DesiStreams.TV [LAST UPDATED: Sep 27, 2012]
xs2inattar
Post Mon Aug 06, 2012 4:00 am
Indian and Pakistani TV channels from DesiStreams - http://desistreams.tv/
Add http://desistreams.tv/ as video webresource.
DesiStreams.groovy
V1: August 05, 2012 - Initial Release
V2: August 09, 2012 - Bug Fix: Set live=true for content
V3: August 21, 2012 - Added support for: wcast.tv
V4: September 27, 2012 - Updated based on changes made to the source website
(25.94 KiB) Downloaded 2352 times
alijan
Post Tue Aug 07, 2012 2:37 pm
Re: DesiStreams.TV
thanks for this works good on my WD live just take some time to start but it works. :D :D :D :D :D
how did you do if i need another web treame is it easy for some like me who is new to all this. :?:
sarishpaul
Post Fri Aug 10, 2012 1:39 am
Re: DesiStreams.TV
I'm new to Seviio.. Can you please develop a plugin for the webresource http://www.bhoomtv.com/malayalam.html. THanks
xs2inattar
Post Fri Aug 10, 2012 1:48 am
Re: DesiStreams.TV
Update: V2 - August 09, 2012 - Bug Fix: Set live=true for content
rosahas
Post Fri Aug 10, 2012 5:16 am
Re: DesiStreams.TV
Thanks!
alijan
Post Fri Aug 10, 2012 4:35 pm
Re: DesiStreams.TV
Thanks will try now v2
suduko
Post Sun Aug 12, 2012 3:13 am
Re: DesiStreams.TV
Thanks for the plugin. It works great.
just one issue if you can please fix that, I dont see all the channels which are on the website www.desistreams.tv
for example, 9xM, Geo TV, Ten Sports etc. Is that a bug in plugin? how can we make sure that all the channels are displayed.
The link for these channels looks similar to others and also the player is same.
appreciate your efforts
suduko
Post Sun Aug 12, 2012 4:48 am
Re: DesiStreams.TV
some update
i restarted serviio and now its showing more channels....total 7 pages on tv, previously it was 5 pages.
this looks random, some channels are picked up and some are left out when I restart serviio.
using serviio 1.01
xs2inattar
Post Sun Aug 12, 2012 11:38 pm
Re: DesiStreams.TV
suduko wrote:Hi,
just one issue if you can please fix that, I dont see all the channels which are on the website http://www.desistreams.tv
Livestreams come and go. If your channels disappear it means that at the time when your online library item was refreshed the channel was not live.
saadsarfraz
Post Tue Aug 21, 2012 9:35 am
Re: DesiStreams.TV
I worked with this plugin for hours and can only see two channels. When I open desistreams I can click and stream most of the channels from my computer but that is not the case with serviio.
xs2inattar
Post Tue Aug 21, 2012 2:00 pm
Re: DesiStreams.TV
They keep changing their streaming sources.
xs2inattar
Post Tue Aug 21, 2012 5:52 pm
Re: DesiStreams.TV
saadsarfraz wrote:I worked with this plugin for hours and can only see two channels. When I open desistreams I can click and stream most of the channels from my computer but that is not the case with serviio.
I have updated the plugin and added support for their new source.
xs2inattar
Re: DesiStreams.TV
UPDATED: V3: August 21, 2012 - Added support for: wcast.tv
alijan
Post Wed Aug 22, 2012 10:32 am
Re: DesiStreams.TV
Thanks will try leter today..:-)
alijan
Post Mon Aug 27, 2012 12:46 pm
Re: DesiStreams.TV
Hi
in my WD live this plug stop working i can se all the channel but non of them are working. dos anyone els have this issue.
xs2inattar
Post Mon Aug 27, 2012 2:29 pm
Re: DesiStreams.TV
Please try force-refreshing the plugin and let me know if it works.
jackis69
Post Tue Aug 28, 2012 4:26 pm
Re: DesiStreams.TV
Hi
I downloaded the .groovy file into the plugin folder add http://desistreams.tv/ as webresources.
OPen VLC media play->view>Playlist->Universal plun n ply->serviio->video-- but nothing is showing there.. ??
what am i doing wrong
ta
xs2inattar
Post Tue Aug 28, 2012 6:33 pm
Re: DesiStreams.TV
jackis69 wrote:Hi
ta
...video -> online
sheikh73
Post Fri Aug 31, 2012 2:13 am
Re: DesiStreams.TV
I add http://desistreams.tv/ as web resource and named it DesiStreams.tv. But the folder is not showing on the tv. On the other side zonytv is working fine.. Any suggestion what could be the reason?
suduko
Post Fri Aug 31, 2012 2:21 am
Re: DesiStreams.TV
sheikh73 wrote:I add http://desistreams.tv/ as web resource and named it DesiStreams.tv. But the folder is not showing on the tv. On the other side zonytv is working fine.. Any suggestion what could be the reason?
Hi Sheikh73, it is working fine for me at the moment.....
Did you download the new version of plugin. then try to restart serviio as well.....
Return to Available plugins
