"File not supported" LN52A750 Problem--Help!!!
bbking67
Post Mon Jun 18, 2012 12:37 am
I am trying to get Serviio working with a Samsung LN52A750 (I'm a Serviio Noob). I can't play any videos at all--most are xvid with mp3 or ac3 audio. Almost all of the files play perfectly using the Samsung PC Share software, however I'd like to be able to play other formats including those with ac3 audio.
At this point I can see the media, but nothing plays using serviio, I get an error that the format is not supported. I have set the type to samsung A series, but no luck.
Any ideas? There don't seem to be many folks in the forum with older Samsungs, though there is a post with someone using v0.4 successfully... should I try that? Or is there something more elemental that I am missing?
Post Mon Jun 18, 2012 4:45 pm
Re: "File not supported" LN52A750 Problem--Help!!!
Did you select Samsung A series as your profile?
bbking67
Post Tue Jun 19, 2012 12:31 pm
Yes I have set it to samsung A Series, but not one media file will play!
Post Tue Jun 19, 2012 5:39 pm
can you post detailed log when you're playing the file?
bbking67
Post Fri Jun 22, 2012 1:40 pm
Yes, but it's not my TV so when I go back to my father's I'll get the logs.
bbking67
Post Thu Aug 02, 2012 10:40 pm
which log would have what you need? I see a serviio.log and a derby.log in the program directory...
Post Thu Aug 02, 2012 11:02 pm
you have to turn on detailed log, then play the file and then post serviio.log
bbking67
Post Thu Aug 02, 2012 11:49 pm
Here is the log...
2012-08-02 18:21:35,603 INFO  [MediaServer] ------------------------------------------------------------------------
2012-08-02 18:21:35,603 INFO  [MediaServer] Serviio DLNA media streaming server v 1.0 (rev. 34c915f37185+)
2012-08-02 18:21:35,603 INFO  [MediaServer] Petr Nejedly 2009-2012
2012-08-02 18:21:35,603 INFO  [MediaServer] http://www.serviio.org
2012-08-02 18:21:35,603 INFO  [MediaServer] Java 1.6.0_33-Sun Microsystems Inc.
2012-08-02 18:21:35,603 INFO  [MediaServer] OS Windows 7 x86 6.1
2012-08-02 18:21:35,603 INFO  [MediaServer] File encoding: windows-1252
2012-08-02 18:21:35,603 INFO  [MediaServer] Headless mode enabled: true
2012-08-02 18:21:35,603 INFO  [MediaServer] User home dir: C:\
2012-08-02 18:21:35,603 INFO  [MediaServer] Temp dir: C:\Windows\TEMP\
2012-08-02 18:21:35,868 INFO  [WebServer] Socket buffer set to 65535 bytes
2012-08-02 18:21:35,884 INFO  [RestletServer] Starting Restlet server (/rest) exposed on port 23423
2012-08-02 18:21:35,931 INFO  [RestletServer] Starting Restlet server (/cds) exposed on port 23424
2012-08-02 18:21:35,931 INFO  [RestletServer] Starting Restlet server (/mediabrowser) exposed on port 23424
2012-08-02 18:21:35,977 INFO  [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2012-08-02 18:21:52,638 INFO  [ServiioConsole] Starting Serviio Console
2012-08-02 18:21:53,059 INFO  [ServiioConsole] Connecting to Serviio REST on localhost:23423
2012-08-02 18:21:57,287 INFO  [DBSchemaUpdateExecutor] Updating DB schema
2012-08-02 18:22:23,836 INFO  [MediaServer] ------------------------------------------------------------------------
2012-08-02 18:22:23,836 INFO  [MediaServer] License: PRO (EVALUATION, id: 11111111-1111-1111-1111-111111111113)
2012-08-02 18:22:24,584 INFO  [ProfilesDefinitionParser] Parsing Profiles definition
2012-08-02 18:22:25,489 INFO  [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2012-08-02 18:22:26,176 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2012-08-02 18:22:26,503 INFO  [ProfilesDefinitionParser] Added profile 'Xbox 360' (id=3)
2012-08-02 18:22:27,049 INFO  [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2012-08-02 18:22:27,548 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2012-08-02 18:22:27,736 INFO  [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2012-08-02 18:22:28,500 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D/E-series)' (id=7)
2012-08-02 18:22:28,547 INFO  [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2012-08-02 18:22:29,514 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012)' (id=sony2012)
2012-08-02 18:22:30,871 INFO  [ProfilesDefinitionParser] Added profile 'Sony BD Player / SMP' (id=10)
2012-08-02 18:22:31,386 INFO  [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2012-08-02 18:22:31,729 INFO  [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2012-08-02 18:22:31,792 INFO  [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2012-08-02 18:22:32,010 INFO  [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2012-08-02 18:22:32,104 INFO  [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2012-08-02 18:22:32,525 INFO  [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2012-08-02 18:22:32,603 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011)' (id=sony2011)
2012-08-02 18:22:33,024 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2010)' (id=sony2010)
2012-08-02 18:22:33,492 INFO  [ProfilesDefinitionParser] Added profile 'Philips' (id=20)
2012-08-02 18:22:33,695 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2009)' (id=sony2009)
2012-08-02 18:22:33,788 INFO  [ProfilesDefinitionParser] Added profile 'Denon AVR' (id=22)
2012-08-02 18:22:34,646 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera E/G/GT/DT/UT (2011/2012)' (id=viera2011a)
2012-08-02 18:22:34,771 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera S/ST/VT (2011)' (id=viera2011)
2012-08-02 18:22:34,896 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera (2010)' (id=viera2010)
