Forwarding of TS Files didn't work anymore
beta
Post Mon Aug 27, 2012 11:49 am
Forwarding of recorded DVB TS Files didn't work anymore.
No Problem before 1.0.1 (or before 1.0).
MKV works perfect.
Has there anything changed about .ts files?
Post Sun Sep 09, 2012 11:27 pm
Re: Forwarding of TS Files didn't work anymore
can you post ffmpeg -i of the file? Also detailed log of playing the file.
beta
Post Wed Sep 12, 2012 11:24 am
Ähhh ...
I think there is no transcoding needed for Samunsung D-Series.
Isn't ffmpeg only used for transcoding?
Post Wed Sep 12, 2012 11:42 am
zip wrote:can you post ffmpeg -i of the file? Also detailed log of playing the file.
We need this information to help you...
beta
Post Thu Sep 13, 2012 9:52 pm
C:\Users\tv>"C:\Program Files (x86)\Serviio\lib\ffmpeg.exe" -i "f:\TV-Aufnahmen\
test.ts"
g-config
[h264 @ 017ECBE0] non-existing PPS referenced
[h264 @ 017ECBE0] non-existing PPS 0 referenced
[h264 @ 017ECBE0] decode_slice_header error
[h264 @ 017ECBE0] no frame!
[mpegts @ 017D11E0] PES packet size mismatch
Last message repeated 2 times
Input #0, mpegts, from 'f:\TV-Aufnahmen\test.ts':
Duration: 01:06:20.53, start: 29822.126189, bitrate: 12947 kb/s
Program 10329
Stream #0:0[0x1465]: Video: h264 (High) ([27][0][0][0] / 0x001B), yuv420p, 1
280x720 [SAR 1:1 DAR 16:9], 56.11 fps, 50 tbr, 90k tbn, 100 tbc
Stream #0:1[0x1466](deu): Audio: mp2 ([3][0][0][0] / 0x0003), 48000 Hz, ster
eo, s16, 192 kb/s
Stream #0:2[0x1467](mis): Audio: mp2 ([3][0][0][0] / 0x0003), 48000 Hz, ster
eo, s16, 192 kb/s
Stream #0:3[0x146a](deu): Audio: ac3 ([6][0][0][0] / 0x0006), 48000 Hz, ster
eo, s16, 448 kb/s
C:\Users\tv>
beta
Post Thu Sep 13, 2012 10:15 pm
Log File is extrag big, so i post some parts of it?
2012-09-14 00:02:41,023 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file test.ts: AVC_TS_MP_HD_AC3_ISO
2012-09-14 00:02:37,844 DEBUG [ProcessExecutor] Starting C:\Program Files (x86)\Serviio\bin\\..\lib/ffmpeg.exe -fflags +genpts -i F:\TV-Aufnahmen\test.ts -y -copyts -c:v copy -vbsf h264_mp4toannexb -c:a ac3 -b:a 192k -ac 2 -map 0:0 -map 0:1 -sn -f mpegts C:\Windows\TEMP\Serviio\transcoding-temp-11178-7-ORIGINAL.stf
2012-09-14 00:02:37,842 DEBUG [FFMPEGWrapper] Invoking FFmpeg to transcode video file: F:\TV-Aufnahmen\test.ts
2012-09-14 00:02:37,836 DEBUG [VideoDeliveryEngine] Delivering file 'test.ts' using transcoding
Hope this helps.
Post Thu Sep 13, 2012 10:33 pm
it's remuxing the file (and was in 0.6.2) because the mp2 audio track (first). You can try to either remove
<Matches container="mpegts" aCodec="mp2" />
from the C/D/E profile (not sure if the file will play then) or remux the file manually so that the ac3 audio track is the first in line.
Post Fri Sep 14, 2012 12:49 am
Isn't this bug 566 again which somehow was changed to staus resolved without fixing the problem?
The error I reported here is pretty obvious.
Post Fri Sep 14, 2012 12:54 pm
jhb50 wrote:Isn't this bug 566 again which somehow was changed to staus resolved without fixing the problem?
It's resolved for 1.1, in my local codebase. You can re-test it in the next beta. It has nothing to do with this problem though. This is caused by transcoding file, which maybe doesn't need to, therefore losing the ffwd functionlity becuse of the annoying Samsung dealing with video time.
Post Fri Sep 14, 2012 1:24 pm
OK, now I understand. I should look at version number for when it was or will be resolved.
Will you ever be able to address that Samsung problem and allow transcoded files to be ff/rew or resumed?
beta
Post Fri Sep 14, 2012 7:49 pm
zip wrote:it's remuxing the file (and was in 0.6.2) because the mp2 audio track (first). You can try to either remove
Seems to work.
I also noticed problemes with forwarding of mkv files (only some of them) if transcoding was on.
If transcoding was off every mkv works with forwarding, so i turned transcoding of.
Post Sun Sep 16, 2012 7:09 pm
jhb50 wrote:Will you ever be able to address that Samsung problem and allow transcoded files to be ff/rew or resumed?
Not sure. I was looking at it again recently and no success.
