problems adding to library with 1.0
kram
Post Thu Jul 26, 2012 1:52 pm
I updated to serviio 1.0 the other day from 0.6.2, I just installed over the top of it like the instructions say. I thought something had gone wrong as not all the files were able to be seen by the tv anymore so I uninstalled servio and stared afresh with 1.0.
Now I can only add 2 locations to the the Library in serviio console, if I try and add a 3rd location ( all on c drive) and click save the serviio console freezes, I tried leaving it for ages a few times and it stays frozen, I can only kill it with task manager.
The 2 file locations that I can add dont work properly either, one is photos and that isnt showing anything at all after atleast 5 hours and the other is a video folder and only a few things are showing on the TV.
I have 2 serviioservice.exe ( i think thats what they are called) running in taskmanager/processes, one just uses a bit of memory and no cpu and the other uses quite a bit of memory and about 33%cpu all the time, also servio console is there too but thats to be expected. Serviio is also running as a service as normal.
I have uninstalled and reinstalled a few times now and also got rid of all my old Java programs and installed the latest java 7, still not working.
Serviio 0.6.2 seemed to work ok, i only had a few profile problems with my Panasonic ET5B, hoped the version 1.0 would help.
Hope someone can help.
kram
Post Thu Jul 26, 2012 2:12 pm
Re: problems adding to library with 1.0
Just found out it also freezes when I removed my pictures folder from the library and clicked Save. It does this with both the server running or stoped.
glenb
Post Thu Jul 26, 2012 2:42 pm
i uninstalled 1.0 because of huge processor use; usually around 50 per cent, rarely under 33 per cent. i also had problems with online sources not working but did not try to fix the file permissions issue mentioned. hopefully the processor use can be ironed out or at least diagnosed to an issue.
Post Thu Jul 26, 2012 3:00 pm
When you install 1.0 over 0.6 you will have high CPU usage for a while as the entire library has to be rebuilt. It is however worth it as it makes checking for changes in the future much faster, it is also required for various new features in 1.0.
During that time, not all of your media will be available.
As for the freezing, zip will have to answer that, maybe something is happening on the same thread before returing to the client which would normally be near instant, but in that case take a while?
kram
Post Thu Jul 26, 2012 3:11 pm
I am aware that it takes a while for items to appear while the database builds but its had ages to work on it and still alot of stuff was missing. My Picture library is 20GB and the video library is 5GB, most things showed up quite quickly with 0.6.2 but still, not being able to add more librarys is the biggest problem.
Would taking a log help anyone diagnose the problem? probably would, Ill see if I can do it.
kram
Post Thu Jul 26, 2012 4:05 pm
ok, I think I enabled detailed loggin, I followed what it says in the wiki but i dont know if it worked, anyway this is what I got....
2012-07-26 16:57:05,698 DEBUG [ServiioConsole] Initializing Serviio Console
2012-07-26 16:57:05,717 DEBUG [ApplicationInstanceManager] Listening for application instances on socket 44332
2012-07-26 16:57:05,718 INFO [ServiioConsole] Starting Serviio Console
2012-07-26 16:57:05,759 DEBUG [SwingHelper] Choosing java look and feel: com.sun.java.swing.plaf.windows.WindowsLookAndFeel
2012-07-26 16:57:05,801 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2012-07-26 16:57:06,273 DEBUG [ServiioConsole] Retrieving console settings
2012-07-26 16:57:06,377 DEBUG [ServiioConsole] Setting console locale to be: en
2012-07-26 16:57:06,382 INFO [Messages] Loaded console message bundle for locale: en
2012-07-26 16:57:06,501 DEBUG [ServiioFrameView] Initializing main frame
2012-07-26 16:57:06,517 DEBUG [ServiioFrameView] System tray is supported
2012-07-26 16:57:08,911 DEBUG [ServiioConsole] Reading application data
2012-07-26 16:57:08,911 DEBUG [RepositoryView$LibraryStatusCheckerThread] Starting library status checking thread
All i did was start the console then tried to add another location to the library and clicked save, then it froze so I killed it with task manager.
glenb07
Post Thu Jul 26, 2012 5:46 pm
will wrote:When you install 1.0 over 0.6 you will have high CPU usage for a while as the entire library has to be rebuilt. It is however worth it as it makes checking for changes in the future much faster, it is also required for various new features in 1.0.
i had the high processor use after a clean install after several hours, all of the media was already indexed except for online sources some of which would not load.