2012-08-02 18:22:34,912 INFO  [ProfilesDefinitionParser] Parsing Profiles definition
2012-08-02 18:22:35,458 INFO  [ProfilesDefinitionParser] Added profile 'Flash player' (id=flv_player)
2012-08-02 18:22:35,770 INFO  [ProfilesDefinitionParser] Added profile 'ServiiGo' (id=serviigo)
2012-08-02 18:22:36,331 INFO  [Device] Created UPnP Device with UUID: 50339d3c-c744-3be9-9a24-dbb8871e1f05, bound address: 192.168.0.101
2012-08-02 18:22:36,362 INFO  [PluginCompilerThread] Looking for plugins at C:\Program Files\Serviio\bin\..\plugins
2012-08-02 18:22:36,378 INFO  [PluginCompilerThread] Started looking for plugins
2012-08-02 18:22:36,394 INFO  [UpdateChecker] Checking if a new version is available
2012-08-02 18:22:36,581 INFO  [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2012-08-02 18:22:36,659 INFO  [WebServer] WebServer starting on port 8895
2012-08-02 18:22:36,674 INFO  [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2012-08-02 18:22:36,674 INFO  [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2012-08-02 18:22:36,674 INFO  [EventDispatcher] Starting EventDispatcher
2012-08-02 18:22:36,690 INFO  [RendererExpirationChecker] Starting RendererExpirationChecker
2012-08-02 18:22:36,690 INFO  [RendererSearchSender] Searching for Renderer devices
2012-08-02 18:22:36,739 INFO  [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth4 (Intel(R) PRO/1000 PL Network Connection) and address 192.168.0.101, timeout = 0
2012-08-02 18:22:37,934 INFO  [RendererManager] Stored a new renderer: uuid='d3a36ffe-97a6-4db6-880f-3ba41a05da83', name = 'Unrecognized device', ipAddress='192.168.0.100', profile = '1'
2012-08-02 18:22:43,503 INFO  [Messages] Loaded console message bundle for locale: en
2012-08-02 18:22:46,889 INFO  [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2012-08-02 18:22:47,778 INFO  [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: en
2012-08-02 18:23:00,461 INFO  [WebServer] WebServer shutting down
2012-08-02 18:23:00,461 INFO  [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2012-08-02 18:23:00,461 INFO  [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2012-08-02 18:23:00,476 INFO  [EventDispatcher] Leaving EventDispatcher
2012-08-02 18:23:00,476 INFO  [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2012-08-02 18:23:00,866 INFO  [WebServer] WebServer starting on port 8895
2012-08-02 18:23:00,866 INFO  [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2012-08-02 18:23:00,866 INFO  [RendererSearchSender] Searching for Renderer devices
2012-08-02 18:23:00,866 INFO  [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2012-08-02 18:23:00,866 INFO  [EventDispatcher] Starting EventDispatcher
2012-08-02 18:23:00,945 INFO  [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth4 (Intel(R) PRO/1000 PL Network Connection) and address 192.168.0.101, timeout = 0
2012-08-02 18:23:01,725 INFO  [RendererExpirationChecker] Leaving RendererExpirationChecker
2012-08-02 18:23:03,223 INFO  [FeedUpdaterThread] Started looking for information about online resources
2012-08-02 18:23:03,223 INFO  [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-08-02 18:23:03,223 INFO  [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2012-08-02 18:23:03,223 INFO  [PlaylistMaintainerThread] Started looking playlist changes
2012-08-02 18:23:15,173 INFO  [LibraryAdditionsCheckerThread] Finished looking for newly added files
2012-08-02 18:23:15,282 INFO  [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2012-08-02 18:23:15,391 INFO  [PlaylistMaintainerThread] Finished looking for playlist changes
2012-08-02 18:23:15,516 INFO  [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-08-02 18:23:15,516 INFO  [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2012-08-02 18:23:15,516 INFO  [PlaylistMaintainerThread] Started looking playlist changes
2012-08-02 18:23:26,530 INFO  [LibraryAdditionsCheckerThread] Finished looking for newly added files
2012-08-02 18:23:26,640 INFO  [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2012-08-02 18:23:26,749 INFO  [PlaylistMaintainerThread] Finished looking for playlist changes
2012-08-02 18:23:26,874 INFO  [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2012-08-02 18:23:26,889 INFO  [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-08-02 18:23:26,889 INFO  [PlaylistMaintainerThread] Started looking playlist changes
2012-08-02 18:23:31,646 WARN  [LibraryAdditionsCheckerThread] An error occured while scanning for item to be added, will continue
org.serviio.db.dao.PersistenceException: Cannot mark Repository with id 1 as scanned
   at org.serviio.library.dao.RepositoryDAOImpl.markRepositoryAsScanned(RepositoryDAOImpl.java:173)
   at org.serviio.library.local.service.RepositoryService.markRepositoryAsScanned(RepositoryService.java:112)
   at org.serviio.library.local.metadata.LibraryAdditionsCheckerThread.run(LibraryAdditionsCheckerThread.java:84)
Caused by: java.sql.SQLNonTransientConnectionException: Connection closed by unknown interrupt.
   at org.apache.derby.impl.jdbc.EmbedStatement.executeStatement(Unknown Source)
   at org.apache.derby.impl.jdbc.EmbedPreparedStatement.executeStatement(Unknown Source)
   at org.apache.derby.impl.jdbc.EmbedPreparedStatement.executeUpdate(Unknown Source)
   at org.serviio.library.dao.RepositoryDAOImpl.markRepositoryAsScanned(RepositoryDAOImpl.java:171)
   ... 2 more
Caused by: java.sql.SQLException: Connection closed by unknown interrupt.
