Can't play any mkvs on Samsung telly from Synology NAS
rgill90
Post Wed Apr 11, 2012 7:01 pm
Hi All
Thanks for the hardwork but i'm currently having a bit of a headache trying to get serviio streaming To my Samsung UE46D5520 TV from the serviio server. I've plenty of 1080p DTS MKVs which when I try to play on my Samsung just say "Not supported File Format". My Standard definition .AVIs play absolutely fine. My Server is a Synology NAS DS212j and ffmpeg output of one file is here:
DiskStation> which ffmpeg
/usr/syno/bin/ffmpeg
DiskStation> ffmpeg -i 9\ \(2009\).mkv
ffmpeg version UNKNOWN, Copyright (c) 2000-2011 the FFmpeg developers
  built on Mar  7 2012 15:59:03 with gcc 4.2.1
  configuration: --arch=arm --target-os=linux --cross-prefix=/usr/local/arm-none-linux-gnueabi/bin/arm-none-linux-gnueabi- --enable-cross-compile --enable-optimizations --disable-yasm --disable-altivec --enable-pic --enable-shared --disable-static --disable-swscale-alpha --disable-ffserver --disable-ffplay --enable-libmp3lame --enable-libfaac --enable-nonfree --enable-version3 --enable-libopencore-amrnb --enable-libopencore-amrwb --disable-decoder=amrnb
  libavutil    50. 40. 1 / 50. 40. 1
  libavcodec   52.120. 0 / 52.120. 0
  libavformat  52.108. 0 / 52.108. 0
  libavdevice  52.  4. 0 / 52.  4. 0
  libavfilter   1. 77. 0 /  1. 77. 0
  libswscale    0. 14. 0 /  0. 14. 0
[matroska,webm @ 0x33f20] Estimating duration from bitrate, this may be inaccurate
Seems stream 0 codec frame rate differs from container frame rate: 180000.00 (180000/1) -> 23.98 (24000/1001)
Input #0, matroska,webm, from '9 (2009).mkv':
  Duration: 01:19:24.25, start: 0.000000, bitrate: 1536 kb/s
    Stream #0.0(eng): Video: h264 (High), yuv420p, 1920x1040 [PAR 1:1 DAR 24:13], 23.98 fps, 23.98 tbr, 1k tbn, 180k tbc (default)
    Stream #0.1: Audio: dca (DTS), 48000 Hz, 6 channels (FL|FR|FC|SL|SR), s16, 1536 kb/s (default)
DiskStation> pwd
/volume1/House47/Movies
DiskStation>
and here's the mediainfo output:
Unique ID                        : 309007917402287274369287087202541946452 (0xE878C297142F5E2E116918BFC476C654)
Complete name                    : /Volumes/House47/Movies/9 (2009).mkv
Format                           : Matroska
File size                        : 2.31 GiB
Duration                         : 1h 19mn
Overall bit rate                 : 4 161 Kbps
Encoded date                     : UTC 2011-02-10 17:15:31
Writing application              : mkvmerge v4.4.0 ('Die Wiederkehr') built on Nov  2 2010 19:32:41
Writing library                  : libebml v1.0.0 + libmatroska v1.0.0
Format profile                   : High@L4.0
Format settings, CABAC           : Yes
Format settings, ReFrames        : 4 frames
Muxing mode                      : Header stripping
Codec ID                         : V_MPEG4/ISO/AVC
Duration                         : 1h 19mn
Bit rate                         : 2 568 Kbps
Width                            : 1 920 pixels
Height                           : 1 040 pixels
Frame rate mode                  : Variable
Frame rate                       : 23.976 fps
Bits/(Pixel*Frame)               : 0.054
Stream size                      : 1.42 GiB (62%)
Writing library                  : x264 core 112
Encoding settings                : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=3 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=crf / mbtree=1 / crf=22.0 / qcomp=0.60 / qpmin=3 / qpmax=51 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
Language                         : English
Color primaries                  : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
Transfer characteristics         : BT.709-5, BT.1361
Matrix coefficients              : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
Format                           : DTS
Format/Info                      : Digital Theater Systems
Codec ID                         : A_DTS
Duration                         : 1h 19mn
Bit rate                         : 1 510 Kbps
Channel(s)                       : 6 channels
Channel positions                : Front: L C R, Side: L R, LFE
Bit depth                        : 24 bits
Stream size                      : 857 MiB (36%)
I know it does say header stripping but i've a few other files which have no header stripping yet they still don't play so I'm wondering if anyone can spot anything else wrong within this file.
