Version 1.0.1 not working
paddy09
Post Sun Aug 12, 2012 10:29 am
I have a (UK) Sony KDL40CX-523 and have used Serviio V 0.6.2 for months without problems.
After upgrading to the new version many, but not all, files of various types will not play correctly - stuttering/jumping/freezing/no audio etc.
The same files play perfectly on the previous version so I have completely uninstalled V1.0.1 and re-installed V0.6.2 and normal service has been resumed.
I note that other posters have had problems with the new version and not being technical I do not profess to understand the reasons given. All I want is to select the file and play so, for the moment, I'll stick with the old version which works.
Evidently, in my case, new isn't always better
Lowlander
Post Sun Aug 12, 2012 11:28 am
Re: Version 1.0.1 not working
Similar situation here, just not quite as hopeless. ;)
I upgraded from 0.6 to 1.0.1 (all versions between had stuttering issues). Haven't tried enough online sources to judge which of them had audio and which hadn't, but my main issue is that those of my videos which are avc/aac play silently with 1.0.1, while others which are avc/ac3 play fine. If I read the Bravia 2011 profile correctly, both avc/aac and avc/ac3 should be just remuxed. No luck with Bravia 2010 profile either.
Devices used:
Bravia KDL-40EX728, Euro model, latest firmware, wired connection
Bravia KDL-24EX320, Euro model, latest firmware, wireless connection
Detailed log of trying to play a avc/acc file looks like so:
2012-08-12 13:11:04,671 DEBUG [WebServer] Incoming connection from /10.240.11.205:41788
2012-08-12 13:11:04,671 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.240.11.205
2012-08-12 13:11:04,671 DEBUG [ResourceTransportRequestHandler] HEAD /resource/52341/MEDIA_ITEM/AVC_TS_MP_SD_AAC_MULT5_ISO-0/ORIGINAL HTTP/1.1, headers = [getcontentFeatures.dlna.org: 1,Pragma: getIfoFileURI.dlna.org,transferMode.dlna.org: Streaming,X-AV-Physical-Unit-Info: pa="BRAVIA KDL-24EX320";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-24EX320"; mv="1.7";,Host: 10.240.11.11:8895]]
2012-08-12 13:11:04,671 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/10.240.11.205, Profile=Sony Bravia TV (2011)'
2012-08-12 13:11:04,671 DEBUG [ResourceDeliveryProcessor] Request for resource 52341 and type 'MEDIA_ITEM' received
2012-08-12 13:11:04,671 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 52341 (local)
2012-08-12 13:11:04,671 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 52341)
2012-08-12 13:11:04,671 DEBUG [VideoDAOImpl] Reading a Video (id = 52341)
2012-08-12 13:11:04,671 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 52341, format AVC_TS_MP_SD_AAC_MULT5_ISO and profile Sony Bravia TV (2011)
2012-08-12 13:11:04,671 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file 1000 Köstlichkeiten - Eine kulinarische Reise durch China (NDR 2007).avc.aac.mkv
2012-08-12 13:11:04,671 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file 1000 Köstlichkeiten - Eine kulinarische Reise durch China (NDR 2007).avc.aac.mkv: AVC_TS_MP_SD_AAC_MULT5_ISO
2012-08-12 13:11:04,671 DEBUG [ResourceDeliveryProcessor] Sending HEAD response back