   ... 12 more
Caused by: ERROR 08000: Connection closed by unknown interrupt.
   at org.apache.derby.iapi.util.InterruptStatus.setInterrupted(Unknown Source)
   at org.apache.derby.iapi.util.InterruptStatus.throwIf(Unknown Source)
   at org.apache.derby.impl.sql.execute.BasicNoPutResultSetImpl.checkCancellationFlag(Unknown Source)
   at org.apache.derby.impl.sql.execute.TableScanResultSet.getNextRowCore(Unknown Source)
   at org.apache.derby.impl.sql.execute.IndexRowToBaseRowResultSet.getNextRowCore(Unknown Source)
   at org.apache.derby.impl.sql.execute.ProjectRestrictResultSet.getNextRowCore(Unknown Source)
   at org.apache.derby.impl.sql.execute.NormalizeResultSet.getNextRowCore(Unknown Source)
   at org.apache.derby.impl.sql.execute.DMLWriteResultSet.getNextRowCore(Unknown Source)
   at org.apache.derby.impl.sql.execute.UpdateResultSet.collectAffectedRows(Unknown Source)
   at org.apache.derby.impl.sql.execute.UpdateResultSet.open(Unknown Source)
   at org.apache.derby.impl.sql.GenericPreparedStatement.executeStmt(Unknown Source)
   at org.apache.derby.impl.sql.GenericPreparedStatement.execute(Unknown Source)
   ... 6 more
2012-08-02 18:23:31,651 INFO  [LibraryAdditionsCheckerThread] Finished looking for newly added files
2012-08-02 18:23:31,744 INFO  [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2012-08-02 18:23:31,847 INFO  [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-08-02 18:23:31,847 INFO  [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2012-08-02 18:23:35,056 INFO  [LibraryAdditionsCheckerThread] Added file 'Dark_Skies_-_1x01_-_The_Awakening_(Part_1_&_2).avi' (title: The Awakening (1)) to Library
2012-08-02 18:23:38,310 INFO  [LibraryAdditionsCheckerThread] Added file 'Dark_Skies_-_1x03_-_Moving_Targets.avi' (title: Moving Targets) to Library
2012-08-02 18:23:41,693 INFO  [LibraryAdditionsCheckerThread] Added file 'Dark_Skies_-_1x04_-_Mercury_Rising.avi' (title: Mercury Rising) to Library
2012-08-02 18:23:43,547 INFO  [LibraryAdditionsCheckerThread] Added file 'Dark_Skies_-_1x05_-_Dark_Days_Night.avi' (title: Dark Days Night) to Library
2012-08-02 18:23:45,253 INFO  [LibraryAdditionsCheckerThread] Added file 'Dark_Skies_-_1x06_-_Dreamland.avi' (title: Dreamland) to Library
2012-08-02 18:23:48,753 INFO  [LibraryAdditionsCheckerThread] Added file 'Dark_Skies_-_1x07_-_Inhuman_Nature.avi' (title: Inhuman Nature) to Library
2012-08-02 18:23:53,055 INFO  [LibraryAdditionsCheckerThread] Added file 'Dark_Skies_-_1x08_-_Ancient_Future.avi' (title: Ancient Future) to Library
2012-08-02 18:23:58,834 INFO  [LibraryAdditionsCheckerThread] Added file 'Dark_Skies_-_1x09_-_Hostile_Convergence.avi' (title: Hostile Convergence) to Library
2012-08-02 18:24:01,965 INFO  [LibraryAdditionsCheckerThread] Added file 'Dark_Skies_-_1x10_-_We_Shall_Overcome.avi' (title: We Shall Overcome) to Library
2012-08-02 18:24:04,090 INFO  [LibraryAdditionsCheckerThread] Added file 'Dark_Skies_-_1x11_-_The_Last_Wave.avi' (title: The Last Wave) to Library
2012-08-02 18:24:07,251 INFO  [LibraryAdditionsCheckerThread] Added file 'Dark_Skies_-_1x12_-_The_Enemy_Within.avi' (title: The Enemy Within) to Library
2012-08-02 18:24:10,367 INFO  [LibraryAdditionsCheckerThread] Added file 'Dark_Skies_-_1x13_-_The_Warren_Omission.avi' (title: The Warren Omission) to Library
2012-08-02 18:24:11,805 INFO  [LibraryAdditionsCheckerThread] Added file 'Dark_Skies_-_1x14_-_White_Rabbit.avi' (title: White Rabbit) to Library
2012-08-02 18:24:14,741 INFO  [LibraryAdditionsCheckerThread] Added file 'Dark_Skies_-_1x15_-_Shades_Of_Gray.avi' (title: Shades of Gray) to Library
2012-08-02 18:24:21,079 INFO  [LibraryAdditionsCheckerThread] Added file 'Dark_Skies_-_1x16_-_Burn,_Baby,_Burn.avi' (title: Burn, Baby, Burn) to Library
2012-08-02 18:24:23,876 INFO  [LibraryAdditionsCheckerThread] Added file 'Dark_Skies_-_1x17_-_Both_Sides_Now.avi' (title: Both Sides Now) to Library
2012-08-02 18:24:25,502 INFO  [LibraryAdditionsCheckerThread] Added file 'Dark_Skies_-_1x18_-_To_Prey_In_Darkness.avi' (title: To Prey in Darkness) to Library
2012-08-02 18:24:27,058 INFO  [LibraryAdditionsCheckerThread] Added file 'Dark_Skies_-_1x19_-_Strangers_In_The_Night.avi' (title: Strangers in the Night) to Library
2012-08-02 18:24:29,212 INFO  [LibraryAdditionsCheckerThread] Added file 'Dark_Skies_-_1x20_-_Bloodlines.avi' (title: Bloodlines) to Library
2012-08-02 18:24:30,195 WARN  [OnlineVideoSourcesMetadataExtractor] Online metadata search returned no results for file Eagles - Melbourne cd1.avi [VideoDescription [type=FILM, names=[eagles melbourne cd1, null], year=null, season=null, episode=null]]
2012-08-02 18:24:30,256 INFO  [LibraryAdditionsCheckerThread] Added file 'Eagles - Melbourne cd1.avi' (title: Eagles - Melbourne cd1) to Library