Thanks in advance
Rich
Post Wed Apr 11, 2012 10:20 pm
Re: Can't play any mkvs on Samsung telly from Synology NAS
this will be caused by header stripping. Try to remove that and see if it plays then.
rgill90
Post Thu Apr 12, 2012 12:27 am
Hi Zip - Cheers for the response but no go. I get exactly the same error. Just for info I've posted the remuxed file mediainfo here:
Unique ID                        : 92906668619182130943034249503444656612 (0x45E52C6B53F43A9BC666DA97032961E4)
Format                           : Matroska
Duration                         : 1h 19mn
Overall bit rate                 : 4 164 Kbps
Encoded date                     : UTC 2012-04-11 23:48:33
Duration                         : 1h 19mn
Bit rate                         : 2 572 Kbps
Stream size                      : 1.43 GiB (62%)
Language                         : English
Format                           : DTS
Codec ID                         : A_DTS
Duration                         : 1h 19mn
Bit depth                        : 24 bits
But the plot thickens as I have found only ONE file (out of about 60 or so i've tried so far) which plays:
Unique ID                        : 316829978449585680121014992316548402251 (0xEE5B3BF99D42D7208D9579D27E7E4C4B)
Complete name                    : /Users/Gilbo/The Bourne Identity (2002).mkv
Format                           : Matroska
File size                        : 3.72 GiB
Duration                         : 1h 58mn
Overall bit rate                 : 4 486 Kbps
Writing application              : HandBrake 0.9.6
Writing library                  : libmkv 0.6.5
Duration                         : 1h 58mn
Bit rate                         : 2 887 Kbps
Height                           : 816 pixels
Display aspect ratio             : 2.35:1
Bits/(Pixel*Frame)               : 0.077
Stream size                      : 2.39 GiB (64%)
Writing library                  : x264 core 120
Encoding settings                : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=3 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=crf / mbtree=1 / crf=22.0 / qcomp=0.60 / qpmin=3 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
Language                         : English
Format                           : DTS
Codec ID                         : A_DTS
Duration                         : 1h 58mn
Bit depth                        : 24 bits
Stream size                      : 1.25 GiB (34%)
Menu
00:00:00.000                     : (01)00:00:00:000
00:06:28.179                     : (02)00:06:28:179
00:08:34.848                     : (03)00:08:34:847
00:11:38.531                     : (04)00:11:38:531
00:13:38.359                     : (05)00:13:38:359
00:19:43.307                     : (06)00:19:43:307
00:25:41.039                     : (07)00:25:41:039
00:29:15.462                     : (08)00:29:15:462
00:36:36.319                     : (09)00:36:36:319
00:43:56.759                     : (10)00:43:56:759
00:48:27.738                     : (11)00:48:27:738
00:51:52.234                     : (12)00:51:52:234
01:02:01.468                     : (13)01:02:01:467
01:10:01.656                     : (14)01:10:01:655
01:18:44.929                     : (15)01:18:44:928
01:24:20.055                     : (16)01:24:20:055
01:32:00.181                     : (17)01:32:00:181
01:38:59.308                     : (18)01:38:59:308
01:45:33.327                     : (19)01:45:33:327
01:51:53.915                     : (20)01:51:53:915
Do you have any other ideas / pointers? Have to say I'm utterly confused!
Cheers
Post Thu Apr 12, 2012 11:06 am
Are you using the right profile? A detailed log might also shed some light on this.
rgill90
Post Thu Apr 12, 2012 11:54 am
Yeah on the Serviio package on the Synology I can see the green dot next to "Samsung C / D Series TV / Reciever" and the Sammy's IP address, so I think it is picking up the right profile. However even if i try to change that it just reverts back to the Samsung profile. Anyway long and short of it is I think the profile is OK.
I'll enable detailed logging (hoping it's the same instructions for the Synology Package) and do some playing around tonight and get back to you.
Thanks for reading and your resposnes so far.