2012-08-12 13:11:04,671 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Date: Sun, 12 Aug 2012 11:11:04 GMT,Server: Windows 2003, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_TS_HD_24_AC3_ISO;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2012-08-12 13:11:04,687 DEBUG [WebServer] Incoming connection from /10.240.11.205:41789
2012-08-12 13:11:04,703 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.240.11.205
2012-08-12 13:11:04,703 DEBUG [ResourceTransportRequestHandler] GET /resource/52341/MEDIA_ITEM/AVC_TS_MP_SD_AAC_MULT5_ISO-0/ORIGINAL HTTP/1.1, headers = [TimeSeekRange.dlna.org: npt=0.000-,getcontentFeatures.dlna.org: 1,Pragma: getIfoFileURI.dlna.org,transferMode.dlna.org: Streaming,X-AV-Physical-Unit-Info: pa="BRAVIA KDL-24EX320";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-24EX320"; mv="1.7";,Host: 10.240.11.11:8895]]
2012-08-12 13:11:04,703 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/10.240.11.205, Profile=Sony Bravia TV (2011)'
2012-08-12 13:11:04,703 DEBUG [ResourceDeliveryProcessor] Request for resource 52341 and type 'MEDIA_ITEM' received
2012-08-12 13:11:04,703 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 52341 (local)
2012-08-12 13:11:04,703 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 52341)
2012-08-12 13:11:04,703 DEBUG [VideoDAOImpl] Reading a Video (id = 52341)
2012-08-12 13:11:04,703 DEBUG [VideoDeliveryEngine] Delivering item '52341' for client 'IPAddress=/10.240.11.205, Profile=Sony Bravia TV (2011)'
2012-08-12 13:11:04,703 DEBUG [VideoDeliveryEngine] Delivering file '1000 Köstlichkeiten - Eine kulinarische Reise durch China (NDR 2007).avc.aac.mkv' using transcoding
2012-08-12 13:11:04,703 DEBUG [AbstractTranscodingDeliveryEngine] No suitable transcoding job exists yet, start one for client 'IPAddress=/10.240.11.205, Profile=Sony Bravia TV (2011)'
2012-08-12 13:11:04,703 DEBUG [MediaItemDAOImpl] Getting file of media item 52341
2012-08-12 13:11:04,703 DEBUG [FFMPEGWrapper] Invoking FFmpeg to transcode video file: G:\Daten\mm2\videos\Dokus\Food (75000)\1000 Köstlichkeiten - Eine kulinarische Reise durch China (NDR 2007).avc.aac.mkv
2012-08-12 13:11:04,703 DEBUG [ProcessExecutor] Starting C:\Program Files (x86)\Serviio\bin\\..\lib/ffmpeg.exe -fflags +genpts -i G:\Daten\mm2\videos\Dokus\Food (75000)\1000 Köstlichkeiten - Eine kulinarische Reise durch China (NDR 2007).avc.aac.mkv -y -copyts -c:v copy -vbsf h264_mp4toannexb -c:a copy -map 0:0 -map 0:1 -sn -f mpegts E:\temp\Serviio\transcoding-temp-52341-sony2011-ORIGINAL.stf
2012-08-12 13:11:05,203 DEBUG [FileBasedTranscodingDeliveryStrategy] Sending transcoding stream
2012-08-12 13:11:05,203 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file 1000 Köstlichkeiten - Eine kulinarische Reise durch China (NDR 2007).avc.aac.mkv: AVC_TS_MP_SD_AAC_MULT5_ISO
2012-08-12 13:11:05,203 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 52341) as read
2012-08-12 13:11:05,218 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2012-08-12 13:11:05,218 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 50000000000
2012-08-12 13:11:05,218 DEBUG [ResourceDeliveryProcessor] Sending file back
2012-08-12 13:11:05,218 DEBUG [ResourceTransportRequestHandler] Creating entity with chunked transfer