2012-08-02 18:24:31,021 WARN  [OnlineVideoSourcesMetadataExtractor] Online metadata search returned no results for file Eagles - Melbourne cd2.avi [VideoDescription [type=FILM, names=[eagles melbourne cd2, null], year=null, season=null, episode=null]]
2012-08-02 18:24:31,091 INFO  [LibraryAdditionsCheckerThread] Added file 'Eagles - Melbourne cd2.avi' (title: Eagles - Melbourne cd2) to Library
2012-08-02 18:24:32,554 WARN  [OnlineVideoSourcesMetadataExtractor] Online metadata search returned no results for file The Winds of War I - The Winds Rise.avi [VideoDescription [type=FILM, names=[the winds of war i the winds rise, null], year=null, season=null, episode=null]]
2012-08-02 18:24:32,604 INFO  [LibraryAdditionsCheckerThread] Added file 'The Winds of War I - The Winds Rise.avi' (title: The Winds of War I - The Winds Rise) to Library
2012-08-02 18:28:09,970 INFO  [RendererManager] Stored a new renderer: uuid='0867a462-a9f5-434f-97c0-749ab94e62b1', name = 'Unrecognized device', ipAddress='192.168.0.101', profile = '1'
2012-08-02 18:31:01,284 INFO  [LibraryAdditionsCheckerThread] Finished looking for newly added files
2012-08-02 18:31:01,384 INFO  [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2012-08-02 18:31:01,484 INFO  [PlaylistMaintainerThread] Finished looking for playlist changes
2012-08-02 18:31:01,600 INFO  [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-08-02 18:31:01,601 INFO  [PlaylistMaintainerThread] Started looking playlist changes
2012-08-02 18:31:01,600 INFO  [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2012-08-02 18:31:02,764 INFO  [LibraryUpdatesCheckerThread] Updated 'Ancient Future' (C:\Movie Share\Dark Skies - SciFi Tv Series\Series1\Dark_Skies_-_1x08_-_Ancient_Future.avi) in Library
2012-08-02 18:31:03,493 INFO  [LibraryUpdatesCheckerThread] Updated 'Hostile Convergence' (C:\Movie Share\Dark Skies - SciFi Tv Series\Series1\Dark_Skies_-_1x09_-_Hostile_Convergence.avi) in Library
2012-08-02 18:31:04,163 INFO  [LibraryUpdatesCheckerThread] Updated 'We Shall Overcome' (C:\Movie Share\Dark Skies - SciFi Tv Series\Series1\Dark_Skies_-_1x10_-_We_Shall_Overcome.avi) in Library
2012-08-02 18:31:05,157 INFO  [LibraryUpdatesCheckerThread] Updated 'The Last Wave' (C:\Movie Share\Dark Skies - SciFi Tv Series\Series1\Dark_Skies_-_1x11_-_The_Last_Wave.avi) in Library
2012-08-02 18:31:06,271 INFO  [LibraryUpdatesCheckerThread] Updated 'The Enemy Within' (C:\Movie Share\Dark Skies - SciFi Tv Series\Series1\Dark_Skies_-_1x12_-_The_Enemy_Within.avi) in Library
2012-08-02 18:31:07,238 INFO  [LibraryUpdatesCheckerThread] Updated 'The Warren Omission' (C:\Movie Share\Dark Skies - SciFi Tv Series\Series1\Dark_Skies_-_1x13_-_The_Warren_Omission.avi) in Library
2012-08-02 18:31:08,025 INFO  [LibraryUpdatesCheckerThread] Updated 'White Rabbit' (C:\Movie Share\Dark Skies - SciFi Tv Series\Series1\Dark_Skies_-_1x14_-_White_Rabbit.avi) in Library
2012-08-02 18:31:08,946 INFO  [LibraryUpdatesCheckerThread] Updated 'The Awakening (1)' (C:\Movie Share\Dark Skies - SciFi Tv Series\Series1\Dark_Skies_-_1x01_-_The_Awakening_(Part_1_&_2).avi) in Library
2012-08-02 18:31:09,686 INFO  [LibraryUpdatesCheckerThread] Updated 'Moving Targets' (C:\Movie Share\Dark Skies - SciFi Tv Series\Series1\Dark_Skies_-_1x03_-_Moving_Targets.avi) in Library
2012-08-02 18:31:10,493 INFO  [LibraryUpdatesCheckerThread] Updated 'Mercury Rising' (C:\Movie Share\Dark Skies - SciFi Tv Series\Series1\Dark_Skies_-_1x04_-_Mercury_Rising.avi) in Library
2012-08-02 18:31:11,589 INFO  [LibraryUpdatesCheckerThread] Updated 'Dark Days Night' (C:\Movie Share\Dark Skies - SciFi Tv Series\Series1\Dark_Skies_-_1x05_-_Dark_Days_Night.avi) in Library
2012-08-02 18:31:12,249 INFO  [LibraryUpdatesCheckerThread] Updated 'Dreamland' (C:\Movie Share\Dark Skies - SciFi Tv Series\Series1\Dark_Skies_-_1x06_-_Dreamland.avi) in Library
2012-08-02 18:31:13,060 INFO  [LibraryUpdatesCheckerThread] Updated 'Inhuman Nature' (C:\Movie Share\Dark Skies - SciFi Tv Series\Series1\Dark_Skies_-_1x07_-_Inhuman_Nature.avi) in Library
2012-08-02 18:31:14,223 INFO  [LibraryUpdatesCheckerThread] Updated 'Shades of Gray' (C:\Movie Share\Dark Skies - SciFi Tv Series\Series1\Dark_Skies_-_1x15_-_Shades_Of_Gray.avi) in Library
2012-08-02 18:31:14,849 INFO  [LibraryUpdatesCheckerThread] Updated 'Burn, Baby, Burn' (C:\Movie Share\Dark Skies - SciFi Tv Series\Series1\Dark_Skies_-_1x16_-_Burn,_Baby,_Burn.avi) in Library
2012-08-02 18:31:16,119 INFO  [LibraryUpdatesCheckerThread] Updated 'Both Sides Now' (C:\Movie Share\Dark Skies - SciFi Tv Series\Series1\Dark_Skies_-_1x17_-_Both_Sides_Now.avi) in Library
