Samsung LE40B651 / Playing m4a file ?
goyon2000
Post Thu Jun 21, 2012 3:03 pm
Hello
I am trying to play my m4a files using serviio and my TV Samsung LE40B651.
If I understand well my TV only support playing mp3 for music .... posting.php?mode=post&f=7# So I have to transcode m4a to mp3, correct ?
Does serviio is able to do that
Thank you
Post Thu Jun 21, 2012 3:36 pm
Re: Samsung LE40B651 / Playing m4a file ?
On serviio console, do you have "Samsung B" profile selected ?
All non-supported audio format should be transcoded to LPCM (supported by this TV model, you can also change to mp3 format but it will be compressed).
goyon2000
Post Fri Jun 22, 2012 9:36 am
Yes Samsung B profile is selected.
When I tried to play a m4a file, the TV says "Media type is not supported."
Post Fri Jun 22, 2012 11:52 am
post detailed log of when you play the file
goyon2000
Post Wed Jun 27, 2012 2:06 pm
Hello
I've made a try with the debu mode enabled.
Nothing special is displayed in the log.
2012-06-27 15:49:35,821 INFO [WebServer] WebServer shutting down
2012-06-27 15:49:35,979 INFO [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2012-06-27 15:49:39,629 INFO [RendererExpirationChecker] Leaving RendererExpirationChecker
2012-06-27 15:49:53,609 INFO [WebServer] WebServer starting on port 8895
2012-06-27 15:49:53,682 INFO [RendererSearchSender] Searching for Renderer devices
2012-06-27 15:49:53,654 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2012-06-27 15:49:53,655 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth0 (eth0)
2012-06-27 15:49:53,706 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2012-06-27 15:49:53,682 INFO [EventDispatcher] Starting EventDispatcher
At the same time I try to opened several m4a file with my samsung.
Post Wed Jun 27, 2012 4:49 pm
It's not with DEBUG enabled. Make sure to restart the service (or PC)
goyon2000
Post Tue Nov 20, 2012 10:05 am
Ok Sorry I am back with my question.
I will try to use the debug mode but I have a general question.
In my samsung manual it is said that the TV will take care only of file with the .mp3 extension.
So If I have only m4a file , do I have to change the extension for all of them or using transcoding will allow to pass this problem ?
Post Thu Nov 22, 2012 12:45 pm
transcoding would help, no need to rename anything
goyon2000
Post Thu Dec 06, 2012 11:29 am
As I am using Serviio on my NAS synology I 've disable Transcoding. is there a way to use transcoding only for audio?
