Re: Hulu (US only)
Any ideas?
WildRushSykes wrote:Whoops my bad JJShavent been on that much of late but i must admit that the Hulu plugin is the only one that was out of date and is now fixed in the latest update
Honestly sometimes i think i need a good smack round the head sometimes because either im blind or dumb or a bit of both hopefully it might fix me
arsaboo wrote:Is there any way to add a particular movie or episode (e.g. http://www.hulu.com/watch/361989) to Serviio. Better still, can I add the entire movie genre in Serviio (e.g., http://www.hulu.com/movies/genres/international/british)? Kindly advice.
2013-01-09 23:55:34,820 WARN [LibraryAdditionsCheckerThread] An error occured while scanning for item to be added, will continue
org.serviio.db.dao.PersistenceException: Cannot mark Repository with id 1 as scanned
at org.serviio.library.dao.RepositoryDAOImpl.markRepositoryAsScanned(RepositoryDAOImpl.java:173)
at org.serviio.library.local.service.RepositoryService.markRepositoryAsScanned(RepositoryService.java:112)
at org.serviio.library.local.metadata.LibraryAdditionsCheckerThread.run(LibraryAdditionsCheckerThread.java:84)
Caused by: java.sql.SQLNonTransientConnectionException: Connection closed by unknown interrupt.
at org.apache.derby.impl.jdbc.EmbedStatement.executeStatement(Unknown Source)
at org.apache.derby.impl.jdbc.EmbedPreparedStatement.executeStatement(Unknown Source)
at org.apache.derby.impl.jdbc.EmbedPreparedStatement.executeUpdate(Unknown Source)
at org.serviio.library.dao.RepositoryDAOImpl.markRepositoryAsScanned(RepositoryDAOImpl.java:171)
... 2 more
Caused by: java.sql.SQLException: Connection closed by unknown interrupt.
... 12 more
Caused by: ERROR 08000: Connection closed by unknown interrupt.
at org.apache.derby.iapi.util.InterruptStatus.setInterrupted(Unknown Source)
at org.apache.derby.iapi.util.InterruptStatus.throwIf(Unknown Source)
at org.apache.derby.impl.sql.execute.BasicNoPutResultSetImpl.checkCancellationFlag(Unknown Source)
at org.apache.derby.impl.sql.execute.TableScanResultSet.getNextRowCore(Unknown Source)
at org.apache.derby.impl.sql.execute.IndexRowToBaseRowResultSet.getNextRowCore(Unknown Source)
at org.apache.derby.impl.sql.execute.ProjectRestrictResultSet.getNextRowCore(Unknown Source)
at org.apache.derby.impl.sql.execute.NormalizeResultSet.getNextRowCore(Unknown Source)
at org.apache.derby.impl.sql.execute.DMLWriteResultSet.getNextRowCore(Unknown Source)
at org.apache.derby.impl.sql.execute.UpdateResultSet.collectAffectedRows(Unknown Source)
at org.apache.derby.impl.sql.execute.UpdateResultSet.open(Unknown Source)
at org.apache.derby.impl.sql.GenericPreparedStatement.executeStmt(Unknown Source)
at org.apache.derby.impl.sql.GenericPreparedStatement.execute(Unknown Source)
... 6 more2013-01-09 23:26:27,929 INFO [MediaServer] ------------------------------------------------------------------------
2013-01-09 23:26:27,944 INFO [MediaServer] Serviio DLNA media streaming server v 1.1 (rev. 6ba0dd933a8e+)
2013-01-09 23:26:27,944 INFO [MediaServer] Petr Nejedly 2009-2012
2013-01-09 23:26:27,944 INFO [MediaServer] http://www.serviio.org
2013-01-09 23:26:27,944 INFO [MediaServer] Java 1.7.0_09-Oracle Corporation
2013-01-09 23:26:27,944 INFO [MediaServer] OS Windows 7 amd64 6.1
2013-01-09 23:26:27,944 INFO [MediaServer] File encoding: windows-1252
2013-01-09 23:26:27,944 INFO [MediaServer] Headless mode enabled: true
2013-01-09 23:26:27,944 INFO [MediaServer] User: SHARK$
2013-01-09 23:26:27,944 INFO [MediaServer] User home dir: C:\
2013-01-09 23:26:27,944 INFO [MediaServer] Temp dir: C:\Windows\TEMP\
2013-01-09 23:26:27,944 INFO [MediaServer] ------------------------------------------------------------------------
2013-01-09 23:26:29,738 INFO [WebServer] Socket buffer set to 65535 bytes
2013-01-09 23:26:29,754 INFO [RestletServer] Starting Restlet server (/rest) exposed on port 23423
2013-01-09 23:26:29,941 INFO [RestletServer] Starting Restlet server (/cds) exposed on port 23424
2013-01-09 23:26:29,941 INFO [RestletServer] Starting Restlet server (/mediabrowser) exposed on port 23424
2013-01-09 23:26:30,003 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2013-01-09 23:26:33,576 INFO [MediaServer] ------------------------------------------------------------------------
2013-01-09 23:26:33,576 INFO [MediaServer] License: PRO (NORMAL, id: 461eb4f9-e405-40eb-85d1-dbc328cefe6b)
2013-01-09 23:26:33,763 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2013-01-09 23:26:35,214 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2013-01-09 23:26:35,744 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2013-01-09 23:26:36,087 INFO [ProfilesDefinitionParser] Added profile 'Xbox 360' (id=3)
2013-01-09 23:26:36,353 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2013-01-09 23:26:36,524 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2013-01-09 23:26:36,649 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2013-01-09 23:26:37,070 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D/E-series)' (id=7)
