Re: YOUTUBE TOP 100 MUSIC VIDEOS WEB RESOURCE
jhb50 wrote:V10 released to fix timeout with Serviio 1.0
With Serviio 1.0.1 the problem is back
TheOne.PC wrote:jhb50 wrote:V10 released to fix timeout with Serviio 1.0
2012-08-13 12:07:48,068 DEBUG [TechnicalMetadataCacheDecorator] Stored technical metadata for online item 'http://www.youtube.com/watch?v=evjkQ3JySMY&feature=youtube_gdata_22' in the cache (online_technical_metadata), returning it
2012-08-13 12:07:48,068 DEBUG [OnlineLibraryManager] Thumbnail http://i2.ytimg.com/vi/evjkQ3JySMY/default.jpg not in cache yet, loading it
2012-08-13 12:07:48,135 DEBUG [CoverImageService] Resizing and storing cover art image
2012-08-13 12:07:48,136 DEBUG [ImageUtils] Starting image resize, size = 3678 bytes
2012-08-13 12:07:48,150 DEBUG [ImageUtils] Returning resized image, size = 2777 bytes
2012-08-13 12:07:48,150 DEBUG [CoverImageService] Image successfully resized
2012-08-13 12:07:48,151 DEBUG [ThumbnailCacheDecorator] Stored entry in the cache (thumbnails), returning it
2012-08-13 12:07:48,151 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 68)
2012-08-13 12:07:48,152 DEBUG [OnlineLibraryManager] Resource http://www.youtubetop100.com?type=475&res=720 not in cache yet, loading it
2012-08-13 12:07:48,152 DEBUG [WebResourceParser] Parsing web resource 'http://www.youtubetop100.com?type=475&res=720'
2012-08-13 12:07:48,153 DEBUG [WebResourceParser] Found matching url extractor (YouTubeTop100) for resource http://www.youtubetop100.com?type=475&res=720
2012-08-13 12:07:48,153 DEBUG [FeedItemUrlExtractor] YouTubeTop100: Starting parsing resource: http://www.youtubetop100.com?type=475&res=720
2012-08-13 12:07:51,978 DEBUG [AbstractCDSLibraryIndexingListener] Library updated, notifying CDS
2012-08-13 12:08:09,351 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth0 (eth0) and address 192.168.1.2, timeout = 0
2012-08-13 12:08:09,352 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 83403509-60a4-3ac0-bae1-94340baf2344
2012-08-13 12:08:11,158 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:36
2012-08-13 12:08:18,160 WARN [FeedUpdaterThread] An error occured while scanning for online item information, will continue
java.io.IOException: Unexpected error while invoking plugin (YouTubeTop100): The operation took more than 30000 ms and has been cancelled.
at org.serviio.library.online.WebResourceParser.parse(WebResourceParser.java:58)
at org.serviio.library.online.OnlineLibraryManager.findResource(OnlineLibraryManager.java:171)
Caused by: java.lang.RuntimeException: The operation took more than 30000 ms and has been cancelled.
at org.serviio.library.online.PluginExecutionProcessor.execute(PluginExecutionProcessor.java:64)
at org.serviio.library.online.WebResourceUrlExtractor.parseWebResource(WebResourceUrlExtractor.java:29)
at org.serviio.library.online.WebResourceParser.parse(WebResourceParser.java:56)
... 4 more
2012-08-13 12:08:18,161 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 69)
2012-08-13 12:08:18,161 DEBUG [OnlineLibraryManager] Resource http://www.youtubetop100.com?type=473&res=720 not in cache yet, loading it
2012-08-13 12:08:18,162 DEBUG [WebResourceParser] Parsing web resource 'http://www.youtubetop100.com?type=473&res=720'
2012-08-13 12:08:18,162 DEBUG [WebResourceParser] Found matching url extractor (YouTubeTop100) for resource http://www.youtubetop100.com?type=473&res=720
2012-08-13 12:08:18,162 DEBUG [FeedItemUrlExtractor] YouTubeTop100: Starting parsing resource: http://www.youtubetop100.com?type=473&res=720
2012-08-13 12:08:32,095 DEBUG [WebServer] I/O error: Connection reset
2012-08-13 12:08:48,117 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth0 (eth0) and address 192.168.1.2, timeout = 0
2012-08-13 12:08:48,119 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 83403509-60a4-3ac0-bae1-94340baf2344
2012-08-13 12:08:48,163 WARN [FeedUpdaterThread] An error occured while scanning for online item information, will continue
... 4 more
2012-08-13 12:08:48,163 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 70)
2012-08-13 12:08:48,164 DEBUG [OnlineLibraryManager] Resource http://www.youtubetop100.com?type=466&res=720 not in cache yet, loading it
2012-08-13 12:08:48,164 DEBUG [WebResourceParser] Parsing web resource 'http://www.youtubetop100.com?type=466&res=720'
2012-08-13 12:08:48,164 DEBUG [WebResourceParser] Found matching url extractor (YouTubeTop100) for resource http://www.youtubetop100.com?type=466&res=720
2012-08-13 12:08:48,164 DEBUG [FeedItemUrlExtractor] YouTubeTop100: Starting parsing resource: http://www.youtubetop100.com?type=466&res=720
2012-08-13 12:08:49,924 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:462012-09-12 15:20:56,810 DEBUG [FeedParser] Parsing feed 'http://www.youtubetop100.com?type=472&res=720'
2012-09-12 15:20:57,162 DEBUG [FeedParser] Feed failed parsing (Invalid XML), trying BOM detection
2012-09-12 15:20:57,166 DEBUG [FeedParser] BOM Feed failed parsing (Invalid XML: Error on line 34: The element type "link" must be terminated by the matching end-tag "</link>".), trying unzipping it
2012-09-12 15:20:57,166 WARN [FeedUpdaterThread] An error occured while scanning for online item information, will continue
java.io.IOException: Cannot parse resource from http://www.youtubetop100.com?type=472&res=720. Message: Error during feed parsing, provided URL probably doesn't point to a valid RSS/Atom feed. Message: Invalid XML
at org.serviio.library.online.OnlineLibraryManager.findResource(OnlineLibraryManager.java:179)
jhb50 wrote:Good idea. viewtopic.php?f=20&t=7500
jenaas2107 wrote:You can watch very interesting movies that comes under top 100 comedy movies. Comedy movies are enjoyable to watch and good to spend the free time of holidays. I also like to watch movies that are very interesting.
