Plugins on OSX (HOW-TO)
elektimad
Post Mon Feb 06, 2012 2:46 pm
Im newbie on serviio and want to install some plugins for testing, but i can't find the "plugins" directory on OSX Lion, or how to create a plugins directory and link it with de serviio console, can anybody help me or guiate to this cause?.
Thanks a lot,
u are doing a great job.
Post Mon Feb 06, 2012 5:16 pm
Re: Plugins on OSX (HOW-TO)
I had to right-click on the app, and show package contents. It's located inside the Serviio.app can give you exact location as dont have mac to hand to look on.
elektimad
Post Mon Feb 06, 2012 8:06 pm
Ok thanks, so i have to create a Plugins folder inside contents and copy all the plugins there?
Thanks a lot.
Post Mon Feb 06, 2012 8:28 pm
elektimad wrote:Ok thanks, so i have to create a Plugins folder inside contents and copy all the plugins there?
Thanks a lot.
the folder should already be in there just copy the files to it :)
casper
Post Mon Jul 09, 2012 4:55 pm
I copied the plugins, restarted Serviio. On my LG TV I do not see any new features. I only see my shared video files. Am I supposed to see anything new?
Post Mon Jul 09, 2012 4:57 pm
You still have to enter the online resource/feed URL. http://www.serviio.org/index.php?option ... icle&id=42
casper
Post Mon Jul 09, 2012 6:39 pm
Ah, thanks.
hnle
Post Wed Mar 13, 2013 9:01 am
Im quite new to Serviio but am starting to figure out this great program.
Question: what is the purpose of a plugin? E.g. a BBC iplayer/ SvtPlay plugin?
From what I can read I still need to enter the URL as I would have to if I didnt have the plugin? What is then the purpose of the plugin?
Will it look differently when I start the Serviio program on the tv?
How do I know that the plugin is working?
Thank you in advance
Post Wed Mar 13, 2013 9:56 am
wojeda
Post Thu Mar 21, 2013 2:28 pm
zip wrote:http://www.serviio.org/features?id=42
Thank you.
This docs states:
NOTE: On a Mac you will have to store it inside Serviio.app. Right-click on Serviio(.app) icon -> Browse contents -> naviagate to Contents/Resources/Java/plugins
Does this mean that with an update the .app will get overwritten and my plugins will be gone? Or should the plugins be stored in a safer place such as
~/Library/Application Support/Serviio/Plug-ins/ ?
Serviio mac mini
Denon AVR-3313CI
Panasonic PT-AE8000U Projector / 135" 2.35:1
Post Thu Mar 21, 2013 5:46 pm
wojeda wrote:Does this mean that with an update the .app will get overwritten and my plugins will be gone?
Yes. I hope to change it in future.
Return to General discussion
