YouTube
Post Tue Aug 21, 2012 6:17 pm
Re: YouTube
I have created a chrome extension
Good stuff.
I suggest you also post this as its own thread under 3rdPartyTools. That will make it easy to find.
Post Thu Aug 23, 2012 3:41 pm
Re: YouTube
Here is the link to that chrome extension now called ServiioTube (chrome extension)
viewtopic.php?f=17&t=7162
zowie
Post Sat Sep 15, 2012 12:10 pm
Re: YouTube
rolfwessels wrote:Hi Everyone,
I see a lot of people struggling to link youtube videos to their serviio. I have created a chrome extension that should make the task trivial.
Requirements
Simple how to:
Open the extension options and add your serviio host name and port number.
For videos just click on the add to play list button. If you don't have one already create a play list and add the video to the playlist. Then go to your manage playlist page and there should be an option to add the playlist to serviio. (remember to click refresh if you have made changes to the list)
You can also add playlists, search results and user feeds. Check out http://code.google.com/p/serviiotube/ for more info and some screen shots.
Excellent works great, thanks.
sheikh73
Post Sun Sep 16, 2012 5:44 pm
Re: YouTube
Is there anyway of adding live youtube channels? For example this stream
http://www.youtube.com/watch?v=62i9gJqkbq0
zowie
Post Mon Sep 17, 2012 8:48 pm
Re: YouTube
sheikh73
Post Tue Sep 18, 2012 10:55 pm
Re: YouTube
Well I tried it and it worked but that channels went Off line :(
Can you help me to add this page : http://www.youtube.com/movies/indian-cinema
Spookyy
Post Sat Sep 22, 2012 5:57 pm
Re: YouTube
"Open the extension options and add your serviio host name and port number."
Mind telling a noob where i get that information from?
Nevermind, i got answer from the other post on 3rd party..
CigDangle
Post Thu Sep 27, 2012 5:23 pm
Re: YouTube
Is anyone experiencing issues with YouTube today? The list of videos appears for whatever feed I'm using, but all of them fail to play...
Xbox 360 - PlayStation 3 - Sony BDP-S370 - HTC Evo V & HP TouchPad running CM9 (Android) - serviio 1.0.1 - Windows 2003 Server Standard x64 Edition
TheOne.PC
Post Thu Sep 27, 2012 6:13 pm
Re: YouTube
CigDangle wrote:Is anyone experiencing issues with YouTube today? The list of videos appears for whatever feed I'm using, but all of them fail to play...
Me too
Chrisnewton
Post Thu Sep 27, 2012 7:00 pm
Re: YouTube
Hi
I have followed the instructions, and when i look at the online sources my you tube feed is listed in there, but when i try to play them back on my ps3 it says no items in folder. I am really new to this so know its my fault. Any ideas?
Thanks all
Chris
WildRushSykes
Post Thu Sep 27, 2012 9:18 pm
Re: YouTube
Same here and im using the latest version im sure zip is looking into it and will post an updated version :D
GamePat
Post Fri Sep 28, 2012 10:13 am
Re: YouTube
Me too
Same here too, worked fine couple days ago.
Franck
Post Fri Sep 28, 2012 9:31 pm
Re: YouTube
same problem here
b0nf4
Post Fri Sep 28, 2012 9:57 pm
Re: YouTube
Same problem here. I fixed it changing the file Youtube.groovy at line 44
def videoInfoUrl = "http://www.youtube.com/get_video_info?&video_id=$videoId$elType&ps=default&eurl=&gl=US&hl=en"
to:
def videoInfoUrl = "http://www.youtube.com/get_video_info?&video_id=$videoId$$elType$&ps=default&eurl=&gl=US&hl=en"
It is working now, but the selected resolution is always the smallest, no matter what resolution is selected on serviio console.
