TV/stream keeps dropping out
Wingsgb
Post Sat Aug 18, 2012 4:53 pm
Hi all,
I usually watch The football streams that are available through sopcast. I pull the sopcast stream in On my server then add it into serviio as a live stream. This usually works fine but I must admit iv not used it since upgrading.
Football season started today and I launch the stream. Connect to the stream on my Samsung tv and after 1min of it playing fine the tv gets disconnected, I reconnect and the same happens again, I tried this on all three of my Samsung TV's and the same happens.
henri
Post Sat Aug 18, 2012 5:22 pm
Re: TV/stream keeps dropping out
The same issue over here. Tried several Premier League streams and it always jumps back to the DLNA/Folder-structure after 45-60 seconds of playing.
:roll:
Wingsgb
Post Sat Aug 18, 2012 5:36 pm
henri wrote:The same issue over here. Tried several Premier League streams and it always jumps back to the DLNA/Folder-structure after 45-60 seconds of playing.
:roll:
Glad im not the only one then as i was thinking maybe it was something iv done during the season break. I running the exact same setup.
here's my log if its any help.
18:20:28,279 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2012-08-18 18:20:28,279 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2012-08-18 18:20:28,279 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 11)
2012-08-18 18:20:31,728 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth3 (Marvell Yukon 88E8055 PCI-E Gigabit Ethernet Controller) and address 192.168.1.143, timeout = 0
2012-08-18 18:20:31,728 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 21f07a66-faaa-39f4-b470-b0fea48bd497
2012-08-18 18:20:33,529 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:47
2012-08-18 18:20:36,175 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.1.119:62469
2012-08-18 18:20:36,175 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.119
2012-08-18 18:20:36,175 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /192.168.1.119:62469
2012-08-18 18:20:36,176 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.1.119:62469
2012-08-18 18:20:36,179 DEBUG [WebServer] Incoming connection from /192.168.1.119:56962
2012-08-18 18:20:36,179 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.119
2012-08-18 18:20:36,179 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 21f07a66-faaa-39f4-b470-b0fea48bd497 from 192.168.1.119 (headers = [Cache-Control: no-cache,Connection: Close,Pragma: no-cache,Accept: text/xml, application/xml,Host: 192.168.1.143:8895,User-Agent: Microsoft-Windows/6.1 UPnP/1.0 Windows-Media-Player-DMS/12.0.7600.16385 DLNADOC/1.50])
2012-08-18 18:20:36,180 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [Cache-Control: no-cache,Connection: Close,Pragma: no-cache,Accept: text/xml, application/xml,Host: 192.168.1.143:8895,User-Agent: Microsoft-Windows/6.1 UPnP/1.0 Windows-Media-Player-DMS/12.0.7600.16385 DLNADOC/1.50]
2012-08-18 18:20:36,180 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.119
2012-08-18 18:20:36,183 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Generic DLNA profile'
2012-08-18 18:20:36,341 DEBUG [WebServer] Incoming connection from /192.168.1.119:56972
2012-08-18 18:20:36,342 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.119
2012-08-18 18:20:36,343 DEBUG [UPnPIconRequestHandler] UPnP icon request received for icon smallPNG
2012-08-18 18:20:39,175 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /192.168.1.119:62469
2012-08-18 18:20:39,175 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.119
2012-08-18 18:20:39,175 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.1.119:62469
2012-08-18 18:20:39,175 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.1.119:62469
2012-08-18 18:20:41,679 DEBUG [WebServer] I/O error: Connection reset
2012-08-18 18:20:42,175 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /192.168.1.119:62469
2012-08-18 18:20:42,175 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.119
2012-08-18 18:20:42,175 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.1.119:62469
2012-08-18 18:20:42,176 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.1.119:62469
2012-08-18 18:20:49,929 DEBUG [WebServer] Incoming connection from /192.168.1.123:49729
2012-08-18 18:20:49,929 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.123
2012-08-18 18:20:49,930 DEBUG [UPnPIconRequestHandler] UPnP icon request received for icon smallPNG
2012-08-18 18:20:54,410 DEBUG [WebServer] Incoming connection from /192.168.1.123:49730
2012-08-18 18:20:54,410 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.123
2012-08-18 18:20:54,410 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#X_GetFeatureList"' from 192.168.1.123:
