[SOLVED] 1.0.1 SONY Bravia - Video Freeze but Sound OK
g10chy
Post Thu Sep 06, 2012 8:50 pm
I have recently upgraded to Ubuntu 12.04 and Serviio 1.0.1 and since then ffmpeg was not working and I have recompiled from the git. AVI files work fine.
HD MKV files play fine for the first few seconds then the picture freezes and the audio continues OK.
I have tried both wireless and wired but that does not make any difference; the video freezes in the same place every time but the audio continues.
I have compiled ffmpeg from the git on the 4th September as you can see from my manual run of the ffmpeg command found in the serviio.log:
xbmc@xbmc-desktop:/tmp/Serviio$ ffmpeg -fflags +genpts -i "/TVShows/Dexter/Dexter Season 6 Complete 720p/Dexter - S06E01 - Those Kinds of Things.mkv" -y -copyts -c:v copy -vbsf h264_mp4toannexb -c:a copy -map 0:0 -map 0:1 -sn -f mpegts /tmp/Serviio/transcoding-temp-1832-sony2012-ORIGINAL.stf
ffmpeg version git-2012-09-04-d83ff76 Copyright (c) 2000-2012 the FFmpeg developers
  built on Sep  4 2012 22:11:51 with gcc 4.6 (Ubuntu/Linaro 4.6.3-1ubuntu5)
  configuration: --enable-gpl --enable-libfaac --enable-libfdk-aac --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-librtmp --enable-libtheora --enable-libvorbis --enable-libvpx --enable-x11grab --enable-libx264 --enable-nonfree --enable-version3
  libavutil      51. 70.100 / 51. 70.100
  libavcodec     54. 55.100 / 54. 55.100
  libavformat    54. 25.104 / 54. 25.104
  libavdevice    54.  2.100 / 54.  2.100
  libavfilter     3. 15.103 /  3. 15.103
  libswscale      2.  1.101 /  2.  1.101
Input #0, matroska,webm, from '/TVShows/Dexter/Dexter Season 6 Complete 720p/Dexter - S06E01 - Those Kinds of Things.mkv':
  Duration: 00:52:36.98, start: 0.000000, bitrate: 4071 kb/s
    Stream #0:0(eng): Video: h264 (High), yuv420p, 1280x720, SAR 1:1 DAR 16:9, 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc (default)
    Stream #0:1(eng): Audio: ac3, 48000 Hz, 5.1(side), s16, 384 kb/s (default)
[mpegts @ 0x9e07b40] muxrate VBR, pcr every 2 pkts, sdt every 200, pat/pmt every 40 pkts
Output #0, mpegts, to '/tmp/Serviio/transcoding-temp-1832-sony2012-ORIGINAL.stf':
    encoder         : Lavf54.25.104
    Stream #0:0(eng): Video: h264, yuv420p, 1280x720 [SAR 1:1 DAR 16:9], q=2-31, 23.98 fps, 90k tbn, 23.98 tbc (default)
    Stream #0:1(eng): Audio: ac3, 48000 Hz, 5.1(side), 384 kb/s (default)
Stream mapping:
  Stream #0:0 -> #0:0 (copy)
  Stream #0:1 -> #0:1 (copy)
frame=  957 fps= 20 q=-1.0 Lsize=   20962kB time=00:00:39.93 bitrate=4299.9kbits/s
video:17315kB audio:1872kB subtitle:0 global headers:0kB muxing overhead 9.249327%
No errors in the serviio.log. CPU and memory on the server are fine during the transcoding. Any ideas to what is causing the picture to freeze or potential solutions?