2012-08-02 18:31:16,811 INFO  [LibraryUpdatesCheckerThread] Updated 'To Prey in Darkness' (C:\Movie Share\Dark Skies - SciFi Tv Series\Series1\Dark_Skies_-_1x18_-_To_Prey_In_Darkness.avi) in Library
2012-08-02 18:31:17,614 INFO  [LibraryUpdatesCheckerThread] Updated 'Strangers in the Night' (C:\Movie Share\Dark Skies - SciFi Tv Series\Series1\Dark_Skies_-_1x19_-_Strangers_In_The_Night.avi) in Library
2012-08-02 18:31:18,627 INFO  [LibraryUpdatesCheckerThread] Updated 'Bloodlines' (C:\Movie Share\Dark Skies - SciFi Tv Series\Series1\Dark_Skies_-_1x20_-_Bloodlines.avi) in Library
2012-08-02 18:31:18,939 WARN  [OnlineVideoSourcesMetadataExtractor] Online metadata search returned no results for file Eagles - Melbourne cd1.avi [VideoDescription [type=FILM, names=[eagles melbourne cd1, null], year=null, season=null, episode=null]]
2012-08-02 18:31:18,949 INFO  [LibraryUpdatesCheckerThread] Updated 'Eagles - Melbourne cd1' (C:\Movie Share\Eagles - Melbourne cd1.avi) in Library
2012-08-02 18:31:19,277 WARN  [OnlineVideoSourcesMetadataExtractor] Online metadata search returned no results for file Eagles - Melbourne cd2.avi [VideoDescription [type=FILM, names=[eagles melbourne cd2, null], year=null, season=null, episode=null]]
2012-08-02 18:31:19,288 INFO  [LibraryUpdatesCheckerThread] Updated 'Eagles - Melbourne cd2' (C:\Movie Share\Eagles - Melbourne cd2.avi) in Library
2012-08-02 18:31:19,783 WARN  [OnlineVideoSourcesMetadataExtractor] Online metadata search returned no results for file The Winds of War I - The Winds Rise.avi [VideoDescription [type=FILM, names=[the winds of war i the winds rise, null], year=null, season=null, episode=null]]
2012-08-02 18:31:19,790 INFO  [LibraryUpdatesCheckerThread] Updated 'The Winds of War I - The Winds Rise' (C:\Movie Share\The Winds of War I - The Winds Rise.avi) in Library
2012-08-02 18:31:19,940 INFO  [LibraryAdditionsCheckerThread] Finished looking for newly added files
2012-08-02 18:31:20,040 INFO  [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2012-08-02 18:31:20,140 INFO  [PlaylistMaintainerThread] Finished looking for playlist changes
2012-08-02 18:31:20,273 INFO  [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-08-02 18:31:20,286 INFO  [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2012-08-02 18:31:20,307 INFO  [PlaylistMaintainerThread] Started looking playlist changes
2012-08-02 18:31:20,661 INFO  [LibraryUpdatesCheckerThread] Updated 'Ancient Future' (C:\Movie Share\Dark Skies - SciFi Tv Series\Series1\Dark_Skies_-_1x08_-_Ancient_Future.avi) in Library
2012-08-02 18:31:20,952 INFO  [LibraryUpdatesCheckerThread] Updated 'Hostile Convergence' (C:\Movie Share\Dark Skies - SciFi Tv Series\Series1\Dark_Skies_-_1x09_-_Hostile_Convergence.avi) in Library
2012-08-02 18:31:21,215 INFO  [LibraryUpdatesCheckerThread] Updated 'We Shall Overcome' (C:\Movie Share\Dark Skies - SciFi Tv Series\Series1\Dark_Skies_-_1x10_-_We_Shall_Overcome.avi) in Library
2012-08-02 18:31:21,475 INFO  [LibraryUpdatesCheckerThread] Updated 'The Last Wave' (C:\Movie Share\Dark Skies - SciFi Tv Series\Series1\Dark_Skies_-_1x11_-_The_Last_Wave.avi) in Library
2012-08-02 18:31:21,733 INFO  [LibraryUpdatesCheckerThread] Updated 'The Enemy Within' (C:\Movie Share\Dark Skies - SciFi Tv Series\Series1\Dark_Skies_-_1x12_-_The_Enemy_Within.avi) in Library
2012-08-02 18:31:21,986 INFO  [LibraryUpdatesCheckerThread] Updated 'The Warren Omission' (C:\Movie Share\Dark Skies - SciFi Tv Series\Series1\Dark_Skies_-_1x13_-_The_Warren_Omission.avi) in Library
2012-08-02 18:31:22,245 INFO  [LibraryUpdatesCheckerThread] Updated 'White Rabbit' (C:\Movie Share\Dark Skies - SciFi Tv Series\Series1\Dark_Skies_-_1x14_-_White_Rabbit.avi) in Library
2012-08-02 18:31:22,798 INFO  [LibraryUpdatesCheckerThread] Updated 'The Awakening (1)' (C:\Movie Share\Dark Skies - SciFi Tv Series\Series1\Dark_Skies_-_1x01_-_The_Awakening_(Part_1_&_2).avi) in Library
2012-08-02 18:31:23,078 INFO  [LibraryUpdatesCheckerThread] Updated 'Moving Targets' (C:\Movie Share\Dark Skies - SciFi Tv Series\Series1\Dark_Skies_-_1x03_-_Moving_Targets.avi) in Library
2012-08-02 18:31:23,333 INFO  [LibraryUpdatesCheckerThread] Updated 'Mercury Rising' (C:\Movie Share\Dark Skies - SciFi Tv Series\Series1\Dark_Skies_-_1x04_-_Mercury_Rising.avi) in Library
2012-08-02 18:31:23,588 INFO  [LibraryUpdatesCheckerThread] Updated 'Dark Days Night' (C:\Movie Share\Dark Skies - SciFi Tv Series\Series1\Dark_Skies_-_1x05_-_Dark_Days_Night.avi) in Library
2012-08-02 18:31:23,845 INFO  [LibraryUpdatesCheckerThread] Updated 'Dreamland' (C:\Movie Share\Dark Skies - SciFi Tv Series\Series1\Dark_Skies_-_1x06_-_Dreamland.avi) in Library
2012-08-02 18:31:24,100 INFO  [LibraryUpdatesCheckerThread] Updated 'Inhuman Nature' (C:\Movie Share\Dark Skies - SciFi Tv Series\Series1\Dark_Skies_-_1x07_-_Inhuman_Nature.avi) in Library
