Titles Missing From Series
JGGiant
Post Thu Aug 02, 2012 6:29 pm
I am having a problem with some episodes not showing up in the series list. If I browse to it by selecting folders, it is there. Once this happens, all I have to do to get it to show up in the Series list is to rename the file. I do this by adding a space to the end of the filename just before the dot in the extension. What is weird, if I then rename the file back, it disappears again.
I have been dealing with this for a while now, and it is starting to get real old. Any help would be greatly appreciated.
Post Thu Aug 02, 2012 7:19 pm
Re: Titles Missing From Series
check the detailed log to see what name it''s using to find the online metadata and if it's successful
JGGiant
Post Fri Aug 03, 2012 3:19 am
A search of the log reviledthe following entry...
2012-07-24 18:41:10,410 WARN [LibraryManager] Cannot read metadata of file /media/TV/TV_500/Pretty Little Liars/Pretty Little Liars - 3x07 - Crazy.mp4 via extractor ONLINE_VIDEO_SOURCES. Message: Cannot retrieve series search results for tvdb.com: connect timed out
So, if the connection times out, does it ever try again? Also, why would the episode disappear if I rename it back to the original name.
Post Fri Aug 03, 2012 4:02 pm
JGGiant wrote:So, if the connection times out, does it ever try again?
No, it won't.
It might be just coincidence. Once ou rename it it'll then treat is as a new file and attempt to get the online metadata again - this time it may succeed. Also note that entries are removed from the library within 1 hour so you might see an episode entry that has been added 1 hour ago when the online MD check worked.
JGGiant
Post Fri Aug 03, 2012 9:07 pm
Thanks for the info. Other than renaming the files, is there a way to trigger a full scan for missing entries?
Post Fri Aug 03, 2012 9:11 pm
Click on Refresh video metadata button on the metadata tab (it'll refresh all video files, not just the missing ones)
JGGiant
Post Mon Aug 06, 2012 11:47 pm
Thanks for all the help.
Users browsing this forum: Google [Bot] and 450 guests