Cheers
rgill90
Post Thu Apr 12, 2012 10:18 pm
ok - interesting what you say about profiles:
Here's the log sniipet when trying to play something which won't play:
2012-04-12 22:11:19,290 DEBUG [WebServer] Incoming connection from /192.168.0.4:47702
2012-04-12 22:11:19,291 DEBUG [ResourceTransportRequestHandler] HEAD /resource/670/MEDIA_ITEM/MATROSKA*0 HTTP/1.0, headers = [getcontentFeatures.dlna.org: 1,Host: 192.168.0.6:8895]]
2012-04-12 22:11:19,291 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.4
2012-04-12 22:11:19,293 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.0.4, Profile=Generic DLNA profile'
2012-04-12 22:11:19,294 DEBUG [ResourceTransportRequestHandler] Request for resource 670 and type 'MEDIA_ITEM' received
2012-04-12 22:11:19,294 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 670 (local)
2012-04-12 22:11:19,294 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 670)
2012-04-12 22:11:19,296 DEBUG [VideoDAOImpl] Reading a Video (id = 670)
2012-04-12 22:11:19,298 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 670, format MATROSKA and profile Generic DLNA profile
2012-04-12 22:11:19,298 DEBUG [ResourceTransportRequestHandler] Sending HEAD response back
2012-04-12 22:11:19,299 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/x-matroska,Content-Length: 8514207027,Date: Thu, 12 Apr 2012 22:11:19 GMT,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/0.6.2,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=MATROSKA;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2012-04-12 22:11:19,317 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target uuid:eb0c2788-b269-38b1-9f7a-7dd642f22200 from address /192.168.0.4:1025
2012-04-12 22:11:19,318 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.0.4:1025
2012-04-12 22:11:19,618 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target uuid:eb0c2788-b269-38b1-9f7a-7dd642f22200 from address /192.168.0.4:1025
2012-04-12 22:11:19,619 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.0.4:1025
2012-04-12 22:11:19,922 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target uuid:eb0c2788-b269-38b1-9f7a-7dd642f22200 from address /192.168.0.4:1025
2012-04-12 22:11:19,923 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.0.4:1025
2012-04-12 22:11:24,038 DEBUG [WebServer] Incoming connection from /192.168.0.4:54009
2012-04-12 22:11:24,040 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.0.4:
2012-04-12 22:11:24,040 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.4
2012-04-12 22:11:24,086 DEBUG [ContentDirectory] Browse() called for renderer Unrecognized device (profile 1) with parameters: objectID = V_M, browseFlag = BrowseDirectChildren, filter = *, startIndex = 0, count = 1, sortCriteria =
2012-04-12 22:11:24,086 DEBUG [LocalContentCacheDecorator] Found entry in the cache (local_default), returning it
2012-04-12 22:11:24,104 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-04-12 22:11:24,159 DEBUG [WebServer] Incoming connection from /192.168.0.4:56818
2012-04-12 22:11:24,160 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.0.4:
2012-04-12 22:11:24,160 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.4
2012-04-12 22:11:24,178 DEBUG [ContentDirectory] Browse() called for renderer Unrecognized device (profile 1) with parameters: objectID = V_M, browseFlag = BrowseDirectChildren, filter = @id,@parentID,@restricted,dc:title,upnp:class,res,dc:date,@childCount,sec:CaptionInfo,sec:CaptionInfoEx, sec:dcmInfo, sec:MetaFileInfo,res@resolution,res@size,upnp:genre,dc:date,upnp:album,res@duration,upnp:albumArtURI,res@bitrate,dc:creator, startIndex = 0, count = 30, sortCriteria =
2012-04-12 22:11:24,178 DEBUG [LocalContentCacheDecorator] Found entry in the cache (local_default), returning it
2012-04-12 22:11:24,291 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-04-12 22:11:25,126 DEBUG [WebServer] Incoming connection from /192.168.0.4:52248
2012-04-12 22:11:25,128 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.0.4:
2012-04-12 22:11:25,128 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.4
2012-04-12 22:11:25,145 DEBUG [ContentDirectory] Browse() called for renderer Unrecognized device (profile 1) with parameters: objectID = V_M, browseFlag = BrowseDirectChildren, filter = @id,@parentID,@restricted,dc:title,upnp:class,res,dc:date,@childCount,sec:CaptionInfo,sec:CaptionInfoEx, sec:dcmInfo, sec:MetaFileInfo,res@resolution,res@size,upnp:genre,dc:date,upnp:album,res@duration,upnp:albumArtURI,res@bitrate,dc:creator, startIndex = 30, count = 30, sortCriteria =
