[SOLVED] NAS not hibernating after upgrading to 1.0
• Page 2 of 3 • 1, 2, 3
Thanks patters for the quick update to the synology package.
Re: [SOLVED] NAS not hibernating after upgrading to 1.0
Done, and it works.
Re: NAS not hibernating after upgrading to 1.0
syncmaster wrote:x2 for me.
off-topic:
I'll have to check if with the Crashplan package for the Synology, that when running, the NAS also doesn't hibernate, if the issue is the same...
Continuing that off-topic...
I get this output from running only CrashPlan. I'll make the same change to that and see if it helps.
- Code:
Aug 25 11:58:50 kernel: [606292.960000] [conf] opened by pid 7202 [u:(/volume1/@appstore/java6/jre/bi), comm:(java)]
Aug 25 11:59:48 kernel: [606350.420000] [/etc/localtime] opened by pid 2909 [u:(scemd), comm:(scemd)]
Aug 25 11:59:50 kernel: [606352.720000] [/volume1/@appstore/CrashPlan/conf/default.service.xml] opened by pid 7136 [u:(/volume1/@appstore/java6/jre/bi), comm:(java)]
Aug 25 12:04:50 kernel: [606652.780000] [/volume1/@appstore/CrashPlan/conf/default.service.xml] opened by pid 7136 [u:(/volume1/@appstore/java6/jre/bi), comm:(java)]
Aug 25 12:09:50 kernel: [606952.840000] [/volume1/@appstore/CrashPlan/conf/default.service.xml] opened by pid 7136 [u:(/volume1/@appstore/java6/jre/bi), comm:(java)]
Aug 25 12:13:51 kernel: [607193.520000] [conf] opened by pid 7202 [u:(/volume1/@appstore/java6/jre/bi), comm:(java)]
Aug 25 12:14:50 kernel: [607253.380000] [/volume1/@appstore/CrashPlan/conf/default.service.xml] opened by pid 7136 [u:(/volume1/@appstore/java6/jre/bi), comm:(java)]
Aug 25 12:19:51 kernel: [607553.440000] [/volume1/@appstore/CrashPlan/conf/default.service.xml] opened by pid 7136 [u:(/volume1/@appstore/java6/jre/bi), comm:(java)]
Aug 25 12:24:51 kernel: [607853.500000] [/volume1/@appstore/CrashPlan/conf/default.service.xml] opened by pid 7136 [u:(/volume1/@appstore/java6/jre/bi), comm:(java)]
Aug 25 12:28:51 kernel: [608094.150000] [conf] opened by pid 7202 [u:(/volume1/@appstore/java6/jre/bi), comm:(java)]
Aug 25 12:29:51 kernel: [608154.030000] [/volume1/@appstore/CrashPlan/conf/default.service.xml] opened by pid 7136 [u:(/volume1/@appstore/java6/jre/bi), comm:(java)]
Aug 25 12:34:51 kernel: [608454.090000] [/volume1/@appstore/CrashPlan/conf/default.service.xml] opened by pid 7136 [u:(/volume1/@appstore/java6/jre/bi), comm:(java)]
Aug 25 12:35:13 kernel: [608475.860000] [/etc/ld.so.cache] opened by pid 23511 [u:(/usr/syno/sbin/sshd), comm:(sshd)]
Aug 25 12:39:51 kernel: [608754.150000] [/volume1/@appstore/CrashPlan/conf/default.service.xml] opened by pid 7136 [u:(/volume1/@appstore/java6/jre/bi), comm:(java)]
Aug 25 12:43:52 kernel: [608994.800000] [conf] opened by pid 7202 [u:(/volume1/@appstore/java6/jre/bi), comm:(java)]
Aug 25 12:44:52 kernel: [609054.680000] [/volume1/@appstore/CrashPlan/conf/default.service.xml] opened by pid 7136 [u:(/volume1/@appstore/java6/jre/bi), comm:(java)]
Aug 25 12:49:52 kernel: [609354.740000] [/volume1/@appstore/CrashPlan/conf/default.service.xml] opened by pid 7136 [u:(/volume1/@appstore/java6/jre/bi), comm:(java)]
Aug 25 12:54:52 kernel: [609654.800000] [/volume1/@appstore/CrashPlan/conf/default.service.xml] opened by pid 7136 [u:(/volume1/@appstore/java6/jre/bi), comm:(java)]
