Make default group for new devices "Limited"
Ryster
Post Tue Jul 24, 2012 9:57 pm
Hi. The new groups to prevent some devices seeing certain content is great, but can you please give us the ability to change which group new devices get put into by default.
They get put into No Restriction currently, which means that any device device can see everything. It should be the other way around by default I think.
Serviio Pro Purchaser - 24/07/2012
Post Tue Jul 24, 2012 10:46 pm
Re: Make default group for new devices "Limited"
I was thinking about doing this as well. Not sure if it should be on the Access Group level, or just Disable device access altogether by default..?
Ryster
Post Thu Jul 26, 2012 10:58 am
Disabling new devices altoghther could confuse some of the less knowledgeable users, wondering why their device can't see their shared folders :-)
Unless you add that as an option called "Prevent new devices from connecting to serviio [ ]" and have that option off by default?
Post Thu Jul 26, 2012 1:00 pm
Ryster wrote:Unless you add that as an option called "Prevent new devices from connecting to serviio [ ]" and have that option off by default?
Yes, that would be the case.
npuser
Post Sat Aug 04, 2012 1:01 am
Ryster wrote:.... They get put into No Restriction currently, which means that any device device can see everything. It should be the other way around by default I think.
NPuser
fscussel
Post Tue Jul 30, 2013 9:50 pm
ok I have seen this thread and have seen another one that produced a ticket which is marked as solved. So let me ask this: Where is the damn option to disable new devices to seeing serviio library? thanks =)
IndividualLover
Post Tue Jul 30, 2013 9:55 pm
Which version are you using? ( windows,linux,mac )
fscussel
Post Tue Jul 30, 2013 10:02 pm
IndividualLover wrote:Which version are you using? ( windows,linux,mac )
sorry, windows!
IndividualLover
Post Tue Jul 30, 2013 10:14 pm
I think you are using serviio 1.2.1. This features ( Make default group for new devices "Limited" and Auto block new devices ) coming with serviio 1.3 ( not released yet, still beta testing )
fscussel
Post Tue Jul 30, 2013 10:26 pm
IndividualLover wrote:I think you are using serviio 1.2.1. This features ( Make default group for new devices "Limited" and Auto block new devices ) coming with serviio 1.3 ( not released yet, still beta testing )
oh, I see... correct. Is it a public beta?
IndividualLover
Post Tue Jul 30, 2013 10:36 pm
No.It's available for beta testers. But RC1 has been released for beta testers. This means it will be release soon. ;)
fscussel
Post Tue Jul 30, 2013 10:41 pm
IndividualLover wrote:No.It's available for beta testers. But RC1 has been released for beta testers. This means it will be release soon. ;)
I would like to be a beta tester, is it possible?
IndividualLover
Post Tue Jul 30, 2013 10:46 pm
You need send pm to @zip
fscussel
Post Tue Jul 30, 2013 10:51 pm
IndividualLover wrote:You need send pm to @zip
ok thanks =)
scottjoc
Post Thu Aug 01, 2013 10:49 am
This is definitely a feature I'm interested in as well.
Return to Feature requests