2012-08-18 18:20:54,415 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-08-18 18:20:54,538 DEBUG [WebServer] Incoming connection from /192.168.1.123:49731
2012-08-18 18:20:54,538 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.123
2012-08-18 18:20:54,538 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#X_GetFeatureList"' from 192.168.1.123:
2012-08-18 18:20:54,543 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-08-18 18:20:54,583 DEBUG [WebServer] Incoming connection from /192.168.1.123:49732
2012-08-18 18:20:54,583 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.123
2012-08-18 18:20:54,584 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#X_GetFeatureList"' from 192.168.1.123:
2012-08-18 18:20:54,584 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.123
2012-08-18 18:20:54,588 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-08-18 18:20:54,609 DEBUG [WebServer] Incoming connection from /192.168.1.123:49733
2012-08-18 18:20:54,610 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.123
2012-08-18 18:20:54,610 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#X_GetFeatureList"' from 192.168.1.123:
2012-08-18 18:20:54,615 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-08-18 18:20:54,638 DEBUG [WebServer] Incoming connection from /192.168.1.123:49734
2012-08-18 18:20:54,638 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.123
2012-08-18 18:20:54,639 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.123:
2012-08-18 18:20:54,639 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.123
2012-08-18 18:20:54,643 DEBUG [ContentDirectory] Browse() called for renderer UE37ES5500 (profile 7) with parameters: objectID = V, browseFlag = BrowseDirectChildren, filter = *, startIndex = 0, count = 1, sortCriteria =
2012-08-18 18:20:54,643 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2012-08-18 18:20:54,644 DEBUG [RepositoryDAOImpl] Retrieving number of repositories for VIDEO [No_Restriction]
2012-08-18 18:20:54,647 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-08-18 18:20:54,670 DEBUG [WebServer] Incoming connection from /192.168.1.123:49735
2012-08-18 18:20:54,670 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.123
2012-08-18 18:20:54,671 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.123:
2012-08-18 18:20:54,671 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.123
2012-08-18 18:20:54,674 DEBUG [ContentDirectory] Browse() called for renderer UE37ES5500 (profile 7) with parameters: objectID = V, browseFlag = BrowseDirectChildren, filter = *, startIndex = 0, count = 30, sortCriteria =
2012-08-18 18:20:54,674 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2012-08-18 18:20:54,675 DEBUG [RepositoryDAOImpl] Retrieving number of repositories for VIDEO [No_Restriction]
2012-08-18 18:20:54,676 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [FEED, WEB_RESOURCE] OnlineRepositories for VIDEO [No_Restriction]
2012-08-18 18:20:54,677 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [LIVE_STREAM] OnlineRepositories for VIDEO [No_Restriction]
2012-08-18 18:20:54,680 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-08-18 18:20:54,833 DEBUG [WebServer] Incoming connection from /192.168.1.123:49736
2012-08-18 18:20:54,833 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.123
2012-08-18 18:20:54,834 DEBUG [UPnPIconRequestHandler] UPnP icon request received for icon smallPNG
2012-08-18 18:20:55,946 DEBUG [WebServer] Incoming connection from /192.168.1.123:49737
2012-08-18 18:20:55,947 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.123
2012-08-18 18:20:55,947 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#X_GetFeatureList"' from 192.168.1.123:
2012-08-18 18:20:55,952 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-08-18 18:20:55,973 DEBUG [WebServer] Incoming connection from /192.168.1.123:49738
2012-08-18 18:20:55,975 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.123
2012-08-18 18:20:55,976 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.123:
2012-08-18 18:20:55,976 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.123
2012-08-18 18:20:55,979 DEBUG [ContentDirectory] Browse() called for renderer UE37ES5500 (profile 7) with parameters: objectID = V_OF, browseFlag = BrowseDirectChildren, filter = *, startIndex = 0, count = 1, sortCriteria =
2012-08-18 18:20:55,979 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2012-08-18 18:20:55,979 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [FEED, WEB_RESOURCE] OnlineRepositories for VIDEO [No_Restriction]
2012-08-18 18:20:55,980 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [LIVE_STREAM] OnlineRepositories for VIDEO [No_Restriction]