2013-01-09 23:26:37,086 INFO [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2013-01-09 23:26:37,772 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012)' (id=sony2012)
2013-01-09 23:26:38,365 INFO [ProfilesDefinitionParser] Added profile 'Sony BD Player / SMP' (id=10)
2013-01-09 23:26:38,599 INFO [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2013-01-09 23:26:38,817 INFO [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2013-01-09 23:26:38,864 INFO [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2013-01-09 23:26:38,973 INFO [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2013-01-09 23:26:39,020 INFO [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2013-01-09 23:26:39,207 INFO [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2013-01-09 23:26:39,301 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011)' (id=sony2011)
2013-01-09 23:26:39,504 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2010)' (id=sony2010)
2013-01-09 23:26:39,738 INFO [ProfilesDefinitionParser] Added profile 'Philips' (id=20)
2013-01-09 23:26:39,863 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2009)' (id=sony2009)
2013-01-09 23:26:39,909 INFO [ProfilesDefinitionParser] Added profile 'Denon AVR' (id=22)
2013-01-09 23:26:40,315 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera G/GT/DT/UT/VT (2011/2012)' (id=viera2011a)
2013-01-09 23:26:40,393 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera E/S/ST/VT (2011)' (id=viera2011)
2013-01-09 23:26:40,455 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera (2010)' (id=viera2010)
2013-01-09 23:26:40,533 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012) - US' (id=sony2012us)
2013-01-09 23:26:40,627 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011) - US' (id=sony2011us)
2013-01-09 23:26:40,767 INFO [ProfilesDefinitionParser] Added profile 'Sony AVReceiver STR' (id=SonySTR)
2013-01-09 23:26:40,830 INFO [ProfilesDefinitionParser] Added profile 'Sony Audio CMT' (id=SonyCMT)
2013-01-09 23:26:40,955 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2013-01-09 23:26:41,235 INFO [ProfilesDefinitionParser] Added profile 'Flash player' (id=flv_player)
2013-01-09 23:26:41,438 INFO [ProfilesDefinitionParser] Added profile 'ServiiGo' (id=serviigo)
2013-01-09 23:26:41,547 INFO [ProfilesDefinitionParser] Added profile 'Windows Phone 8' (id=wp8)
2013-01-09 23:26:42,437 INFO [Device] Created UPnP Device with UUID: dee3f94e-28dc-363d-ab06-b84cb061d425, bound address: 192.168.1.136
2013-01-09 23:26:43,357 INFO [PluginCompilerThread] Looking for plugins at C:\Program Files\Serviio\bin\..\plugins
2013-01-09 23:26:43,357 INFO [UpdateChecker] Checking if a new version is available
2013-01-09 23:26:43,373 INFO [PluginCompilerThread] Started looking for plugins
2013-01-09 23:26:46,929 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2013-01-09 23:26:47,101 INFO [WebServer] WebServer starting on port 8895
2013-01-09 23:26:47,132 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2013-01-09 23:26:47,132 INFO [EventDispatcher] Starting EventDispatcher
2013-01-09 23:26:47,132 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2013-01-09 23:26:47,132 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2013-01-09 23:26:47,201 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth3 (Marvell Yukon 88E8056 PCI-E Gigabit Ethernet Controller) and address 192.168.1.136, timeout = 0
2013-01-09 23:26:47,295 INFO [PluginCompilerThread] Added Feed plugin Hulu (US only) (Hulu.groovy), version: 1
2013-01-09 23:26:47,482 INFO [RendererSearchSender] Searching for Renderer devices, will multicast on 1 NICs
2013-01-09 23:27:13,528 INFO [FeedUpdaterThread] Started looking for information about online resources
2013-01-09 23:27:13,531 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2013-01-09 23:27:13,590 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2013-01-09 23:27:13,591 INFO [PlaylistMaintainerThread] Started looking playlist changes
2013-01-09 23:28:21,496 INFO [ServiioConsole] Starting Serviio Console
2013-01-09 23:28:22,939 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2013-01-09 23:28:33,633 INFO [Messages] Loaded console message bundle for locale: en
2013-01-09 23:29:11,390 INFO [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2013-01-09 23:29:12,472 INFO [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: en
2013-01-09 23:53:48,151 INFO [WebServer] WebServer shutting down
2013-01-09 23:53:48,151 INFO [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2013-01-09 23:53:48,151 INFO [EventDispatcher] Leaving EventDispatcher
2013-01-09 23:53:48,151 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2013-01-09 23:53:48,151 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2013-01-09 23:53:52,247 INFO [RendererExpirationChecker] Leaving RendererExpirationChecker
