internet connection loss when using serviio
tek428
Post Thu Oct 04, 2012 12:34 am
I was a long time tversity user only switching to tversity a few days ago. I love it because it is much less of a system resource hog.
I have a major problem with it though. When I turn on my xbox360 and start streaming to it, I lose internet connectivity to every device in the house. The pc that serviio is on, my laptop, the wifes netbook, my phone, the kids laptop...etc. The stream from my pc to the xbox continues to work perfectly, but nothing can connect to the internet.
I am behind a linksys router that has not gave any trouble before, but the only way to get my internet connectivity back is to stop serviio and power cycle my router.
What is going on here?
tek428
Post Thu Oct 04, 2012 8:51 pm
Re: internet connection loss when using serviio
I have dug and looked everywhere and came up empty handed for an answer. Something is happening to the dns on my router whenever I use Serviio. I can still access websites by IP, but not by name. Interesting.
Happens every single time.
Have to uninstall for now and go back to tversity... sigh.
Xmantium
Post Thu Oct 04, 2012 9:35 pm
tek428 wrote:I was a long time tversity user only switching to tversity a few days ago.
Do you mean switching to Serviio?
Have you tried forwarding TCP port 23423 on your router?
tek428
Post Thu Oct 04, 2012 9:47 pm
Yes, I meant to say switched to serviio.
I have forwarded port 23423 tcp, 1900 udp, and 41952 both. Those ports are open on the pc hosting serviio, windows firewall is disabled.
grolschie
Post Fri Oct 05, 2012 1:10 am
Xmantium wrote:Have you tried forwarding TCP port 23423 on your router?
Is this to enable access to the mediabrowser from outside one's network (i.e. from the internet)?
Xmantium
Post Fri Oct 05, 2012 10:50 am
Serviio DNLA is 23423, Serviio MediaBrowser is 23424
Have you opened both these ports?
tek428
Post Fri Oct 05, 2012 11:55 am
I have not opened port 23424. I wouldn't think that would have anything to do with my problem.
When serviio appears to screw up my DNS settings, the stream from the serviio server to the xbox continues on without a hiccup. It is every other item in my house that has an IP address that suddenly can't connect to the internet.
I even plugged a static DNS server address into my router in hopes that would solve the issue, but it didn't.
I am also connected to my work via a VPN, and that connection drops also when I start a serviio media stream.
JerseyJoe123
Post Fri Oct 05, 2012 12:21 pm
Regarding the stream that you are playing, is it an online stream or a local file that resides on your home network?
tek428
Post Fri Oct 05, 2012 8:02 pm
All files are local files of the .mp4 format.
JerseyJoe123
Post Sun Oct 07, 2012 1:30 am
Hmmm. Just as an experiment, try changing the DNS entries on your Serviio box and XBox themselves to use Google DNS addresses 8.8.8.8 and 8.8.4.4, rather than the DNS defined on your router.
Also, does your Serviio box also happen to have a torrent client installed on it? What brand of modem does your ISP use?
Spadge
Post Sun Oct 07, 2012 3:13 am
Try running 'ipconfig /all' on your laptop etc before and after you run Serviio, just to see if something weird is going on with DHCP somewhere.
Look at DNS and mask entries specifically.
Then run 'nslookup www.google.com' as it should tell you the IP address of the DNS server it is using to resolve names with.
These steps should clarify whether the problem is one of DNS traffic not getting in/out or whether settings are being changed.