Post Thu Jul 26, 2012 5:49 pm
not much in the log, did you restart your PC? It looks to me like a Java issue, you might want to try earlier version.. just make sure you only have 1 installed on your system.
kram
Post Thu Jul 26, 2012 6:12 pm
There is nothing mentioned in the wiki about restarting your PC after editing log4j, it says to stop the serviio service and restart it, which takes forever.
I got bored waiting and restarted the PC instead, I now have a copy of the log file :D . Its really long and I dont know how to make it appear in one of those scrolling boxes within a post so appologies for making the thread difficult to read :roll:
I have had to edit the log because the forum wont let me post it, says its too big....
2012-07-26 18:41:42,309 DEBUG [MediaItemDAOImpl] Getting file of media item 9
2012-07-26 18:41:42,310 DEBUG [LibraryAdditionsCheckerThread] Found file 'test4.mkv', checking if it's already in the Library
2012-07-26 18:41:42,310 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item test4.mkv
2012-07-26 18:41:42,310 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 9) and extractor EMBEDDED
2012-07-26 18:41:42,310 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: C:\Users\Mark\Videos\Test Videos\matroska\test4.mkv, ignore case: true
2012-07-26 18:41:42,311 DEBUG [MediaItemDAOImpl] Media item test4.mkv doesn't exist in DB yet
2012-07-26 18:41:42,311 DEBUG [LibraryAdditionsCheckerThread] File not in Library, will add it
2012-07-26 18:41:42,311 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 9) and extractor COVER_IMAGE_IN_FOLDER
2012-07-26 18:41:42,313 DEBUG [MediaItemDAOImpl] Getting file of media item 10
2012-07-26 18:41:42,314 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 10) and extractor EMBEDDED
2012-07-26 18:41:42,314 DEBUG [VideoExtractionStrategy] Extracting metadata of video file: C:\Users\Mark\Videos\Test Videos\matroska\test4.mkv
2012-07-26 18:41:42,316 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 10) and extractor COVER_IMAGE_IN_FOLDER
2012-07-26 18:41:42,317 DEBUG [FFMPEGWrapper] Invoking FFMPEG to retrieve media information for file: C:\Users\Mark\Videos\Test Videos\matroska\test4.mkv
2012-07-26 18:41:42,317 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe -i C:\Users\Mark\Videos\Test Videos\matroska\test4.mkv
2012-07-26 18:41:42,334 DEBUG [MediaItemDAOImpl] Getting file of media item 11
2012-07-26 18:41:42,335 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 11) and extractor EMBEDDED
2012-07-26 18:41:42,336 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 11) and extractor COVER_IMAGE_IN_FOLDER
2012-07-26 18:41:42,338 DEBUG [MediaItemDAOImpl] Getting file of media item 12
2012-07-26 18:41:42,339 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 12) and extractor EMBEDDED
2012-07-26 18:41:42,340 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 12) and extractor COVER_IMAGE_IN_FOLDER
2012-07-26 18:41:42,342 DEBUG [LibraryUpdatesCheckerThread] Looking for removed playlist files in repository: C:\Users\Mark\Pictures
2012-07-26 18:41:42,342 DEBUG [PlaylistDAOImpl] Reading Playlists for Repository (id = 2)
2012-07-26 18:41:42,343 DEBUG [LibraryUpdatesCheckerThread] Looking for removed/updated files in repository: C:\Users\Mark\Pictures
2012-07-26 18:41:42,343 DEBUG [MediaItemDAOImpl] Reading MediaItems for Repository (id = 2)
2012-07-26 18:41:42,343 DEBUG [MediaItemDAOImpl] Reading dirty MediaItems for Repository (id = 1)
2012-07-26 18:41:42,363 DEBUG [RepositoryDAOImpl] Marking Repository 1 as scanned with current timestamp
2012-07-26 18:41:42,416 DEBUG [MediaItemDAOImpl] Reading dirty MediaItems for Repository (id = 2)
2012-07-26 18:41:42,417 DEBUG [RepositoryDAOImpl] Marking Repository 2 as scanned with current timestamp
2012-07-26 18:42:23,147 DEBUG [WebServer] I/O error: Connection reset
2012-07-26 18:42:35,799 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2012-07-26 18:42:35,800 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2012-07-26 18:42:35,800 DEBUG [ConfigEntryDAOImpl] Reading a ConfigEntry (name = search_hidden_files)
2012-07-26 18:42:35,800 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2012-07-26 18:42:35,806 DEBUG [ConfigEntryDAOImpl] Updating ConfigEntry (name = search_hidden_files, value = false)
2012-07-26 18:42:35,816 DEBUG [ConfigEntryDAOImpl] Reading a ConfigEntry (name = search_updated_files)
