Re: YouTube
I have created a chrome extension
I suggest you also post this as its own thread under 3rdPartyTools. That will make it easy to find.
rolfwessels wrote:Hi Everyone,
I see a lot of people struggling to link youtube videos to their serviio. I have created a chrome extension that should make the task trivial.
Requirements
Simple how to:
Open the extension options and add your serviio host name and port number.
For videos just click on the add to play list button. If you don't have one already create a play list and add the video to the playlist. Then go to your manage playlist page and there should be an option to add the playlist to serviio. (remember to click refresh if you have made changes to the list)
You can also add playlists, search results and user feeds. Check out http://code.google.com/p/serviiotube/ for more info and some screen shots.
CigDangle wrote:Is anyone experiencing issues with YouTube today? The list of videos appears for whatever feed I'm using, but all of them fail to play...
TheOne.PC wrote:CigDangle wrote:Is anyone experiencing issues with YouTube today? The list of videos appears for whatever feed I'm using, but all of them fail to play...
Me too
2012-09-30 11:41:40,859 DEBUG [FeedParser] Found matching url extractor (YouTube) for resource http://gdata.youtube.com/feeds/api/playlists/PLB3rLY2txX-goL4pG5pb4AabLE3DqN9CH
2012-09-30 11:41:40,859 DEBUG [FeedItemUrlExtractor] YouTube: Starting extraction of url for item: Global Citizen Festival -- LIVE!
2012-09-30 11:41:41,421 DEBUG [FeedParser] Unexpected error during url extractor plugin invocation (YouTube) for item Global Citizen Festival -- LIVE!: Cannot access first() element from an empty List
2012-09-30 11:41:41,421 DEBUG [OnlineContentCacheDecorator] Stored online content 'http://gdata.youtube.com/feeds/api/playlists/PLB3rLY2txX-goL4pG5pb4AabLE3DqN9CH' in the cache (online_feeds), returning it
2012-09-30 11:41:41,421 DEBUG [OnlineLibraryManager] Resource http://gdata.youtube.com/feeds/api/playlists/PLB3rLY2txX-goL4pG5pb4AabLE3DqN9CH will expire in the cache on Mon Oct 01 11:41:41 NZDT 2012hlsvp=http%3A%2F%2Fwww.youtube.com%2Fapi%2Fmanifest%2Fhls_variant%2Fupn%2FMFHi0UJjSR0%2Fsparams%2Fid%252Cip%252Cipbits%252Cmaudio%252Cplaylist_type%252Cpmbypass%252Cexpire%2Fplaylist_type%2FLIVE%2Fmaudio%2F1%2Fip%2F69.172.80.245%2Fipbits%2F8%2Fsignature%2F0B13E933595682AF163DAE628893F4C317025030.657BA447F1B00BDE7FB516ACBCACC331FA38CA7C%2Fsver%2F3%2Fsource%2Fyt_live_broadcast%2Fexpire%2F1348989238%2Fkey%2Fyt1%2Fpmbypass%2Fyes%2Fid%2F88c8cd3a82eb130a%2Ffile%2Findex.m3u8\u0026amp;
Magnus wrote:As far as i understand the Groovy plugin should be able to work in a QNAP NAS as well but i cannot find out how to actually copy the Groovy plugin to the correct folder on the NAS. To me it does not seem to be that easy compared to windows. Any kind of help would be much appreciated!