Output from serviio.log (sorry for the lots of useless cr@p):
2012-09-06 21:57:45,755 DEBUG [WebServer] Incoming connection from /192.168.0.7:43036
2012-09-06 21:57:45,756 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.7
2012-09-06 21:57:45,757 DEBUG [ResourceTransportRequestHandler] HEAD /resource/1832/MEDIA_ITEM/AVC_TS_MP_HD_AC3_ISO-0/ORIGINAL HTTP/1.1, headers = [getcontentFeatures.dlna.org: 1,Pragma: getIfoFileURI.dlna.org,transferMode.dlna.org: Streaming,X-AV-Physical-Unit-Info: pa="BRAVIA KDL-22EX320";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-22EX320"; mv="1.7";,Host: 192.168.0.4:8895]]
2012-09-06 21:57:45,757 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.7
2012-09-06 21:57:45,758 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.0.7, Profile=Sony Bravia TV (2012)'
2012-09-06 21:57:45,759 DEBUG [ResourceDeliveryProcessor] Request for resource 1832 and type 'MEDIA_ITEM' received
2012-09-06 21:57:45,759 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1832 (local)
2012-09-06 21:57:45,759 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 1832)
2012-09-06 21:57:45,760 DEBUG [VideoDAOImpl] Reading a Video (id = 1832)
2012-09-06 21:57:45,762 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1832, format AVC_TS_MP_HD_AC3_ISO and profile Sony Bravia TV (2012)
2012-09-06 21:57:45,762 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file Dexter - S06E01 - Those Kinds of Things.mkv
2012-09-06 21:57:45,762 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Dexter - S06E01 - Those Kinds of Things.mkv: AVC_TS_MP_HD_AC3_ISO
2012-09-06 21:57:45,763 DEBUG [ResourceDeliveryProcessor] Sending HEAD response back
2012-09-06 21:57:45,763 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Date: Thu, 06 Sep 2012 20:57:45 GMT,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_TS_HD_24_AC3_ISO;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2012-09-06 21:57:45,865 DEBUG [WebServer] Incoming connection from /192.168.0.7:43037
2012-09-06 21:57:45,866 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.7
2012-09-06 21:57:45,867 DEBUG [ResourceTransportRequestHandler] GET /resource/1832/MEDIA_ITEM/AVC_TS_MP_HD_AC3_ISO-0/ORIGINAL HTTP/1.1, headers = [TimeSeekRange.dlna.org: npt=0.000-,getcontentFeatures.dlna.org: 1,Pragma: getIfoFileURI.dlna.org,transferMode.dlna.org: Streaming,X-AV-Physical-Unit-Info: pa="BRAVIA KDL-22EX320";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-22EX320"; mv="1.7";,Host: 192.168.0.4:8895]]
2012-09-06 21:57:45,867 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.7
2012-09-06 21:57:45,868 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.0.7, Profile=Sony Bravia TV (2012)'
2012-09-06 21:57:45,869 DEBUG [ResourceDeliveryProcessor] Request for resource 1832 and type 'MEDIA_ITEM' received
2012-09-06 21:57:45,869 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1832 (local)
2012-09-06 21:57:45,870 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 1832)
2012-09-06 21:57:45,871 DEBUG [VideoDAOImpl] Reading a Video (id = 1832)
2012-09-06 21:57:45,872 DEBUG [VideoDeliveryEngine] Delivering item '1832' for client 'IPAddress=/192.168.0.7, Profile=Sony Bravia TV (2012)'
2012-09-06 21:57:45,872 DEBUG [VideoDeliveryEngine] Delivering file 'Dexter - S06E01 - Those Kinds of Things.mkv' using transcoding
2012-09-06 21:57:45,873 DEBUG [AbstractTranscodingDeliveryEngine] A suitable transcoding job already exists, re-use it for client 'IPAddress=/192.168.0.7, Profile=Sony Bravia TV (2012)'
2012-09-06 21:57:45,873 DEBUG [FileBasedTranscodingDeliveryStrategy] Transcoded file '/tmp/Serviio/transcoding-temp-1832-sony2012-ORIGINAL.stf' is complete, sending simple stream
2012-09-06 21:57:45,874 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Dexter - S06E01 - Those Kinds of Things.mkv: AVC_TS_MP_HD_AC3_ISO
2012-09-06 21:57:45,874 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 1832) as read
