stream url expires quickly
scrissti
Post Tue Mar 13, 2012 12:14 pm
Hi everyone,
I have a nice website which offers hundreds of tv shows http://serialepenet.ro It is paied and pretty good.
I have managed to make a plugin for it and it works, problem is that the URLs to the streams are available only for about 2 hours, and as I have loads of movies with loads of episodes, library refresh and cache take more than half an hour for only about 5 movies. And i would need to refresh it every 2 hours...
What I'm thinking is whether it is possible to not cache it at all, except for the thumbnail and somehow tell Serviio that the stream is always live and make the web requests to retrieve the actual stream url only when I press play on the TV?
Is it possible to specify something like that in the WebResourceItem class ?
Does the extractUrl method of the WebResourceUrlExtractor class gets executed when I press play on the TV ?
I would appreciate any ideas
Post Tue Mar 13, 2012 12:19 pm
Re: stream url expires quickly
use "expires immediately" as documented in the guide.
can you tell me how you handled the logon/password for the paid site in your plugin?
scrissti
Post Tue Mar 13, 2012 12:25 pm
I set this to the org.serviio.library.online.ContentURLContainer object in the extractUrl method?
and how does it work, when I press play on tv it calls the "extractUrl" method (again)?
scrissti
Post Tue Mar 13, 2012 12:28 pm
regarding login, i was very fortunate as the site works just by specifying a static cookie, it doesn't actually require credentials post.
And the cookie I specified to the openURL() method
If it didn't work with the static cookie I would have tried to login with creds in the querystring, so do a GET instead of POST,
or use a different java HTTP request package
Post Tue Mar 13, 2012 12:49 pm
scrissti wrote:I set this to the org.serviio.library.online.ContentURLContainer object in the extractUrl method?
yes and yes
scrissti
Post Tue Mar 13, 2012 8:28 pm
ContentURLContainer extractUrl(WebResourceItem item, PreferredQuality requestedQuality) {
   return new ContentURLContainer(fileType: MediaFileType.VIDEO, contentUrl: item.getAdditionalInfo()['WebResourceItemUrl_LOW'], thumbnailUrl: item.getAdditionalInfo()['WebResourceItemThumbnailUrl'], expiresImmediately: true)
If i have this in the log file I get :
2012-03-13 22:25:02,824 WARN [WebResourceParser] Plugin sri returned no value for resource item 'power_of_art/sezon_1/episod_2'
2012-03-13 22:25:02,825 DEBUG [WebResourceParser] Skipping web resource item 'power_of_art/sezon_1/episod_2' because it's not of type VIDEO
2012-03-13 22:25:02,825 DEBUG [FeedItemUrlExtractor] sri: Starting extraction of url for item: power_of_art/sezon_1/episod_1
2012-03-13 22:25:02,825 WARN [FeedItemUrlExtractor] Online item expires but no cache key has been set
2012-03-13 22:25:02,825 DEBUG [FeedItemUrlExtractor] sri: Finished extraction of url: no result
and of course i don't see anything on the tv...
any ideas?
scrissti
Post Wed Mar 14, 2012 8:32 am
    WebResourceContainer extractItems(URL resourceUrl, int maxItems) {
       ep_videourl=getMovieRealURL(new URL(videourl))
       WebResourceItem item = new WebResourceItem(title: ep_title,
                                                   additionalInfo: ['WebResourceItemThumbnailUrl': ep_thumb,
        'WebResourceItemUrl_LOW'     : ep_videourl,
        'WebResourceItemUrl_MEDIUM'  : ep_videourl,
        'WebResourceItemUrl_HIGH'    : ep_videourl,
        'WebResourceItemInfoUrl'     : ep_videourl,
        'bula'                       : ep_web_url])
        def videourl=item.getAdditionalInfo()['bula']
        return new ContentURLContainer(fileType: MediaFileType.VIDEO, contentUrl: videourl, thumbnailUrl: item.getAdditionalInfo()['WebResourceItemThumbnailUrl'])
Have tried also this but not working after a few hours
Post Wed Mar 14, 2012 11:26 am
When you use expiresOn or expiresImmediately, you probably need "cachekey":
String cacheKey – a unique identifier of the content (i.e. this item with this quality) used
as a key to technical metadata cache; optional if expiresOn nor expiresImmediately is
provided
On TrailerAddictRss.groovy plugin, I use the currentTime for unique identifier like this :
def cacheKey = getClass().getName() + "_${VideoId}_${requestedQuality}_"+(System.currentTimeMillis()/1000).toInteger()
Post Wed Mar 14, 2012 12:34 pm
you should not use time as a key, it negates the effect of the key, ie it'll run ffmpeg -i every time the method returns a new (nonexisting) cache key.
