Forwarding of TS Files didn't work anymore
No Problem before 1.0.1 (or before 1.0).
MKV works perfect.
Has there anything changed about .ts files?
zip wrote:can you post ffmpeg -i of the file? Also detailed log of playing the file.
C:\Users\tv>"C:\Program Files (x86)\Serviio\lib\ffmpeg.exe" -i "f:\TV-Aufnahmen\
test.ts"
g-config
[h264 @ 017ECBE0] non-existing PPS referenced
[h264 @ 017ECBE0] non-existing PPS 0 referenced
[h264 @ 017ECBE0] decode_slice_header error
[h264 @ 017ECBE0] no frame!
[mpegts @ 017D11E0] PES packet size mismatch
Last message repeated 2 times
Input #0, mpegts, from 'f:\TV-Aufnahmen\test.ts':
Duration: 01:06:20.53, start: 29822.126189, bitrate: 12947 kb/s
Program 10329
Stream #0:0[0x1465]: Video: h264 (High) ([27][0][0][0] / 0x001B), yuv420p, 1
280x720 [SAR 1:1 DAR 16:9], 56.11 fps, 50 tbr, 90k tbn, 100 tbc
Stream #0:1[0x1466](deu): Audio: mp2 ([3][0][0][0] / 0x0003), 48000 Hz, ster
eo, s16, 192 kb/s
Stream #0:2[0x1467](mis): Audio: mp2 ([3][0][0][0] / 0x0003), 48000 Hz, ster
eo, s16, 192 kb/s
Stream #0:3[0x146a](deu): Audio: ac3 ([6][0][0][0] / 0x0006), 48000 Hz, ster
eo, s16, 448 kb/s
C:\Users\tv>
2012-09-14 00:02:41,023 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file test.ts: AVC_TS_MP_HD_AC3_ISO
2012-09-14 00:02:37,844 DEBUG [ProcessExecutor] Starting C:\Program Files (x86)\Serviio\bin\\..\lib/ffmpeg.exe -fflags +genpts -i F:\TV-Aufnahmen\test.ts -y -copyts -c:v copy -vbsf h264_mp4toannexb -c:a ac3 -b:a 192k -ac 2 -map 0:0 -map 0:1 -sn -f mpegts C:\Windows\TEMP\Serviio\transcoding-temp-11178-7-ORIGINAL.stf
2012-09-14 00:02:37,842 DEBUG [FFMPEGWrapper] Invoking FFmpeg to transcode video file: F:\TV-Aufnahmen\test.ts
2012-09-14 00:02:37,836 DEBUG [VideoDeliveryEngine] Delivering file 'test.ts' using transcoding
jhb50 wrote:Isn't this bug 566 again which somehow was changed to staus resolved without fixing the problem?
zip wrote:it's remuxing the file (and was in 0.6.2) because the mp2 audio track (first). You can try to either remove
from the C/D/E profile (not sure if the file will play then) or remux the file manually so that the ac3 audio track is the first in line.
jhb50 wrote:Will you ever be able to address that Samsung problem and allow transcoded files to be ff/rew or resumed?
Users browsing this forum: No registered users and 58 guests