2012-09-06 21:57:45,892 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2012-09-06 21:57:45,892 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 21465276
2012-09-06 21:57:45,893 DEBUG [ResourceDeliveryProcessor] Sending file back
2012-09-06 21:57:45,893 DEBUG [ResourceTransportRequestHandler] Creating entity with chunked transfer
2012-09-06 21:57:45,893 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,TimeSeekRange.dlna.org: npt=0.0-3156.0/3156,Date: Thu, 06 Sep 2012 20:57:45 GMT,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_TS_HD_24_AC3_ISO;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2012-09-06 21:57:46,879 DEBUG [RendererDAOImpl] Retrieving list of all stored renderers
2012-09-06 21:57:49,088 DEBUG [WebServer] I/O error: Broken pipe
2012-09-06 21:57:49,098 DEBUG [WebServer] Incoming connection from /192.168.0.7:43038
2012-09-06 21:57:49,099 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.7
2012-09-06 21:57:49,100 DEBUG [ResourceTransportRequestHandler] GET /resource/1832/MEDIA_ITEM/AVC_TS_MP_HD_AC3_ISO-0/ORIGINAL HTTP/1.1, headers = [TimeSeekRange.dlna.org: npt=0.000-,getcontentFeatures.dlna.org: 1,Pragma: getIfoFileURI.dlna.org,transferMode.dlna.org: Streaming,X-AV-Physical-Unit-Info: pa="BRAVIA KDL-22EX320";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-22EX320"; mv="1.7";,Host: 192.168.0.4:8895]]
2012-09-06 21:57:49,100 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.7
2012-09-06 21:57:49,101 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.0.7, Profile=Sony Bravia TV (2012)'
2012-09-06 21:57:49,102 DEBUG [ResourceDeliveryProcessor] Request for resource 1832 and type 'MEDIA_ITEM' received
2012-09-06 21:57:49,102 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1832 (local)
2012-09-06 21:57:49,102 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 1832)
2012-09-06 21:57:49,103 DEBUG [VideoDAOImpl] Reading a Video (id = 1832)
2012-09-06 21:57:49,105 DEBUG [VideoDeliveryEngine] Delivering item '1832' for client 'IPAddress=/192.168.0.7, Profile=Sony Bravia TV (2012)'
2012-09-06 21:57:49,105 DEBUG [VideoDeliveryEngine] Delivering file 'Dexter - S06E01 - Those Kinds of Things.mkv' using transcoding
2012-09-06 21:57:49,106 DEBUG [AbstractTranscodingDeliveryEngine] A suitable transcoding job already exists, re-use it for client 'IPAddress=/192.168.0.7, Profile=Sony Bravia TV (2012)'
2012-09-06 21:57:49,106 DEBUG [FileBasedTranscodingDeliveryStrategy] Transcoded file '/tmp/Serviio/transcoding-temp-1832-sony2012-ORIGINAL.stf' is complete, sending simple stream
2012-09-06 21:57:49,107 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Dexter - S06E01 - Those Kinds of Things.mkv: AVC_TS_MP_HD_AC3_ISO
2012-09-06 21:57:49,107 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 1832) as read
2012-09-06 21:57:49,127 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2012-09-06 21:57:49,127 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 21465276
2012-09-06 21:57:49,128 DEBUG [ResourceDeliveryProcessor] Sending file back
2012-09-06 21:57:49,128 DEBUG [ResourceTransportRequestHandler] Creating entity with chunked transfer
2012-09-06 21:57:49,128 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,TimeSeekRange.dlna.org: npt=0.0-3156.0/3156,Date: Thu, 06 Sep 2012 20:57:49 GMT,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_TS_HD_24_AC3_ISO;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2012-09-06 21:57:50,553 DEBUG [MediaItemDAOImpl] Getting file of media item 1561
2012-09-06 21:57:51,886 DEBUG [RendererDAOImpl] Retrieving list of all stored renderers
2012-09-06 21:57:56,895 DEBUG [RendererDAOImpl] Retrieving list of all stored renderers
2012-09-06 21:58:01,314 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1561) and extractor EMBEDDED
2012-09-06 21:58:01,315 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1561) and extractor COVER_IMAGE_IN_FOLDER
2012-09-06 21:58:01,902 DEBUG [RendererDAOImpl] Retrieving list of all stored renderers