2012-07-26 18:42:35,816 DEBUG [ConfigEntryDAOImpl] Updating ConfigEntry (name = search_updated_files, value = true)
2012-07-26 18:42:35,818 DEBUG [ConfigEntryDAOImpl] Reading a ConfigEntry (name = repository_automatic_check)
2012-07-26 18:42:35,818 DEBUG [ConfigEntryDAOImpl] Updating ConfigEntry (name = repository_automatic_check, value = true)
2012-07-26 18:42:35,820 DEBUG [ConfigEntryDAOImpl] Reading a ConfigEntry (name = repository_automatic_check_interval)
2012-07-26 18:42:35,821 DEBUG [ConfigEntryDAOImpl] Updating ConfigEntry (name = repository_automatic_check_interval, value = 5)
2012-07-26 18:42:35,822 DEBUG [ConfigEntryDAOImpl] Reading a ConfigEntry (name = online_feed_max_num_items)
2012-07-26 18:42:35,823 DEBUG [ConfigEntryDAOImpl] Updating ConfigEntry (name = online_feed_max_num_items, value = 20)
2012-07-26 18:42:35,839 DEBUG [ConfigEntryDAOImpl] Reading a ConfigEntry (name = online_feed_expiry_interval)
2012-07-26 18:42:35,839 DEBUG [ConfigEntryDAOImpl] Updating ConfigEntry (name = online_feed_expiry_interval, value = 24)
2012-07-26 18:42:41,840 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth3 (Realtek PCIe GBE Family Controller) and address 192.168.0.2, timeout = 0
2012-07-26 18:42:41,841 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device c41c5514-0d79-3774-967b-023b9e31d01f
2012-07-26 18:42:42,485 DEBUG [WebServer] Incoming connection from /192.168.0.6:44576
2012-07-26 18:42:42,485 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.6
2012-07-26 18:42:42,486 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device c41c5514-0d79-3774-967b-023b9e31d01f from 192.168.0.6 (headers = [User-Agent: Panasonic MIL DLNA CP UPnP/1.0 DLNADOC/1.50,Host: 192.168.0.2:8895,X-PANASONIC-Registration: VklFUkEgRVQ1IFNlcmllcwAAAAAAAAAAAAA=,X-PANASONIC-DMP-Profile: MPEG_PS_PAL JPEG_SM PV_DIVX_DIV3 PV_DIVX_DIV4 PV_DIVX_DIVX PV_DIVX_DX50 PV_DRM_DIVX_DIV3 PV_DRM_DIVX_DIV4 PV_DRM_DIVX_DIVX PV_DRM_DIVX_DX50])
2012-07-26 18:42:42,486 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.6
2012-07-26 18:42:42,487 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [User-Agent: Panasonic MIL DLNA CP UPnP/1.0 DLNADOC/1.50,Host: 192.168.0.2:8895,X-PANASONIC-Registration: VklFUkEgRVQ1IFNlcmllcwAAAAAAAAAAAAA=,X-PANASONIC-DMP-Profile: MPEG_PS_PAL JPEG_SM PV_DIVX_DIV3 PV_DIVX_DIV4 PV_DIVX_DIVX PV_DIVX_DX50 PV_DRM_DIVX_DIV3 PV_DRM_DIVX_DIV4 PV_DRM_DIVX_DIVX PV_DRM_DIVX_DX50]
2012-07-26 18:42:42,488 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.6
2012-07-26 18:42:42,490 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Panasonic Viera (2010)'
2012-07-26 18:42:43,641 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:46
2012-07-26 18:42:58,356 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.0.2:61032
2012-07-26 18:42:58,356 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.2
2012-07-26 18:43:01,356 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.0.2:61032
2012-07-26 18:43:01,356 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.2
2012-07-26 18:43:04,356 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.0.2:61032
2012-07-26 18:43:04,356 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.2
2012-07-26 18:43:30,375 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth3 (Realtek PCIe GBE Family Controller) and address 192.168.0.2, timeout = 0
2012-07-26 18:43:30,376 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device c41c5514-0d79-3774-967b-023b9e31d01f
2012-07-26 18:43:31,015 DEBUG [WebServer] Incoming connection from /192.168.0.6:19402
2012-07-26 18:43:31,015 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.6
2012-07-26 18:43:31,016 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device c41c5514-0d79-3774-967b-023b9e31d01f from 192.168.0.6 (headers = [User-Agent: Panasonic MIL DLNA CP UPnP/1.0 DLNADOC/1.50,Host: 192.168.0.2:8895,X-PANASONIC-Registration: VklFUkEgRVQ1IFNlcmllcwAAAAAAAAAAAAA=,X-PANASONIC-DMP-Profile: MPEG_PS_PAL JPEG_SM PV_DIVX_DIV3 PV_DIVX_DIV4 PV_DIVX_DIVX PV_DIVX_DX50 PV_DRM_DIVX_DIV3 PV_DRM_DIVX_DIV4 PV_DRM_DIVX_DIVX PV_DRM_DIVX_DX50])
2012-07-26 18:43:31,016 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.6
2012-07-26 18:43:31,017 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [User-Agent: Panasonic MIL DLNA CP UPnP/1.0 DLNADOC/1.50,Host: 192.168.0.2:8895,X-PANASONIC-Registration: VklFUkEgRVQ1IFNlcmllcwAAAAAAAAAAAAA=,X-PANASONIC-DMP-Profile: MPEG_PS_PAL JPEG_SM PV_DIVX_DIV3 PV_DIVX_DIV4 PV_DIVX_DIVX PV_DIVX_DX50 PV_DRM_DIVX_DIV3 PV_DRM_DIVX_DIV4 PV_DRM_DIVX_DIVX PV_DRM_DIVX_DX50]
