YOUTUBE TOP 100 MUSIC VIDEOS WEB RESOURCE
TheOne.PC
Post Sun Aug 12, 2012 8:08 pm
Re: YOUTUBE TOP 100 MUSIC VIDEOS WEB RESOURCE
jhb50 wrote:V10 released to fix timeout with Serviio 1.0
With Serviio 1.0.1 the problem is back :(
Post Sun Aug 12, 2012 8:54 pm
Thanks for letting me know but its not happening to me. I have an open issue with zip on this. Could you please post your "DEBUG" log starting at the line 2012-08-08 20:24:17,688 DEBUG [WebResourceParser] Parsing web resource 'http://www.youtubetop100.com' through to the 30000 timeout so we can pin the problem down?
TheOne.PC
Post Mon Aug 13, 2012 10:13 am
2012-08-13 12:07:48,068 DEBUG [TechnicalMetadataCacheDecorator] Stored technical metadata for online item 'http://www.youtube.com/watch?v=evjkQ3JySMY&feature=youtube_gdata_22' in the cache (online_technical_metadata), returning it
2012-08-13 12:07:48,068 DEBUG [OnlineLibraryManager] Thumbnail http://i2.ytimg.com/vi/evjkQ3JySMY/default.jpg not in cache yet, loading it
2012-08-13 12:07:48,135 DEBUG [CoverImageService] Resizing and storing cover art image
2012-08-13 12:07:48,136 DEBUG [ImageUtils] Starting image resize, size = 3678 bytes
2012-08-13 12:07:48,150 DEBUG [ImageUtils] Returning resized image, size = 2777 bytes
2012-08-13 12:07:48,150 DEBUG [CoverImageService] Image successfully resized
2012-08-13 12:07:48,151 DEBUG [ThumbnailCacheDecorator] Stored entry in the cache (thumbnails), returning it
2012-08-13 12:07:48,151 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 68)
2012-08-13 12:07:48,152 DEBUG [OnlineLibraryManager] Resource http://www.youtubetop100.com?type=475&res=720 not in cache yet, loading it
2012-08-13 12:07:48,152 DEBUG [WebResourceParser] Parsing web resource 'http://www.youtubetop100.com?type=475&res=720'
2012-08-13 12:07:48,153 DEBUG [WebResourceParser] Found matching url extractor (YouTubeTop100) for resource http://www.youtubetop100.com?type=475&res=720
2012-08-13 12:07:48,153 DEBUG [FeedItemUrlExtractor] YouTubeTop100: Starting parsing resource: http://www.youtubetop100.com?type=475&res=720
2012-08-13 12:07:51,978 DEBUG [AbstractCDSLibraryIndexingListener] Library updated, notifying CDS
2012-08-13 12:08:09,351 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth0 (eth0) and address 192.168.1.2, timeout = 0
2012-08-13 12:08:09,352 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 83403509-60a4-3ac0-bae1-94340baf2344
2012-08-13 12:08:11,158 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:36
2012-08-13 12:08:18,160 WARN  [FeedUpdaterThread] An error occured while scanning for online item information, will continue
java.io.IOException: Unexpected error while invoking plugin (YouTubeTop100): The operation took more than 30000 ms and has been cancelled.
   at org.serviio.library.online.WebResourceParser.parse(WebResourceParser.java:58)
   at org.serviio.library.online.OnlineLibraryManager.findResource(OnlineLibraryManager.java:171)
Caused by: java.lang.RuntimeException: The operation took more than 30000 ms and has been cancelled.
   at org.serviio.library.online.PluginExecutionProcessor.execute(PluginExecutionProcessor.java:64)
   at org.serviio.library.online.WebResourceUrlExtractor.parseWebResource(WebResourceUrlExtractor.java:29)
   at org.serviio.library.online.WebResourceParser.parse(WebResourceParser.java:56)
   ... 4 more
2012-08-13 12:08:18,161 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 69)
2012-08-13 12:08:18,161 DEBUG [OnlineLibraryManager] Resource http://www.youtubetop100.com?type=473&res=720 not in cache yet, loading it
2012-08-13 12:08:18,162 DEBUG [WebResourceParser] Parsing web resource 'http://www.youtubetop100.com?type=473&res=720'
2012-08-13 12:08:18,162 DEBUG [WebResourceParser] Found matching url extractor (YouTubeTop100) for resource http://www.youtubetop100.com?type=473&res=720
2012-08-13 12:08:18,162 DEBUG [FeedItemUrlExtractor] YouTubeTop100: Starting parsing resource: http://www.youtubetop100.com?type=473&res=720
2012-08-13 12:08:32,095 DEBUG [WebServer] I/O error: Connection reset
2012-08-13 12:08:48,117 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth0 (eth0) and address 192.168.1.2, timeout = 0
2012-08-13 12:08:48,119 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 83403509-60a4-3ac0-bae1-94340baf2344
2012-08-13 12:08:48,163 WARN  [FeedUpdaterThread] An error occured while scanning for online item information, will continue
   ... 4 more
2012-08-13 12:08:48,163 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 70)
2012-08-13 12:08:48,164 DEBUG [OnlineLibraryManager] Resource http://www.youtubetop100.com?type=466&res=720 not in cache yet, loading it
2012-08-13 12:08:48,164 DEBUG [WebResourceParser] Parsing web resource 'http://www.youtubetop100.com?type=466&res=720'
2012-08-13 12:08:48,164 DEBUG [WebResourceParser] Found matching url extractor (YouTubeTop100) for resource http://www.youtubetop100.com?type=466&res=720
2012-08-13 12:08:48,164 DEBUG [FeedItemUrlExtractor] YouTubeTop100: Starting parsing resource: http://www.youtubetop100.com?type=466&res=720
2012-08-13 12:08:49,924 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:46
Post Mon Aug 13, 2012 2:40 pm
I do not know why you are getting the timeout while adding items. The I/O error is likely the cause but I don't know where that is coming from. The same urls work fine for me.
