[SOLVED] Audio problem - stereo only
freinhar
Post Sun Sep 30, 2012 2:40 am
I already searched through the forums and was unable to find a thread dealing with this issue so thought I'd ask.
I am trying to stream from Serviio installed on my Synology NAS to a Sony Bravia 2011 EX520 and everything works great except for the fact that I can't get surround sound working.
All movies that I stream (ones where I know they have Dolby 5.1) pop up as stereo audio on the TV. In the Serviio console, I have the "keep original audio channels" option ticked.
Any ideas? Your help is much appreciated!
Post Sun Sep 30, 2012 9:10 am
Re: Audio problem - stereo only
Serviio always select the first audio track for transcoding process.
Does this file is streamed in native format or transcode ?
Could you provide information about your file?
Could you enable detailed logging (see signature link), play the file and find on log the ffmpeg command line used ?
freinhar
Post Sun Sep 30, 2012 10:45 am
This is the MediaInfo readout from one of the files (I am having this issue with all files that play as 5.1 on my PC).
First track is 6 channel DTS, second channel is 2 channel AC3.
Format : Matroska
Format version : Version 2
File size : 7.94 GiB
Duration : 1h 55mn
Overall bit rate : 9 812 Kbps
Encoded date : UTC 2010-09-14 03:23:30
Writing application : mkvmerge v3.2.0 ('Beginnings') built on Feb 12 2010 16:46:17
Writing library : libebml v0.7.9 + libmatroska v0.8.1
Format : AVC
Format profile : High@L4.1
Format settings, CABAC : Yes
Codec ID : V_MPEG4/ISO/AVC
Duration : 1h 55mn
Bit rate : 8 085 Kbps
Width : 1 920 pixels
Height : 816 pixels
Display aspect ratio : 2.35:1
Frame rate mode : Constant
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.215
Stream size : 6.38 GiB (80%)
Title : x264_L4.1 @ 8085 Kbps
Writing library : x264 core 104 r1703 cd21d05
Encoding settings : cabac=1 / ref=5 / deblock=1:-3:-3 / analyse=0x3:0x113 / me=umh / subme=9 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=32 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-4 / threads=12 / sliced_threads=0 / nr=0 / decimate=0 / interlaced=0 / constrained_intra=0 / bframes=5 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc=2pass / mbtree=0 / bitrate=8085 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:0.90
Language : English
Default : Yes
Forced : No
Audio #1
Format : DTS
Codec ID : A_DTS
Duration : 1h 55mn
Bit rate mode : Constant
Bit rate : 1 510 Kbps
Channel(s) : 6 channels
Sampling rate : 48.0 KHz
Bit depth : 24 bits
Compression mode : Lossy
Stream size : 1.22 GiB (15%)
Title : English DTS 5.1 @ 1.5 Mbps
Language : English
Default : Yes
Forced : No
Audio #2
Format : AC-3
Format/Info : Audio Coding 3
Codec ID : A_AC3
Duration : 1h 55mn
Bit rate : 224 Kbps
Channel(s) : 2 channels
Bit depth : 16 bits
Stream size : 186 MiB (2%)
Title : English Commentary Dolby Digital 2.0 @ 224 Kbps
Language : English
Default : No
Forced : No
Text
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Title : English SDH
Language : English
Default : Yes
Forced : No
I wanted to try to get the detailed log for you, but I was unable to find the log4j.xml file on my Synology NAS server where Serviio is installed. Please let me know how I should proceed and thanks for your assistance!
freinhar
Post Sun Sep 30, 2012 10:55 am
For what it's worth I don't think it's playing the second track (i.e. not the commentary), it's just that the DTS track is somehow not coming through correctly.
freinhar
Post Wed Oct 17, 2012 11:03 am
Illico wrote:Serviio always select the first audio track for transcoding process.
Hi Illico,
Thanks for your help.
I finally figured out how to enable detailed logging for Serviio on my NAS so I was going to post the logged ffmpeg command line for you but it turns out to not be necessary - I (accidentally) fixed the issue.
I stream from Serviio to my TV, which in turn is hooked up to an AV receiver. For some reason the receiver doesn't recognise the audio stream coming from the TV as Dolby Digital when streamed using Serviio and so just reproduces stereo sound.
If I "trick" the receiver by playing another Dolby Digital source before streaming (i.e. Blu-Ray player or Xbox 360), so that the receiver is already in Dolby Digital mode, and I then stream a file using Serviio, the surround sound gets reproduced without any problems, so it works! Still not sure what the issue is because this only occurs when streaming using Serviio (i.e. if I stream using the integrated DLNA server from my NAS, which supports much less formats so I tend not to use it otherwise, this doesn't occur) but this workaround has got it fixed.
Cheers,
Fabian