2012-09-06 21:58:03,578 DEBUG [LibraryAdditionsCheckerThread] Found file 'The.Sopranos.S02E01.720p.HDTV.x264.mkv', checking if it's already in the Library
2012-09-06 21:58:03,578 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item The.Sopranos.S02E01.720p.HDTV.x264.mkv
2012-09-06 21:58:03,578 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: /TVShows/The Sopranos/Season 2/The.Sopranos.S02E01.720p.HDTV.x264.mkv, ignore case: false
2012-09-06 21:58:03,580 DEBUG [MediaItemDAOImpl] Media item The.Sopranos.S02E01.720p.HDTV.x264.mkv already exists in DB
2012-09-06 21:58:03,580 DEBUG [LibraryAdditionsCheckerThread] Found file 'The.Sopranos.S02E08.720p.HDTV.x264.mkv', checking if it's already in the Library
2012-09-06 21:58:03,580 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item The.Sopranos.S02E08.720p.HDTV.x264.mkv
2012-09-06 21:58:03,581 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: /TVShows/The Sopranos/Season 2/The.Sopranos.S02E08.720p.HDTV.x264.mkv, ignore case: false
2012-09-06 21:58:03,582 DEBUG [MediaItemDAOImpl] Media item The.Sopranos.S02E08.720p.HDTV.x264.mkv already exists in DB
2012-09-06 21:58:03,583 DEBUG [LibraryAdditionsCheckerThread] Found file 'The.Sopranos.S02E11.720p.HDTV.x264.mkv', checking if it's already in the Library
2012-09-06 21:58:03,583 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item The.Sopranos.S02E11.720p.HDTV.x264.mkv
2012-09-06 21:58:03,584 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: /TVShows/The Sopranos/Season 2/The.Sopranos.S02E11.720p.HDTV.x264.mkv, ignore case: false
2012-09-06 21:58:03,585 DEBUG [MediaItemDAOImpl] Media item The.Sopranos.S02E11.720p.HDTV.x264.mkv already exists in DB
2012-09-06 21:58:03,585 DEBUG [LibraryAdditionsCheckerThread] Found file 'The.Sopranos.S02E13.720p.HDTV.x264.mkv', checking if it's already in the Library
2012-09-06 21:58:03,586 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item The.Sopranos.S02E13.720p.HDTV.x264.mkv
2012-09-06 21:58:03,586 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: /TVShows/The Sopranos/Season 2/The.Sopranos.S02E13.720p.HDTV.x264.mkv, ignore case: false
2012-09-06 21:58:03,587 DEBUG [MediaItemDAOImpl] Media item The.Sopranos.S02E13.720p.HDTV.x264.mkv already exists in DB
2012-09-06 21:58:03,587 DEBUG [LibraryAdditionsCheckerThread] Found file 'The.Sopranos.S02E07.720p.HDTV.x264.mkv', checking if it's already in the Library
2012-09-06 21:58:03,587 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item The.Sopranos.S02E07.720p.HDTV.x264.mkv
2012-09-06 21:58:03,587 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: /TVShows/The Sopranos/Season 2/The.Sopranos.S02E07.720p.HDTV.x264.mkv, ignore case: false
2012-09-06 21:58:03,588 DEBUG [MediaItemDAOImpl] Media item The.Sopranos.S02E07.720p.HDTV.x264.mkv already exists in DB
2012-09-06 21:58:03,589 DEBUG [LibraryAdditionsCheckerThread] Found file 'The.Sopranos.S02E05.720p.HDTV.x264.mkv', checking if it's already in the Library
2012-09-06 21:58:03,589 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item The.Sopranos.S02E05.720p.HDTV.x264.mkv
2012-09-06 21:58:03,589 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: /TVShows/The Sopranos/Season 2/The.Sopranos.S02E05.720p.HDTV.x264.mkv, ignore case: false
2012-09-06 21:58:03,590 DEBUG [MediaItemDAOImpl] Media item The.Sopranos.S02E05.720p.HDTV.x264.mkv already exists in DB
2012-09-06 21:58:03,590 DEBUG [LibraryAdditionsCheckerThread] Found file 'The.Sopranos.S02E06.720p.HDTV.x264.mkv', checking if it's already in the Library
2012-09-06 21:58:03,591 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item The.Sopranos.S02E06.720p.HDTV.x264.mkv
2012-09-06 21:58:03,591 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: /TVShows/The Sopranos/Season 2/The.Sopranos.S02E06.720p.HDTV.x264.mkv, ignore case: false
2012-09-06 21:58:03,592 DEBUG [MediaItemDAOImpl] Media item The.Sopranos.S02E06.720p.HDTV.x264.mkv already exists in DB
2012-09-06 21:58:03,592 DEBUG [LibraryAdditionsCheckerThread] Found file 'The.Sopranos.S02E04.720p.HDTV.x264.mkv', checking if it's already in the Library
