DesiStreams.TV [LAST UPDATED: Sep 27, 2012]
Add http://desistreams.tv/ as video webresource.
suduko wrote:Hi,
Thanks for the plugin. It works great.
just one issue if you can please fix that, I dont see all the channels which are on the website http://www.desistreams.tv
for example, 9xM, Geo TV, Ten Sports etc. Is that a bug in plugin? how can we make sure that all the channels are displayed.
The link for these channels looks similar to others and also the player is same.
appreciate your efforts
saadsarfraz wrote:I worked with this plugin for hours and can only see two channels. When I open desistreams I can click and stream most of the channels from my computer but that is not the case with serviio.
jackis69 wrote:Hi
I downloaded the .groovy file into the plugin folder add http://desistreams.tv/ as webresources.
OPen VLC media play->view>Playlist->Universal plun n ply->serviio->video-- but nothing is showing there.. ??
what am i doing wrong
ta
sheikh73 wrote:I add http://desistreams.tv/ as web resource and named it DesiStreams.tv. But the folder is not showing on the tv. On the other side zonytv is working fine.. Any suggestion what could be the reason?