2012-08-02 18:31:24,371 INFO  [LibraryUpdatesCheckerThread] Updated 'Shades of Gray' (C:\Movie Share\Dark Skies - SciFi Tv Series\Series1\Dark_Skies_-_1x15_-_Shades_Of_Gray.avi) in Library
2012-08-02 18:31:24,623 INFO  [LibraryUpdatesCheckerThread] Updated 'Burn, Baby, Burn' (C:\Movie Share\Dark Skies - SciFi Tv Series\Series1\Dark_Skies_-_1x16_-_Burn,_Baby,_Burn.avi) in Library
2012-08-02 18:31:24,869 INFO  [LibraryUpdatesCheckerThread] Updated 'Both Sides Now' (C:\Movie Share\Dark Skies - SciFi Tv Series\Series1\Dark_Skies_-_1x17_-_Both_Sides_Now.avi) in Library
2012-08-02 18:31:25,007 INFO  [LibraryAdditionsCheckerThread] Finished looking for newly added files
2012-08-02 18:31:25,164 INFO  [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2012-08-02 18:31:25,213 INFO  [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-08-02 18:31:25,228 INFO  [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2012-08-02 18:31:25,529 INFO  [LibraryUpdatesCheckerThread] Updated 'To Prey in Darkness' (C:\Movie Share\Dark Skies - SciFi Tv Series\Series1\Dark_Skies_-_1x18_-_To_Prey_In_Darkness.avi) in Library
2012-08-02 18:31:25,809 INFO  [LibraryUpdatesCheckerThread] Updated 'Strangers in the Night' (C:\Movie Share\Dark Skies - SciFi Tv Series\Series1\Dark_Skies_-_1x19_-_Strangers_In_The_Night.avi) in Library
2012-08-02 18:31:26,442 INFO  [LibraryUpdatesCheckerThread] Updated 'Bloodlines' (C:\Movie Share\Dark Skies - SciFi Tv Series\Series1\Dark_Skies_-_1x20_-_Bloodlines.avi) in Library
2012-08-02 18:31:26,696 INFO  [LibraryUpdatesCheckerThread] Updated 'Eagles - Melbourne cd1' (C:\Movie Share\Eagles - Melbourne cd1.avi) in Library
2012-08-02 18:31:26,883 INFO  [LibraryUpdatesCheckerThread] Updated 'Eagles - Melbourne cd2' (C:\Movie Share\Eagles - Melbourne cd2.avi) in Library
2012-08-02 18:31:27,328 INFO  [LibraryUpdatesCheckerThread] Updated 'The Winds of War I - The Winds Rise' (C:\Movie Share\The Winds of War I - The Winds Rise.avi) in Library
2012-08-02 18:31:41,467 INFO  [RendererManager] Stored a new renderer: uuid='e3aee8e4-0b7e-4fd3-8765-61879b23f571', name = 'Unrecognized device', ipAddress='192.168.0.103', profile = '1'
2012-08-02 18:32:51,673 INFO  [WebServer] WebServer shutting down
2012-08-02 18:32:51,674 INFO  [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2012-08-02 18:32:51,674 INFO  [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2012-08-02 18:32:51,675 INFO  [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2012-08-02 18:32:51,677 INFO  [EventDispatcher] Leaving EventDispatcher
2012-08-02 18:32:52,051 INFO  [WebServer] WebServer starting on port 8895
2012-08-02 18:32:52,051 INFO  [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2012-08-02 18:32:52,051 INFO  [RendererSearchSender] Searching for Renderer devices
2012-08-02 18:32:52,051 INFO  [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2012-08-02 18:32:52,051 INFO  [EventDispatcher] Starting EventDispatcher
2012-08-02 18:32:52,120 INFO  [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth4 (Intel(R) PRO/1000 PL Network Connection) and address 192.168.0.101, timeout = 0
2012-08-02 18:40:07,822 INFO  [WebServer] WebServer shutting down
2012-08-02 18:40:07,822 INFO  [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2012-08-02 18:40:07,823 INFO  [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2012-08-02 18:40:07,823 INFO  [EventDispatcher] Leaving EventDispatcher
2012-08-02 18:40:07,824 INFO  [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2012-08-02 18:40:11,958 INFO  [WebServer] WebServer starting on port 8895
2012-08-02 18:40:11,958 INFO  [RendererSearchSender] Searching for Renderer devices
2012-08-02 18:40:11,958 INFO  [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2012-08-02 18:40:11,958 INFO  [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2012-08-02 18:40:11,958 INFO  [EventDispatcher] Starting EventDispatcher
2012-08-02 18:40:12,024 INFO  [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth4 (Intel(R) PRO/1000 PL Network Connection) and address 192.168.0.101, timeout = 0
2012-08-02 18:47:36,285 INFO  [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2012-08-02 18:47:36,285 INFO  [WebServer] WebServer shutting down
2012-08-02 18:47:36,520 INFO  [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2012-08-02 18:47:36,526 INFO  [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2012-08-02 18:47:36,528 INFO  [EventDispatcher] Leaving EventDispatcher
2012-08-02 18:47:39,416 INFO  [WebServer] WebServer starting on port 8895
2012-08-02 18:47:39,419 INFO  [RendererSearchSender] Searching for Renderer devices
2012-08-02 18:47:39,426 INFO  [EventDispatcher] Starting EventDispatcher