2012-09-06 21:58:03,592 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item The.Sopranos.S02E04.720p.HDTV.x264.mkv
2012-09-06 21:58:03,592 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: /TVShows/The Sopranos/Season 2/The.Sopranos.S02E04.720p.HDTV.x264.mkv, ignore case: false
2012-09-06 21:58:03,593 DEBUG [MediaItemDAOImpl] Media item The.Sopranos.S02E04.720p.HDTV.x264.mkv already exists in DB
2012-09-06 21:58:03,593 DEBUG [LibraryAdditionsCheckerThread] Found file 'The.Sopranos.S02E03.720p.HDTV.x264.mkv', checking if it's already in the Library
2012-09-06 21:58:03,594 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item The.Sopranos.S02E03.720p.HDTV.x264.mkv
2012-09-06 21:58:03,594 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: /TVShows/The Sopranos/Season 2/The.Sopranos.S02E03.720p.HDTV.x264.mkv, ignore case: false
2012-09-06 21:58:03,595 DEBUG [MediaItemDAOImpl] Media item The.Sopranos.S02E03.720p.HDTV.x264.mkv already exists in DB
2012-09-06 21:58:03,595 DEBUG [LibraryAdditionsCheckerThread] Found file 'The.Sopranos.S02E10.720p.HDTV.x264.mkv', checking if it's already in the Library
2012-09-06 21:58:03,595 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item The.Sopranos.S02E10.720p.HDTV.x264.mkv
2012-09-06 21:58:03,595 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: /TVShows/The Sopranos/Season 2/The.Sopranos.S02E10.720p.HDTV.x264.mkv, ignore case: false
2012-09-06 21:58:03,596 DEBUG [MediaItemDAOImpl] Media item The.Sopranos.S02E10.720p.HDTV.x264.mkv already exists in DB
2012-09-06 21:58:03,596 DEBUG [LibraryAdditionsCheckerThread] Found file 'The.Sopranos.S02E09.720p.HDTV.x264.mkv', checking if it's already in the Library
2012-09-06 21:58:03,597 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item The.Sopranos.S02E09.720p.HDTV.x264.mkv
2012-09-06 21:58:03,597 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: /TVShows/The Sopranos/Season 2/The.Sopranos.S02E09.720p.HDTV.x264.mkv, ignore case: false
2012-09-06 21:58:03,598 DEBUG [MediaItemDAOImpl] Media item The.Sopranos.S02E09.720p.HDTV.x264.mkv already exists in DB
2012-09-06 21:58:03,598 DEBUG [LibraryAdditionsCheckerThread] Found file 'The.Sopranos.S02E12.720p.HDTV.x264.mkv', checking if it's already in the Library
2012-09-06 21:58:03,598 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item The.Sopranos.S02E12.720p.HDTV.x264.mkv
2012-09-06 21:58:03,598 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: /TVShows/The Sopranos/Season 2/The.Sopranos.S02E12.720p.HDTV.x264.mkv, ignore case: false
2012-09-06 21:58:03,599 DEBUG [MediaItemDAOImpl] Media item The.Sopranos.S02E12.720p.HDTV.x264.mkv already exists in DB
2012-09-06 21:58:03,600 DEBUG [LibraryAdditionsCheckerThread] Found file 'The.Sopranos.S02E02.720p.HDTV.x264.mkv', checking if it's already in the Library
2012-09-06 21:58:03,600 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item The.Sopranos.S02E02.720p.HDTV.x264.mkv
2012-09-06 21:58:03,600 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: /TVShows/The Sopranos/Season 2/The.Sopranos.S02E02.720p.HDTV.x264.mkv, ignore case: false
2012-09-06 21:58:03,601 DEBUG [MediaItemDAOImpl] Media item The.Sopranos.S02E02.720p.HDTV.x264.mkv already exists in DB
2012-09-06 21:58:03,603 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /TVShows/Dexter
2012-09-06 21:58:04,886 DEBUG [MediaItemDAOImpl] Getting file of media item 1562
2012-09-06 21:58:07,211 DEBUG [RendererDAOImpl] Retrieving list of all stored renderers
2012-09-06 21:58:10,994 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1562) and extractor EMBEDDED
2012-09-06 21:58:10,995 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /TVShows/Dexter/Dexter Season 6 Complete 720p
2012-09-06 21:58:10,996 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1562) and extractor COVER_IMAGE_IN_FOLDER
2012-09-06 21:58:11,242 DEBUG [TranscodingJobListener] Transcoding finished; successful: true
Thanks in advance.
