Make default group for new devices "Limited"
They get put into No Restriction currently, which means that any device device can see everything. It should be the other way around by default I think.
Ryster wrote:Unless you add that as an option called "Prevent new devices from connecting to serviio [ ]" and have that option off by default?
Ryster wrote:.... They get put into No Restriction currently, which means that any device device can see everything. It should be the other way around by default I think.
IndividualLover wrote:Which version are you using? ( windows,linux,mac )
IndividualLover wrote:I think you are using serviio 1.2.1. This features ( Make default group for new devices "Limited" and Auto block new devices ) coming with serviio 1.3 ( not released yet, still beta testing )
IndividualLover wrote:No.It's available for beta testers. But RC1 has been released for beta testers. This means it will be release soon.
IndividualLover wrote:You need send pm to @zip