2012-07-26 18:43:31,018 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.6
2012-07-26 18:43:31,021 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Panasonic Viera (2010)'
2012-07-26 18:43:31,898 DEBUG [RendererManager] Retrieve device description from http://192.168.0.6:55000/dmr/ddd.xml
2012-07-26 18:43:32,176 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:56
2012-07-26 18:43:32,718 DEBUG [RendererManager] Looking for a renderer profile for: friendly name = 'VIERA ET5 Series', model name= 'Panasonic VIErA', model number = 'null', manufacturer = 'Panasonic', product code = 'null', server name = 'FreeBSD/8.0 UPnP/1.0 Panasonic-MIL-DLNA-SV/1.0'
2012-07-26 18:43:32,719 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.6
2012-07-26 18:43:32,720 DEBUG [RendererDAOImpl] Deleting a Renderer (uuid = 8ba09be3-e133-47fe-9c97-bb522a1bf918)
2012-07-26 18:43:32,721 DEBUG [RendererDAOImpl] Creating a new Renderer (uuid = 4d454930-0100-1000-8001-cc7ee77f022b)
2012-07-26 18:43:32,723 INFO [RendererManager] Stored a new renderer: uuid='4d454930-0100-1000-8001-cc7ee77f022b', name = 'Panasonic VIErA', ipAddress='192.168.0.6', profile = 'viera2011a'
2012-07-26 18:43:32,723 DEBUG [RendererManager] Adding renderer Renderer [uuid=4d454930-0100-1000-8001-cc7ee77f022b, ipAddress=192.168.0.6, name=Panasonic VIErA, profileId=viera2011a, manuallyAdded=false, forcedProfile=false, enabled=true, accessGroupId=1] to list of active renderers
2012-07-26 18:43:35,801 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2012-07-26 18:43:35,801 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2012-07-26 18:44:15,226 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target upnp:rootdevice from address /192.168.0.2:61032
2012-07-26 18:44:15,226 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.2
2012-07-26 18:44:15,229 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.0.2:61032
2012-07-26 18:44:15,311 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-wifialliance-org:device:WFADevice:1 from address /192.168.0.2:61032
2012-07-26 18:44:15,312 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.2
2012-07-26 18:44:16,755 DEBUG [WebServer] Incoming connection from /192.168.0.2:49518
2012-07-26 18:44:16,755 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.2
2012-07-26 18:44:16,756 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device c41c5514-0d79-3774-967b-023b9e31d01f from 192.168.0.2 (headers = [Cache-Control: no-cache,Connection: Keep-Alive,Pragma: no-cache,Accept: text/xml, application/xml,User-Agent: FDSSDP,Host: 192.168.0.2:8895])
2012-07-26 18:44:16,757 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.2
2012-07-26 18:44:16,757 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [Cache-Control: no-cache,Connection: Keep-Alive,Pragma: no-cache,Accept: text/xml, application/xml,User-Agent: FDSSDP,Host: 192.168.0.2:8895]
2012-07-26 18:44:16,758 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.2
2012-07-26 18:44:16,760 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Generic DLNA profile'
2012-07-26 18:44:18,226 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target upnp:rootdevice from address /192.168.0.2:61032
2012-07-26 18:44:18,226 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.2
2012-07-26 18:44:18,227 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.0.2:61032
2012-07-26 18:44:18,312 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-wifialliance-org:device:WFADevice:1 from address /192.168.0.2:61032
2012-07-26 18:44:18,312 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.2
2012-07-26 18:44:21,226 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target upnp:rootdevice from address /192.168.0.2:61032
2012-07-26 18:44:21,226 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.2
2012-07-26 18:44:21,227 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.0.2:61032
2012-07-26 18:44:21,312 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-wifialliance-org:device:WFADevice:1 from address /192.168.0.2:61032
2012-07-26 18:44:21,312 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.2
All i did was start the PC, leave it for a few seconds then tried to add C:\Users\Mark\Documents\TVRecordings to the Library and unselected the metadata option and selected Video and clicked save. The console then freezes.