Aug 25 12:58:53 kernel: [609895.440000] [conf] opened by pid 7202 [u:(/volume1/@appstore/java6/jre/bi), comm:(java)]
Aug 25 12:59:52 kernel: [609955.330000] [/volume1/@appstore/CrashPlan/conf/default.service.xml] opened by pid 7136 [u:(/volume1/@appstore/java6/jre/bi), comm:(java)]
Aug 25 13:00:18 kernel: [609980.860000] [/etc/localtime] opened by pid 2909 [u:(scemd), comm:(scemd)]
Aug 25 13:05:52 kernel: [610315.400000] [/volume1/@appstore/CrashPlan/conf/default.service.xml] opened by pid 7136 [u:(/volume1/@appstore/java6/jre/bi), comm:(java)]
Aug 25 13:10:52 kernel: [610615.460000] [/volume1/@appstore/CrashPlan/conf/default.service.xml] opened by pid 7136 [u:(/volume1/@appstore/java6/jre/bi), comm:(java)]
Aug 25 13:14:53 kernel: [610856.370000] [conf] opened by pid 7202 [u:(/volume1/@appstore/java6/jre/bi), comm:(java)]
Aug 25 13:15:53 kernel: [610916.000000] [/volume1/@appstore/CrashPlan/conf/default.service.xml] opened by pid 7136 [u:(/volume1/@appstore/java6/jre/bi), comm:(java)]
Aug 25 13:20:53 kernel: [611216.060000] [/volume1/@appstore/CrashPlan/conf/default.service.xml] opened by pid 7136 [u:(/volume1/@appstore/java6/jre/bi), comm:(java)]
Aug 25 13:25:53 kernel: [611516.120000] [/volume1/@appstore/CrashPlan/conf/default.service.xml] opened by pid 7136 [u:(/volume1/@appstore/java6/jre/bi), comm:(java)]
Aug 25 13:29:53 kernel: [611756.760000] [conf] opened by pid 7202 [u:(/volume1/@appstore/java6/jre/bi), comm:(java)]
Aug 25 13:30:53 kernel: [611816.650000] [/volume1/@appstore/CrashPlan/conf/default.service.xml] opened by pid 7136 [u:(/volume1/@appstore/java6/jre/bi), comm:(java)]
Aug 25 13:35:53 kernel: [612116.710000] [/volume1/@appstore/CrashPlan/conf/default.service.xml] opened by pid 7136 [u:(/volume1/@appstore/java6/jre/bi), comm:(java)]
Aug 25 13:40:53 kernel: [612416.770000] [/volume1/@appstore/CrashPlan/conf/default.service.xml] opened by pid 7136 [u:(/volume1/@appstore/java6/jre/bi), comm:(java)]
EDIT - left it running for a bit, the change seems to have stopped the conf thing, but CrashPlan is still polling default.service.xml every 5 minutes
- Code:
Aug 25 16:08:04 kernel: [621246.760000] [/volume1/@appstore/CrashPlan/conf/default.service.xml] opened by pid 26672 [u:(/volume1/@appstore/java6/jre/bi), comm:(java)]
Aug 25 16:13:04 kernel: [621546.820000] [/volume1/@appstore/CrashPlan/conf/default.service.xml] opened by pid 26672 [u:(/volume1/@appstore/java6/jre/bi), comm:(java)]
Aug 25 16:18:04 kernel: [621846.880000] [/volume1/@appstore/CrashPlan/conf/default.service.xml] opened by pid 26672 [u:(/volume1/@appstore/java6/jre/bi), comm:(java)]
Aug 25 16:23:04 kernel: [622147.340000] [/volume1/@appstore/CrashPlan/conf/default.service.xml] opened by pid 26672 [u:(/volume1/@appstore/java6/jre/bi), comm:(java)]
I've tried searching but I can't find anything about this, the other threads are more about logging:
http://forum.qnap.com/viewtopic.php?p=263106
Thing is, why on earth would it poll default.service.xml so regularly - that's the default config. The running config is stored in my.service.xml.
@patters: The -D parameter that works is specifically for the Java preferences framework, nothing to do with this xml file, which is probably specific to Crashplan app.