2012-08-18 18:20:55,981 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1000000000110001 and profile Samsung TV / player (C/D/E-series)
2012-08-18 18:20:55,981 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [FEED, WEB_RESOURCE] OnlineRepositories for VIDEO [No_Restriction]
2012-08-18 18:20:55,981 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [LIVE_STREAM] OnlineRepositories for VIDEO [No_Restriction]
2012-08-18 18:20:55,986 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-08-18 18:20:56,004 DEBUG [WebServer] Incoming connection from /192.168.1.123:49739
2012-08-18 18:20:56,004 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.123
2012-08-18 18:20:56,005 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.123:
2012-08-18 18:20:56,005 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.123
2012-08-18 18:20:56,008 DEBUG [ContentDirectory] Browse() called for renderer UE37ES5500 (profile 7) with parameters: objectID = V_OF, browseFlag = BrowseDirectChildren, filter = *, startIndex = 0, count = 30, sortCriteria =
2012-08-18 18:20:56,008 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2012-08-18 18:20:56,009 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [FEED, WEB_RESOURCE] OnlineRepositories for VIDEO [No_Restriction]
2012-08-18 18:20:56,009 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [LIVE_STREAM] OnlineRepositories for VIDEO [No_Restriction]
2012-08-18 18:20:56,010 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1000000000110001 and profile Samsung TV / player (C/D/E-series)
2012-08-18 18:20:56,010 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [FEED, WEB_RESOURCE] OnlineRepositories for VIDEO [No_Restriction]
2012-08-18 18:20:56,010 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [LIVE_STREAM] OnlineRepositories for VIDEO [No_Restriction]
2012-08-18 18:20:56,017 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-08-18 18:20:56,162 DEBUG [WebServer] Incoming connection from /192.168.1.123:49740
2012-08-18 18:20:56,162 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.123
2012-08-18 18:20:56,163 DEBUG [UPnPIconRequestHandler] UPnP icon request received for icon smallPNG
2012-08-18 18:20:57,319 DEBUG [WebServer] Incoming connection from /192.168.1.123:49741
2012-08-18 18:20:57,320 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.123
2012-08-18 18:20:57,320 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.123:
2012-08-18 18:20:57,323 DEBUG [ContentDirectory] Browse() called for renderer UE37ES5500 (profile 7) with parameters: objectID = V_OF^FOL_$OI1000000000110001, browseFlag = BrowseMetadata, filter = *, startIndex = 0, count = 1, sortCriteria =
2012-08-18 18:20:57,323 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2012-08-18 18:20:57,324 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 11)
2012-08-18 18:20:57,324 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1000000000110001 and profile Samsung TV / player (C/D/E-series)
2012-08-18 18:20:57,328 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-08-18 18:20:57,461 DEBUG [WebServer] Incoming connection from /192.168.1.123:49742
2012-08-18 18:20:57,462 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.123
2012-08-18 18:20:57,463 DEBUG [ResourceTransportRequestHandler] HEAD /resource/1000000000110001/MEDIA_ITEM/MPEG_PS_NTSC-0/ORIGINAL HTTP/1.0, headers = [getcontentFeatures.dlna.org: 1,Host: 192.168.1.143:8895]]
2012-08-18 18:20:57,464 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.123
2012-08-18 18:20:57,464 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.123, Profile=Samsung TV / player (C/D/E-series)'
2012-08-18 18:20:57,465 DEBUG [ResourceDeliveryProcessor] Request for resource 1000000000110001 and type 'MEDIA_ITEM' received
2012-08-18 18:20:57,465 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1000000000110001 (online)
2012-08-18 18:20:57,465 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 11)
2012-08-18 18:20:57,466 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1000000000110001, format MPEG_PS_NTSC and profile Samsung TV / player (C/D/E-series)
2012-08-18 18:20:57,467 DEBUG [ResourceDeliveryProcessor] Sending HEAD response back
2012-08-18 18:20:57,467 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Content-Length: 50000000000,Date: Sat, 18 Aug 2012 17:20:57 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=MPEG_PS_NTSC;DLNA.ORG_OP=00;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=8D500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2012-08-18 18:20:57,478 DEBUG [WebServer] Incoming connection from /192.168.1.123:49743
2012-08-18 18:20:57,479 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.123