Cheers,
b0nf4
Post Sat Sep 29, 2012 9:18 am
Re: YouTube
Plugin updated in the top post
grolschie
Post Sat Sep 29, 2012 10:45 pm
Re: YouTube
Youtube Live events don't seem to work. e.g.
http://gdata.youtube.com/feeds/api/playlists/PLB3rLY2txX-goL4pG5pb4AabLE3DqN9CH
The playlist shows no videos. In the log I see:
2012-09-30 11:41:40,859 DEBUG [FeedParser] Found matching url extractor (YouTube) for resource http://gdata.youtube.com/feeds/api/playlists/PLB3rLY2txX-goL4pG5pb4AabLE3DqN9CH
2012-09-30 11:41:40,859 DEBUG [FeedItemUrlExtractor] YouTube: Starting extraction of url for item: Global Citizen Festival -- LIVE!
2012-09-30 11:41:41,421 DEBUG [FeedParser] Unexpected error during url extractor plugin invocation (YouTube) for item Global Citizen Festival -- LIVE!: Cannot access first() element from an empty List
2012-09-30 11:41:41,421 DEBUG [OnlineContentCacheDecorator] Stored online content 'http://gdata.youtube.com/feeds/api/playlists/PLB3rLY2txX-goL4pG5pb4AabLE3DqN9CH' in the cache (online_feeds), returning it
2012-09-30 11:41:41,421 DEBUG [OnlineLibraryManager] Resource http://gdata.youtube.com/feeds/api/playlists/PLB3rLY2txX-goL4pG5pb4AabLE3DqN9CH will expire in the cache on Mon Oct 01 11:41:41 NZDT 2012
The video URL is:
http://www.youtube.com/watch?v=iMjNOoLrEwo&feature=youtube_gdata
I have downloaded the latest plugin today.
Post Sun Sep 30, 2012 12:45 am
Re: YouTube
I don't think live streams ever worked. There is a url is on the page in a different place than normal yt vids. Note resolution is only 128x72. There are no high quality links.
Found in this tag:
hlsvp=http%3A%2F%2Fwww.youtube.com%2Fapi%2Fmanifest%2Fhls_variant%2Fupn%2FMFHi0UJjSR0%2Fsparams%2Fid%252Cip%252Cipbits%252Cmaudio%252Cplaylist_type%252Cpmbypass%252Cexpire%2Fplaylist_type%2FLIVE%2Fmaudio%2F1%2Fip%2F69.172.80.245%2Fipbits%2F8%2Fsignature%2F0B13E933595682AF163DAE628893F4C317025030.657BA447F1B00BDE7FB516ACBCACC331FA38CA7C%2Fsver%2F3%2Fsource%2Fyt_live_broadcast%2Fexpire%2F1348989238%2Fkey%2Fyt1%2Fpmbypass%2Fyes%2Fid%2F88c8cd3a82eb130a%2Ffile%2Findex.m3u8\u0026amp;
grolschie
Post Sun Sep 30, 2012 2:29 am
Re: YouTube
Thanks. It was looking and sounding very good on via a web-browser.
Magnus
Post Mon Oct 01, 2012 8:46 am
Re: YouTube
Hi everybody,
As far as i understand the Groovy plugin should be able to work in a QNAP NAS as well but i cannot find out how to actually copy the Groovy plugin to the correct folder on the NAS. To me it does not seem to be that easy compared to windows. Any kind of help would be much appreciated!
Xmantium
Post Mon Oct 01, 2012 7:35 pm
Re: YouTube
Magnus wrote:As far as i understand the Groovy plugin should be able to work in a QNAP NAS as well but i cannot find out how to actually copy the Groovy plugin to the correct folder on the NAS. To me it does not seem to be that easy compared to windows. Any kind of help would be much appreciated!
I have a QNAP NAS, to copy the groovy file you need to use a program called WinSCP
And copy all your groovy file to this location /share/MD0_DATA/.qpkg/Serviio/plugins/
Return to Available plugins
Users browsing this forum: No registered users and 89 guests
