Samsung TV not detected with Serviio
madwax
Post Sun Sep 30, 2012 1:17 pm
Hi
I downloaded Serviio and can start the Console, then I selected a folder of files to be shared.
Problem is that Serviio doesn't detect the TV, therefore I can not make the link between MacBook and TV.
What is strange is that I can actually detect Serviio server with my mobile SII through AllShare app.
I can then get access to the folder of files and launch a file and choose the TV as player.
But I finally get this message on the TV : "The selected file is not currently supported".
So... two problems
1/ how to make the direct link between Serviio and TV,
2/ How to play the files (.avi) that are not supported at the moment.
Thks for your help !
Post Sun Sep 30, 2012 4:46 pm
Re: Samsung TV not detected with Serviio
http://www.serviio.org/component/conten ... e?id=21#q1
Make sure the TV is on the same subnet as the Mac.
madwax
Post Thu Oct 04, 2012 2:12 pm
Hi
I can finally make it run correctly and used it during several days to watch some movies.
It is great !
But now I am blocked when I start my laptop and launch Serviio console.
I have this message and Serviio does not open at all.
"can not connect to Serviio server, it does not seem to be running. Exiting..."
I tried to re start several times, still the same issue.
What should I do ?
Thks
Post Thu Oct 04, 2012 2:29 pm
madwax wrote:But now I am blocked when I start my laptop and launch Serviio console.
When you start serviio console, serviio services should be started.
Check that after a reboot, serviio services restart automatically.
fabryd
Post Thu Oct 18, 2012 11:04 am
Hi, i have the same problem on my es7000, serviio doesnt detect my tv, is on the same network, i added the server ip manually in bound ip address, but the player list is empty, so i added the tv ip manually, selected samsung C/D/E series but the problem remains, i have opened the 8895 and 1900 ports as suggested
i dont know what to do :(
Post Thu Oct 18, 2012 11:44 am
Please attach you serviio.log file.
fabryd
Post Thu Oct 18, 2012 3:54 pm
Here's the log file
edit: After posting the log file, nobody can help me? :(
(55.41 KiB) Downloaded 606 times
Post Tue Oct 23, 2012 4:36 pm
Is 10.71.212.55 the IP of the PC? Also, post detailed log (see my signature)
fabryd
Post Wed Oct 24, 2012 10:59 am
zip wrote:Is 10.71.212.55 the IP of the PC? Also, post detailed log (see my signature)
that address changes often, now has changed in 10.71.212.53, but i changed it in bound ip, now the tv has that address (10.71.212.55)
heres my log file in debug mode as you suggested
(118.43 KiB) Downloaded 543 times
Post Thu Oct 25, 2012 12:07 pm
Can you fix the IP on your router? Ideally both, the PC and the TV.
The log is not in debug mode (there are no DEBUG statements)
fabryd
Post Thu Oct 25, 2012 2:03 pm
Reinstalled serviio, seems this time is debug mode, i see debug on the lower rows of the log
(159.72 KiB) Downloaded 539 times
Post Thu Oct 25, 2012 3:42 pm
Are you using a firewall/antivirus? Make sure the ports are open as described here: http://www.serviio.org/component/conten ... e?id=21#q1
fabryd
Post Thu Oct 25, 2012 3:53 pm
Yes i have tried everything :(
i think i can't use it
fabryd
Post Mon Oct 29, 2012 10:02 am
Ive tried serviio and samsung allshare on my notebook on the same network and it works perfect, maybe the problem is some conflicts on the opened ports
ar2000d
Post Mon Nov 12, 2012 9:05 pm
zip wrote: Make sure the TV is on the same subnet as the Mac.
Please excuse my ignorance, but I think the reason my TV and PC cannot communicate is something to do with them not being on the same subnet. I have a Samsung smart TV and a desktop running Serviio and they cannot see each other. However my laptop with Serviio and TV are connected. The desktop and TV are wired to the network and the laptop is wireless.
How do I configure my network so the desktop and TV are on the same subnet?
Andy
Post Tue Nov 13, 2012 12:46 am
Whjat are the IP addresses of the TV and the Mac?
ar2000d
Post Fri Nov 16, 2012 9:07 am
The IP address of the TV is 192.168.1.96
The IP address of the PC is 193.168.1.136
csholmq
Post Fri Nov 16, 2012 9:50 am
And what is the netmask? (255.255.*.*)
Post Fri Nov 16, 2012 12:36 pm
they have to be on the same subnet, ie the first 3 numbers have to be the same for the multicast to work.
ar2000d
Post Fri Nov 16, 2012 2:18 pm
the subnet mask is 225.225.225.0 on both devices. Also I have tried it both with the firewall off and on