Cache key should be unique to the file itself, so I normally use something like (video_id + quality). If you're 100% sure all the files have the same technical metadata (codec, resolution, bitrate, etc), you can even use a constant cacheKey so that ffmpeg -i is only run 1x for the whole feed.
scrissti
Post Wed Mar 14, 2012 2:01 pm
Thank you very much,
I'll test it tonight
Post Wed Mar 14, 2012 2:30 pm
zip wrote:you should not use time as a key.
Thanks,
Good to know, I will check that for my groovy plugins.
scrissti
Post Thu Mar 15, 2012 3:37 pm
unfortunately still not working, please take a look and let me know where i'm wrong. I think it's a principle issue.
My code is like this
       def ep_WebUrl=ep_href.toString()
        def ep_streamUrl=getMovieRealURL(ep_href)
        println ep_href
        'WebResourceItemUrl_LOW'     : ep_streamUrl,
        'WebResourceItemUrl_MEDIUM'  : ep_streamUrl,
        'WebResourceItemUrl_HIGH'    : ep_WebUrl,
        'WebResourceItemInfoUrl'     : ep_streamUrl])
        Episodes <<item
        def videoWeburl=item.getAdditionalInfo()['WebResourceItemUrl_HIGH']
        def streamUrl=getMovieRealURL(new URL(videoWeburl))
        return new ContentURLContainer(fileType: MediaFileType.VIDEO, contentUrl: streamUrl, thumbnailUrl: item.getAdditionalInfo()['WebResourceItemThumbnailUrl'],expiresImmediately: true, cacheKey:videoWeburl)
So the idea is, i have two urls to an episode.
A web url :eg http://serialepenet.ro/house_m_d/sezon_8/episod_7
and a stream url: http://s5.serialepenet.ro:81/video/7f89 ... /46140.mp4
The stream Url is valid only for an hour or two.
So the strategy i took was to put in the WebResourceItem object both urls, the stream url to be called for video metadata to be cahed and the web url to be cached and to be available in the extractUrl method to use it in order to retrieve again the stream url when i press play on the tv remote.
Please take a look at the code and let me know where i'm wrong.
Post Thu Mar 15, 2012 5:55 pm
first, you're not dealing with different qualities, right?
It looks ok, what exactly doesn't work? post detailed log.
scrissti
Post Fri Mar 16, 2012 9:46 am
I got this in the logs, and at that time when there should be no activty (TV is off, cache is set to 24 hours)
2012-03-16 11:42:43,571 WARN  [FeedUpdaterThread] An error occured while scanning for online item information, will continue
java.io.IOException: Unexpected error while invoking plugin (sri): no protocol: tml    PUBLIC
   at org.serviio.library.online.WebResourceParser.parse(WebResourceParser.java:58)
   at org.serviio.library.online.OnlineLibraryManager.findResource(OnlineLibraryManager.java:169)
   at org.serviio.library.online.OnlineLibraryManager.findResourceInCacheOrParse(OnlineLibraryManager.java:184)
   at org.serviio.library.online.metadata.FeedUpdaterThread.getOnlineItems(FeedUpdaterThread.java:158)
   at org.serviio.library.online.metadata.FeedUpdaterThread.run(FeedUpdaterThread.java:95)
Caused by: java.net.MalformedURLException: no protocol: tml    PUBLIC
   at java.net.URL.<init>(Unknown Source)
   at sun.reflect.GeneratedConstructorAccessor1899.newInstance(Unknown Source)
   at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown Source)
   at java.lang.reflect.Constructor.newInstance(Unknown Source)
   at org.codehaus.groovy.reflection.CachedConstructor.invoke(CachedConstructor.java:77)
   at org.codehaus.groovy.runtime.callsite.ConstructorSite$ConstructorSiteNoUnwrapNoCoerce.callConstructor(ConstructorSite.java:102)
   at org.codehaus.groovy.runtime.callsite.AbstractCallSite.callConstructor(AbstractCallSite.java:190)
   at Seriale.getMovieRealURL(serialepenet.groovy:115)
   at Seriale$getMovieRealURL.callCurrent(Unknown Source)
   at Seriale.extractItems(serialepenet.groovy:86)
   at org.serviio.library.online.WebResourceUrlExtractor.parseWebResource(WebResourceUrlExtractor.java:29)
   at org.serviio.library.online.WebResourceParser.parse(WebResourceParser.java:56)
From the TV it seems that some times it works some times it doesn't.
And yes I don't care about different qualities.
Post Fri Mar 16, 2012 12:16 pm
it tries to get the URL for the first time, but fails:
You have o check your code (like 58) and see what kind of URL you're returning, it probably valid, ie has a wrong (tml) protocol, instead of http, rtmp, etc.
Return to Plugin development