2012-08-12 13:11:05,218 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,TimeSeekRange.dlna.org: npt=0.0-1689.0/1689,Date: Sun, 12 Aug 2012 11:11:05 GMT,Server: Windows 2003, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_TS_HD_24_AC3_ISO;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2012-08-12 13:11:08,484 DEBUG [WebServer] I/O error: Software caused connection abort: socket write error
2012-08-12 13:11:08,500 DEBUG [WebServer] Incoming connection from /10.240.11.205:41790
2012-08-12 13:11:08,500 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.240.11.205
2012-08-12 13:11:08,500 DEBUG [ResourceTransportRequestHandler] GET /resource/52341/MEDIA_ITEM/AVC_TS_MP_SD_AAC_MULT5_ISO-0/ORIGINAL HTTP/1.1, headers = [TimeSeekRange.dlna.org: npt=0.000-,getcontentFeatures.dlna.org: 1,Pragma: getIfoFileURI.dlna.org,transferMode.dlna.org: Streaming,X-AV-Physical-Unit-Info: pa="BRAVIA KDL-24EX320";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-24EX320"; mv="1.7";,Host: 10.240.11.11:8895]]
2012-08-12 13:11:08,500 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/10.240.11.205, Profile=Sony Bravia TV (2011)'
2012-08-12 13:11:08,500 DEBUG [ResourceDeliveryProcessor] Request for resource 52341 and type 'MEDIA_ITEM' received
2012-08-12 13:11:08,500 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 52341 (local)
2012-08-12 13:11:08,515 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 52341)
2012-08-12 13:11:08,515 DEBUG [VideoDAOImpl] Reading a Video (id = 52341)
2012-08-12 13:11:08,515 DEBUG [VideoDeliveryEngine] Delivering item '52341' for client 'IPAddress=/10.240.11.205, Profile=Sony Bravia TV (2011)'
2012-08-12 13:11:08,515 DEBUG [VideoDeliveryEngine] Delivering file '1000 Köstlichkeiten - Eine kulinarische Reise durch China (NDR 2007).avc.aac.mkv' using transcoding
2012-08-12 13:11:08,515 DEBUG [AbstractTranscodingDeliveryEngine] A suitable transcoding job already exists, re-use it for client 'IPAddress=/10.240.11.205, Profile=Sony Bravia TV (2011)'
2012-08-12 13:11:08,515 DEBUG [FileBasedTranscodingDeliveryStrategy] Sending transcoding stream
2012-08-12 13:11:08,515 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file 1000 Köstlichkeiten - Eine kulinarische Reise durch China (NDR 2007).avc.aac.mkv: AVC_TS_MP_SD_AAC_MULT5_ISO
2012-08-12 13:11:08,515 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 52341) as read
2012-08-12 13:11:08,515 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2012-08-12 13:11:08,515 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 50000000000
2012-08-12 13:11:08,515 DEBUG [ResourceDeliveryProcessor] Sending file back
2012-08-12 13:11:08,515 DEBUG [ResourceTransportRequestHandler] Creating entity with chunked transfer
2012-08-12 13:11:08,515 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,TimeSeekRange.dlna.org: npt=0.0-1689.0/1689,Date: Sun, 12 Aug 2012 11:11:08 GMT,Server: Windows 2003, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_TS_HD_24_AC3_ISO;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2012-08-12 13:11:09,125 DEBUG [TranscodingJobListener] Transcoding finished; successful: true
2012-08-12 13:11:18,796 WARN  [FeedUpdaterThread] Failed to retrieve online item information for rtmp://68.68.26.4:1935/live pageURL=http://www.veemi.com playpath=castonen swfVfy=0 live=1. It might not play.