Attached is the V10 Top100.groovy with log statements added which will show a line each time an item is added. If you will use that groovy and post the log it will give me more info.
Top100.groovy
DEBUG VERSION
(10.92 KiB) Downloaded 919 times
TheOne.PC
Post Mon Aug 13, 2012 5:54 pm
Everything all right, i wasn't using the v10 of the plugin because it wasn't in the "all plugin pack" - http://forum.serviio.org/viewtopic.php?f=20&t=3820
Sorry :?
Post Mon Aug 13, 2012 8:19 pm
Version 11 posted with Version number added to log so users can verify version being used.
ansonkemp
Post Wed Sep 12, 2012 1:36 pm
Using Version 11 and getting this error
2012-09-12 15:20:56,810 DEBUG [FeedParser] Parsing feed 'http://www.youtubetop100.com?type=472&res=720'
2012-09-12 15:20:57,162 DEBUG [FeedParser] Feed failed parsing (Invalid XML), trying BOM detection
2012-09-12 15:20:57,166 DEBUG [FeedParser] BOM Feed failed parsing (Invalid XML: Error on line 34: The element type "link" must be terminated by the matching end-tag "</link>".), trying unzipping it
2012-09-12 15:20:57,166 WARN [FeedUpdaterThread] An error occured while scanning for online item information, will continue
java.io.IOException: Cannot parse resource from http://www.youtubetop100.com?type=472&res=720. Message: Error during feed parsing, provided URL probably doesn't point to a valid RSS/Atom feed. Message: Invalid XML
at org.serviio.library.online.OnlineLibraryManager.findResource(OnlineLibraryManager.java:179)
Does anyone know why?
Post Wed Sep 12, 2012 5:02 pm
As it says this is a webresource not an rss/atom.
Post Tue Sep 18, 2012 3:13 am
Version 12 added to support new YouTube code. Prior versions no longer work.
grolschie
Post Tue Sep 18, 2012 4:42 am
Thank you for that jhb50.
Xmantium
Post Fri Sep 21, 2012 9:01 pm
Hi jhb50, this plugin just gets better, thankyou very much! Who knew Gangnam Style is the most popular track in my household and many to discover!
Are you able to add the Billboard Top 20 list too? - http://www.youtube.com/playlist?list=BB ... ature=plpp
The latest playlist date can be found on the right hand side here
Post Sat Sep 22, 2012 12:53 am
Good idea. viewtopic.php?f=20&t=7500
Xmantium
Post Sat Sep 22, 2012 7:39 am
jhb50 wrote:Good idea. viewtopic.php?f=20&t=7500
That was quick!
Was not possible to include this list in this plugin rather than a new one?
This way it will be less maintenance for you when there's changes to YouTube.
jenaas2107
Post Thu Oct 04, 2012 7:17 am
You can watch very interesting movies that comes under top 100 comedy movies. Comedy movies are enjoyable to watch and good to spend the free time of holidays. I also like to watch movies that are very interesting.
Post Thu Oct 04, 2012 12:39 pm
jenaas2107 wrote:You can watch very interesting movies that comes under top 100 comedy movies. Comedy movies are enjoyable to watch and good to spend the free time of holidays. I also like to watch movies that are very interesting.
That site only ranks movies and shows trailers. It does not show the movies themselves.
YTMY
Post Sun Oct 21, 2012 3:30 pm
hi, first thanks for one of the best plugins :)
Until recently everything was flawless. But this week I noticed a problem - titles do not correspond to videos. When I press to play for example a gotye song, it plays a totally different video (which I think is from the same playlist). Can it be that Youtube coding changed somehow or is my library messed up? Refreshing, restarting, re-adding source does not help. Here is the example of one source (the same problem is for all sources I use with this plugin):
P.S. I encounter the same problem with Billboard top 20 plugin.
Thanks for your help in advance.
| Samsung UE32C6500 LED | Windows 7 x64 | 5Ghz wi-fi N 300Mbps setup |
Post Sun Oct 21, 2012 8:55 pm
Thanks for the heads up. YouTube changed the format so I've posted V13.
Post Fri Nov 30, 2012 10:26 pm
V14 corrects 'for' parameter error.
Post Sun Dec 09, 2012 6:35 pm
Version 15 posted to force daily listing per youtube change.
Post Sun Dec 09, 2012 8:44 pm
Version 16 posted to restore weekly listing
Return to Available plugins
Users browsing this forum: No registered users and 112 guests