2012-08-18 18:20:57,479 DEBUG [ResourceTransportRequestHandler] GET /resource/1000000000110001/MEDIA_ITEM/MPEG_PS_NTSC-0/ORIGINAL HTTP/1.0, headers = [getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,getMediaInfo.sec: 1,Host: 192.168.1.143:8895]]
2012-08-18 18:20:57,480 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.123, Profile=Samsung TV / player (C/D/E-series)'
2012-08-18 18:20:57,491 DEBUG [ResourceDeliveryProcessor] Request for resource 1000000000110001 and type 'MEDIA_ITEM' received
2012-08-18 18:20:57,491 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1000000000110001 (online)
2012-08-18 18:20:57,491 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 11)
2012-08-18 18:20:57,491 DEBUG [VideoDeliveryEngine] Delivering item '1000000000110001' for client 'IPAddress=/192.168.1.123, Profile=Samsung TV / player (C/D/E-series)'
2012-08-18 18:20:57,491 DEBUG [VideoDeliveryEngine] Delivering file 'http://127.0.0.1:8902/' in native format
2012-08-18 18:20:57,492 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 50000000000
2012-08-18 18:20:57,492 DEBUG [ResourceDeliveryProcessor] Sending file back
2012-08-18 18:20:57,492 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Content-Length: 50000000000,Date: Sat, 18 Aug 2012 17:20:57 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=MPEG_PS_NTSC;DLNA.ORG_OP=00;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=8D500000000000000000000000000000,transferMode.dlna.org: Streaming,MediaInfo.sec: SEC_Duration=18000000;]]
2012-08-18 18:20:57,492 DEBUG [OnlineInputStream] Reading 1512000 bytes starting at 0
2012-08-18 18:20:57,522 DEBUG [OnlineInputStream] Byte range not supported for http://127.0.0.1:8902/, returning the whole stream
2012-08-18 18:20:58,224 DEBUG [WebServer] Incoming connection from /192.168.1.123:57132
2012-08-18 18:20:58,225 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.123
2012-08-18 18:20:58,225 DEBUG [ResourceTransportRequestHandler] HEAD /resource/1000000000110001/MEDIA_ITEM/MPEG_PS_NTSC-0/ORIGINAL HTTP/1.0, headers = [getCaptionInfo.sec: 1]]
2012-08-18 18:20:58,225 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.123, Profile=Samsung TV / player (C/D/E-series)'
2012-08-18 18:20:58,226 DEBUG [ResourceDeliveryProcessor] Request for resource 1000000000110001 and type 'MEDIA_ITEM' received
2012-08-18 18:20:58,226 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1000000000110001 (online)
2012-08-18 18:20:58,226 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 11)
2012-08-18 18:20:58,226 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1000000000110001, format MPEG_PS_NTSC and profile Samsung TV / player (C/D/E-series)
2012-08-18 18:20:58,226 DEBUG [ResourceDeliveryProcessor] Sending HEAD response back
2012-08-18 18:20:58,226 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Content-Length: 50000000000,Date: Sat, 18 Aug 2012 17:20:58 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,transferMode.dlna.org: Streaming]]
2012-08-18 18:21:21,447 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth3 (Marvell Yukon 88E8055 PCI-E Gigabit Ethernet Controller) and address 192.168.1.143, timeout = 0
2012-08-18 18:21:21,457 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 21f07a66-faaa-39f4-b470-b0fea48bd497
2012-08-18 18:21:23,258 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:51
2012-08-18 18:21:28,280 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2012-08-18 18:21:28,280 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2012-08-18 18:21:28,281 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 11)
2012-08-18 18:21:28,625 DEBUG [PlaylistDAOImpl] Reading all Playlists
2012-08-18 18:21:33,980 DEBUG [RepositoryDAOImpl] Reading all Repositories
2012-08-18 18:21:34,842 DEBUG [RepositoryDAOImpl] Marking Repository 2 as scanned with current timestamp
2012-08-18 18:21:39,294 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /192.168.1.123:24234
2012-08-18 18:21:39,294 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.123
2012-08-18 18:21:39,295 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.1.123:24234
2012-08-18 18:21:44,969 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2012-08-18 18:21:44,969 DEBUG [OnlineInputStream] Closing stream
2012-08-18 18:21:45,176 DEBUG [WebServer] I/O error: Connection reset
2012-08-18 18:22:15,778 DEBUG [WebServer] Incoming connection from /192.168.1.123:49748
2012-08-18 18:22:15,778 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.123
2012-08-18 18:22:15,778 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 21f07a66-faaa-39f4-b470-b0fea48bd497 from 192.168.1.123 (headers = [HOST: 192.168.1.143:8895,ACCEPT-ENCODING: deflate,ACCEPT-LANGUAGE: en-us,User-Agent: SEC_HHP_[TV]UE37ES5500/1.0 DLNADOC/1.50])
