H264 Hi10p / 10-bit transcoding
• Page 1 of 1
Hey there! I did a search already and didn't find anything on this topic yet. Does Serviio support transcoding of H264 Hi10p files? I run XBMC on an ION box and with the current VDPAU profile Hi10p is not supported (which means that 1080p or 720p files in Hi10p stutter badly). I was hoping to use the power of my core i5 desktop to transcode these types of files to XBMC but I need to know if Serviio supports this. Thanks!
Re: H264 Hi10p / 10-bit transcoding
If there is no mention on the forum, then its probably that no one has had a problem/doesn't use them. If I was you I would simply try it, install serviio add the files and try to play them. Serviio will support transcoding from pretty much anything provided ffmpeg can read it.
If they don't work (it is quite likely that serviio won't try to transcode them) then http://wiki.serviio.org/doku.php?id=file_np and we can setup a working profile for them. You could also try the Direct TV profile that transcodes almost everything, although it is always nicer to transcode only the videos that really need it.
Edit, looking at a profile we can select to transcode based on the profile and level, so far I've only seen profile main and high, so would need zip to confirm if we could use 'high 10' in the profile field.
OK I have installed serviio and the problem that I see streaming from XBMC remains. Namely I am getting like 8FPS on a file which has 24FPS :-/
My desktop is a core i5-2400, 16GB ram, windows 7 64-bit, dual ATI radeon HD 5670 (crossfired).
Output of ffmpeg -i:
Output from mediainfo:
I would really like to be able to transcode these 1080p and 720p H264 Hi10p files by taking advantage of the computing power of the machine upon which they reside, rather than asking my little Atom N330/ION box to do it...
- Code:
C:\Program Files\Serviio\lib>ffmpeg -i "J:\Tiger & Bunny\[Zurako]_Tiger_&_Bunny
_01v2_(BD_1080p_FLAC)_[DB7E34FE].mkv"
nfig
libavutil 51. 32. 0 / 51. 32. 0
libavcodec 53. 42. 0 / 53. 42. 0
libavformat 53. 24. 0 / 53. 24. 0
libavdevice 53. 4. 0 / 53. 4. 0
libavfilter 2. 53. 0 / 2. 53. 0
libswscale 2. 1. 0 / 2. 1. 0
Seems stream 0 codec frame rate differs from container frame rate: 47.95 (3692/7
7) -> 48.00 (48/1)
Input #0, matroska,webm, from 'J:\Tiger & Bunny\[Zurako]_Tiger_&_Bunny_01v2_(BD_
1080p_FLAC)_[DB7E34FE].mkv':
Duration: 00:24:11.48, start: 0.000000, bitrate: 9567 kb/s
Chapter #0.0: start 0.000000, end 50.175000
title : Introduction
Chapter #0.1: start 50.175000, end 140.223000
title : Opening Theme
Chapter #0.2: start 140.223000, end 624.415000
title : Part A
Chapter #0.3: start 624.415000, end 1322.112000
title : Part B
Chapter #0.4: start 1322.112000, end 1412.452000
title : Ending Theme
Chapter #0.5: start 1412.452000, end 1435.517000
title : After Ending
Chapter #0.6: start 1435.517000, end 1451.488000
title : Preview
Stream #0:0(jpn): Video: h264 (High 10), yuv420p10le, 1920x1080 [SAR 1:1 DAR
16:9], 23.97 fps, 48 tbr, 1k tbn, 47.95 tbc
title : Tiger & Bunny Episode 01
Stream #0:1(jpn): Audio: flac, 48000 Hz, stereo, s32 (default)
title : FLAC 2.0 24-bit
Stream #0:2(eng): Subtitle: ssa (default)
title : Dmonhiro
Stream #0:3: Attachment: ttf
filename : ArnoPro-Regular.otf
mimetype : application/x-truetype-font
Stream #0:4: Attachment: ttf
filename : Antipasto.ttf
Stream #0:5: Attachment: ttf
filename : GeosansLight.ttf
Stream #0:6: Attachment: ttf
filename : LT.ttf
Stream #0:7: Attachment: ttf
filename : LT_3italic.ttf
- Code:
Unique ID : 234871887686581177626294426787924541193 (0xB0B2AE1EE70822FA9D3521869EC1FF09)
Complete name : J:\Tiger & Bunny\[Zurako]_Tiger_&_Bunny_01v2_(BD_1080p_FLAC)_[DB7E34FE].mkv
Format : Matroska