   at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveMetadata(FeedUpdaterThread.java:291)
   at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveTechnicalMetadata(FeedUpdaterThread.java:209)
   at org.serviio.library.online.metadata.FeedUpdaterThread.run(FeedUpdaterThread.java:102)
   at org.serviio.library.metadata.FFmpegMetadataRetriever.validateCodecsFound(FFmpegMetadataRetriever.java:382)
   at org.serviio.library.metadata.FFmpegMetadataRetriever.retrieveMetadata(FFmpegMetadataRetriever.java:86)
   at org.serviio.library.metadata.FFmpegMetadataRetriever.retrieveOnlineMetadata(FFmpegMetadataRetriever.java:124)
   at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveMetadata(FeedUpdaterThread.java:268)
   ... 2 more
2012-08-12 13:11:18,796 DEBUG [FeedUpdaterThread] Retrieving information about the video stream 'PBS-EAST KAMU-12 Texas A&M'
2012-08-12 13:11:18,796 DEBUG [FFMPEGWrapper] Invoking FFMPEG to retrieve media information for file: rtsp://winstream.kamu.tamu.edu/kamu-tv
2012-08-12 13:11:18,796 DEBUG [ProcessExecutor] Starting C:\Program Files (x86)\Serviio\bin\\..\lib/ffmpeg.exe -rtsp_transport +tcp+udp -i rtsp://winstream.kamu.tamu.edu/kamu-tv
2012-08-12 13:11:21,046 DEBUG [WebServer] I/O error: Software caused connection abort: socket write error
2012-08-12 13:11:21,937 DEBUG [WebServer] Incoming connection from /10.240.11.205:41794
2012-08-12 13:11:21,968 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.240.11.205
2012-08-12 13:11:21,968 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 10.240.11.205:
2012-08-12 13:11:22,125 DEBUG [ContentDirectory] Browse() called for renderer KDL-24EX320 (profile sony2011) with parameters: objectID = V_LV, browseFlag = BrowseDirectChildren, filter = dc:title,av:mediaClass,dc:date,@childCount,res,upnp:class,res@resolution,upnp:album,upnp:genre,upnp:albumArtURI,upnp:albumArtURI@dlna:profileID,dc:creator,res@size,res@duration,res@bitrate,res@protocolInfo, startIndex = 0, count = 10, sortCriteria = -dc:date
2012-08-12 13:11:22,125 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2012-08-12 13:11:22,125 DEBUG [VideoDAOImpl] Retrieving list of 10 last viewed videos (from=0, count=10) [No_Restriction]
Any hints highly appreciated. :?
Have a nice one,
Low
NX3
Post Sun Aug 12, 2012 12:02 pm
This is the main thread for the lack of audio online for Sony 2011 series;
viewtopic.php?f=11&t=6858
Lowlander
Post Sun Aug 12, 2012 12:18 pm
I was aware that there is a thread about online audio issues, and the chances were good for being told "mate, we are talking about online issues here" over there. So I just thought I might put my offline audio issues somewhere else...
Never mind, I'll give the online audio issues thread just a few days to mature and see if the solution does apply to mute playback of offline content as well.
paddy09
Post Sun Aug 12, 2012 5:24 pm
As a result of having to revert to an earlier version, each time I switch the PC on I get the Console splash screen and a reminder to update to a new version.
I obviously don't want to update because of the problems I had so, is there any way of disabling this reminder which is becoming an annoyance
Lowlander
Post Sun Aug 12, 2012 9:26 pm
Paddy,
Serviio does not necessarily need the console running for normal service operation. You may as well remove it from the start menu's startup folder, and if you should wish to access the console, use the desktop icon to fire it up. The update message will still show up, but much less frequently.
CU
Low
xs2inattar
Post Mon Aug 13, 2012 4:04 am
Similar issues with PS3. Files that were working with 0.6.2 and 1.0 are having issues with 1.0.1.
None of the mkv files are working. Also a few avi files have no sound.
Lowlander
Post Mon Aug 13, 2012 7:29 am
As a quick workaround, I went into the Sony 2012 profile and commented out just the three matching rules that prevent aac audio from being transcoded. Formerly mute videos play with ac3 sound now.
And I commented out the ruleset from online transcoding section which does _not_ transcode audio and get sound from online sources as well.
Just workarounds though, maybe we can trick the Bravias into properly accepting aac audio.
abz
Post Mon Aug 13, 2012 3:34 pm
I had 2 issues upgrading to 1.0.1 from 0.6.2
1. Choppy playback
2. Aspect ration on my KDL55HX820 & KDL40NX710
i addressed problem 2 by replacing the profiles.xml file with the back the installer created when installing,
but the choppy playback i cant seem to solve, can anyone point me in the right direction when i can download, 0.6.2 from... i think at this point id like to rollback until the kinks aresorted out.
