The black art of "sharing" in Vista!
hexeta
Post Fri Jun 29, 2012 5:22 pm
Try as I might I doubt I will ever understand the Windows logic of "sharing". :|
On my Vista PC, I have "shared" the Blue "Pictures" folder in the full and certain knowledge that all sub-folders will inherit this shared state.
......Wrong! :shock: only those sub-folders which Serviio fancies viewing will be shared! :lol:
How do I get to see those which Serviio doesn't want to show me? :(
hexeta
Post Wed Jul 04, 2012 7:54 pm
Re: The black art of "sharing" in Vista!
Hello..............is there anyone there? :D
Post Thu Jul 05, 2012 2:55 pm
did you read this? viewtopic.php?f=11&t=1297
hexeta
Post Thu Jul 05, 2012 3:03 pm
zip wrote:did you read this? viewtopic.php?f=11&t=1297
I have now!
Was it supposed to help me with this problem?
I can't find anything that seems to relate to it. :cry:
This is the folder hierarchy, I just dont understand Serviio's selectiveity :?
Folder hierarchy.jpg (69.82 KiB) Viewed 8684 times
hexeta
Post Mon Jul 09, 2012 12:28 pm
Help?
Post Tue Jul 10, 2012 4:29 pm
Sharing in Windows has nothing to do with sharing in Serviio. You just have to make sure access rights on all the folders are the same as on those that work. You can also check the log to see if Serviio attempts to share files from those folders.
hexeta
Post Tue Jul 10, 2012 5:10 pm
zip wrote:Sharing in Windows has nothing to do with sharing in Serviio. You just have to make sure access rights on all the folders are the same as on those that work. You can also check the log to see if Serviio attempts to share files from those folders.
Where do I look for "access rights"?
Is that what Vista calls "Permissions" found on the "Security" tab?
If so they're all the same; there is no difference between the files that Serviio can see and those it can't. :?
Either way, that doesn't explain why the folder "All Holidays" has been made visible to Serviio merely by prefixing the same hitherto invisible folder, previously named just "Holidays" with the word "All"........no other changes were made to the folder to achieve this. :shock:
I'll try to look at the log , but I don't understand how Serviio could try to access files which are in folders that are invisible to it? :o
hexeta
Post Tue Jul 10, 2012 6:09 pm
There are a few Serviio log text docs:
One Runs from 28 May 2011 to 13 June 2011
Another from 15 July 2011 to 25 Aug 2011
and a current one running from 10 May 2012 upto today as attached.
Sorry, I can't understand it, does it shed any light? :?
There is also a "derby.log" refering to Apache software and Java, is that important?
(358.75 KiB) Downloaded 559 times
Post Wed Jul 11, 2012 9:21 pm
I suggest you reinstall Serviio, turn on detailed log (see my signature) and then add some folders. then we should see what is going on. This log doesn't show anything unfortunately.