2012-08-02 18:47:39,426 INFO  [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2012-08-02 18:47:39,428 INFO  [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2012-08-02 18:47:39,584 INFO  [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth4 (Intel(R) PRO/1000 PL Network Connection) and address 192.168.0.101, timeout = 0
2012-08-02 18:55:15,184 INFO  [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2012-08-02 18:55:15,185 INFO  [WebServer] WebServer shutting down
2012-08-02 18:55:15,186 INFO  [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2012-08-02 18:55:15,186 INFO  [EventDispatcher] Leaving EventDispatcher
2012-08-02 18:55:15,186 INFO  [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2012-08-02 18:55:18,784 INFO  [WebServer] WebServer starting on port 8895
2012-08-02 18:55:18,785 INFO  [RendererSearchSender] Searching for Renderer devices
2012-08-02 18:55:18,786 INFO  [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2012-08-02 18:55:18,786 INFO  [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2012-08-02 18:55:18,787 INFO  [EventDispatcher] Starting EventDispatcher
2012-08-02 18:55:18,855 INFO  [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth4 (Intel(R) PRO/1000 PL Network Connection) and address 192.168.0.101, timeout = 0
2012-08-02 18:56:04,954 INFO  [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2012-08-02 18:56:04,954 INFO  [WebServer] WebServer shutting down
2012-08-02 18:56:04,955 INFO  [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2012-08-02 18:56:04,955 INFO  [EventDispatcher] Leaving EventDispatcher
2012-08-02 18:56:04,956 INFO  [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2012-08-02 18:56:13,862 INFO  [WebServer] WebServer starting on port 8895
2012-08-02 18:56:13,863 INFO  [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2012-08-02 18:56:13,864 INFO  [RendererSearchSender] Searching for Renderer devices
2012-08-02 18:56:13,865 INFO  [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2012-08-02 18:56:13,865 INFO  [EventDispatcher] Starting EventDispatcher
2012-08-02 18:56:13,938 INFO  [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth4 (Intel(R) PRO/1000 PL Network Connection) and address 192.168.0.101, timeout = 0
2012-08-02 18:56:14,366 INFO  [RendererManager] Stored a new renderer: uuid='e1bbe939-282c-4106-9c5a-ce31f5794515', name = 'Unrecognized device', ipAddress='192.168.0.101', profile = '1'
2012-08-02 18:56:14,970 INFO  [RendererManager] Stored a new renderer: uuid='7db46fda-1904-4ca2-a8e6-74ac4989cfc1', name = 'Unrecognized device', ipAddress='192.168.0.100', profile = '1'
2012-08-02 19:00:06,400 INFO  [WebServer] WebServer shutting down
2012-08-02 19:00:06,401 INFO  [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2012-08-02 19:00:06,402 INFO  [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2012-08-02 19:00:06,402 INFO  [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2012-08-02 19:00:06,406 INFO  [EventDispatcher] Leaving EventDispatcher
2012-08-02 19:00:06,801 INFO  [WebServer] WebServer starting on port 8895
2012-08-02 19:00:06,802 INFO  [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2012-08-02 19:00:06,802 INFO  [RendererSearchSender] Searching for Renderer devices
2012-08-02 19:00:06,803 INFO  [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2012-08-02 19:00:06,803 INFO  [EventDispatcher] Starting EventDispatcher
2012-08-02 19:00:06,878 INFO  [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth4 (Intel(R) PRO/1000 PL Network Connection) and address 192.168.0.101, timeout = 0
2012-08-02 19:02:05,138 INFO  [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2012-08-02 19:02:05,138 INFO  [WebServer] WebServer shutting down
2012-08-02 19:02:05,139 INFO  [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2012-08-02 19:02:05,140 INFO  [EventDispatcher] Leaving EventDispatcher
2012-08-02 19:02:05,140 INFO  [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2012-08-02 19:02:09,837 INFO  [WebServer] WebServer starting on port 8895
2012-08-02 19:02:09,843 INFO  [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2012-08-02 19:02:09,843 INFO  [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2012-08-02 19:02:09,843 INFO  [RendererSearchSender] Searching for Renderer devices
2012-08-02 19:02:09,849 INFO  [EventDispatcher] Starting EventDispatcher
2012-08-02 19:02:09,906 INFO  [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth4 (Intel(R) PRO/1000 PL Network Connection) and address 192.168.0.101, timeout = 0
2012-08-02 19:04:16,708 INFO  [RendererManager] Stored a new renderer: uuid='f17d14aa-cf1c-4865-9059-d46e2eeafe46', name = 'Unrecognized device', ipAddress='192.168.0.102', profile = '1'
