MyiPlayer.com [LAST UPDATE: Sep-25-2012]
xs2inattar
Post Sat Aug 04, 2012 12:49 am
Myiplayer.com http://www.myiplayer.com actively maintains a list of live channels available over the internet, so that you don't have to maintain the list yourself.
The plugin crawls myiplayer.com and extracts the channels. Only the channels for which I was able to identify how to extract the stream information are currently supported.
Please install the plugin and let me know if you have any issues.
Add the links as a video web-resource.
Sample URLs to use as video web resource:
US Channels: http://www.myiplayer.com/uschannels.php
UK Channels: http://www.myiplayer.com/ukchannels.php
News: http://www.myiplayer.com/serieschannels.php
Music: http://www.myiplayer.com/musicchannels.php
Sports: http://www.myiplayer.com/sportschannels.php
MyiPlayer.groovy
V1: August 03, 2012 - Initial Release
V2: August 04, 2012 - Thumbnail Issue Fixed
V3: August 09, 2012 - Bug Fix: Set live=true for the content.
V4: August 10, 2012 - Added support for: viovu.com, liveflash.tv
V5: August 21, 2012 - Added support for: wcast.tv
V6: August 31, 2012 - Added support for: castup.tv
V7: September 25, 2012 - Added support for: 9stream.com, skystreamlive.com, espnwatch.net
(69.26 KiB) Downloaded 1426 times
xs2inattar
Post Sat Aug 04, 2012 3:03 pm
Re: MyiPlayer.com
v2 - August 04, 2012 - Fixed an issue with channel thumbnails not showing up.
yaro
Post Sat Aug 04, 2012 6:35 pm
MyiPlayer.com
The sports URL is not working.
xs2inattar
Post Sat Aug 04, 2012 8:35 pm
Re: MyiPlayer.com
yaro wrote:The sports URL is not working.
My bad, the link for sports is sportchannels.php not sportschannels.php
I have fixed it in the first post.
martyn
Post Mon Aug 06, 2012 5:39 am
Re: MyiPlayer.com
nice one m8 Image
xs2inattar
Post Fri Aug 10, 2012 1:47 am
Re: MyiPlayer.com
Update: V3 - August 09, 2012 - Bug Fix: Set live=true for content
Post Fri Aug 10, 2012 3:12 am
Re: MyiPlayer.com
Not working too well. UK channels only 4 show, play for a few seconds and hang, sports only 1 shows and plays, all low quality, on 5 =160x120??.
xs2inattar
Post Fri Aug 10, 2012 5:23 pm
Re: MyiPlayer.com
jhb50 wrote:Not working too well. UK channels only 4 show, play for a few seconds and hang, sports only 1 shows and plays, all low quality, on 5 =160x120??.
I am in US, so while writing the plugin i was mostly testing with US channels. Most of the UK channels require the UK IP, so i was not able to work with them. If you could provide the code for extracting stream information for UK channels that require uk ip, I will add that to the plugin.
also for sports channels i get around 20 streams.
xs2inattar
Re: MyiPlayer.com
Update: V4 - August 10, 2012 - Add support for: viovu.com, liveflash.tv
Post Sun Aug 19, 2012 3:53 am
Re: MyiPlayer.com
Impressive list of channels! I am puzzled however because so many of the ones I have tried are not english language. History, HBO and many others.
Is there any setting within the plugin that might point to a particular channel? How do we find out where these streams come from? With any luck there can be a simple tweak somewhere.
xs2inattar
Post Tue Aug 21, 2012 2:03 pm
Re: MyiPlayer.com
Update: V5: August 21, 2012 - Added support for: wcast.tv
George_L
Post Sat Sep 22, 2012 5:33 pm
Re: MyiPlayer.com
Only seeing 1 or 2 thumbnail links per channel now. They do work. Was seeing many multiple links previously. Anyone else have this issue?
seaman
Post Mon Sep 24, 2012 4:42 pm
Re: MyiPlayer.com
George_L wrote:Only seeing 1 or 2 thumbnail links per channel now. They do work. Was seeing many multiple links previously. Anyone else have this issue?
Yes, I can confirm the same... one or two items in folders...
xs2inattar
Post Tue Sep 25, 2012 10:49 pm
Re: MyiPlayer.com
UPDATE:
aig01
Post Wed Oct 03, 2012 4:32 pm
Re: MyiPlayer.com [LAST UPDATE: Sep-25-2012]
Can't seem to get the feed for Skystream is there a particular web resource to use?
Samsung D5500 - Server: MB Pro - Lion - 8GB Ram - 2.2 GHz i7
seaman
Post Thu Oct 04, 2012 4:43 am
Re: MyiPlayer.com
xs2inattar wrote:UPDATE:
Works fine, good job, thanks :)
amlumsden
Post Fri Oct 12, 2012 12:18 pm
Was watching Sports channels ok last night but noticed today that the folder is now not showing, although the others are. Am totally new to this so wondered if anyone else was having a similar problem and what it could be. :)
xs2inattar
Post Fri Oct 12, 2012 6:23 pm
amlumsden wrote:Was watching Sports channels ok last night but noticed today that the folder is now not showing, although the others are. Am totally new to this so wondered if anyone else was having a similar problem and what it could be. :)
Try using the following link for sports: http://www.myiplayer.com/sportschannels.php
actually the page was initally sportchannels.php, they have changed it to sportschannels.php; notice the 's' added after sport.
So use the above link for sports and it should all be good. :)
amlumsden
Post Sat Oct 13, 2012 11:31 am
Many thanks for your response. It worked! :D
jshg46
Post Fri Oct 26, 2012 9:49 pm
Is this plugin still working? I am not having any luck with it.
Return to Available plugins