Petr
Help translate Serviio
I got the same problem, but with the latest package from patters
Synology DS213 (DSM 4.1-2668)
Serviio Package 1.1.0-015
Java SE for Embedded 7 (1.7.0_10-013)
Any help would be greatly appreciated
- Code:
Jan 5 19:12:37 kernel: [14530.930000] [/volume1/public/serviio/plugins] opened by pid 25459 [u:(/volume1/@appstore/java7/jre/bi), comm:(java)]
Jan 5 19:12:47 kernel: [14540.950000] [/volume1/public/serviio/plugins] opened by pid 25459 [u:(/volume1/@appstore/java7/jre/bi), comm:(java)]
Jan 5 19:12:57 kernel: [14550.970000] [/volume1/public/serviio/plugins] opened by pid 25459 [u:(/volume1/@appstore/java7/jre/bi), comm:(java)]
Jan 5 19:13:07 kernel: [14560.990000] [/volume1/public/serviio/plugins] opened by pid 25459 [u:(/volume1/@appstore/java7/jre/bi), comm:(java)]
Jan 5 19:13:17 kernel: [14571.010000] [/volume1/public/serviio/plugins] opened by pid 25459 [u:(/volume1/@appstore/java7/jre/bi), comm:(java)]
Jan 5 19:13:27 kernel: [14581.030000] [/volume1/public/serviio/plugins] opened by pid 25459 [u:(/volume1/@appstore/java7/jre/bi), comm:(java)]
Jan 5 19:13:37 kernel: [14591.050000] [/volume1/public/serviio/plugins] opened by pid 25459 [u:(/volume1/@appstore/java7/jre/bi), comm:(java)]
Jan 5 19:13:47 kernel: [14601.070000] [/volume1/public/serviio/plugins] opened by pid 25459 [u:(/volume1/@appstore/java7/jre/bi), comm:(java)]
Jan 5 19:13:57 kernel: [14611.090000] [/volume1/public/serviio/plugins] opened by pid 25459 [u:(/volume1/@appstore/java7/jre/bi), comm:(java)]
Jan 5 19:14:07 kernel: [14621.110000] [/volume1/public/serviio/plugins] opened by pid 25459 [u:(/volume1/@appstore/java7/jre/bi), comm:(java)]
Jan 5 19:14:17 kernel: [14631.130000] [/volume1/public/serviio/plugins] opened by pid 25459 [u:(/volume1/@appstore/java7/jre/bi), comm:(java)]
Jan 5 19:14:27 kernel: [14641.150000] [/volume1/public/serviio/plugins] opened by pid 25459 [u:(/volume1/@appstore/java7/jre/bi), comm:(java)]
Jan 5 19:14:37 kernel: [14651.170000] [/volume1/public/serviio/plugins] opened by pid 25459 [u:(/volume1/@appstore/java7/jre/bi), comm:(java)]
This is caused by Serviio checking if there are any new plugins. There is no way of disabling this at the moment.
https://bitbucket.org/xnejp03/serviio/i ... revent-hdd
Petr
This still seems to be the case - my Synology NAS never hibernates. I've got the library refreshing every few hours and online webresources doing the same (HAHASport, Coolsport, SkysportsPlus, Stopstream).
I've noticed that the online side of things, despite either having a "?refresh=xxx" parameter or refresh at console default time, online resources appear to be accessed every couple of minutes.
I'd really like my NAS to sleep when not being used.
Did you add the new system property to disable checking for new plugins?
Petr
I thought that was included in the Synology package itself? I haven't changed any parameters at all.
It's not included, AFAIK. It's a personal preference of each user.
Petr
I gathered from patters posts of
That it was out of my control and had already been taken care of. Is this not the case?
patters wrote:If you have a Synology - don't worry, I'll update the package today with a new version incorporating that setting.
patters wrote:Done
Where can i change the syncintervall? I have a zyxel nsa 310 with serviio.
I've renamed //volume1/public/serviio/plugins to //volume1/public/serviio/_plugins to see what effect it would have.
Since doing so, the Java process no-longer drives the CPU to almost 100% all day and actually sleeps, but the Synology still fails to hibernate after 10 minutes as set.