It did this when I had Java 6 something on and now with java 7.
Mark.
Post Thu Jul 26, 2012 6:17 pm
could you zip the log up and add as an attachment?
kram
Post Thu Jul 26, 2012 6:45 pm
Thanks for taking the time to look at my problem.
serviio log 1.zip
(9.16 KiB) Downloaded 539 times
reiffert
Post Thu Jul 26, 2012 7:19 pm
Same issue for me adding a mounted share drive:
2012-07-26 21:15:42,858 WARN [LibraryAdditionsCheckerThread] Folder 'Z:\Serien' is either not an existing directory or cannot be read due to access rights
2012-07-26 21:15:42,858 DEBUG [LibraryUpdatesCheckerThread] Looking for removed playlist files in repository: Z:\Serien
2012-07-26 21:15:42,858 DEBUG [RepositoryDAOImpl] Marking Repository 1 as scanned with current timestamp
2012-07-26 21:15:42,858 DEBUG [PlaylistDAOImpl] Reading Playlists for Repository (id = 1)
2012-07-26 21:15:42,859 DEBUG [LibraryUpdatesCheckerThread] Looking for removed/updated files in repository: Z:\Serien
2012-07-26 21:15:42,859 DEBUG [MediaItemDAOImpl] Reading MediaItems for Repository (id = 1)
2012-07-26 21:15:42,860 DEBUG [MediaItemDAOImpl] Reading dirty MediaItems for Repository (id = 1)
Z:\Serien is mounted as guest, access works out just fine for every other program.
Please let me know if you've got any questions.
Regards
Thomas
Post Thu Jul 26, 2012 7:28 pm
Nothing suspicious in the log... Is the adding folders the only thing that freezes? Can you for example save Presentation changes?
Remote drive - you have to give the system accunt that runs the Serviio service the rights, or change the user that runs the service. More in FAQ.
reiffert
Post Thu Jul 26, 2012 7:52 pm
Hello Petr,
I'm getting the same results when running the serviio service with the default
- local system account with [x] let the service and the system exchange data
and when running the serviio service under the
- the username that is currently logged on
Saving presentation changes works out just fine.
reiffert
Post Thu Jul 26, 2012 7:56 pm
\\host\share\path did the trick. thanks Petr.
kappclark
Post Thu Jul 26, 2012 8:06 pm
glenb wrote:i uninstalled 1.0 because of huge processor use; usually around 50 per cent, rarely under 33 per cent. i also had problems with online sources not working but did not try to fix the file permissions issue mentioned. hopefully the processor use can be ironed out or at least diagnosed to an issue.
I noticed the same thing today - upgraded my Windows 7 64bit laptop to 1.0 and saw huge increase in CPU utilization (65 - 80 %) .. another XP laptop with 0.6.2 idles at 2-3% ...
Post Thu Jul 26, 2012 8:08 pm
Did you check the log what it's doing? It's rebuilding your entire library most likely.
kram
Post Thu Jul 26, 2012 9:08 pm
Hi Zip,
seems to be just when using the library. I can change presentations and other things just fine, nothing hangs or crashes.
Post Thu Jul 26, 2012 9:24 pm
So how did you manage to share at least some files when you cannot save the folders?
kram
Post Thu Jul 26, 2012 9:48 pm
It just does, i can add 2 locations to the library, one is C:\Users\Mark\Pictures, the other is C:\Users\Mark\video.
If I try and remove one of those it will freeze when I save, if I try and add another it will freeze when i save.
Also the database dosent seem to be being updated, no photos at all have been available on the TV at all today, usually with 0.6.2 i get a few new folders in the photo library appearing every few minutes or so.
Users browsing this forum: Google [Bot] and 220 guests