g10chy
Post Thu Sep 06, 2012 9:09 pm
Re: 1.0.1 SONY Bravia - Video Freeze but Sound OK
MediaInfo Output:
Complete name                            : \\DISKSTATION\TVShows\Dexter\Dexter Season 6 Complete 720p\Dexter - S06E01 - Those Kinds of Things.mkv
File size                                : 1.50 GiB
Duration                                 : 52mn 36s
Overall bit rate                         : 4 071 Kbps
Writing application                      : x264.exe
Writing library                          : mkv2rls x264-tv version built on 2011. febr. 17
Format settings, ReFrames                : 8 frames
Bit rate                                 : 3 606 Kbps
Frame rate mode                          : Variable
Original frame rate                      : 23.976 fps
Writing library                          : x264 core 118 r2085+614 d1cc25d
Encoding settings                        : cabac=1 / ref=8 / deblock=1:-1:-1 / analyse=0x3:0x133 / me=umh / subme=9 / psy=1 / fade_compensate=0.00 / psy_rd=1.00:0.15 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-3 / threads=36 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / fgo=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=crf / mbtree=1 / crf=18.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
Duration                                 : 52mn 36s
Bit rate                                 : 384 Kbps
Stream size                              : 145 MiB (9%)
Post Fri Sep 07, 2012 5:31 am
Its probably a hight CPU load during transcoding.
The ffmpeg transcoding process fps=20 is too low compare to the video frame rate 23.98fps, so the video freeze.
g10chy
Post Fri Sep 07, 2012 7:57 am
Just ran ffmpeg again and the fps never dropped below 86
frame=  164 fps=0.0 q=-1.0 size=    1009kB time=00:00:06.91 bitrate=1195.7kbits/       frame=  196 fps=180 q=-1.0 size=    1899kB time=00:00:08.22 bitrate=1891.2kbits/       frame=  246 fps=152 q=-1.0 size=    2953kB time=00:00:10.27 bitrate=2355.3kbits/       frame=  296 fps=138 q=-1.0 size=    3800kB time=00:00:12.54 bitrate=2481.6kbits/       frame=  351 fps=131 q=-1.0 size=    4772kB time=00:00:14.84 bitrate=2632.6kbits/       frame=  377 fps=118 q=-1.0 size=    5443kB time=00:00:15.87 bitrate=2809.3kbits/       frame=  427 fps=114 q=-1.0 size=    6439kB time=00:00:17.92 bitrate=2943.4kbits/       frame=  480 fps=113 q=-1.0 size=    7416kB time=00:00:20.22 bitrate=3004.1kbits/       frame=  529 fps=109 q=-1.0 size=    8389kB time=00:00:22.27 bitrate=3085.7kbits/       frame=  573 fps=107 q=-1.0 size=    9412kB time=00:00:24.06 bitrate=3204.1kbits/       frame=  601 fps=102 q=-1.0 size=   10242kB time=00:00:25.08 bitrate=3344.4kbits/       frame=  624 fps= 98 q=-1.0 size=   11307kB time=00:00:26.11 bitrate=3547.4kbits/       frame=  680 fps= 98 q=-1.0 size=   12552kB time=00:00:28.41 bitrate=3618.6kbits/       frame=  737 fps= 98 q=-1.0 size=   13809kB time=00:00:30.78 bitrate=3674.8kbits/       frame=  775 fps= 97 q=-1.0 size=   14918kB time=00:00:32.51 bitrate=3758.8kbits/       frame=  820 fps= 96 q=-1.0 size=   16297kB time=00:00:34.30 bitrate=3891.7kbits/       frame=  866 fps= 96 q=-1.0 size=   17304kB time=00:00:36.35 bitrate=3899.5kbits/       frame=  894 fps= 93 q=-1.0 size=   18536kB time=00:00:37.37 bitrate=4062.6kbits/       frame=  915 fps= 91 q=-1.0 size=   19501kB time=00:00:38.40 bitrate=4160.2kbits/       frame=  945 fps= 89 q=-1.0 size=   20560kB time=00:00:39.42 bitrate=4272.1kbits/       frame=  986 fps= 88 q=-1.0 size=   21761kB time=00:00:41.21 bitrate=4325.2kbits/       frame= 1016 fps= 87 q=-1.0 size=   23023kB time=00:00:42.49 bitrate=4438.2kbits/
top is showing my CPU as 50% idle during the manual running of ffmpeg.