Login with putty on synology NAS
username: root
password: your admin password
change folder to "/volume1/@appstore/Serviio/bin/"
edit serviio.sh
add "-Dplugins.check=false" to line 57 (which begins with "JAVA_OPTS=") almost at the end, like this:
press esc to leave vi's text edit mode
type :w to save
type :q to exit
type exit to leave ssh session
restart serviio service in DSM's web interface
restart your nas, just to be sure
be happy
username: root
edit serviio.sh
- Code:
JAVA_OPTS="-Djava.net.preferIPv4Stack=true -Djava.awt.headless=true -Dderby.system.home=$SERVIIO_HOME/library -Dserviio.home=$SERVIIO_HOME -Dserviio.defaultTranscodeFolder=/volume1/@tmp -Dffmpeg.location=$SERVIIO_HOME/bin/ffmpeg-wrapper.sh -Dplugins.location=/volume1/public/serviio -Dplugins.check=false -Djava.util.prefs.syncInterval=86400 -Dserviio.fixedPointEncoders"
type :w to save
type :q to exit
be happy
I just add -Dplugins.check=false and my NAS DS212j is still not hibernating.. When I disable serrvio hibernation works. Any idea?
I have newest DSM and serrvio.
Would need a log like the ones above showing which file is accessed by the serviio process.
Petr
Hi all,
trying to figure out why my DS213j is not hibernating when serviio is running (when serviio is not started, everything works as expected).
Here is my setup:
DSM 4.3-3810
Serviio 1.3.1-0023
I have disabled every possible option from the console which can cause hdd activity.
Below are the JAVA_OPTS in the bin directory
./serviio-console.sh:JAVA_OPTS="-Dserviio.home=$SERVIIO_CONSOLE_HOME -Djava.net.preferIPv4Stack=true"
./serviio-console.sh:"$JAVA" -Xms5M -XX:+UseParNewGC -XX:MinHeapFreeRatio=5 -XX:MaxHeapFreeRatio=10 $JAVA_OPTS -classpath "$SERVIIO_CONSOLE_CLASS_PATH" org.serviio.console.ServiioConsole "$@"
./serviio.sh:JAVA_OPTS="-Djava.net.preferIPv4Stack=true -Djava.awt.headless=true -Dderby.system.home=$SERVIIO_HOME/library -Dserviio.home=$SERVIIO_HOME -Dserviio.defaultTranscodeFolder=/volume1/@tmp -Dffmpeg.location=$SERVIIO_HOME/bin/ffmpeg -Dplugins.location=/volume1/public/serviio -Djava.util.prefs.syncInterval=86400 -Dplugins.check=false"
./serviio.sh:"$JAVA" -Xmx384m -Xms20M -XX:+UseParNewGC -XX:MinHeapFreeRatio=10 -XX:MaxHeapFreeRatio=20 $JAVA_OPTS -classpath "$SERVIIO_CLASS_PATH" org.serviio.MediaServer "$@"
I tried to add -Dplugins.check=false which can be seen above but this didn't help.
I enabled the hibernation debug tool and what I cans ee in the log is a records like these:
Dec 8 17:45:35 DiskStation1 kernel: [ 8225.870714] [/.htaccess] opened by pid 6919 [u:(/usr/syno/apache/bin/httpd), comm:(httpd)]
Dec 8 17:45:41 DiskStation1 kernel: [ 8231.886666] [/.htaccess] opened by pid 6948 [u:(/usr/syno/apache/bin/httpd), comm:(httpd)]
Dec 8 17:45:43 DiskStation1 kernel: [ 8233.594427] [/volume1/@appstore/Serviio/lib/serviio.jar] opened by pid 7102 [u:(/volume1/@appstore/java7/jre/bi), comm:(java)]
Dec 8 17:45:46 DiskStation1 kernel: [ 8236.869130] [/.htaccess] opened by pid 5383 [u:(/usr/syno/apache/bin/httpd), comm:(httpd)]
Dec 8 17:45:48 DiskStation1 kernel: [ 8238.661952] [/volume1/@appstore/Serviio/lib/serviio.jar] opened by pid 7103 [u:(/volume1/@appstore/java7/jre/bi), comm:(java)]
Dec 8 17:45:51 DiskStation1 kernel: [ 8241.881554] [/.htaccess] opened by pid 6922 [u:(/usr/syno/apache/bin/httpd), comm:(httpd)]