2013-01-09 23:53:52,527 WARN [ServiioStatusService] ValidationException occured. Returning error code 400 to the REST layer. Message: null
2013-01-09 23:53:59,424 INFO [WebServer] WebServer starting on port 8895
2013-01-09 23:53:59,425 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2013-01-09 23:53:59,425 INFO [EventDispatcher] Starting EventDispatcher
2013-01-09 23:53:59,425 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2013-01-09 23:53:59,445 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth3 (Marvell Yukon 88E8056 PCI-E Gigabit Ethernet Controller) and address 192.168.1.136, timeout = 0
2013-01-09 23:53:59,780 INFO [RendererSearchSender] Searching for Renderer devices, will multicast on 1 NICs
2013-01-09 23:54:14,029 WARN [ServiioStatusService] ValidationException occured. Returning error code 400 to the REST layer. Message: null
2013-01-09 23:54:29,932 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2013-01-09 23:54:30,032 INFO [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2013-01-09 23:54:30,132 INFO [PlaylistMaintainerThread] Finished looking for playlist changes
2013-01-09 23:54:30,302 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2013-01-09 23:54:30,302 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2013-01-09 23:54:30,387 INFO [PlaylistMaintainerThread] Started looking playlist changes
2013-01-09 23:54:34,493 INFO [WebServer] WebServer shutting down
2013-01-09 23:54:34,493 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2013-01-09 23:54:34,493 INFO [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2013-01-09 23:54:34,493 INFO [EventDispatcher] Leaving EventDispatcher
2013-01-09 23:54:34,493 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2013-01-09 23:54:37,997 INFO [WebServer] WebServer starting on port 8895
2013-01-09 23:54:37,997 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2013-01-09 23:54:37,997 INFO [EventDispatcher] Starting EventDispatcher
2013-01-09 23:54:37,997 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2013-01-09 23:54:38,017 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth3 (Marvell Yukon 88E8056 PCI-E Gigabit Ethernet Controller) and address 192.168.1.136, timeout = 0
2013-01-09 23:54:38,348 INFO [RendererSearchSender] Searching for Renderer devices, will multicast on 1 NICs
2013-01-09 23:55:32,496 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2013-01-09 23:55:32,596 INFO [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2013-01-09 23:55:32,696 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2013-01-09 23:55:32,696 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2013-01-09 23:55:33,063 WARN [LibraryAdditionsCheckerThread] An error occured while scanning for item to be added, will continue
org.serviio.db.dao.PersistenceException: Cannot mark Repository with id 3 as scanned
... 2 more
... 12 more
... 6 more
2013-01-09 23:55:33,064 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2013-01-09 23:55:33,120 INFO [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
darkcloud784 wrote:I have yet to get a plugin to work. I get the link to the RSS feed, set it as an RSS/Atom in the library and click add. I move the groovy file to the plugins folder inside the root of serviio. This is the only error I get after restarting the server:
- Code:
... 2 more
... 12 more
... 6 more
I have posted on 3 different plugin topics and have yet to get any support on these types of issues from the authors. I am on a windows 7 PC, streaming to a Samsung TV. Full Detailed log below:
- Code:
... 2 more
... 12 more
... 6 more
slyguy42o wrote:
not seeing anything useful in your logs.
What URL are you trying to use?
Also can you enable detailed logging and post another set after trying with this enabled?
2013-01-16 23:41:27,305 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 12)
2013-01-16 23:41:27,305 DEBUG [OnlineLibraryManager] Resource http://www.hulu.com/feed/show/12138/episodes not in cache yet, loading it
2013-01-16 23:41:27,305 DEBUG [FeedParser] Parsing feed 'http://www.hulu.com/feed/show/12138/episodes'
2013-01-16 23:41:27,905 DEBUG [AbstractCDSLibraryIndexingListener] Library updated, notifying CDS
2013-01-16 23:41:28,114 DEBUG [FeedParser] Found matching url extractor (Hulu (US only)) for resource http://www.hulu.com/feed/show/12138/episodes
2013-01-16 23:41:28,114 DEBUG [FeedItemUrlExtractor] Hulu (US only): Starting extraction of url for item: Teenage Mutant Ninja Turtles - s1 | e12 - It Came from the Depths
2013-01-16 23:41:30,179 DEBUG [FeedParser] Unexpected error during url extractor plugin invocation (Hulu (US only)) for item Teenage Mutant Ninja Turtles - s1 | e12 - It Came from the Depths: Invalid SMIL XML, content probably expired. Expression: (matcher.count == 1)
2013-01-16 23:41:30,180 DEBUG [FeedItemUrlExtractor] Hulu (US only): Starting extraction of url for item: Teenage Mutant Ninja Turtles - s1 | e11 - Mousers Attack!
Users browsing this forum: Google [Bot] and 6 guests