Format version : Version 2
File size : 1.62 GiB
Duration : 24mn 11s
Overall bit rate : 9 567 Kbps
Encoded date : UTC 2012-01-15 14:27:52
Writing application : mkvmerge v3.4.0 ('Rapunzel') built on May 15 2010 09:38:20
Writing library : libebml v0.8.0 + libmatroska v0.9.0
Attachment : Yes / Yes / Yes / Yes / Yes
Format : AVC
Format profile : High 10@L5.1
Format settings, CABAC : Yes
Format settings, ReFrames : 16 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 24mn 11s
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 10 bits
Scan type : Progressive
Title : Tiger & Bunny Episode 01
Writing library : x264 core 120 r2120 0c7dab9
Encoding settings : cabac=1 / ref=16 / deblock=1:0:-1 / analyse=0x3:0x113 / me=umh / subme=10 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=6 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=8 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=crf / mbtree=1 / crf=16.5 / qcomp=0.60 / qpmin=0 / qpmax=81 / qpstep=4 / ip_ratio=1.40 / aq=1:1.10
Language : Japanese
Default : No
Forced : No
Format : FLAC
Format/Info : Free Lossless Audio Codec
Codec ID : A_FLAC
Duration : 24mn 11s
Bit rate mode : Variable
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Bit depth : 24 bits
Title : FLAC 2.0 24-bit
Writing library : libFLAC 1.2.1 (UTC 2007-09-17)
Language : Japanese
Default : Yes
Forced : No
Text
Format : ASS
Codec ID : S_TEXT/ASS
Codec ID/Info : Advanced Sub Station Alpha
Compression mode : Lossless
Title : Dmonhiro
Language : English
Default : Yes
Forced : No
Menu
00:00:00.000 : Introduction
00:00:50.175 : Opening Theme
00:02:20.223 : Part A
00:10:24.415 : Part B
00:22:02.112 : Ending Theme
00:23:32.452 : After Ending
00:23:55.517 : Preview
Can you try the DirecTV HD-DVR profile (select it in the console).
was what I was expecting, If we can select the High 10 in the profile then we can only transcode what is needed. Otherwise, we might be able to get away with just using the level to filter out those files. Failing that, we can certainly get it to transcode all h264 content.
I'd be thrilled with only transcoding the hi10p stuff.
will wrote:Can you try the DirecTV HD-DVR profile (select it in the console).
Where is that setting?
EDIT: never mind - I found it. Yeah that totally worked.
reading up a little in the forums, it looks like I have to make a tradeoff - either MKV gets transcoded OR MKV doesn't get transcoded but embedded subtitles work.
Is there no way to transcode MKV but retain the embedded subs?
not at the moment.
Petr
Help translate Serviio
Oh poo. is that something that I could contribute to?
Waiting for ffmpeg https://bitbucket.org/xnejp03/serviio/i ... -subtitles
Petr
ticket opened over a year ago. Responsible: nobody. Version: None. Priority: Major...
any ETA on that?
any ETA on that?
Sadly we are waiting on ffmpeg supporting this feature, once it does it will hopefully be intergrated into serviio pretty quickly.
I would love this as my player doesn't allow fastforwarding if I don't enable transcoding, but then I loose subtitles, i've had a look a few times for an intermediate solution, but I don't think there is one.
It's shockingly hard to find exactly what google search on FFMPEG will describe exactly this use case. I'm trying to determine if there's already a ticket on FFMPEG's trac for this problem. Any ideas?
So i've looked for ffmpeg burn in sub or ffmpeg hard code subtitles etc for embeding the subtitles into the video as text.
FFmpeg devs discuss it for example here: https://lists.ffmpeg.org/pipermail/ffmp ... 17059.html
I'm following their mailing list so should know once this becomes available
Petr
• Page 1 of 1
Users browsing this forum: Google [Bot] and 102 guests