Dec 8 18:05:54 DiskStation1 kernel: [ 9444.952243] [/.htaccess] opened by pid 6919 [u:(/usr/syno/apache/bin/httpd), comm:(httpd)]
Dec 8 18:05:57 DiskStation1 kernel: [ 9447.796884] [/volume1/@appstore/Serviio/lib/serviio.jar] opened by pid 7105 [u:(/volume1/@appstore/java7/jre/bi), comm:(java)]
Dec 8 18:06:00 DiskStation1 kernel: [ 9450.952975] [/.htaccess] opened by pid 6948 [u:(/usr/syno/apache/bin/httpd), comm:(httpd)]
Dec 8 18:06:03 DiskStation1 kernel: [ 9453.645628] [/volume1/@appstore/Serviio/lib/serviio.jar] opened by pid 7106 [u:(/volume1/@appstore/java7/jre/bi), comm:(java)]
Dec 8 18:06:05 DiskStation1 kernel: [ 9455.962713] [/.htaccess] opened by pid 5383 [u:(/usr/syno/apache/bin/httpd), comm:(httpd)]
Dec 8 18:06:10 DiskStation1 kernel: [ 9460.947284] [/.htaccess] opened by pid 6922 [u:(/usr/syno/apache/bin/httpd), comm:(httpd)]
Dec 8 18:06:11 DiskStation1 kernel: [ 9462.298407] [/volume1/@appstore/Serviio/lib/serviio.jar] opened by pid 7108 [u:(/volume1/@appstore/java7/jre/bi), comm:(java)]
Dec 8 18:26:13 DiskStation1 kernel: [10664.038661] [/.htaccess] opened by pid 6919 [u:(/usr/syno/apache/bin/httpd), comm:(httpd)]
Dec 8 18:26:19 DiskStation1 kernel: [10670.041611] [/.htaccess] opened by pid 6948 [u:(/usr/syno/apache/bin/httpd), comm:(httpd)]
Dec 8 18:26:21 DiskStation1 kernel: [10672.385308] [/volume1/@appstore/Serviio/lib/serviio.jar] opened by pid 7111 [u:(/volume1/@appstore/java7/jre/bi), comm:(java)]
Dec 8 18:26:24 DiskStation1 kernel: [10675.028355] [/.htaccess] opened by pid 5383 [u:(/usr/syno/apache/bin/httpd), comm:(httpd)]
Dec 8 18:26:27 DiskStation1 kernel: [10677.737572] [/volume1/@appstore/Serviio/lib/serviio.jar] opened by pid 7112 [u:(/volume1/@appstore/java7/jre/bi), comm:(java)]
Dec 8 18:26:29 DiskStation1 kernel: [10680.028939] [/.htaccess] opened by pid 6922 [u:(/usr/syno/apache/bin/httpd), comm:(httpd)]
Dec 8 18:26:32 DiskStation1 kernel: [10682.841794] [/volume1/@appstore/Serviio/lib/serviio.jar] opened by pid 7113 [u:(/volume1/@appstore/java7/jre/bi), comm:(java)]
Any help from someone more experienced will be appreciated.
Looking at the log, does my problem have anything to do with the integrated media browser, because the rows with the /.htaccess appearing ONLY a seconds before/after the serviio log events.
If there is an option to disable the media browser, would like to try it.
Best Regards,
nikiangel
Here is my setup:
DSM 4.3-3810
Serviio 1.3.1-0023
Best Regards,
nikiangel
the .htaccess file is not used by Serviio itself. It seems something is trying to access the Apache server running on the NAS though.
Petr
Could be a coincidence with the .htaccess log but do you have any idea what setting/featurecan cause these
to happen every 20 minutes ?
Asking because without serviio the system does hibernate successfully.
There is a possibility the system itself, when going to hibernation to cause the serviio process to access this file but I will check this by increasing the hibernation period and see how often the process described above happens then.
Checked with different hibernation settings (30 min, 60 min) but the java process accessing serviio.jar every 20 minutes.
What I'm doing for now is to shutdown serviio when I don't use it so synology can hibernate.
I'm willing to cooperate with testings if someone has some ideas.
Users browsing this forum: Baidu [Spider], Google [Bot] and 27 guests