2012-08-18 18:22:15,778 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [HOST: 192.168.1.143:8895,ACCEPT-ENCODING: deflate,ACCEPT-LANGUAGE: en-us,User-Agent: SEC_HHP_[TV]UE37ES5500/1.0 DLNADOC/1.50]
2012-08-18 18:22:15,778 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Samsung TV / player (C/D/E-series)'
2012-08-18 18:22:15,788 DEBUG [WebServer] Incoming connection from /192.168.1.123:49749
2012-08-18 18:22:15,788 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.123
2012-08-18 18:22:15,788 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ConnectionManager
2012-08-18 18:22:15,788 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2012-08-18 18:22:15,798 DEBUG [WebServer] Incoming connection from /192.168.1.123:49750
2012-08-18 18:22:15,798 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.123
2012-08-18 18:22:15,798 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ContentDirectory
2012-08-18 18:22:15,798 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2012-08-18 18:22:15,808 DEBUG [WebServer] Incoming connection from /192.168.1.123:49751
2012-08-18 18:22:15,808 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.123
2012-08-18 18:22:15,808 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service X_MS_MediaReceiverRegistrar
2012-08-18 18:22:15,818 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2012-08-18 18:22:16,978 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:42
2012-08-18 18:22:28,282 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2012-08-18 18:22:28,282 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2012-08-18 18:22:28,283 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 11)
2012-08-18 18:23:00,191 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth3 (Marvell Yukon 88E8055 PCI-E Gigabit Ethernet Controller) and address 192.168.1.143, timeout = 0
2012-08-18 18:23:00,191 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 21f07a66-faaa-39f4-b470-b0fea48bd497
2012-08-18 18:23:01,991 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:55
2012-08-18 18:23:28,287 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2012-08-18 18:23:28,287 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2012-08-18 18:23:28,287 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 11)
2012-08-18 18:23:57,651 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth3 (Marvell Yukon 88E8055 PCI-E Gigabit Ethernet Controller) and address 192.168.1.143, timeout = 0
2012-08-18 18:23:57,651 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 21f07a66-faaa-39f4-b470-b0fea48bd497
2012-08-18 18:23:59,451 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:59
2012-08-18 18:24:28,287 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2012-08-18 18:24:28,287 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2012-08-18 18:24:28,287 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 11)
2012-08-18 18:24:59,590 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth3 (Marvell Yukon 88E8055 PCI-E Gigabit Ethernet Controller) and address 192.168.1.143, timeout = 0
2012-08-18 18:24:59,590 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 21f07a66-faaa-39f4-b470-b0fea48bd497
2012-08-18 18:25:01,390 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:37
2012-08-18 18:25:28,287 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2012-08-18 18:25:28,287 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2012-08-18 18:25:28,288 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 11)
2012-08-18 18:25:39,709 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth3 (Marvell Yukon 88E8055 PCI-E Gigabit Ethernet Controller) and address 192.168.1.143, timeout = 0
2012-08-18 18:25:39,709 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 21f07a66-faaa-39f4-b470-b0fea48bd497
2012-08-18 18:25:41,519
henri
Post Sat Aug 18, 2012 5:50 pm
Wingsgb wrote:I running the exact same setup.
Me too. I first thought it may be some impulse-signal from Sky or ESPN (yeah, conspiracy theory :)) so I tried other streams from other countries (e.g. a low-bitrate stream from the Polish League) = same issue.
When I stream 720p/1080p files from my HDD, it works without any problem.
henri
Post Sat Aug 18, 2012 8:20 pm
Do you use Serviio 1.0.1 or still 1.0? I downgraded to 1.0 and now I can stream a certain "bloody" ;) Sopcast stream without any interruption. Try it out! Will see tomorrow if it work during PL...
Wingsgb
Post Sat Aug 18, 2012 10:51 pm
Yes I recently updated to 1.0.1
Same thing, I also have no issues streaming high qauilty streams. Especially through the browser.
