Samsung E series Blu-Ray Player
I am happily using Serviio to stream to our bedroom smart Sony Bravia TV and want to avoid using the Samsung streaming software.
Can you confirm that Serviio and the new E series are compataible.
Unique ID : 225441811388252739408119676473534068483 (0xA99A8376809F08078B8B6A3FA8383703)
Complete name : E:\My Downloads\Accel World\[UTW]_Accel_World_-_01_[h264-720p][F574698F].mkv
Format : Matroska
Format version : Version 2
File size : 527 MiB
Duration : 23mn 40s
Overall bit rate : 3 114 Kbps
Movie name : Accel World - 01: Acceleration
Encoded date : UTC 2012-04-07 05:45:48
Writing application : mkvmerge v5.0.1 ('Es ist Sommer') built on Oct 9 2011 11:55:43
Writing library : libebml v1.2.2 + libmatroska v1.3.0
Attachment : Yes / Yes / Yes / Yes / Yes / Yes / Yes / Yes
Format : AVC
Format profile : High 10@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 8 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 23mn 40s
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 10 bits
Scan type : Progressive
Title : H.264 720p HDTV
Writing library : x264 core 120 r2164+656 2ff844c
Encoding settings : cabac=1 / ref=9 / deblock=1:-1:-1 / analyse=0x3:0x133 / me=umh / subme=10 / psy=1 / fade_compensate=1.00 / psy_rd=0.65:0.10 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-3 / threads=6 / sliced_threads=0 / nr=0 / decimate=0 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / fgo=0 / bframes=7 / b_pyramid=1 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=120 / rc=crf / mbtree=1 / crf=17.0 / qcomp=0.80 / qpmin=0 / qpmax=81 / qpstep=4 / ip_ratio=1.32 / aq=1:0.90
Language : Japanese
Default : Yes
Forced : No
Color primaries : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
Transfer characteristics : BT.709-5, BT.1361
Matrix coefficients : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
Format : AAC
Format profile : LC
Codec ID : A_AAC
Duration : 23mn 40s
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Compression mode : Lossy
Title : AAC 2.0 192Kbps
Language : Japanese
Default : Yes
Forced : No
Text
Format : ASS
Codec ID : S_TEXT/ASS
Codec ID/Info : Advanced Sub Station Alpha
Compression mode : Lossless
Title : Styled Subtitles
Language : English
Default : Yes
Forced : No
Menu
00:00:00.000 : en:Part A
00:07:58.019 : en:Part B
00:21:59.944 : en:Ending
00:23:29.991 : en:Previewzip wrote:did you select the C/D profile?
zip wrote:Just noticed that the MKV MediaInfo you posted is High-10 profile, which is probably the problem. ATM Serviio doesn't recognize this profile and thus cannot trigger transcoding just for that.
will wrote:Zip added the fix last night so it will be include in 1.0 which is being beta tested at the moment. I guess the eta is around about a month +/- a few weeks.