tek428
Post Sun Oct 07, 2012 7:33 pm
Here is the ipconfig before starting the serviio stream:
Windows IP Configuration
   Host Name . . . . . . . . . . . . : Inspiron-17r
   Primary Dns Suffix  . . . . . . . :
   Node Type . . . . . . . . . . . . : Hybrid
   IP Routing Enabled. . . . . . . . : No
   WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Local Area Connection 2:
   Media State . . . . . . . . . . . : Media disconnected
   Connection-specific DNS Suffix  . :
   Description . . . . . . . . . . . : TAP-Win32 Adapter V9
   Physical Address. . . . . . . . . : 00-FF-B1-4B-30-A0
   DHCP Enabled. . . . . . . . . . . : Yes
   Autoconfiguration Enabled . . . . : Yes
Wireless LAN adapter Wireless Network Connection 3:
   Description . . . . . . . . . . . : Microsoft Virtual WiFi Miniport Adapter #
2
   Physical Address. . . . . . . . . : 84-A6-C8-12-15-B1
Wireless LAN adapter Wireless Network Connection 2:
Ethernet adapter Bluetooth Network Connection:
   Description . . . . . . . . . . . : Bluetooth Device (Personal Area Network)
   Physical Address. . . . . . . . . : 84-A6-C8-12-15-B4
Ethernet adapter Local Area Connection:
   Connection-specific DNS Suffix  . : wds03.com
   Description . . . . . . . . . . . : Realtek PCIe FE Family Controller
   Physical Address. . . . . . . . . : 5C-F9-DD-49-0B-F8
Wireless LAN adapter Wireless Network Connection:
   Description . . . . . . . . . . . : Intel(R) Centrino(R) Wireless-N 2230
   Physical Address. . . . . . . . . : 84-A6-C8-12-15-B0
   Link-local IPv6 Address . . . . . : fe80::8c9b:fa55:1abc:ee3e%11(Preferred)
   IPv4 Address. . . . . . . . . . . : 192.168.1.105(Preferred)
   Subnet Mask . . . . . . . . . . . : 255.255.255.0
   Lease Obtained. . . . . . . . . . : Sunday, October 07, 2012 2:59:59 PM
   Lease Expires . . . . . . . . . . : Monday, October 08, 2012 2:59:58 PM
   Default Gateway . . . . . . . . . : 192.168.1.1
   DHCP Server . . . . . . . . . . . : 192.168.1.1
   DHCPv6 IAID . . . . . . . . . . . : 193242824
   DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-17-EA-12-0A-5C-F9-DD-49-0B-F8
   DNS Servers . . . . . . . . . . . : 208.67.222.222
                                       208.67.220.220
   NetBIOS over Tcpip. . . . . . . . : Enabled
Tunnel adapter Local Area Connection* 12:
   Description . . . . . . . . . . . : Microsoft 6to4 Adapter
   Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
   DHCP Enabled. . . . . . . . . . . : No
Tunnel adapter isatap.{B14B30A0-CD0E-4185-9524-574BBF1DEE02}:
   Description . . . . . . . . . . . : Microsoft ISATAP Adapter #2
Tunnel adapter isatap.{BAF667B1-613B-48D3-BF49-AFD8DE4036C8}:
   Description . . . . . . . . . . . : Microsoft ISATAP Adapter #3
Tunnel adapter Teredo Tunneling Pseudo-Interface:
   Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
   IPv6 Address. . . . . . . . . . . : 2001:0:4137:9e76:8e7:1ff:3f57:fe96(Prefer
red)
   Link-local IPv6 Address . . . . . : fe80::8e7:1ff:3f57:fe96%18(Preferred)
   Default Gateway . . . . . . . . . : ::
   NetBIOS over Tcpip. . . . . . . . : Disabled
nslookup before starting stream:
Server:  resolver1.opendns.com
Address:  208.67.222.222
Non-authoritative answer:
Addresses:  2607:f8b0:4003:c02::68
          74.125.142.103
          74.125.142.106
          74.125.142.104
          74.125.142.105
          74.125.142.99
          74.125.142.147
And the results of both after the stream has started, and all internet connectivity is lost to all devices connected to my router:
2
   Lease Expires . . . . . . . . . . : Monday, October 08, 2012 2:59:59 PM
                                       208.67.220.220
nslookup www.google.comm
DNS request timed out.
    timeout was 2 seconds.
Server:  UnKnown
*** Request to UnKnown timed-out
Spadge
Post Sun Oct 07, 2012 7:44 pm
OK, try turning off encryption on your wireless router settings and see if the same problem occurs.
grolschie
Post Sun Oct 07, 2012 8:46 pm
Xmantium wrote:Serviio DNLA is 23423, Serviio MediaBrowser is 23424
I don't think accessing port 23423 from the internet would be a good idea... just my $0.02.
Spadge wrote:OK, try turning off encryption on your wireless router settings and see if the same problem occurs.
Not a good solution I would think... again, just my $0.02.
Spadge
Post Sun Oct 07, 2012 8:51 pm
Not a good solution... just my $0.02.
Temporarily turning off encryption because it might be saturating the router's CPU not good?
Makes perfect sense to me.
tek428
Post Sun Oct 07, 2012 9:46 pm
That seems to have worked! Everything maintained connection during the streaming time with no security.
So, I downloaded the latest firmware for this router, re-enabled the encryption, and now it is working even with encryption.
Thanks guys!
grolschie
Post Mon Oct 08, 2012 9:17 pm
Ok, cool. I was just being cautious from a security point of view. Anyways, I'm glad your advice helped. :D