I'll try switching back to 1.0 tomorrow and report back when the match is on. Did you do a fresh install? I'll have to find a link for 1.0 on google as its not on the main site no more. This might prove it in the new build.
henri
Post Sun Aug 19, 2012 7:26 am
Wingsgb wrote:Yes I recently updated to 1.0.1
Please let me/us know if it worked :) Could be helpful for many football fans!
Post Sun Aug 19, 2012 11:15 am
I think it's down to the quality of the stream. 1.0.1 did have no changes from 1.0 that could affect this.
henri
Post Sun Aug 19, 2012 11:47 am
zip wrote:I think it's down to the quality of the stream. 1.0.1 did have no changes from 1.0 that could affect this.
Hi, stream was the same. On the pc the stream was played without any interruption. Also tried various different streams, all of them were gone after a max of 1 minute :cry: Soon Wigan - Chelsea will start, will see then...
henri
Post Sun Aug 19, 2012 11:53 am
Update: stream just stopped again :cry: :cry: :cry: It's really a mystery...
Wingsgb
Post Sun Aug 19, 2012 12:06 pm
Iv downgraded to version 1.0 and the stream is still dropping out.
@zip what do you mean down to the quality of the stream? It was never an issue before and the stream is playing fine on the server with a 98% buffer.
I'm going to roll back to 0.6.2 when I know it definitely worked and see what happens
henri
Post Sun Aug 19, 2012 12:24 pm
Wingsgb wrote:I'm going to roll back to 0.6.2 when I know it definitely worked and see what happens
Did the same about 10 minutes ago and the stream is still working as normal... so the issue most likely to be caused by the switch from 0.6.2 to 1.0. :?:
Since I only use Serviio for this purpose I can live with 0.6.2 but I guess there are many others who also use it differently.
EDIT: Stream stopped again. I give up and start to believe the conspiracy theory... :cry:
Wingsgb
Post Sun Aug 19, 2012 1:13 pm
Mine seems to be playing but on my D series tv im getting some serious transcoding issues, it wont settle out, stop starting with a messed up pic. The E series tv is doing the same but throwing up an error saying unsupported audio.
This sucks :( how its not your theory lol and its a problem on our ends/ serviio
henri
Post Sun Aug 19, 2012 1:21 pm
Wingsgb wrote:Mine seems to be playing
For how long?
Wingsgb wrote:its a problem on our ends/ serviio
Must definitely be.. as it makes no sense that the stream is running flawless on the PC :)
Wingsgb
Post Sun Aug 19, 2012 1:49 pm
For how long?
Well i had it running for just over 5min which is alot longer than it was but im having some sort of transcoding issues now so stop it while i have a play with the profile. It played smooth on 1.0.1 just kept cutting out.
There's got to be something happening between serviio picking the stream link up and transcoding it. Its not that the stream ends, serviio is getting disconnected itself.
C:\Program Files\Serviio\lib>ffmpeg.exe -i "http://127.0.0.1:8902/"
nfig
  libavutil    51. 32. 0 / 51. 32. 0
  libavcodec   53. 42. 0 / 53. 42. 0
  libavformat  53. 24. 0 / 53. 24. 0
  libavfilter   2. 53. 0 /  2. 53. 0
[NULL @ 0158a800] non-existing PPS referenced
[h264 @ 0158a800] non-existing PPS 0 referenced
[h264 @ 0158a800] decode_slice_header error
[h264 @ 0158a800] no frame!
[h264 @ 0158a800] non-existing PPS referenced
[mpeg @ 00338040] max_analyze_duration 5000000 reached at 5016000
[mpeg @ 00338040] Estimating duration from bitrate, this may be inaccurate
Input #0, mpeg, from 'http://127.0.0.1:8902/':
  Duration: N/A, start: 49763.978189, bitrate: 192 kb/s
    Stream #0:0[0x1c0]: Audio: mp2, 48000 Hz, stereo, s16, 192 kb/s
    Stream #0:1[0x1e0]: Video: h264 (High), yuv420p, 1280x720 [SAR 1:1 DAR 16:9]
, 31.96 fps, 25 tbr, 90k tbn, 50 tbc
henri
Post Sun Aug 19, 2012 3:22 pm
Wingsgb wrote:Well i had it running for just over 5min which is alot longer than it was
That's right... but the best would be if it runs 90 minutes ;) It's really strange that I was able to watch a stream yesterday for 2 hours without interruption (1.0) :roll:
Post Sun Aug 19, 2012 8:14 pm
h264 in mpeg (ps) container is weird. usually h264 is in mpegts. Might be FFmpeg doesn't like it - try to get the latest FFmpeg.