xbmc@xbmc-desktop:~$ top
top - 08:56:52 up 1 day, 13:20,  3 users,  load average: 1.94, 1.25, 1.09
Tasks: 183 total,   2 running, 181 sleeping,   0 stopped,   0 zombie
Cpu(s): 18.9%us,  1.2%sy,  0.0%ni, 55.5%id, 24.2%wa,  0.0%hi,  0.2%si,  0.0%st
Mem:   1543224k total,  1437552k used,   105672k free,    58552k buffers
Swap:  6142972k total,     5644k used,  6137328k free,   464004k cached
  PID USER      PR  NI  VIRT  RES  SHR S %CPU %MEM    TIME+  COMMAND
 1860 xbmc      20   0  673m 477m  21m R   71 31.7   1462:37 xbmc.bin
18298 root      20   0 37196 7740 3904 D    5  0.5   0:05.58 ffmpeg
Videos still freezing in the same position and never recovers.
Post Fri Sep 07, 2012 10:35 am
g10chy wrote:Videos still freezing in the same position and never recovers.
Which position? Could you check the video bitrate with this tool http://wiki.serviio.org/doku.php?id=vbitrate
Does the transcoding process finishes at the end of file or crashes at your "freeze" position ?
g10chy
Post Fri Sep 07, 2012 10:52 am
It freezes about 4-5 secs in when the red dexter logo comes up.
Nothing wrong with the file as it plays fine directly through xbmc or PC.
I am at work but will upload the nitrate output later.
Also, the transcoding continues in the background and does not crash I just cancel it shortly after the video freezes bit sound continues. The video never recovers no matter how long you leave it.
Sent from my HTC One X using Tapatalk 2
g10chy
Post Sun Sep 09, 2012 8:29 pm
I have run Bitrate viewer against the file.
Average = 4,558 kbps
Peak = 14,432 kbps
Whats your opinion?
Post Mon Sep 10, 2012 7:05 am
g10chy wrote:I have run Bitrate viewer against the file.
Peak = 14,432 kbps
Whats your opinion?
That should be good, I usually seen some problems around 20Mbps, with some Sony Bravia.
I noticed that your file use "variable frame rate mode", not sure Sony devices support this well.
Could you try with TsMuxertools to remux the file and force frame rate to 23.976fps (there were some options, like change "framterate")
g10chy
Post Tue Sep 11, 2012 1:57 pm
Thanks I will try tsmuxer tonight and let you know how I get on
g10chy
Post Fri Sep 14, 2012 11:17 am
Tried playing a 480p mkv last night with the same problem!! Could it be an issue with my ffmpeg?
Post Fri Sep 14, 2012 12:38 pm
g10chy wrote:Tried playing a 480p mkv last night with the same problem!! Could it be an issue with my ffmpeg?
Check the frame rate mode of your 480p. Do you try with TsMuxer ?
Check that you have the latest git version or check this : http://www.serviio.org/download
g10chy
Post Fri Sep 14, 2012 7:13 pm
Bitrate of 4,000 average with 10,000 peak for the 480p mkv file.
I remuxed the 720p mkv to fixed frame rate of 24 fps but this also changed the format to m2ts (which plays fine through Serviio). However I don't fancy having to remux all my mkv videos to get them to play.
This is my version of ffmpeg version git-2012-09-04-d83ff76.
Any ideas?
Thanks for all your help so far.
g10chy
Post Fri Sep 14, 2012 8:11 pm
Removed and recompiled ffmpeg to the version you linked to on the serviio download link and its now working with no freezing :D :D :D