2012-04-12 22:11:25,146 DEBUG [LocalContentCacheDecorator] Found entry in the cache (local_default), returning it
2012-04-12 22:11:25,254 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-04-12 22:11:25,322 DEBUG [WebServer] Incoming connection from /192.168.0.4:56547
2012-04-12 22:11:25,323 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.0.4:
2012-04-12 22:11:25,323 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.4
2012-04-12 22:11:25,341 DEBUG [ContentDirectory] Browse() called for renderer Unrecognized device (profile 1) with parameters: objectID = V_M, browseFlag = BrowseDirectChildren, filter = @id,@parentID,@restricted,dc:title,upnp:class,res,dc:date,@childCount,sec:CaptionInfo,sec:CaptionInfoEx, sec:dcmInfo, sec:MetaFileInfo,res@resolution,res@size,upnp:genre,dc:date,upnp:album,res@duration,upnp:albumArtURI,res@bitrate,dc:creator, startIndex = 60, count = 30, sortCriteria =
2012-04-12 22:11:25,341 DEBUG [LocalContentCacheDecorator] Found entry in the cache (local_default), returning it
2012-04-12 22:11:25,459 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-04-12 22:11:25,526 DEBUG [WebServer] Incoming connection from /192.168.0.4:59675
2012-04-12 22:11:25,527 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.0.4:
2012-04-12 22:11:25,527 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.4
2012-04-12 22:11:25,546 DEBUG [ContentDirectory] Browse() called for renderer Unrecognized device (profile 1) with parameters: objectID = V_M, browseFlag = BrowseDirectChildren, filter = @id,@parentID,@restricted,dc:title,upnp:class,res,dc:date,@childCount,sec:CaptionInfo,sec:CaptionInfoEx, sec:dcmInfo, sec:MetaFileInfo,res@resolution,res@size,upnp:genre,dc:date,upnp:album,res@duration,upnp:albumArtURI,res@bitrate,dc:creator, startIndex = 90, count = 30, sortCriteria =
2012-04-12 22:11:25,547 DEBUG [LocalContentCacheDecorator] Found entry in the cache (local_default), returning it
2012-04-12 22:11:25,664 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-04-12 22:11:25,732 DEBUG [WebServer] Incoming connection from /192.168.0.4:38171
2012-04-12 22:11:25,733 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.0.4:
2012-04-12 22:11:25,733 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.4
2012-04-12 22:11:25,752 DEBUG [ContentDirectory] Browse() called for renderer Unrecognized device (profile 1) with parameters: objectID = V_M, browseFlag = BrowseDirectChildren, filter = *, startIndex = 0, count = 1, sortCriteria =
2012-04-12 22:11:25,753 DEBUG [LocalContentCacheDecorator] Found entry in the cache (local_default), returning it
2012-04-12 22:11:25,770 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-04-12 22:11:25,783 DEBUG [WebServer] Incoming connection from /192.168.0.4:43516
2012-04-12 22:11:25,784 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.0.4:
2012-04-12 22:11:25,784 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.4
2012-04-12 22:11:25,802 DEBUG [ContentDirectory] Browse() called for renderer Unrecognized device (profile 1) with parameters: objectID = V_M, browseFlag = BrowseDirectChildren, filter = @id,@parentID,@restricted,dc:title,upnp:class,res,dc:date,@childCount,sec:CaptionInfo,sec:CaptionInfoEx, sec:dcmInfo, sec:MetaFileInfo,res@resolution,res@size,upnp:genre,dc:date,upnp:album,res@duration,upnp:albumArtURI,res@bitrate,dc:creator, startIndex = 120, count = 30, sortCriteria =
2012-04-12 22:11:25,802 DEBUG [LocalContentCacheDecorator] Found entry in the cache (local_default), returning it
2012-04-12 22:11:25,920 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-04-12 22:11:25,988 DEBUG [WebServer] Incoming connection from /192.168.0.4:56918
2012-04-12 22:11:25,989 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.0.4:
2012-04-12 22:11:25,989 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.4
2012-04-12 22:11:26,014 DEBUG [ContentDirectory] Browse() called for renderer Unrecognized device (profile 1) with parameters: objectID = V_M, browseFlag = BrowseDirectChildren, filter = @id,@parentID,@restricted,dc:title,upnp:class,res,dc:date,@childCount,sec:CaptionInfo,sec:CaptionInfoEx, sec:dcmInfo, sec:MetaFileInfo,res@resolution,res@size,upnp:genre,dc:date,upnp:album,res@duration,upnp:albumArtURI,res@bitrate,dc:creator, startIndex = 150, count = 30, sortCriteria =
2012-04-12 22:11:26,014 DEBUG [LocalContentCacheDecorator] Found entry in the cache (local_default), returning it
2012-04-12 22:11:26,149 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
So, to me it looks like it's trying to play using the generc DLNA profile.