Wingsgb
Post Sun Aug 19, 2012 11:29 pm
Will try again tomorrow with latest build of ffmpeg, thought I had it tbh, will check.
I do know BZ did some upgrading on his side recently (last month)
Wingsgb
Post Mon Aug 20, 2012 6:32 pm
BZ stream is live now for the Monday night football. I have upgraded serviio back to 1.0.1 and checked my ffmpeg version. This was an old build so have installed the latest.
Loaded everything up and it played for just under 10min then disconnects.
Tried reconnecting and it is back to disconnecting every min.
BZ stream (crashing out)
C:\Program Files\Serviio\lib>ffmpeg.exe -i "http://127.0.0.1:8902"
ffmpeg version N-43594-gf0896a6 Copyright (c) 2000-2012 the FFmpeg developers
  built on Aug 15 2012 21:25:48 with gcc 4.7.1 (GCC)
  configuration: --enable-gpl --enable-version3 --disable-pthreads --enable-runt
ime-cpudetect --enable-avisynth --enable-bzlib --enable-frei0r --enable-libass -
-enable-libcelt --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-l
ibfreetype --enable-libgsm --enable-libmp3lame --enable-libnut --enable-libopenj
peg --enable-librtmp --enable-libschroedinger --enable-libspeex --enable-libtheo
ra --enable-libutvideo --enable-libvo-aacenc --enable-libvo-amrwbenc --enable-li
bvorbis --enable-libvpx --enable-libx264 --enable-libxavs --enable-libxvid --ena
ble-zlib
  libavutil      51. 69.100 / 51. 69.100
  libavcodec     54. 52.100 / 54. 52.100
  libavformat    54. 23.101 / 54. 23.101
  libavdevice    54.  2.100 / 54.  2.100
  libavfilter     3.  9.100 /  3.  9.100
  libswscale      2.  1.101 /  2.  1.101
[NULL @ 044f87e0] non-existing PPS referenced
[h264 @ 044f87e0] non-existing PPS 0 referenced
[h264 @ 044f87e0] decode_slice_header error
[h264 @ 044f87e0] no frame!
[h264 @ 044f87e0] non-existing PPS referenced
[mpeg @ 0243bce0] max_analyze_duration 5000000 reached at 5016000
[mpeg @ 0243bce0] Estimating duration from bitrate, this may be inaccurate
Input #0, mpeg, from 'http://127.0.0.1:8902':
  Duration: N/A, start: 3008.078222, bitrate: 192 kb/s
, 38.75 fps, 25 tbr, 90k tbn, 50 tbc
YES stream (working)
ble-zlib
[wmv3 @ 01f0e3c0] Extra data: 8 bits left, value: 0
[asf @ 01f0bce0] freeing incomplete packet size 4213, new 4045
[asf @ 01f0bce0] Estimating duration from bitrate, this may be inaccurate
Guessed Channel Layout for  Input Stream #0.1 : stereo
Input #0, asf, from 'http://127.0.0.1:8902':
    WMFSDKVersion   : 11.0.6002.18049
    WMFSDKNeeded    : 0.0.0.0000
    IsVBR           : 0
  Duration: N/A, start: 5054.666000, bitrate: 1072 kb/s
    Stream #0:0(dut): Video: wmv3 (Main) (WMV3 / 0x33564D57), yuv420p, 720x404,
1024 kb/s, 30 tbr, 1k tbn, 1k tbc
    Stream #0:1(dut): Audio: wmav2 (a[1][0][0] / 0x0161), 44100 Hz, stereo, s16,
 48 kb/s
Dose this mean its ffmpeg thats having the problem
henri
Post Mon Aug 20, 2012 6:37 pm
Wingsgb wrote:BZ stream is live now for the Monday night football. I have upgraded serviio back to 1.0.1 and checked my ffmpeg version. This was an old build so have installed the latest.
