecid mp4a
videocodecid avc1
width 720.00
height 406.00
frameWidth 720.00
frameHeight 406.00
displayWidth 720.00
displayHeight 406.00
framerate 30.00
trackinfo:
timescale 0.00
language eng
sampledescription:
sampletype
type audio
config 1190
description {AACFrame: size: 0, rate: 48000, channels: 2, samples: 1
024, errorBitsAbsent: true, profileObjectType: "LC"}
timescale 0.00
language eng
sampledescription:
sampletype
type video
profile-level-id 4d401e
sprop-parameter-sets Z01AHtsC0NfmwEQAAAMABAAAAwDyPFi7gAA=,aOqMsg==
description {H264CodecConfigInfo: profile: "Main", level: 3.0, frame
Size: 720x406, displaySize: 720x406, PAR: 1:1, crop: l:0 r:0 t:0 b:5, frameRate:
30.0}
rtpsessioninfo:
connectiondata IN IP4 192.168.50.6
information N/A
name Unnamed
origin - 15201779123388486269 15201779123388486269 IN IP4 jp-6-
xcd-1
timing 0 0
protocolversion 0
attributes:
tool vlc 1.1.10
charset UTF-8
type broadcast
[flv @ 018c9460] Estimating duration from bitrate, this may be inaccurate
Input #0, flv, from 'rtmp://216.155.128.59:1935/2e2cd swfUrl=http://www3.nhk.or.
kworld/r/movie/index.html playpath=nhkworldhd.sdp swfVfy=0 live=1':
Duration: N/A, start: 0.000000, bitrate: N/A
Stream #0:0: Video: h264 (Main), yuv420p, 720x406 [SAR 1:1 DAR 360:203], 30
tbr, 1k tbn, 60 tbc
Stream #0:1: Audio: aac, 48000 Hz, stereo, s16
Do you think that the argument is not getting transfered from the console enclosed?
serviio-buddy
Post Thu Mar 08, 2012 3:25 am
What Sony model are you using? If you are using the Sony SMP-N100 and if your stream is M2TS, then it will only work about 10% of the time and we're not sure yet what is causing this problem.
Last edited by serviio-buddy on Sat Mar 10, 2012 5:29 pm, edited 2 times in total.
serviio-buddy
toksy
Post Thu Mar 08, 2012 3:29 am
SMP-N100
Latest firmware
Well, that's why I was suggesting that it was the way the link is typed in serviio.
Users browsing this forum: Baidu [Spider] and 8 guests