2012-08-02 19:32:27,245 INFO  [RendererManager] Stored a new renderer: uuid='dcb6586f-c0aa-425f-b614-62050a05d5f1', name = 'Unrecognized device', ipAddress='192.168.0.199', profile = '1'
2012-08-02 19:34:02,825 INFO  [WebServer] WebServer shutting down
2012-08-02 19:34:02,913 INFO  [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2012-08-02 19:34:02,921 INFO  [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2012-08-02 19:34:02,922 INFO  [EventDispatcher] Leaving EventDispatcher
2012-08-02 19:34:02,922 INFO  [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2012-08-02 19:34:03,465 INFO  [WebServer] WebServer starting on port 8895
2012-08-02 19:34:03,466 INFO  [RendererSearchSender] Searching for Renderer devices
2012-08-02 19:34:03,467 INFO  [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2012-08-02 19:34:03,467 INFO  [EventDispatcher] Starting EventDispatcher
2012-08-02 19:34:03,467 INFO  [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2012-08-02 19:34:03,560 INFO  [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth4 (Intel(R) PRO/1000 PL Network Connection) and address 192.168.0.101, timeout = 0
2012-08-02 19:34:24,926 INFO  [WebServer] WebServer shutting down
2012-08-02 19:34:24,926 INFO  [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2012-08-02 19:34:24,984 INFO  [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2012-08-02 19:34:24,985 INFO  [EventDispatcher] Leaving EventDispatcher
2012-08-02 19:34:24,985 INFO  [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2012-08-02 19:34:26,506 INFO  [WebServer] WebServer starting on port 8895
2012-08-02 19:34:26,507 INFO  [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2012-08-02 19:34:26,507 INFO  [RendererSearchSender] Searching for Renderer devices
2012-08-02 19:34:26,508 INFO  [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2012-08-02 19:34:26,508 INFO  [EventDispatcher] Starting EventDispatcher
2012-08-02 19:34:26,567 INFO  [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth4 (Intel(R) PRO/1000 PL Network Connection) and address 192.168.0.101, timeout = 0
2012-08-02 19:41:21,163 INFO  [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2012-08-02 19:41:21,164 INFO  [WebServer] WebServer shutting down
2012-08-02 19:41:21,190 INFO  [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2012-08-02 19:41:21,192 INFO  [EventDispatcher] Leaving EventDispatcher
2012-08-02 19:41:21,197 INFO  [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2012-08-02 19:41:25,929 INFO  [WebServer] WebServer starting on port 8895
2012-08-02 19:41:25,935 INFO  [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2012-08-02 19:41:25,936 INFO  [RendererSearchSender] Searching for Renderer devices
2012-08-02 19:41:25,936 INFO  [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2012-08-02 19:41:25,942 INFO  [EventDispatcher] Starting EventDispatcher
2012-08-02 19:41:26,019 INFO  [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth4 (Intel(R) PRO/1000 PL Network Connection) and address 192.168.0.101, timeout = 0
2012-08-02 19:46:04,687 INFO  [RendererManager] Stored a new renderer: uuid='816429d9-4698-492f-9d52-aa61dafd805c', name = 'Unrecognized device', ipAddress='192.168.0.101', profile = '1'
bbking67
Post Thu Aug 02, 2012 11:51 pm
In addition, on this network, all I see for each device is a yellow icon and "unrecognized device" for various network devices. The network seems fine otherwise... and the Samsung DLNA sharing app works for these files and they play using USB. So there's something really screwy going on.
Now I have just tested using a .MP4 file and it works! The .avi files, which are xvid, do not work over the network. I'm guessing that no .avi's are going to work at the moment. Any suggestions?
bbking67
Post Fri Aug 03, 2012 2:40 am
Well, just a little update on my issue with .avi files.
It turns out that the Samsung LN52A750 works reasonably well with the DirecTV HD-DVR setting. The avi's don't work with any of the Samsung profiles for me. I tried a coupkle of different TV firmwares (1012 and 2003) and there was no difference.
After I found that MP4 files seemed to work, i tried various profiles and found that the 2009 Sony profile worked with the .avi files but broke the MP4's.
So now I need to fine tune the profile and get the TV working perfectly (it's actually very usable right now). I did notice that forward and reverse don't work, which sucks... is there a way to get that working?
/bbking67
Post Fri Aug 03, 2012 4:10 pm
marcjero
Post Sat Aug 04, 2012 8:35 pm
try this profile: viewtopic.php?f=10&t=1941&start=40#p49587
Yes I had exactly the same problem and changing the mime type for AVI solved it. Please provide feedback because some issues can be related to tv firmware bugs not serviio.
