H264 Hi10p / 10-bit transcoding
blm14
Post Sun May 06, 2012 3:02 pm
Hey there! I did a search already and didn't find anything on this topic yet. Does Serviio support transcoding of H264 Hi10p files? I run XBMC on an ION box and with the current VDPAU profile Hi10p is not supported (which means that 1080p or 720p files in Hi10p stutter badly). I was hoping to use the power of my core i5 desktop to transcode these types of files to XBMC but I need to know if Serviio supports this. Thanks!
Post Sun May 06, 2012 3:12 pm
Re: H264 Hi10p / 10-bit transcoding
If there is no mention on the forum, then its probably that no one has had a problem/doesn't use them. If I was you I would simply try it, install serviio add the files and try to play them. Serviio will support transcoding from pretty much anything provided ffmpeg can read it.
If they don't work (it is quite likely that serviio won't try to transcode them) then http://wiki.serviio.org/doku.php?id=file_np and we can setup a working profile for them. You could also try the Direct TV profile that transcodes almost everything, although it is always nicer to transcode only the videos that really need it.
Edit, looking at a profile we can select to transcode based on the profile and level, so far I've only seen profile main and high, so would need zip to confirm if we could use 'high 10' in the profile field.
<Video targetContainer="mpegts" targetVCodec="mpeg2video" targetACodec="ac3" aBitrate="192">
   <Matches container="matroska" vCodec="h264" profile="high" levelGreaterThan="4.1" />
blm14
Post Sun May 06, 2012 3:29 pm
OK I have installed serviio and the problem that I see streaming from XBMC remains. Namely I am getting like 8FPS on a file which has 24FPS :-/
My desktop is a core i5-2400, 16GB ram, windows 7 64-bit, dual ATI radeon HD 5670 (crossfired).
Output of ffmpeg -i:
C:\Program Files\Serviio\lib>ffmpeg  -i "J:\Tiger & Bunny\[Zurako]_Tiger_&_Bunny
_01v2_(BD_1080p_FLAC)_[DB7E34FE].mkv"
nfig
  libavutil    51. 32. 0 / 51. 32. 0
  libavcodec   53. 42. 0 / 53. 42. 0
  libavformat  53. 24. 0 / 53. 24. 0
  libavfilter   2. 53. 0 /  2. 53. 0
Seems stream 0 codec frame rate differs from container frame rate: 47.95 (3692/7
7) -> 48.00 (48/1)
Input #0, matroska,webm, from 'J:\Tiger & Bunny\[Zurako]_Tiger_&_Bunny_01v2_(BD_
1080p_FLAC)_[DB7E34FE].mkv':
  Duration: 00:24:11.48, start: 0.000000, bitrate: 9567 kb/s
    Chapter #0.0: start 0.000000, end 50.175000
      title           : Introduction
    Chapter #0.1: start 50.175000, end 140.223000
      title           : Opening Theme
    Chapter #0.2: start 140.223000, end 624.415000
      title           : Part A
    Chapter #0.3: start 624.415000, end 1322.112000
      title           : Part B
    Chapter #0.4: start 1322.112000, end 1412.452000
      title           : Ending Theme
    Chapter #0.5: start 1412.452000, end 1435.517000
      title           : After Ending
    Chapter #0.6: start 1435.517000, end 1451.488000
      title           : Preview
    Stream #0:0(jpn): Video: h264 (High 10), yuv420p10le, 1920x1080 [SAR 1:1 DAR
 16:9], 23.97 fps, 48 tbr, 1k tbn, 47.95 tbc
      title           : Tiger & Bunny Episode 01
    Stream #0:1(jpn): Audio: flac, 48000 Hz, stereo, s32 (default)
      title           : FLAC 2.0 24-bit
    Stream #0:2(eng): Subtitle: ssa (default)
      title           : Dmonhiro
    Stream #0:3: Attachment: ttf
      filename        : ArnoPro-Regular.otf
      mimetype        : application/x-truetype-font
    Stream #0:4: Attachment: ttf
      filename        : Antipasto.ttf
    Stream #0:5: Attachment: ttf
      filename        : GeosansLight.ttf
    Stream #0:6: Attachment: ttf
      filename        : LT.ttf
    Stream #0:7: Attachment: ttf
      filename        : LT_3italic.ttf
Output from mediainfo:
Unique ID                                : 234871887686581177626294426787924541193 (0xB0B2AE1EE70822FA9D3521869EC1FF09)
Complete name                            : J:\Tiger & Bunny\[Zurako]_Tiger_&_Bunny_01v2_(BD_1080p_FLAC)_[DB7E34FE].mkv
File size                                : 1.62 GiB
Duration                                 : 24mn 11s
Overall bit rate                         : 9 567 Kbps
Encoded date                             : UTC 2012-01-15 14:27:52
Writing application                      : mkvmerge v3.4.0 ('Rapunzel') built on May 15 2010 09:38:20
Writing library                          : libebml v0.8.0 + libmatroska v0.9.0
Attachment                               : Yes / Yes / Yes / Yes / Yes
