Xbox 360
• Page 1 of 1
Ok, so I have an Xbox 360 and a PS3. I have a few 1080P MP4 files that I am trying to play on the Xbox 360. When trying to play them I get the error 69-C00D36B4 and that it is an unsupported type. I was under the impression that Serviio would transcode it if necessary?
Re: Xbox 360
post ffmpeg -i of the file
Petr
Help translate Serviio
Re: Xbox 360
Ok, stupid question. Where would I find the ffmpeg executable? I looked in the serviio plugin directory and nothing is in there. That might be the problem.
Re: Xbox 360
Nevermind. I found it.
Sometimes you just need to look harder.
I am playing with Serviio on Server 2012 and the interface is totally different and I think it made me slightly retarded for a minute.
- Code:
g-config
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'Iron_Man_2008.mp4':
major_brand : isom
minor_version : 1
compatible_brands: isomavc1
Duration: 02:06:01.79, start: 0.000000, bitrate: 2711 kb/s
Stream #0:0(und): Video: h264 (High) (avc1 / 0x31637661), yuv420p, 1920x800
[SAR 1:1 DAR 12:5], 2071 kb/s, 23.98 fps, 23.98 tbr, 24k tbn, 47.95 tbc
handler_name : Imported with GPAC 0.4.6-DEV (internal rev. 7)
Stream #0:1(eng): Audio: aac (mp4a / 0x6134706D), 32000 Hz, 5.1, s16, 636 kb
/s
handler_name : GPAC ISO Audio Handler
Re: Xbox 360
I assume that is what you were looking for?
Re: Xbox 360
Yes, it looks like the problem is the 5.1 audio - XBox only supports 2.0 AAC streams. Serviio doesn't currently invoke transcoding based on number of audio channels. I'll open a ticket to implement this.
Petr
Re: Xbox 360
Thanks. I appreciate the assistance. I just wish Serviio had the web server interface like Subsonic does, then I would be able to just run Serviio instead of both Serviio and Subsonic. I donated to Subsonic because I use it so much remotely.
Once I can get Serviio to work for my needs, I will have to see about upgrading to the paid version.
Re: Xbox 360
CyberSquire wrote:I just wish Serviio had the web server interface like Subsonic does, then I would be able to just run Serviio instead of both Serviio and Subsonic. I donated to Subsonic because I use it so much remotely.Once I can get Serviio to work for my needs, I will have to see about upgrading to the paid version.
Wish granted
If you have an Android device, ServiiGo works well with it.
Re: Xbox 360
zip wrote:Yes, it looks like the problem is the 5.1 audio - XBox only supports 2.0 AAC streams. Serviio doesn't currently invoke transcoding based on number of audio channels. I'll open a ticket to implement this.
Thicket created here: https://bitbucket.org/xnejp03/serviio/i ... -number-of
Petr
Re: Xbox 360
Is this ticket being worked on or is there a workaround like reencoding the file?
• Page 1 of 1
Users browsing this forum: Google [Bot] and 18 guests
