Xbox 360
CyberSquire
Post Fri Sep 21, 2012 1:36 am
Xbox 360
Ok, so I have an Xbox 360 and a PS3. I have a few 1080P MP4 files that I am trying to play on the Xbox 360. When trying to play them I get the error 69-C00D36B4 and that it is an unsupported type. I was under the impression that Serviio would transcode it if necessary? :mrgreen:
Post Fri Sep 21, 2012 12:35 pm
Re: Xbox 360
post ffmpeg -i of the file
CyberSquire
Post Sat Sep 22, 2012 10:14 pm
Re: Xbox 360
Ok, stupid question. Where would I find the ffmpeg executable? I looked in the serviio plugin directory and nothing is in there. That might be the problem.
CyberSquire
Post Sat Sep 22, 2012 10:33 pm
Re: Xbox 360
Nevermind. I found it. :) Sometimes you just need to look harder. :) I am playing with Serviio on Server 2012 and the interface is totally different and I think it made me slightly retarded for a minute. :P
g-config
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'Iron_Man_2008.mp4':
    major_brand     : isom
    minor_version   : 1
    compatible_brands: isomavc1
  Duration: 02:06:01.79, start: 0.000000, bitrate: 2711 kb/s
    Stream #0:0(und): Video: h264 (High) (avc1 / 0x31637661), yuv420p, 1920x800
[SAR 1:1 DAR 12:5], 2071 kb/s, 23.98 fps, 23.98 tbr, 24k tbn, 47.95 tbc
      handler_name    : Imported with GPAC 0.4.6-DEV (internal rev. 7)
    Stream #0:1(eng): Audio: aac (mp4a / 0x6134706D), 32000 Hz, 5.1, s16, 636 kb
/s
      handler_name    : GPAC ISO Audio Handler
CyberSquire
Post Sat Sep 22, 2012 10:39 pm
Re: Xbox 360
I assume that is what you were looking for? :)
Post Sun Sep 23, 2012 11:42 am
Re: Xbox 360
Yes, it looks like the problem is the 5.1 audio - XBox only supports 2.0 AAC streams. Serviio doesn't currently invoke transcoding based on number of audio channels. I'll open a ticket to implement this.
CyberSquire
Post Sat Sep 29, 2012 1:26 am
Re: Xbox 360
Thanks. I appreciate the assistance. I just wish Serviio had the web server interface like Subsonic does, then I would be able to just run Serviio instead of both Serviio and Subsonic. I donated to Subsonic because I use it so much remotely. :) Once I can get Serviio to work for my needs, I will have to see about upgrading to the paid version. :)
Xmantium
Post Sat Sep 29, 2012 9:04 pm
Re: Xbox 360
CyberSquire wrote:I just wish Serviio had the web server interface like Subsonic does, then I would be able to just run Serviio instead of both Serviio and Subsonic. I donated to Subsonic because I use it so much remotely. :) Once I can get Serviio to work for my needs, I will have to see about upgrading to the paid version. :)
Wish granted :D Serviio does have MediaBrowser, its web based so you can watch or listen your content on the move!
If you have an Android device, ServiiGo works well with it.
Post Wed May 01, 2013 1:03 pm
Re: Xbox 360
zip wrote:Yes, it looks like the problem is the 5.1 audio - XBox only supports 2.0 AAC streams. Serviio doesn't currently invoke transcoding based on number of audio channels. I'll open a ticket to implement this.
Thicket created here: https://bitbucket.org/xnejp03/serviio/i ... -number-of
weiyentan
Post Sat Feb 08, 2014 5:08 am
Re: Xbox 360
Is this ticket being worked on or is there a workaround like reencoding the file?
Users browsing this forum: No registered users and 66 guests