Format profile                           : High 10@L5.1
Format settings, ReFrames                : 16 frames
Duration                                 : 24mn 11s
Height                                   : 1 080 pixels
Bit depth                                : 10 bits
Title                                    : Tiger & Bunny Episode 01
Writing library                          : x264 core 120 r2120 0c7dab9
Encoding settings                        : cabac=1 / ref=16 / deblock=1:0:-1 / analyse=0x3:0x113 / me=umh / subme=10 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=6 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=8 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=crf / mbtree=1 / crf=16.5 / qcomp=0.60 / qpmin=0 / qpmax=81 / qpstep=4 / ip_ratio=1.40 / aq=1:1.10
Language                                 : Japanese
Format                                   : FLAC
Format/Info                              : Free Lossless Audio Codec
Codec ID                                 : A_FLAC
Duration                                 : 24mn 11s
Bit depth                                : 24 bits
Title                                    : FLAC 2.0 24-bit
Writing library                          : libFLAC 1.2.1 (UTC 2007-09-17)
Language                                 : Japanese
Text
Format                                   : ASS
Codec ID                                 : S_TEXT/ASS
Codec ID/Info                            : Advanced Sub Station Alpha
Compression mode                         : Lossless
Title                                    : Dmonhiro
Menu
00:00:00.000                             : Introduction
00:00:50.175                             : Opening Theme
00:02:20.223                             : Part A
00:10:24.415                             : Part B
00:22:02.112                             : Ending Theme
00:23:32.452                             : After Ending
00:23:55.517                             : Preview
I would really like to be able to transcode these 1080p and 720p H264 Hi10p files by taking advantage of the computing power of the machine upon which they reside, rather than asking my little Atom N330/ION box to do it... :)
Post Sun May 06, 2012 3:44 pm
Can you try the DirecTV HD-DVR profile (select it in the console).
was what I was expecting, If we can select the High 10 in the profile then we can only transcode what is needed. Otherwise, we might be able to get away with just using the level to filter out those files. Failing that, we can certainly get it to transcode all h264 content.
blm14
Post Sun May 06, 2012 6:54 pm
I'd be thrilled with only transcoding the hi10p stuff. :)
blm14
Post Sun May 06, 2012 7:20 pm
will wrote:Can you try the DirecTV HD-DVR profile (select it in the console).
Where is that setting?
EDIT: never mind - I found it. Yeah that totally worked. :) 1080p 10bit file playing cleanly and perfectly, with one exception. Subtitles not working LOL
blm14
Post Sun May 06, 2012 7:39 pm
reading up a little in the forums, it looks like I have to make a tradeoff - either MKV gets transcoded OR MKV doesn't get transcoded but embedded subtitles work.
Is there no way to transcode MKV but retain the embedded subs?
Post Sun May 06, 2012 11:35 pm
not at the moment.
blm14
Post Mon May 07, 2012 9:50 pm
Oh poo. is that something that I could contribute to? :)
Post Mon May 07, 2012 10:56 pm
blm14
Post Tue May 08, 2012 12:40 pm
ticket opened over a year ago. Responsible: nobody. Version: None. Priority: Major... :(
any ETA on that?
Post Tue May 08, 2012 4:05 pm
Sadly we are waiting on ffmpeg supporting this feature, once it does it will hopefully be intergrated into serviio pretty quickly.
I would love this as my player doesn't allow fastforwarding if I don't enable transcoding, but then I loose subtitles, i've had a look a few times for an intermediate solution, but I don't think there is one.
blm14
Post Thu May 10, 2012 2:59 am
It's shockingly hard to find exactly what google search on FFMPEG will describe exactly this use case. I'm trying to determine if there's already a ticket on FFMPEG's trac for this problem. Any ideas?
Post Thu May 10, 2012 7:14 am
So i've looked for ffmpeg burn in sub or ffmpeg hard code subtitles etc for embeding the subtitles into the video as text.
Post Thu May 10, 2012 7:58 pm
FFmpeg devs discuss it for example here: https://lists.ffmpeg.org/pipermail/ffmp ... 17059.html
I'm following their mailing list so should know once this becomes available
Users browsing this forum: Google [Bot] and 99 guests