I've noticed I've got 2 recognised connections for the TV (please see attached screen shot)
I've tried deleting the non samsung one but it just keeps coming back, i've tried stopping / starting the server...any other ideas at all?
Screen shot 2012-04-12 at 23.16.08.png (125.66 KiB) Viewed 15305 times
Post Fri Apr 13, 2012 4:41 pm
that is weird, not sure if it's a bug in the UI or the server (the fact that you cannot delete it). Try to remove both .4 entries and retstart serviio.
rgill90
Post Fri Apr 13, 2012 6:54 pm
Yeah tried that - even if i delete all devices, stop the service then load the GUI back up again the devices all reappear.
I really think it's becuase I use DHCP and the Samsung telly now has the address another device (probably my macbook) had which i was using to test connectivity when i initially installed serviio.
I don't think its anything uninstalling and reinstalling the whole package won't cure but before i do that I might try to get the attention of patters, the chap who wrote the package, see if the there's anything i can hack to get shot of those devices.
patters
Post Fri Apr 13, 2012 10:19 pm
I've not seen that kind of behaviour on mine. However, I have set my devices to always get the same IP reservation on my broadband router (which I think is the general recommendation for Serviio). If it has somehow got corrupted (could be WebUI-related as Zip says) then I'd recommend you uninstall the package completely and start again.
If you still get problems, perhaps configure Serviio using the Serviio Remote Console from another computer so as to eliminate the WebUI from the equation.
rgill90
Post Sat Apr 14, 2012 9:52 am
Screen shot 2012-04-14 at 10.43.32.png (60.12 KiB) Viewed 15269 times
Hi
Just to tell you all its fixed. I've set my devices to get the same IP address from my router and uninstalled and reinstalled serviio on my NAS. I now still get 2 entries for the samsung telly (same ip addresses) but now when i change the one which defaulted to the generic profile to the samsung profile the change sticks and it doesn;t revert back to the generic profile like it kept doing before - i still can't delete one of them though. I'm seeing the same behaviour through the client itslef on the NAS and the web Client.
Anyway, I don;t really mind. Alls working really well - everything I've tried so far plays. Very happy with it - thanks for all your hardwork in making this a great little media server.
Post Sun Apr 15, 2012 12:21 am
rgill90 wrote:thanks for all your hardwork in making this a great little media server.
It's not so little any more now :-D
rgill90
Post Mon Apr 16, 2012 9:17 am
Ha! yes - to clarify - very big in terms of following / userbase, but my NAS will tell you it's little in terms of footprint on it's resources :D
Jimmy Cullen
Post Fri May 11, 2012 8:51 pm
Hey, great post and follow up with resolution. I've been suffering with the same problems for the past couple of months, but this has allowed me now to play .mkv format.
I wasn't aware that the profile was selectable from a drop down, or that the erroneous devices that appeared in the list could be deleted.
For the record I have a UE32D5000 with a fixed IP, which appeared twice in the list of devices, plus two other PCs (Ubuntu). I deleted the three incorrect devices and changed the profile of the TV and now I can play .mkv files. Serviio is running on a Xen VM (Debian Squeeze).
Once again cheers for the software and the solution!
Jimmy