Abz
Post Mon Aug 13, 2012 6:26 pm
Lowlander wrote:As a quick workaround, I went into the Sony 2012 profile and commented out just the three matching rules that prevent aac audio from being transcoded. Formerly mute videos play with ac3 sound now.
Can you post the profile?
Post Mon Aug 13, 2012 6:27 pm
xs2inattar wrote:Similar issues with PS3. Files that were working with 0.6.2 and 1.0 are having issues with 1.0.1.
1.0 and 1.0.1 had no changes that could be relevant to what you're seeing. Are you using the right profiles?
NX3
Post Mon Aug 13, 2012 8:28 pm
I added this to the 2011 profile to get online audio working, seems to do the job but not for iplayer. I've not investigated any further as yet
<OnlineTranscoding>
      <Video targetContainer="mpegts" targetACodec="ac3" forceInheritance="false">
      <Matches container="mp4" aCodec="aac" />
      <Matches container="applehttp" vCodec="h264" />
   </OnlineTranscoding>
Lowlander
Post Tue Aug 14, 2012 1:41 pm
zip wrote:Can you post the profile?
Yes, of course, but it's just the stock 1.0.1 profile with some lines referring to AAC commented out:
From the sony2012 section:
         <!-- Remux containers with h264 video + AC3 audio to MPEG-TS stream without transcoding (pass AAC audio on to the next matching ruleset) -->
         <Video targetContainer="mpegts" forceInheritance="true">
            <Matches container="avi" vCodec="h264" aCodec="ac3" />
            <!-- <Matches container="avi" vCodec="h264" aCodec="aac" />         -->
            <Matches container="matroska" vCodec="h264" aCodec="ac3" />
            <!-- <Matches container="matroska" vCodec="h264" aCodec="aac" />    -->
            <Matches container="flv" vCodec="h264" aCodec="ac3" />
            <!-- <Matches container="flv" vCodec="h264" aCodec="aac" />         -->
And I commented out the first ruleset in sony2012's OnlineTranscoding section to leave everything to the second ruleset, which transcodes any online audio to ac3.
In the meantime I went back to my trusted 0.6 version and found that aac had to be transcoded back then as well. Is it vaguely possible that the Bravias don't like aac in an mpegts container at all? I seem to remember that we once could play matroska/avc/aac and matroska/avc/ac3 natively when we tricked the Bravias into playing matroska without remuxing it. The cost back then was the inability to pause/resume, fastforward or rewind such a stream.
Hava a nice one,
Low
NX3
Post Tue Aug 14, 2012 5:25 pm
To clarify you've got files stored locally with AAC that don't play on your 2011 sony ? What model have you got and what firmware version are you on ?
For the record, I've got a KDL-37EX723 and KDL-26EX320 both running firmware "PKG4.012EUA" from 10th August 2012
Can you download and try this file:
http://pdl.stream.aol.com/pdlext/aol/br ... 20p_dl.mov
Stored locally that works, played online no audio so my set can cope with the AAC audio depending on how its delivered it seems.
Lowlander
Post Wed Aug 15, 2012 12:20 pm
nx3,
I think we speak of different things here. I meant "online" as in "OnlineTranscoding" of internet sources, opposed to playing back files stored locally (i.e. on a server in my own basement), delivered by Serviio. Haven't tried playing back files from a local storage (USB) on the TV yet.
As stated above I think the Bravias don't like the mpegts/avc/aac combination created by Serviio remuxing processes following suitable matching rules. I'm pretty sure this applies to transcoding/remuxing of online (=internet) sources as well, but that's another thread. We could try remuxing some mkv/avc/aac file to ts and feeding it to the TV "locally" via USB. Haven't got any FAT formatted stick at the moment though...
NX3 wrote:so my set can cope with the AAC audio depending on how its delivered it seems.
Exactly. Main difference is that a mov/avc/aac file that plays fine from USB is delivered as mpegts/avc/aac through DLNA, a combination the Sonys don't seem to like.
